Home » Modeling » EMF » [TENEO] No annotated model element present for Diagram
[TENEO] No annotated model element present for Diagram [message #430520] Mon, 25 May 2009 14:56 Go to next message
Originally posted by: krdbrm.gmail.com
I get the following Exeption if I try mapping my ECOR model.
java.lang.IllegalArgumentException: No annotated model element present
for: Diagram for type EClass has its epackage been registered with Teneo?
at
org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedMod elImpl.checkAnnotatedPresent(PAnnotatedModelImpl.java:346)
at
org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedMod elImpl.getPAnnotated(PAnnotatedModelImpl.java:288)
at
org.eclipse.emf.teneo.annotations.pamodel.impl.PAnnotatedERe ferenceImpl.getAReferenceType(PAnnotatedEReferenceImpl.java: 158)
at
org.eclipse.emf.teneo.annotations.mapper.EFeatureAnnotator.a nnotate(EFeatureAnnotator.java:99)
at
org.eclipse.emf.teneo.annotations.mapper.EClassAnnotator.ann otate(EClassAnnotator.java:242)
at
org.eclipse.emf.teneo.hibernate.annotations.HbEClassAnnotato r.annotate(HbEClassAnnotator.java:55)
at
org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator .processPackage(AnnotationGenerator.java:167)
at
org.eclipse.emf.teneo.annotations.mapper.AnnotationGenerator .map(AnnotationGenerator.java:135)
at
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:146)
at
org.eclipse.emf.teneo.annotations.mapper.PersistenceMappingB uilder.buildMapping(PersistenceMappingBuilder.java:67)
at
org.eclipse.emf.teneo.hibernate.HbDataStore.mapEPackages(HbD ataStore.java:624)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.mapModel( HbSessionDataStore.java:155)
I also registered the following Epackages with dataStore.setEPackages:
myModelPackage.eINSTANCE
NotationPackage.eINSTANCE
EcorePackage.eINSTANCE
XMLTypePackage.eINSTANCE
someone has previously had problems with Diagram? Diagram is an Epackage
from GMF and i dont create it myslef.
thanks a lot
Bahram
Re: [TENEO] No annotated model element present for Diagram [message #430522 is a reply to message #430520] Mon, 25 May 2009 17:02 Go to previous messageGo to next message
Hi Bahram,
What is the epackage which contains Diagram? That one also needs to be registered.
gr. Martin
Bahram Kord wrote:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> thanks a lot
> Bahram
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [TENEO] No annotated model element present for Diagram [message #430523 is a reply to message #430522] Mon, 25 May 2009 20:09 Go to previous messageGo to next message
Hi Martin,
tanks for your message.
I mean Diagram from org.eclipse.gmf.runtime.notation.NotationPackage. I
registered also this Package although have this Exeption.
gr. Bahram
Martin Taal schrieb:
> Hi Bahram,
> registered.
> gr. Martin
> Bahram Kord wrote:
>> Hi,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Epackage from GMF and i dont create it myslef.
>> thanks a lot
>> Bahram
Re: [TENEO] No annotated model element present for Diagram [message #430524 is a reply to message #430523] Tue, 26 May 2009 00:03 Go to previous messageGo to next message
Hi Bahram,
The line numbers in the exception trace do not seem to match with what I have. Which version are you using?
gr. Martin
Bahram wrote:
> Hi Martin,
> gr. Bahram
>> Hi Bahram,
>> registered.
>> gr. Martin
>> Bahram Kord wrote:
>>> Hi,
>>> present for: Diagram for type EClass has its epackage been registered
>>> with Teneo?
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> thanks a lot
>>> Bahram
The Netherlands
Re: [TENEO] No annotated model element present for Diagram [message #430527 is a reply to message #430524] Tue, 26 May 2009 01:49 Go to previous messageGo to next message
Guys,
Can Teneo persist instance of Ecore or instances of EClasses that extend
EModelElements? The GMF notation model derives most of its classes from
EModelElement, as does UML2 or OCL (not so many here).
Cheers
/Eike
> Hi Bahram,
> gr. Martin
> Bahram wrote:
>> Hi Martin,
>> I registered also this Package although have this Exeption.
>> gr. Bahram
>>> Hi Bahram,
>>> be registered.
>>> gr. Martin
>>> Bahram Kord wrote:
>>>> Hi,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> thanks a lot
>>>> Bahram
Re: [TENEO] No annotated model element present for Diagram [message #430528 is a reply to message #430527] Tue, 26 May 2009 02:21 Go to previous messageGo to next message
Hi Eike,
Yes the ecore model itself can also be persisted with Teneo.
gr. Martin
Eike Stepper wrote:
> Guys,
> Cheers
> /Eike
> http://thegordian.blogspot.com
>> Hi Bahram,
>> gr. Martin
>> Bahram wrote:
>>> Hi Martin,
>>> gr. Bahram
>>>> Hi Bahram,
>>>> be registered.
>>>> gr. Martin
>>>> Bahram Kord wrote:
>>>>> Hi,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> thanks a lot
>>>>> Bahram
The Netherlands
Re: [TENEO] No annotated model element present for Diagram [message #430530 is a reply to message #430524] Tue, 26 May 2009 03:42 Go to previous messageGo to next message
I am using Teneo EMF version 1.0.1.v200809211527-....
best regards
Bahram
> Hi Bahram,
> gr. Martin
> Bahram wrote:
>> Hi Martin,
>> gr. Bahram
>>> Hi Bahram,
>>> be registered.
>>> gr. Martin
>>> Bahram Kord wrote:
>>>> Hi,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> thanks a lot
>>>> Bahram
Re: [TENEO] No annotated model element present for Diagram [message #430533 is a reply to message #430530] Tue, 26 May 2009 06:17 Go to previous messageGo to next message
Hi Bahram,
Possibly it helps if you can upgrade to a more recent version of Teneo:
see the 1.0.4 maintenance builds in the bottom of this page:
http://www.eclipse.org/modeling/emf/downloads/?project=teneo
or the 1.1.0 build for Eclipse 3.5
gr. Martin
Bahram Kord wrote:
> best regards
> Bahram
>> Hi Bahram,
>> gr. Martin
>> Bahram wrote:
>>> Hi Martin,
>>> gr. Bahram
>>>> Hi Bahram,
>>>> be registered.
>>>> gr. Martin
>>>> Bahram Kord wrote:
>>>>> Hi,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> thanks a lot
>>>>> Bahram
The Netherlands
Re: [TENEO] ID from EString [message #430614 is a reply to message #430533] Fri, 29 May 2009 15:51 Go to previous messageGo to next message
Hi Martin,
Thank you. it works. but I have now following Exception.
java.lang.ClassCastException: java.lang.String
at org.hibernate.type.LongType.set(LongType.java:42)
at org.hibernate.type.NullableType.nullSafeSet(NullableType.jav a:136)
at org.hibernate.type.NullableType.nullSafeSet(NullableType.jav a:107)
at org.hibernate.type.AnyType.nullSafeSet(AnyType.java:144)
at
org.hibernate.persister.entity.AbstractEntityPersister.dehyd rate(AbstractEntityPersister.java:1997)
at
org.hibernate.persister.entity.AbstractEntityPersister.dehyd rate(AbstractEntityPersister.java:1974)
at
org.hibernate.persister.entity.AbstractEntityPersister$3.bin dValues(AbstractEntityPersister.java:2152)
at
org.hibernate.id.insert.AbstractReturningDelegate.performIns ert(AbstractReturningDelegate.java:32)
at
org.hibernate.persister.entity.AbstractEntityPersister.inser t(AbstractEntityPersister.java:2158)
at
org.hibernate.persister.entity.AbstractEntityPersister.inser t(AbstractEntityPersister.java:2638)
at
org.hibernate.action.EntityIdentityInsertAction.execute(Enti tyIdentityInsertAction.java:48)
at org.hibernate.engine.ActionQueue.execute(ActionQueue.java:25 0)
at
org.hibernate.event.def.AbstractSaveEventListener.performSav eOrReplicate(AbstractSaveEventListener.java:298)
at
org.hibernate.event.def.AbstractSaveEventListener.performSav e(AbstractSaveEventListener.java:181)
at
org.hibernate.event.def.AbstractSaveEventListener.saveWithGe neratedId(AbstractSaveEventListener.java:107)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.sav eWithGeneratedOrRequestedId(DefaultSaveOrUpdateEventListener .java:187)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.ent ityIsTransient(DefaultSaveOrUpdateEventListener.java:172)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.per formSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:94)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.onS aveOrUpdate(DefaultSaveOrUpdateEventListener.java:70)
at org.hibernate.impl.SessionImpl.fireSaveOrUpdate(SessionImpl. java:507)
at org.hibernate.impl.SessionImpl.saveOrUpdate(SessionImpl.java :499)
at org.hibernate.impl.SessionImpl.saveOrUpdate(SessionImpl.java :495)
at
org.eclipse.emf.teneo.hibernate.HbSessionWrapper.saveOrUpdat e(HbSessionWrapper.java:161)
at
org.eclipse.emf.teneo.hibernate.resource.HibernateResource.s aveResource(HibernateResource.java:353)
at
org.eclipse.emf.teneo.resource.StoreResource.save(StoreResou rce.java:430)
at
org.efixes.ui.EfixesProjectCreationWizardDb.performFinish(Ef ixesProjectCreationWizardDb.java:243)
at
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:742)
I have in mapping Statements following Tag about Id :
<class name="org.efixes.impl.IdentifiableImpl"
entity-name="Identifiable" abstract="true" lazy="false"
discriminator-value="Identifiable" table="`identifiable`">
<meta attribute="eclassName">Identifiable</meta>
<meta
attribute="epackage">http://www.efixes.org/efixes.ecore/efixes</meta>
<id name="id" type="java.lang.String">
<column not-null="true" unique="false" name="`id`"/>
</id>
<discriminator column="`dtype`" type="string"/>
<version name="e_version" column="e_version"
access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler ">
<meta attribute="syntheticVersion">true</meta>
</version>
</class>
can you pls help me to solve this problem. I will not change my Id-Type
to ELong.
Best rgards.
Bahram
> Hi Bahram,
> gr. Martin
> Bahram Kord wrote:
>> Hi,
>> best regards
>> Bahram
>>> Hi Bahram,
>>> gr. Martin
>>> Bahram wrote:
>>>> Hi Martin,
>>>> I mean Diagram from
>>>> org.eclipse.gmf.runtime.notation.NotationPackage. I registered
>>>> gr. Bahram
>>>>> Hi Bahram,
>>>>> be registered.
>>>>> gr. Martin
>>>>> Bahram Kord wrote:
>>>>>> Hi,
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> thanks a lot
>>>>>> Bahram
Re: [TENEO] ID from EString [message #430617 is a reply to message #430614] Fri, 29 May 2009 16:34 Go to previous messageGo to next message
Hi Bahram,
I am not sure if it is the ID it is failing on. Can you put a breakpoint in AnyType and check which column/efeature it
is trying to set?
gr. Martin
Bahram Kord wrote:
> Hi Martin,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> <meta
> </id>
> </version>
> </class>
> to ELong.
> Best rgards.
> Bahram
>> Hi Bahram,
>> gr. Martin
>> Bahram Kord wrote:
>>> Hi,
>>> best regards
>>> Bahram
>>>> Hi Bahram,
>>>> gr. Martin
>>>> Bahram wrote:
>>>>> Hi Martin,
>>>>> I mean Diagram from
>>>>> gr. Bahram
>>>>>> Hi Bahram,
>>>>>> to be registered.
>>>>>> gr. Martin
>>>>>> Bahram Kord wrote:
>>>>>>> Hi,
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> thanks a lot
>>>>>>> Bahram
The Netherlands
Re: [TENEO] ID from EString [message #430690 is a reply to message #430617] Wed, 03 June 2009 20:12 Go to previous messageGo to next message
Hi Martin,
I have this problem if i try to set an Element to my Diagram. I set
Diagram with
diagram .setElement(myModel);
I found many Discoution about this problem but any solution.
gr. Bahram
> Hi Bahram,
> in AnyType and check which column/efeature it is trying to set?
> gr. Martin
> Bahram Kord wrote:
>> Hi Martin,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> <meta
>> </id>
>> </version>
>> </class>
>> Id-Type to ELong.
>> Best rgards.
>> Bahram
>>> Hi Bahram,
>>> gr. Martin
>>> Bahram Kord wrote:
>>>> Hi,
>>>> best regards
>>>> Bahram
>>>>> Hi Bahram,
>>>>> gr. Martin
>>>>> Bahram wrote:
>>>>>> Hi Martin,
>>>>>> I mean Diagram from
>>>>>> gr. Bahram
>>>>>>> Hi Bahram,
>>>>>>> to be registered.
>>>>>>> gr. Martin
>>>>>>> Bahram Kord wrote:
>>>>>>>> Hi,
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> thanks a lot
>>>>>>>> Bahram
Re: [TENEO] ID from EString [message #430692 is a reply to message #430690] Thu, 04 June 2009 01:48 Go to previous messageGo to next message
Hi Bahram,
I think we need to dig a bit deeper.
It fails in this statement:
identifierType.nullSafeSet(st, id, index+1, idsettable, session);
Apparently hibernate thinks that the id is a long while the value in the object is a string. Looking at the mapping you
showed below there is no reason why hibernate would assume that the id is a long. So my feel is that this exception is
for another object/efeature.
Can you put a breakpoint in AnyType and check which column/efeature from which eclass it is trying to set in the Anytype?
An easy way to get the sources visible in eclipse is to open the hibernate.jar and add the source directory of hibernate
to it (so the jar contains both sources and classes).
Then when you have found it also post the mapping of the eclass and the id hibernate mapping (if that is done in a super
type).
gr. Martin
Bahram wrote:
> Hi Martin,
> Diagram with
> gr. Bahram
>> Hi Bahram,
>> breakpoint in AnyType and check which column/efeature it is trying to
>> set?
>> gr. Martin
>> Bahram Kord wrote:
>>> Hi Martin,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> <meta
>>> </id>
>>> </version>
>>> </class>
>>> Id-Type to ELong.
>>> Best rgards.
>>> Bahram
>>>> Hi Bahram,
>>>> gr. Martin
>>>> Bahram Kord wrote:
>>>>> Hi,
>>>>> best regards
>>>>> Bahram
>>>>>> Hi Bahram,
>>>>>> gr. Martin
>>>>>> Bahram wrote:
>>>>>>> Hi Martin,
>>>>>>> I mean Diagram from
>>>>>>> gr. Bahram
>>>>>>>> Hi Bahram,
>>>>>>>> to be registered.
>>>>>>>> gr. Martin
>>>>>>>> Bahram Kord wrote:
>>>>>>>>> Hi,
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> thanks a lot
>>>>>>>>> Bahram
The Netherlands
Re: [TENEO] ID from EString [message #431069 is a reply to message #430692] Thu, 25 June 2009 11:50 Go to previous messageGo to next message
Hi martin,
thank you for your replay an sorry for delay of my message.
I set the breakpoint at the anyType. this problem caused by setting an Embeddedsoftware to Diagram
EmbeddedSoftware mapping :
<subclass name="org.efixes.software.impl.EmbeddedSoftwareImpl" entity-name="EmbeddedSoftware" abstract="false" lazy="false" extends="SoftwareElement" discriminator-value="EmbeddedSoftware">
<meta attribute="eclassName">EmbeddedSoftware</meta>
<meta attribute="epackage">http://www.efixes.org/efixes.ecore/efixes/software</meta>
<list name="tasks" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="embeddedsoftware_tasks">
<column name="`embeddedsoftware_tasks_id`" not-null="false" unique="false"/>
</key>
<list-index column="`embeddedsoftware_tasks_idx`"/>
<one-to-many entity-name="Task"/>
</list>
<list name="softwareConnections" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="embeddedsoftware_softwareconnections">
<column name="`embeddedsoftware_softwareconnections_id`" not-null="false" unique="false"/>
</key>
<list-index column="`embeddedsoftware_softwareconnections_idx`"/>
<one-to-many entity-name="SoftwareConnection"/>
</list>
<list name="ports" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="embeddedsoftware_ports">
<column name="`embeddedsoftware_ports_id`" not-null="false" unique="false"/>
</key>
<list-index column="`embeddedsoftware_ports_idx`"/>
<one-to-many entity-name="Port"/>
</list>
<list name="sources" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="embeddedsoftware_sources">
<column name="`embeddedsoftware_sources_id`" not-null="false" unique="false"/>
</key>
<list-index column="`embeddedsoftware_sources_idx`"/>
<one-to-many entity-name="Source"/>
</list>
<list name="sinks" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="embeddedsoftware_sinks">
<column name="`embeddedsoftware_sinks_id`" not-null="false" unique="false"/>
</key>
<list-index column="`embeddedsoftware_sinks_idx`"/>
<one-to-many entity-name="Sink"/>
</list>
<list name="responseTimeProbes" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="embeddedsoftware_responsetimeprobes">
<column name="`embeddedsoftware_responsetimeprobes_id`" not-null="false" unique="false"/>
</key>
<list-index column="`embeddedsoftware_responsetimeprobes_idx`"/>
<one-to-many entity-name="ResponseTimeProbe"/>
</list>
<list name="inspectionProbes" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="embeddedsoftware_inspectionprobes">
<column name="`embeddedsoftware_inspectionprobes_id`" not-null="false" unique="false"/>
</key>
<list-index column="`embeddedsoftware_inspectionprobes_idx`"/>
<one-to-many entity-name="SwInspectionProbe"/>
</list>
<list name="boundedSpectrumElements" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="embeddedsoftware_boundedspectrumelements">
<column name="`embeddedsoftware_boundedspectrumelements_id`" not-null="false" unique="false"/>
</key>
<list-index column="`embeddedsoftware_boundedspectrumelements_idx`"/>
<one-to-many entity-name="BoundedSpectrumElement"/>
</list>
</subclass>
this is the Identifiable mapping:
<class name="org.efixes.impl.IdentifiableImpl" entity-name="Identifiable" abstract="true" lazy="false" discriminator-value="Identifiable" table="`identifiable`">
<meta attribute="epackage">http://www.efixes.org/efixes.ecore/efixes</meta>
</id>
<version name="e_version" column="e_version" access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler ">
</version>
</class>
br. Bahram
> Hi Bahram,
> session);
> object is a string. Looking at the mapping you showed below there is no
> that this exception is for another object/efeature.
> hibernate.jar and add the source directory of hibernate to it (so the
> id hibernate mapping (if that is done in a super type).
> gr. Martin
> Bahram wrote:
>> Hi Martin,
>> Diagram with
>> gr. Bahram
>>> Hi Bahram,
>>> set?
>>> gr. Martin
>>> Bahram Kord wrote:
>>>> Hi Martin,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> <meta
>>>> </id>
>>>> </version>
>>>> </class>
>>>> Id-Type to ELong.
>>>> Best rgards.
>>>> Bahram
>>>>> Hi Bahram,
>>>>> Teneo:
>>>>> gr. Martin
>>>>> Bahram Kord wrote:
>>>>>> Hi,
>>>>>> best regards
>>>>>> Bahram
>>>>>>> Hi Bahram,
>>>>>>> gr. Martin
>>>>>>> Bahram wrote:
>>>>>>>> Hi Martin,
>>>>>>>> I mean Diagram from
>>>>>>>> gr. Bahram
>>>>>>>>> Hi Bahram,
>>>>>>>>> gr. Martin
>>>>>>>>> Bahram Kord wrote:
>>>>>>>>>> Hi,
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> an Epackage from GMF and i dont create it myslef.
>>>>>>>>>> thanks a lot
>>>>>>>>>> Bahram
Re: [TENEO] ID from EString [message #431074 is a reply to message #431069] Thu, 25 June 2009 13:46 Go to previous messageGo to next message
Hi Bahram,
Hmm, okay, I did some more checking and it seems that any-types are mapped with the default idtype as long. Sorry for
not noting it earlier :-(.
Can you enter a bugzilla for this? Then I can make this option/annotation driven. Is not difficult to do (so in/after
the weekend I will do a new build).
gr. Martin
Bahram Kord wrote:
> Hi martin,
> <meta
> </key>
> </list>
> <key update="true"
> </key>
> <list-index
> </list>
> </key>
> </list>
> </key>
> </list>
> </key>
> </list>
> <key update="true"
> </key>
> <list-index
> </list>
> <key update="true"
> </key>
> </list>
> <key update="true"
> <column
> unique="false"/>
> </key>
> <list-index
> </list>
> </subclass>
> <meta
> </id>
> </version>
> </class>
> br. Bahram
>> Hi Bahram,
>> session);
>> the object is a string. Looking at the mapping you showed below there
>> feel is that this exception is for another object/efeature.
>> the id hibernate mapping (if that is done in a super type).
>> gr. Martin
>> Bahram wrote:
>>> Hi Martin,
>>> Diagram with
>>> gr. Bahram
>>>> Hi Bahram,
>>>> to set?
>>>> gr. Martin
>>>> Bahram Kord wrote:
>>>>> Hi Martin,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> <meta
>>>>> </id>
>>>>> </version>
>>>>> </class>
>>>>> Id-Type to ELong.
>>>>> Best rgards.
>>>>> Bahram
>>>>>> Hi Bahram,
>>>>>> Teneo:
>>>>>> gr. Martin
>>>>>> Bahram Kord wrote:
>>>>>>> Hi,
>>>>>>> best regards
>>>>>>> Bahram
>>>>>>>> Hi Bahram,
>>>>>>>> gr. Martin
>>>>>>>> Bahram wrote:
>>>>>>>>> Hi Martin,
>>>>>>>>> I mean Diagram from
>>>>>>>>> gr. Bahram
>>>>>>>>>> Hi Bahram,
>>>>>>>>>> gr. Martin
>>>>>>>>>> Bahram Kord wrote:
>>>>>>>>>>> Hi,
>>>>>>>>>>> element present for: Diagram for type EClass has its epackage
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> at
>>>>>>>>>>> thanks a lot
>>>>>>>>>>> Bahram
The Netherlands
Re: [TENEO] ID from EString [message #431099 is a reply to message #431074] Fri, 26 June 2009 15:59 Go to previous message
hi martin,
i entered a bugzilla whit for that with ID 281705.
br bahram
> Hi Bahram,
> mapped with the default idtype as long. Sorry for not noting it earlier
> option/annotation driven. Is not difficult to do (so in/after the
> gr. Martin
> Bahram Kord wrote:
>> Hi martin,
>> <meta
>> </key>
>> </list>
>> <key update="true"
>> <column
>> unique="false"/>
>> </key>
>> <list-index
>> </list>
>> </key>
>> </list>
>> </key>
>> </list>
>> </key>
>> </list>
>> <key update="true"
>> <column
>> unique="false"/>
>> </key>
>> <list-index
>> </list>
>> <key update="true"
>> </key>
>> <list-index
>> </list>
>> <key update="true"
>> <column
>> unique="false"/>
>> </key>
>> <list-index
>> </list>
>> </subclass>
>> <meta
>> </id>
>> </version>
>> </class>
>> br. Bahram
>>> Hi Bahram,
>>> session);
>>> gr. Martin
>>> Bahram wrote:
>>>> Hi Martin,
>>>> Diagram with
>>>> gr. Bahram
>>>>> Hi Bahram,
>>>>> to set?
>>>>> gr. Martin
>>>>> Bahram Kord wrote:
>>>>>> Hi Martin,
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> <meta
>>>>>> </id>
>>>>>> </version>
>>>>>> </class>
>>>>>> Id-Type to ELong.
>>>>>> Best rgards.
>>>>>> Bahram
>>>>>>> Hi Bahram,
>>>>>>> Teneo:
>>>>>>> gr. Martin
>>>>>>> Bahram Kord wrote:
>>>>>>>> Hi,
>>>>>>>> best regards
>>>>>>>> Bahram
>>>>>>>>> Hi Bahram,
>>>>>>>>> gr. Martin
>>>>>>>>> Bahram wrote:
>>>>>>>>>> Hi Martin,
>>>>>>>>>> I mean Diagram from
>>>>>>>>>> gr. Bahram
>>>>>>>>>>> Hi Bahram,
>>>>>>>>>>> gr. Martin
>>>>>>>>>>> Bahram Kord wrote:
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> at
>>>>>>>>>>>> thanks a lot
>>>>>>>>>>>> Bahram
Previous Topic:[QUERY] Does EMF Query run in Standalone mode?
Next Topic:The definitive truth about multiple inheritance
Current Time: Wed Nov 05 07:31:23 EST 2025
Powered by FUDForum. Page generated in 0.04225 seconds
