Home » Language IDEs » AspectJ » AJDT 1.2.0M1 released
AJDT 1.2.0M1 released [message #42820] Wed, 13 October 2004 12:50 Go to next message
Originally posted by: mchapman.uk.ibm.com
After many months of hard work the AJDT team are delighted to announce the
first milestone release of AJDT 1.2.0.
The new improvements in this release are extensive - please read the three
pages of the New and Noteworthy document for details.
This is a milestone release, to reflect the fact that some of the new
functionality may be incomplete or unstable in places. However we believe
this release is still a "safe" upgrade from 1.1.12, in that everything
that worked in 1.1.12 should work at least as well here.
Supported versions of Eclipse for this release are: 3.0.0, 3.0.1, and
3.1M1. Note that 3.1M2 will not work. Tested platforms are Windows and
Linux.
Please see the AJDT homepage for the New and Noteworthy, download
information, and the latest release notes:
http://www.eclipse.org/ajdt
Finally, the Eclipse download server has been heavily loaded recently, so
please be patient if the download is slow.
Matt + the rest of the AJDT team.
Matt Chapman
AJDT Development, http://www.eclipse.org/ajdt
Re: AJDT 1.2.0M1 released - Bug [message #42852 is a reply to message #42820] Wed, 13 October 2004 18:06 Go to previous messageGo to next message
Originally posted by: geirAoves.online.no
Should bugs for the M releases also be reported to Bugzilla, or here?
I have discovered the following bug:
Eclipse 3.01, AJDT 1.2.0M1. One AJDT Project with .java and .aj files in
same project.
Problem: Outline view for a Java class correctly shows advised methods:
However, double clicking on the advise DOES NOT take me to the Pointcut like
it did in 1.1.12. The same goes for the Outline view for an Aspect: It shows
Advised Java code: However, double clicking on e.g. an advised method DOES
NOT take me to that method in the Java code like in 1.1.12.
Geir Ove
"Matt Chapman" <mchapman@uk.ibm.com> wrote in message
news:pan.2004.10.13.16.50.14.844389@uk.ibm.com...
> Linux.
> Regards,
> Matt Chapman
Re: AJDT 1.2.0M1 released - Bug [message #42882 is a reply to message #42852] Thu, 14 October 2004 05:43 Go to previous messageGo to next message
Originally posted by: hawkinsh.uk.ibm.com
Geir Ove wrote:
> Hello,
> same project.
> Geir Ove
Hi Geir,
Bugs found on the M releases should still be reported via Bugzilla. I've
just had a look and there is a 1.2.0M1 option in the "Version" section
when you report an AJDT bug, so when you please raise a bug and select
that.
As for the problem you're seeing. I've had a look at the AspectJ Bean
Example in the outline view using the same environment as you mentioned
and the links work for me (there are .java and .aj files in there). Could
you try this on your machine? (To get the AspectJ Examples, go to File >
New > Other > AspectJ > AspectJ Examples > Bean Example). If you're still
seeing problems, could you raise a bug with steps to help us recreate it?
Thanks, Helen
Re: AJDT 1.2.0M1 released [message #43005 is a reply to message #42820] Mon, 18 October 2004 08:46 Go to previous message
Originally posted by: sbouchet.emn.fr
Humm, i am unable to connect to the update site today with the eclipse
update . while trying to open via a web browser give me a 403 error page :
Forbidden
You don't have permission to access /technology/ajdt/30/update on this
server.
Additionally, a 403 Forbidden error was encountered while trying to use
an ErrorDocument to handle the request.
Stephane
> Linux.
> Regards,
Re: AJDT 1.2.0M1 released - Bug [message #584206 is a reply to message #42820] Wed, 13 October 2004 18:06 Go to previous message
same project.
Geir Ove
> Linux.
> Regards,
> Matt Chapman
Re: AJDT 1.2.0M1 released - Bug [message #584223 is a reply to message #42852] Thu, 14 October 2004 05:43 Go to previous message
Geir Ove wrote:
> Hello,
> same project.
> Geir Ove
Hi Geir,
that.
Thanks, Helen
Re: AJDT 1.2.0M1 released [message #584284 is a reply to message #42820] Mon, 18 October 2004 08:46 Go to previous message
Forbidden
server.
Stephane
> Linux.
> Regards,
Previous Topic:Plugin and Fragment with AspectJ
Next Topic:Something's strange about opening/closing projects
Current Time: Fri Oct 31 11:18:50 EDT 2025
Powered by FUDForum. Page generated in 0.03916 seconds
