Home » Modeling » EMF » Removing generated icons from the ctool16 folder
Removing generated icons from the ctool16 folder [message #428198] Fri, 13 March 2009 10:22 Go to next message
Originally posted by: j4r0d.hotmail.com
In my EMF based plugin I am using a tree view. In the create child context
menu, I have noticed that if I remove the image of the child element from
the ctool16 folder, the corresponding image of the obj16 folder is used and
decorated ('+' sign appearing on the top right quarter).
I found this really great, but unfortunately in case of the child element
already exists in the model, the grayed decorated icon in the menu only
shows up when the mouse cursor is above the "create child" element... else
no icon appears! This may be related to the fact that the look of the icon
is slightly different depending on the position of the mouse cursor (as
previously described).
Is this a bug? Can I do something so I can get my menu displayed with every
decorated icon?
Thanks for your help.
J.
Re: Removing generated icons from the ctool16 folder [message #428200 is a reply to message #428198] Fri, 13 March 2009 10:43 Go to previous messageGo to next message
Jarod,
I think you are talking specifically about items that are disabled and
the fact they show no icon until the mouse selection navigates to them.
I notice the same thing in the "Edit" menu though, so I have to assume
this is just the way the system behaves...
Jarod Mills wrote:
> decorated icon?
> J.
Re: Removing generated icons from the ctool16 folder [message #428210 is a reply to message #428200] Fri, 13 March 2009 15:11 Go to previous messageGo to next message
Thanks for your quick answer Ed.
Don't you think this behavior is quite strange? I mean, I don't get the
point about having a disabled item which cannot show up an icon unless you
navigate to it. What is the logic? Which application behaves this way?
As I said the decoration feature is great, but from my point of view, it is
not well suited if it does not properly handle this case.
"Ed Merks" wrote:
> Jarod,
> I think you are talking specifically about items that are disabled and the
> fact they show no icon until the mouse selection navigates to them. I
> notice the same thing in the "Edit" menu though, so I have to assume this
> Jarod Mills wrote:
>> Hi,
>> context menu, I have noticed that if I remove the image of the child
>> element from the ctool16 folder, the corresponding image of the obj16
>> folder is used and decorated ('+' sign appearing on the top right
>> quarter).
>> else no icon appears! This may be related to the fact that the look of
>> the icon is slightly different depending on the position of the mouse
>> cursor (as previously described).
>> every decorated icon?
>> J.
Re: Removing generated icons from the ctool16 folder [message #428220 is a reply to message #428210] Sat, 14 March 2009 07:20 Go to previous messageGo to next message
--------------030401060505090307030407
Jarod,
Comments below.
Not really. If a menu item is disabled I don't suppose you really need
an icon to draw attention to something you can't do anyway.
> navigate to it.
To make it less eye catching?
I did point you to the "Edit" menu on the menu bar, so as far as I can
tell, this is just the way the system behaves, or maybe just the way
Eclipse behaves. In either case, my opinions are not likely to change it.
I don't think it's within my ability to control this.
> "Ed Merks" wrote:
>> Jarod,
>> Jarod Mills wrote:
>>> Hi,
>>> quarter).
>>> J.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Jarod,<br>
<br>
Comments below.<br>
<br>
<br>
Jarod Mills wrote:
<blockquote cite="mid:gpebcj$1du$1@build.eclipse.org" type="cite">
<pre wrap="">Thanks for your quick answer Ed.
Don't you think this behavior is quite strange?</pre>
</blockquote>
Not really.&nbsp; If a menu item is disabled I don't suppose you really need
an icon to draw attention to something you can't do anyway.<br>
<pre wrap=""> I mean, I don't get the
navigate to it.</pre>
</blockquote>
To make it less eye catching?<br>
<pre wrap=""> What is the logic? Which application behaves this way?
</pre>
</blockquote>
Eclipse behaves.&nbsp; In either case, my opinions are not likely to change
it.<br>
<pre wrap="">
</pre>
</blockquote>
I don't think it's within my ability to control this.<br>
<pre wrap="">
"Ed Merks" wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Jarod,
Jarod Mills wrote:
</pre>
<pre wrap="">Hi,
quarter).
J.
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------030401060505090307030407--
Re: Removing generated icons from the ctool16 folder [message #428223 is a reply to message #428220] Sat, 14 March 2009 07:29 Go to previous messageGo to next message
Guys,
Sorry that I jump in, but as I contributed the initial version of this
overlaying feature I felt tempted. More inline...
Ed Merks schrieb:
> Jarod,
> Comments below.
> need an icon to draw attention to something you can't do anyway.
I think it is less a question of drawing attention but more of intuitive
recognition of known functionality in the forrest of menu actions.
The icon form of a disabled function should IMHO not differ from the
enabled form.
BTW. what I still find annoying about this overlay feature is that I
have to delete the generated ctool icons after each regeneration. A
GenModel switch do disable ctool icon generation would be much
appreciated! ;-)
Cheers
/Eike
>> navigate to it.
>> "Ed Merks" wrote:
>>> Jarod,
>>> Jarod Mills wrote:
>>>> Hi,
>>>> quarter).
>>>> J.
Re: Removing generated icons from the ctool16 folder [message #428225 is a reply to message #428223] Sat, 14 March 2009 07:59 Go to previous messageGo to next message
Eike,
Comments below.
Eike Stepper wrote:
> Guys,
> Ed Merks schrieb:
>> Jarod,
>> Comments below.
> intuitive recognition of known functionality in the forrest of menu
> actions.
> enabled form.
No matter how many times I'm told this it will still remain beyond my
capacity to control :-P
> appreciated! ;-)
You mean like the "Creation Icons" property?
> Cheers
> /Eike
> http://thegordian.blogspot.com
>>> I mean, I don't get the point about having a disabled item which
>>> cannot show up an icon unless you navigate to it.
>> can tell, this is just the way the system behaves, or maybe just the
>> way Eclipse behaves. In either case, my opinions are not likely to
>> change it.
>>> view, it is not well suited if it does not properly handle this case.
>>> "Ed Merks" wrote:
>>>> Jarod,
>>>> and the fact they show no icon until the mouse selection navigates
>>>> to them. I notice the same thing in the "Edit" menu though, so I
>>>> have to assume this is just the way the system behaves...
>>>> Jarod Mills wrote:
>>>>> Hi,
>>>>> child element from the ctool16 folder, the corresponding image of
>>>>> the obj16 folder is used and decorated ('+' sign appearing on the
>>>>> top right quarter).
>>>>> element already exists in the model, the grayed decorated icon in
>>>>> the menu only shows up when the mouse cursor is above the "create
>>>>> child" element... else no icon appears! This may be related to the
>>>>> fact that the look of the icon is slightly different depending on
>>>>> the position of the mouse cursor (as previously described).
>>>>> with every decorated icon?
>>>>> J.
Re: Removing generated icons from the ctool16 folder [message #428231 is a reply to message #428225] Sun, 15 March 2009 04:48 Go to previous message
Ed,
You're right. I thought I'd remember that the "Child Icon Creation"
option would not do what I want. But I double checked and can confirm:
It does exactly that ;-)
Cheers
/Eike
Ed Merks schrieb:
> Eike,
> Comments below.
> Eike Stepper wrote:
>> Guys,
>> this overlaying feature I felt tempted. More inline...
>> Ed Merks schrieb:
>>> Jarod,
>>> Comments below.
>> actions.
>> enabled form.
>> appreciated! ;-)
>> Cheers
>> /Eike
>>> change it.
>>>> "Ed Merks" wrote:
>>>>> Jarod,
>>>>> Jarod Mills wrote:
>>>>>> Hi,
>>>>>> child context menu, I have noticed that if I remove the image of
>>>>>> the child element from the ctool16 folder, the corresponding
>>>>>> image of the obj16 folder is used and decorated ('+' sign
>>>>>> the fact that the look of the icon is slightly different
>>>>>> depending on the position of the mouse cursor (as previously
>>>>>> described).
>>>>>> J.
Previous Topic:raw container warnings
Next Topic:ResourceSet save options?
Current Time: Sun Jul 20 23:15:22 EDT 2025
Powered by FUDForum. Page generated in 0.41103 seconds
