Home » Eclipse Projects » Rich Client Platform (RCP) » RCP with webservice using internal Tomcat plugin
RCP with webservice using internal Tomcat plugin [message #428025] Fri, 06 May 2005 06:39 Go to next message
I trying to add some remote administration features to my RCP application.
For this I would like to enable the different services/components to
talk between each other directly in the same JVM OR to remotely through
a webserver.
I have found that the help plugin, which I will use in the future
contains already the Tomcat installation.
I would like to reuse the org.eclipse.tomcat plugin to host my servlet
instead of adding an external Tomcat server.
I have found several tutorial on developping for Tomcat, but nothing on
the internal tomcat server...
Does anyone have any experience on using the internal Tomcat server ?
Cédric
PS: I am planning to use the lightweight Burlap protocol for the
webservice communication
(http://www.caucho.com/resin-3.0/protocols/burlap.xtp)
Re: RCP with webservice using internal Tomcat plugin [message #428029 is a reply to message #428025] Fri, 06 May 2005 08:55 Go to previous messageGo to next message
If you insist that you MUST use Tomcat...there is an article about
stripping tomcat for personal application use on onjava.com. However-I
would suggest using Jetty.
Re: RCP with webservice using internal Tomcat plugin [message #428034 is a reply to message #428029] Fri, 06 May 2005 11:09 Go to previous messageGo to next message
I would like not to bundle a big piece software when a similar software
is already present in the distribution...
If jetty library size is not too big I will give it a try.
Thanks for the pointer.
Cedric
Re: RCP with webservice using internal Tomcat plugin [message #428061 is a reply to message #428025] Sat, 07 May 2005 08:21 Go to previous messageGo to next message
Eclipse help system has an `intenal' extension point for the web
application.
http://help.eclipse.org/help30/topic/org.eclipse.platform.do c.isv/reference/extension-points/org_eclipse_help_base_webap p.html
#This extension point is used by org.eclipse.help.webapp plugin.
Probably, you can use this internal extension point. But I think that
it is hard to use an internal server, because default port is
automatically selected for the help broswer.
ryu
"Cédric Hyppolite" <cedric.hyppolite@free.fr> wrote in message
news:d5fhsf$hka$1@news.eclipse.org...
> For this I would like to enable the different services/components to talk
> between each other directly in the same JVM OR to remotely through a
> webserver.
> I have found that the help plugin, which I will use in the future contains
> Cédric
Re: RCP with webservice using internal Tomcat plugin [message #443667 is a reply to message #428061] Thu, 02 February 2006 11:27 Go to previous messageGo to next message
Originally posted by: hermann.woock.t-systems.com
I have a very similar problem. I'd like to have a webservice within my RCP-Application. Therefor I need a Tomcat that corresponses with my businesslogic that resists in my plugins. I wonder how I can build this connection between a Servlet and my plugins.
Re: RCP with webservice using internal Tomcat plugin [message #449413 is a reply to message #443667] Fri, 12 May 2006 05:51 Go to previous message
Originally posted by: pohngerald.yahoo.de
I have the same problem...do you found any solution?
Previous Topic:How to hide and Show views????
Next Topic:How change the tab color
Current Time: Mon Sep 01 00:04:24 EDT 2025
Powered by FUDForum. Page generated in 0.04767 seconds
