Home » Modeling » EMF » A Question about JET Tutorial 1
A Question about JET Tutorial 1 [message #427621] Tue, 24 February 2009 11:09 Go to next message
I am new to JET and would like to following the tutorial. But I have
question as follow:
Where should I copy the following code?
>We can create an instance of the HelloWorldTemplate template implementation
>class and invoke its generate method like this:
> HelloWorldTemplate helloworld = new HelloWorldTemplate();
> String result = helloworld.generate(null);
> System.out.println(result);
In the template, HelloWorldTemplate, or a new java file? How to run the
generated file? Thanks.
Williams.
Re: A Question about JET Tutorial 1 [message #427622 is a reply to message #427621] Tue, 24 February 2009 12:04 Go to previous messageGo to next message
Williams,
For any .java file that contains a main() method, you'll be able, from
the editor or on the file itself in the explorer, to invoke "Run
As->Java Application"
> question as follow:
>> implementation class and invoke its generate method like this:
> the generated file? Thanks.
> Williams.
Re: A Question about JET Tutorial 1 [message #427630 is a reply to message #427622] Tue, 24 February 2009 21:53 Go to previous messageGo to next message
Thanks, Ed. I got the following link:
http://www.eclipse.org/articles/Article-JET/jet_tutorial1.ht ml
when I typed jet tutorial 1 in google, which seems obsolete.
Now I know how to do it. Thanks.
W.
Ed Merks wrote:
> Williams,
>> question as follow:
>> Williams.
Re: A Question about JET Tutorial 1 [message #427985 is a reply to message #427621] Mon, 09 March 2009 08:37 Go to previous messageGo to next message
"Williams " <cool_go_blue@yahoo.com> schrieb im Newsbeitrag
news:007e2e299b6470a11eed0306fbb1960b$1@www.eclipse.org...
I, too, have a question. I cannot follow the tutorial. I do not seem to have
JET installed. I have tons of EMF plugins now, but there is no such thing as
a JET nature or any JET preferences. Where do I fail?
Bye,
Mike
Michael Piefel
netCCM GmbH
Re: A Question about JET Tutorial 1 [message #427987 is a reply to message #427985] Mon, 09 March 2009 08:47 Go to previous messageGo to next message
Mike,
Is org.eclipse.emf.codegen installed? That's where JET is located. If
org.eclipse.emf.codegen.ui is installed, then you should be able to add
a jet nature to your Java project.
> to have JET installed. I have tons of EMF plugins now, but there is no
> such thing as a JET nature or any JET preferences. Where do I fail?
> Bye,
> Mike
Re: A Question about JET Tutorial 1 [message #427991 is a reply to message #427987] Mon, 09 March 2009 10:08 Go to previous messageGo to next message
"Ed Merks" <Ed.Merks@gmail.com> schrieb im Newsbeitrag
news:gp334d$ek6$4@build.eclipse.org...
> org.eclipse.emf.codegen.ui is installed, then you should be able to add a
Yes, both are installed (version *_2.4.0.v200902171115). Still, no JET can
be seen anywhere in Eclipse.
I remember that it did work quite some time ago when I first looked at it.
The tutorial is also a few years old. Did something fundamental change?
Bye,
Mike
Michael Piefel
netCCM GmbH
Re: A Question about JET Tutorial 1 [message #427993 is a reply to message #427991] Mon, 09 March 2009 10:43 Go to previous messageGo to next message
Mike,
It should still work with File->New->Other..->Java Emitter
Templates->Convert Projects to JET Projects... Isn't that available?
>> If org.eclipse.emf.codegen.ui is installed, then you should be able
>> to add a jet nature to your Java project.
> can be seen anywhere in Eclipse.
> it. The tutorial is also a few years old. Did something fundamental
> change?
> Bye,
> Mike
Re: A Question about JET Tutorial 1 [message #428092 is a reply to message #427993] Tue, 10 March 2009 06:02 Go to previous message
news:gp39u2$b61$1@build.eclipse.org...
No, it was not available. However, I downloaded and installed a fresh
Eclipse and added the two EMF Codegen plugins to it, et voilà, it started
working again.
Eclipse seems to be like Windows used to be, a fresh install from time to
time works wonders. The amount of time I spent hunting for plugin yesterday
is quite sad, but I thank you for confirming that I already had the right
plugins in view.
Bye,
Mike
Michael Piefel
netCCM GmbH
Previous Topic:Possible EObjectResolvingEList.addAll() / didChange() NPE bug?
Next Topic:EcoreUitl.resolveAll
Current Time: Thu Nov 06 07:54:12 EST 2025
Powered by FUDForum. Page generated in 0.04308 seconds
