Home » Modeling » EMF » CDO Serverv. 2.0 and Embedded Derby setup
CDO Serverv. 2.0 and Embedded Derby setup [message #427478] |
Wed, 18 February 2009 16:56  |
I need help setting up CDO Server 2.0. I'm using the
org.eclipse.emf.cdo.server 2.0.0.v200902121924 plugin. When I execute the
server using the following cdo-server.xml file:
<cdoServer>
<!--acceptor type="http"/ -->
<acceptor type="tcp" listenAddr="0.0.0.0" port="2036">
<!-- negotiator type="challenge" description="/tmp/users.db"/ -->
</acceptor>
<repository name="repo1">
<property name="overrideUUID"
value="1ff5d226-b1f0-40fb-aba2-0c31b38c764f"/>
<property name="supportingAudits" value="true"/>
<property name="verifyingRevisions" value="false"/>
<property name="currentLRUCapacity" value="10000"/>
<property name="revisedLRUCapacity" value="100"/>
<store type="db">
<mappingStrategy type="horizontal">
<property name="toManyReferences"
value="ONE_TABLE_PER_REFERENCE"/>
<property name="toOneReferences" value="LIKE_ATTRIBUTES"/>
</mappingStrategy>
<dbAdapter name="derby-embedded"/>
<dataSource class="org.apache.derby.jdbc.EmbeddedDataSource"
databaseName="/tmp/cdodb1"
createDatabase="create"/>
</store>
</repository>
</cdoServer>
I get the following error: Store factory not found: db.
I've installed both org.apache.derby and org.apache.derby.core plugins and
specified them as "Reguired Plug-ins" in the cdo server plugin.xml, but
that obviously is not enough. Can anyone help me. While there is some
documentation for cdo server 1.X. It is not applicable to v 2.0.
Re: CDO Serverv. 2.0 and Embedded Derby setup [message #943465 is a reply to message #427507] |
Sun, 14 October 2012 10:36   |
Sorry to resurrect this old thread, but I have the exact same problem and I seem unable to circumvent it.
I am quite new to CDO, so I'm trying to learn by following instructions.
I imported the example and slightly modified cdo-server.xml:
<cdoServer>
<acceptor type="tcp" listenAddr="0.0.0.0" port="2036"/>
<property name="overrideUUID" value=""/>
<property name="supportingBranches" value="true"/>
<property name="supportingEcore" value="true"/>
<property name="ensureReferentialIntegrity" value="true"/>
<property name="allowInterruptRunningQueries" value="false"/>
<property name="idGenerationLocation" value="STORE"/> <!-- Possible values: STORE | CLIENT -->
<store type="db">
<property name="connectionKeepAlivePeriod" value="60"/>
<property name="qualifiedNames" value="true"/>
</mappingStrategy>
databaseName="/data/repo1"
</store>
</repository>
</cdoServer>
I get the error:
Configuration location:
file:/D:/Work/StudioM/workspace/.metadata/.plugins/org.eclipse.pde.core/ExampleMasterServer/
Configuration file:
file:/D:/Work/StudioM/workspace/.metadata/.plugins/org.eclipse.pde.core/ExampleMasterServer/config.ini loaded
Install location:
file:/D:/opt/eclipse_3.8/
Framework located:
file:/D:/opt/eclipse_3.8/plugins/org.eclipse.osgi_3.8.1.v20120830-144521.jar
Framework classpath:
Debug options:
file:/D:/Work/StudioM/workspace/.metadata/.plugins/org.eclipse.pde.core/ExampleMasterServer/.options loaded
osgi> Time to load bundles: 18
Starting application: 626
app thread - org.eclipse.emf.cdo.server.app.0 [debug.om] Starting bundle org.eclipse.net4j.util
app thread - org.eclipse.emf.cdo.server.app.0 [debug.lifecycle] Activating ManagedContainer
app thread - org.eclipse.emf.cdo.server.app.0 [debug.lifecycle] Activating {}
app thread - org.eclipse.emf.cdo.server.app.0 [debug.lifecycle.dump] DUMP PluginFactoryRegistry@1
Registry.autoCommit = true
Registry.transaction = null
HashMapRegistry.map =
org.eclipse.net4j.Negotiators[challenge]=Factory[org.eclipse.net4j.Negotiators, challenge]
org.eclipse.net4j.randomizers[default]=Factory[org.eclipse.net4j.randomizers, default]
org.eclipse.net4j.userManagers[file]=Factory[org.eclipse.net4j.userManagers, file]
org.eclipse.net4j.executorServices[default]=Factory[org.eclipse.net4j.executorServices, default]
org.eclipse.emf.cdo.server.browsers[default]=Factory[org.eclipse.emf.cdo.server.browsers, default]
org.eclipse.net4j.util.timers[daemon]=Factory[org.eclipse.net4j.util.timers, daemon]
extensionRegistryListener = org.eclipse.net4j.internal.util.factory.PluginFactoryRegistry$1@20c12654
app thread - org.eclipse.emf.cdo.server.app.0 [debug.lifecycle] Activating []
app thread - org.eclipse.emf.cdo.server.app.0 [debug.om] Starting bundle org.eclipse.emf.cdo.server
app thread - org.eclipse.emf.cdo.server.app.0 [debug.om] Starting bundle org.eclipse.emf.cdo.common
app thread - org.eclipse.emf.cdo.server.app.0 [debug.lifecycle.dump] DUMP PluginElementProcessorList@2
processors =
org.eclipse.net4j.util.security.ChallengeNegotiatorConfigurer@dd9a6ac
org.eclipse.emf.cdo.spi.server.RepositoryUserManager$RepositoryInjector@4c4d6d4e
extensionRegistryListener = org.eclipse.net4j.internal.util.container.PluginElementProcessorList$1@28e4f4ad
app thread - org.eclipse.emf.cdo.server.app.0 [debug.lifecycle.dump] DUMP PluginContainer@3
ManagedContainer.factoryRegistry =
ManagedContainer.postProcessors =
ManagedContainer.elementRegistry =
app thread - org.eclipse.emf.cdo.server.app.0 [debug.om] Plugin container created: ManagedContainer
app thread - org.eclipse.emf.cdo.server.app.0 [debug.om] Starting application org.eclipse.emf.cdo.server.app
[INFO] CDO server starting
app thread - org.eclipse.emf.cdo.server.app.0 [debug.repository] Configuring CDO server from D:\Work\StudioM\workspace\cdo.example.master\config\cdo-server.xml
app thread - org.eclipse.emf.cdo.server.app.0 [debug.repository] Configuring repository repo1 (type=default)
[ERROR] Store factory not found: db
java.lang.IllegalStateException: Store factory not found: db
at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.getStoreFactory(RepositoryConfigurator.java:281)
at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.createStore(RepositoryConfigurator.java:291)
at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.getRepository(RepositoryConfigurator.java:164)
at org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:106)
at org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)
at org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplication.java:63)
at org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
main [debug.om] Stopping bundle org.eclipse.emf.cdo.server
main [debug.om] Stopping bundle org.eclipse.emf.cdo.common
main [debug.om] Stopping bundle org.eclipse.net4j.util
main [debug.lifecycle] Deactivating ManagedContainer
main [debug.lifecycle] Deactivating {org.eclipse.net4j.Negotiators[challenge]=Factory[org.eclipse.net4j.Negotiators, challenge], org.eclipse.net4j.randomizers[default]=Factory[org.eclipse.net4j.randomizers, default], org.eclipse.net4j.userManagers[file]=Factory[org.eclipse.net4j.userManagers, file], org.eclipse.net4j.executorServices[default]=Factory[org.eclipse.net4j.executorServices, default], org.eclipse.emf.cdo.server.browsers[default]=Factory[org.eclipse.emf.cdo.server.browsers, default], org.eclipse.net4j.util.timers[daemon]=Factory[org.eclipse.net4j.util.timers, daemon]}
main [debug.lifecycle] Deactivating [org.eclipse.net4j.util.security.ChallengeNegotiatorConfigurer@dd9a6ac, org.eclipse.emf.cdo.spi.server.RepositoryUserManager$RepositoryInjector@4c4d6d4e]
My plugin dependencies (currently, after many trials) look like this:
D:\opt\eclipse_3.8\plugins\org.eclipse.core.runtime_3.8.0.v20120521-2346.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.osgi_3.8.1.v20120830-144521.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.equinox.common_3.6.100.v20120522-1841.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.core.jobs_3.5.200.v20120521-2346.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.core.runtime.compatibility.registry_3.5.100.v20120521-2346\runtime_registry_compatibility.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.equinox.registry_3.5.200.v20120522-1841.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.equinox.preferences_3.5.0.v20120522-1841.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.core.contenttype_3.4.200.v20120523-2004.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.equinox.app_1.3.100.v20120522-1841.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.emf.cdo.server_4.1.1.v20120727-1146.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.emf.cdo_4.1.1.v20120727-1146.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.emf.ecore_2.8.1.v20120911-0500.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.emf.common_2.8.0.v20120911-0500.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.emf.ecore.xmi_2.8.0.v20120911-0500.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.emf.cdo.common_4.1.1.v20120821-1005.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.net4j.util_3.2.1.v20120727-1146.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.emf.cdo.server.admin_4.1.1.v20120821-1005.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.net4j_4.1.1.v20120821-1005.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.emf.cdo.server.db_4.1.1.v20120727-1146.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.net4j.db_4.1.0.v20120719-0822.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.emf.cdo.server.net4j_4.0.100.v20120821-1005.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.net4j.tcp_4.1.0.v20120821-1005.jar
D:\opt\eclipse_3.8\plugins\org.eclipse.net4j.db.h2_4.0.100.v20120821-1005.jar
D:\opt\eclipse_3.8\plugins\org.h2_1.1.117.v201105142352.jar
D:\opt\eclipse_3.8\dropins\org.apache.derby.core_10.8.2\derby.jar
D:\opt\eclipse_3.8\dropins\org.apache.derby.core_10.8.2\derbyclient.jar
D:\opt\eclipse_3.8\dropins\org.apache.derby.core_10.8.2\derbynet.jar
D:\opt\eclipse_3.8\dropins\org.apache.derby.core_10.8.2\derbytools.jar
What am I doing wrong?
TiA
Mauro
Re: CDO Serverv. 2.0 and Embedded Derby setup [message #946538 is a reply to message #943465] |
Tue, 16 October 2012 02:50  |
Am 14.10.2012 16:36, schrieb Mauro Condarelli:
> <cdoServer>
Please make sure you really need these 4 options or turn them off because they all may have a negative impact on some
characteristics.
> <store type="db">
> <property name="connectionKepAlivePeriod" value="60"/>
> </mappingStrategy>
IIRC, Derby is know to be pretty slow. Have you tried H2 already?
> </store>
> </repository>
> </cdoServer>
> I get the error:
> Configuration file:
> Install location:
> Framework located:
> Debug options:
> HashMapRegistry.map = org.eclipse.net4j.Negotiators[challenge]=Factory[org.eclipse.net4j.Negotiators, challenge]
> processors = mailto:org.eclipse.net4j.util.security.ChallengeNegotiatorConfigurer@dd9a6ac
> ManagedContainer.factoryRegistry = org.eclipse.net4j.Negotiators[challenge]=Factory[org.eclipse.net4j.Negotiators,
> challenge]
> ManagedContainer.postProcessors = mailto:org.eclipse.net4j.util.security.ChallengeNegotiatorConfigurer@dd9a6ac
You may want to set a breakpoint in org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.createExecutableExtension()
and find out why the needed factory couldn't be created. The one you need is contributed by the
org.eclipse.emf.cdo.server.db plugin:
<extension
point="org.eclipse.emf.cdo.server.storeFactories">
<storeFactory
class="org.eclipse.emf.cdo.server.internal.db.DBStoreFactory"
storeType="db">
</storeFactory>
</extension>
Make sure that plugin is properly *resolved* by OSGi.
Cheers
/Eike
http://www.esc-net.de
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> main [debug.lifecycle] Deactivating [mailto:org.eclipse.net4j.util.security.ChallengeNegotiatorConfigurer@dd9a6ac,
> TiA
> Mauro
Current Time: Sat Jul 19 04:00:33 EDT 2025
Powered by FUDForum. Page generated in 0.04505 seconds
