Home » Modeling » EMF » Re: [JFace Databinding] Bind EMap value to Text
Re: [JFace Databinding] Bind EMap value to Text [message #427374] Sun, 15 February 2009 12:38 Go to next message
Hi Kai,
I don't think there's direct support for this currently. The only
possibility i see currently is to create a volatile transient feature
(height) whenever the height changes you fire a notification for the
height feature.
If you have further question please we should discuss on the
EMF-Newsgroup - I think with the 3.5 properties API one can also observe
map-attributes but I'm not 100% sure.
Tom
Kai Schlamp schrieb:
> Hello.
> I want to observe a map (better to say a specific value belonging to a
> specific key) that is a child of an EMF EObject.
> Example (Pseudocode):
> Datastructure:
> class Building extends EObject {
> EMap properties
> Binding:
> bindingContext.bindValue(SWTObservables.observeText(myTextFi eld,
> SWT.Modify), EMFObservables.observe???(myBuilding???, ???), null, null);
> So how do I bind, let's say myBuilding.getProperties.get("height") to
> myTextField?
> Best regards,
> Kai
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: [JFace Databinding] Bind EMap value to Text [message #427376 is a reply to message #427374] Sun, 15 February 2009 18:28 Go to previous messageGo to next message
Comments below.
Tom Schindl schrieb:
> Hi Kai,
> height feature.
This won't be an option as there are quite many entries in my map that I
want to bind Text's to.
Does someone have a clue how to do that? I am not aware of the 3.5
properties API (althought I am using the current 3.5 milestone release).
> Tom
>> Hello.
>> Datastructure:
>> EMap properties
>> Binding:
>> myTextField?
>> Best regards,
>> Kai
Re: [JFace Databinding] Bind EMap value to Text [message #427377 is a reply to message #427376] Mon, 16 February 2009 04:00 Go to previous messageGo to next message
Hi Kai,
What one would need to write is an ObservableValue implementation for a
Map-Entry (as the current EMFObservables.observeMap() is for multi
valued features).
I'll take a look into how EMap-works and how it fires events so that one
could write an ObservableValue implementation for a specific key.
Something like this:
EMFObservables#observeMapEntry(
EObject obj,
EStructuralFeature feature,
String key)
I've never used EMap before but does it fire events on map changes?
The properties API I mentioned before isn't a solution and when using
EMF you could not use it because I'm still working on the EMF-port [1]
or if you prefer a workspace setup of the appropriate modules (I had to
patch the databinding.core which I need to recode soon) and see example
usage[2].
Tom
[1]https://bugs.eclipse.org/bugs/show_bug.cgi?id=262160
[2] http://github.com/tomsontom/emf-databinding-example/tree/mas ter
> Comments below.
>> Hi Kai,
>> height feature.
>> Tom
>>> Hello.
>>> Datastructure:
>>> EMap properties
>>> Binding:
>>> myTextField?
>>> Best regards,
>>> Kai
Re: [JFace Databinding] Bind EMap value to Text [message #427381 is a reply to message #427377] Mon, 16 February 2009 07:13 Go to previous messageGo to next message
--------------010005070204030908040903
Guys,
An EMap is effectively just a list of EObjects that implement
Map.Entry. There's no generated API/interface for the map entry EClass,
but the usual meta data for it exists in the generated package and such
an EClass will always have a "key" and a "value" feature. So you should
be able to observe the one entry in the usual way. You could use
eMap.indexOf(key) and then eMap.get(index) to get the Map.Entry and then
you could cast it to EObject...
Tom Schindl wrote:
> Hi Kai,
> valued features).
> EObject obj,
> String key)
> usage[2].
> Tom
>> Comments below.
>>> Hi Kai,
>>> height feature.
>>> Tom
>>>> Hello.
>>>> Datastructure:
>>>> EMap properties
>>>> Binding:
>>>> myTextField?
>>>> Best regards,
>>>> Kai
<html>
<head>
http-equiv="Content-Type">
</head>
Guys,<br>
<br>
Map.Entry.
Re: [JFace Databinding] Bind EMap value to Text [message #427402 is a reply to message #427381] Mon, 16 February 2009 17:01 Go to previous messageGo to next message
Thanks for the explanations, Ed.
Do you have a simple example when using a bindingContext?
Lets assume the simple data structure from my first posting:
EMap props
and now I need the IObservableValue of myBuilding.getProps.get("height")
for example to bind it to a text.
EMFObservables.observeValue(myBuilding.getProps, ???)
Kai
Ed Merks schrieb:
> Guys,
> Tom Schindl wrote:
>> Hi Kai,
>> valued features).
>> EObject obj,
>> String key)
>> usage[2].
>> Tom
>>> Comments below.
>>>> Hi Kai,
>>>> height feature.
>>>> Tom
>>>>> Hello.
>>>>> Datastructure:
>>>>> EMap properties
>>>>> Binding:
>>>>> myTextField?
>>>>> Best regards,
>>>>> Kai
Re: [JFace Databinding] Bind EMap value to Text [message #427403 is a reply to message #427381] Mon, 16 February 2009 18:29 Go to previous messageGo to next message
Hi Ed,
I just looked how an feature modeled as an EMap works and I'm sorry but
I think I don't get it. An EMap is an ordinary java.util.Map and it
doesn't fire events. Do you by change talk about an EFeatureMap?
So I don't see a chance to provide an ObservableValue implementation for
an entry in the map.
Tom
Ed Merks schrieb:
> Guys,
> Tom Schindl wrote:
>> Hi Kai,
>> valued features).
>> EObject obj,
>> String key)
>> usage[2].
>> Tom
>>> Comments below.
>>>> Hi Kai,
>>>> height feature.
>>>> Tom
>>>>> Hello.
>>>>> Datastructure:
>>>>> EMap properties
>>>>> Binding:
>>>>> myTextField?
>>>>> Best regards,
>>>>> Kai
Re: [JFace Databinding] Bind EMap value to Text [message #427416 is a reply to message #427402] Tue, 17 February 2009 11:20 Go to previous messageGo to next message
--------------010701050905050605080100
Kai,
Comments below.
Unfortunately not.
> EMap props
> myBuilding.getProps.get("height") for example to bind it to a text.
This should yield you an EObject you can observe like all the other
examples:
(EObject)myBuilding.getProps().get(getProps().indexOfKey("height "))
Presumably there is a XyzPackage.Literals.STRING_TO_ABC_MAP__VALUE
feature for that map entry...
> Kai
> Ed Merks schrieb:
>> Guys,
>> EClass, but the usual meta data for it exists in the generated
>> package and such an EClass will always have a "key" and a "value"
>> feature. So you should be able to observe the one entry in the usual
>> way. You could use eMap.indexOf(key) and then eMap.get(index) to get
>> the Map.Entry and then you could cast it to EObject...
>> Tom Schindl wrote:
>>> Hi Kai,
>>> valued features).
>>> one
>>> EObject obj,
>>> String key)
>>> usage[2].
>>> Tom
>>>> Comments below.
>>>>> Hi Kai,
>>>>> height feature.
>>>> that I
>>>>> observe
>>>> release).
>>>>> Tom
>>>>>> Hello.
>>>>>> to a
>>>>>> Datastructure:
>>>>>> EMap properties
>>>>>> Binding:
>>>>>> null);
>>>>>> myTextField?
>>>>>> Best regards,
>>>>>> Kai
<html>
<head>
</head>
Kai,<br>
<br>
Comments below.<br>
<br>
Kai Schlamp wrote:
<blockquote cite="mid:gncno2$jco$1@build.eclipse.org" type="cite">Thanks
<br>
<br>
</blockquote>
Unfortunately not.<br>
<blockquote cite="mid:gncno2$jco$1@build.eclipse.org" type="cite"><br>
<br>
<br>
<br>
Re: [JFace Databinding] Bind EMap value to Text [message #427417 is a reply to message #427403] Tue, 17 February 2009 11:22 Go to previous messageGo to next message
--------------010903070500010801010803
Tom,
Comments below.
Tom Schindl wrote:
> Hi Ed,
I thought it was totally self-evident. :-P
No, it's not. It's a containment EList with all the other methods on a
java.util.Map, and you can get a Map view of it.
FeatureMap is a different thing. No one asked about that yet I don't think.
Yes because the Map.Entry instances implement EObject (because the EMap
is just a containment list).
> Tom
> Ed Merks schrieb:
>> Guys,
>> Tom Schindl wrote:
>>> Hi Kai,
>>> valued features).
>>> EObject obj,
>>> String key)
>>> usage[2].
>>> Tom
>>>> Comments below.
>>>>> Hi Kai,
>>>>> height feature.
>>>>> Tom
>>>>>> Hello.
>>>>>> Datastructure:
>>>>>> EMap properties
>>>>>> Binding:
>>>>>> myTextField?
>>>>>> Best regards,
>>>>>> Kai
<html>
<head>
</head>
Tom,<br>
<br>
Comments below.<br>
<br>
Tom Schindl wrote:
<blockquote cite="mid:gncsse$67u$1@build.eclipse.org" type="cite">
<pre wrap="">Hi Ed,
I think I don't get it.</pre>
</blockquote>
I thought it was totally self-evident. :-P<br>
<pre wrap=""> An EMap is an ordinary java.util.Map and it
doesn't fire events.</pre>
</blockquote>
No, it's not.
Re: [JFace Databinding] Bind EMap value to Text [message #427426 is a reply to message #427417] Tue, 17 February 2009 13:30 Go to previous messageGo to next message
Could you guys please provide me with a simple .ecore so that I generate
the code and write an ObservableValue implementation which should be
quite easy?
Tom
Ed Merks schrieb:
> Tom,
> Comments below.
> Tom Schindl wrote:
>> Hi Ed,
>> Tom
>> Ed Merks schrieb:
>>> Guys,
>>> Tom Schindl wrote:
>>>> Hi Kai,
>>>> valued features).
>>>> EObject obj,
>>>> String key)
>>>> usage[2].
>>>> Tom
>>>>> Comments below.
>>>>>> Hi Kai,
>>>>>> height feature.
>>>>>> Tom
>>>>>>> Hello.
>>>>>>> Datastructure:
>>>>>>> EMap properties
>>>>>>> Binding:
>>>>>>> myTextField?
>>>>>>> Best regards,
>>>>>>> Kai
Re: [JFace Databinding] Bind EMap value to Text [message #427427 is a reply to message #427426] Tue, 17 February 2009 14:24 Go to previous messageGo to next message
--------------020502050807080607090901
Tom,
Ecore.ecore has EAnnotation.details so you can do this directly with the
Ecore model. I'm not sure that anything that doesn't already exist is
needed...
Tom Schindl wrote:
> quite easy?
> Tom
> Ed Merks schrieb:
>> Tom,
>> Comments below.
>> Tom Schindl wrote:
>>> Hi Ed,
>>> Tom
>>> Ed Merks schrieb:
>>>> Guys,
>>>> Tom Schindl wrote:
>>>>> Hi Kai,
>>>>> valued features).
>>>>> EObject obj,
>>>>> String key)
>>>>> usage[2].
>>>>> Tom
>>>>>> Comments below.
>>>>>>> Hi Kai,
>>>>>>> height feature.
>>>>>>> Tom
>>>>>>>> Hello.
>>>>>>>> Datastructure:
>>>>>>>> EMap properties
>>>>>>>> Binding:
>>>>>>>> myTextField?
>>>>>>>> Best regards,
>>>>>>>> Kai
<html>
<head>
</head>
Tom,<br>
<br>
the Ecore model.
Re: [JFace Databinding] Bind EMap value to Text [message #427435 is a reply to message #427416] Tue, 17 February 2009 18:15 Go to previous messageGo to next message
Comment below
> examples:
Yes, this works fine.
Here a little example of how a complete binding looks like:
bindingContext.bindValue(SWTObservables.observeText(textFiel d),
EMFObservables.observeValue((EObject)
document.getProperties().get(document.getProperties().indexO fKey( "title")),
DocumentModelPackage.Literals.DOCUMENT_PROPERTY_MAP__VALUE), null, null);
Thanks Ed.
Re: [JFace Databinding] Bind EMap value to Text [message #427441 is a reply to message #427435] Wed, 18 February 2009 02:14 Go to previous messageGo to next message
Should we provide this as part of our EMFObservables-API?
EMFObservables.observeMapValue(
myBuilding,
DocumentModelPackage.Literals.DOCUMENT_PROPERTY,
"title",
Tom
> Comment below
>> examples:
> Thanks Ed.
Re: [JFace Databinding] Bind EMap value to Text [message #427444 is a reply to message #427441] Wed, 18 February 2009 03:55 Go to previous messageGo to next message
I added a factory method to my current working branch of EMF-Databinding
[1] (where I mainly implement the IProperty-Interfaces of 3.5).
You can fetch the sources from my public git repo [2] which also
provides a nice RCP Example Application showing many (if not all aspects
of Eclipse-Databinding with EMF).
If you are interested in EMF-Technologies (Ecore, Teneo, CDO) and RCP
I'll present all those concepts at EclipseCon 2009 [3].
Tom
[3]Mixing Eclipse Technologies to create Enterprise Ready
Database-RCP-Frontends - http://www.eclipsecon.org/2009/sessions?id=446
> myBuilding,
> "title",
> Tom
>> Comment below
>>> examples:
>> Thanks Ed.
Re: [JFace Databinding] Bind EMap value to Text [message #427482 is a reply to message #427441] Wed, 18 February 2009 18:27 Go to previous messageGo to next message
Comments below.
> myBuilding,
> "title",
It looks indeed much cleaner and readable than the other code with
"indexOfKey" and so on. So in my opinion it would be useful.
Kai
Re: [JFace Databinding] Bind EMap value to Text [message #506276 is a reply to message #427444] Wed, 06 January 2010 13:18 Go to previous messageGo to next message
Originally posted by: Thomas.Kowatsch.ruag.com
Hi Tom.
Do I miss something? I cannot find this method in the EMFObservable class.
--Thomas
> Tom
>> myBuilding,
>> "title",
>> Tom
>>> Comment below
>>>> examples:
>>> Thanks Ed.
Re: [JFace Databinding] Bind EMap value to Text [message #506317 is a reply to message #506276] Wed, 06 January 2010 13:58 Go to previous messageGo to next message
Probably I removed it in later iterations (I really can't even remember
this very discussion) :-(. I guess you are in need of such a method right?
If you need something file a bugzilla and CC me on the bug. I hope I can
find some time and motivation (I'm trying hard to remotivate myself but
didn't fully succeeded yet) to spend on EMF-Databinding .
Tom
Am 06.01.10 19:18, schrieb Thomas Kowatsch:
> Hi Tom.
> --Thomas
>> Hi,
>> Tom
>>> myBuilding,
>>> "title",
>>> Tom
>>>> Comment below
>>>>> examples:
>>>> null);
>>>> Thanks Ed.
Re: [JFace Databinding] Bind EMap value to Text [message #1115801 is a reply to message #506317] Tue, 24 September 2013 11:40 Go to previous messageGo to next message
i'm struggling with FeatureMaps and databinding. Can please someone show me an example how to do that or give me a hint, where i can find some documentation to this topic?
Thanks.
Re: [JFace Databinding] Bind EMap value to Text [message #1239495 is a reply to message #1115801] Tue, 04 February 2014 05:06 Go to previous message
Hy Tom,
got here after our e4-dev discussion on persistentState ... well very unfortunate you removed it, I could really use it to realize the binding to keys in the Map. Is this still an ongoing topic or did you completely cease work on this?
thanks,
marco
Previous Topic:OOM, ResourceSet, unload(), reloads (Xtext), IReferableElementsUnloader..
Next Topic:How to use 2 implementations of the same model ?
Current Time: Sun Nov 09 19:13:36 EST 2025
Powered by FUDForum. Page generated in 0.07067 seconds
