Home » Modeling » EMF » emf batch delete very slow
emf batch delete very slow [message #427068] Fri, 30 January 2009 11:13 Go to next message
I have a tableViewer (SWT.VIRTUAL) with about 20000 rows. The table is
backed by a AdapterFactoryContentProvider. If I select all and delete, it
takes too long, like one row per second.
Through debugger, I can see after an object is deleted from EList, the
tableViewer is notified and it is searching linearly through table items
to find the deleted object. Then does an update. That is probably why is
taking so long for 20000 rows.
Any tips are appreciated. I will try to turn off viewer updates until the
end. But not sure how to do it.
John
Re: emf batch delete very slow [message #427069 is a reply to message #427068] Fri, 30 January 2009 13:25 Go to previous messageGo to next message
John,
There was a similar question earlier in the week. At that time I
suggested they look what's happening in
AdapterFacotoryContentProvider.ViewerRefresh.merge. I would expect this
would merge the notifications. I don't recall if there was a response
to the suggestion...
> it takes too long, like one row per second.
> items to find the deleted object. Then does an update. That is
> probably why is taking so long for 20000 rows.
> the end. But not sure how to do it.
> John
Re: emf batch delete very slow [message #427070 is a reply to message #427069] Fri, 30 January 2009 15:00 Go to previous messageGo to next message
Ed,
Thanks for the tip. I will give a try tonight. I guess I probably need to
override some ViewerRefresh implementation to avoid table viewer updates.
John
Re: emf batch delete very slow [message #427078 is a reply to message #427069] Fri, 30 January 2009 23:54 Go to previous messageGo to next message
Hi Ed,
It turned out NotifyChangedToViewerRefresh.handleNotifyChanged is used
instead of viewerRefresh.
I was following the recipe you posted on
http://webui.sourcelabs.com/eclipse/issues/207324
that generates table columns using properties and PropertyEditingSupport.
It is very cool. I also followed your EMF book (1st edition) 14.2.3 to add
intermediary view objects for lists in my model.
If I remove the intermediary objects, delete all doesn't take long. It
seems that the intermediary listens to EList directly so each remove(i)
causes viewer to update.
By the way, when there is no intermediary, most of the time is spent in
UniqueEList.add function called by DeleteCommand.execute function. I
wonder why not use a HashSet.
John
Re: emf batch delete very slow [message #427083 is a reply to message #427078] Sat, 31 January 2009 07:56 Go to previous messageGo to next message
John,
HashSets have random ordering when you iterate over them, but it seems a
LinkedHashSet ought to work well. Feel free to open a bugzilla
enhancement request.
John Ye wrote:
> Hi Ed,
> PropertyEditingSupport. It is very cool. I also followed your EMF book
> (1st edition) 14.2.3 to add intermediary view objects for lists in my
> model.
> remove(i) causes viewer to update.
> in UniqueEList.add function called by DeleteCommand.execute function.
> I wonder why not use a HashSet.
> John
Re: emf batch delete very slow [message #427096 is a reply to message #427083] Sun, 01 February 2009 23:49 Go to previous messageGo to next message
I logged eclipse ticket number 263175 for DeleteCommand.execute using
UniqueEList.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=263175
For my main problem, I overrode AdapterFactoryContentProvider's
notifyChanged function to create a ViewNotification if notification is not
an instance of IViewerNotification.
It seems to work OK, but I did run into a couple of null pointer warnings.
public void notifyChanged(Notification notification) {
if (viewer != null && viewer.getControl() != null &&
!viewer.getControl().isDisposed()) {
if (viewerRefresh == null) {
viewerRefresh = new ViewerRefresh(viewer);
if (notification instanceof IViewerNotification) {
} else {
notification = new ViewerNotification(notification);
if (viewerRefresh.addNotification((IViewerNotification) notification)) {
viewer.getControl().getDisplay().asyncExec(viewerRefresh);
Suggestions are appreciated.
John
Re: emf batch delete very slow [message #427104 is a reply to message #427096] Mon, 02 February 2009 07:47 Go to previous messageGo to next message
John,
Comments below.
> UniqueEList.
I've committed the change.
> not an instance of IViewerNotification.
> warnings.
> } else {
> notification)) {
Why not just do an instanceof test, create the ViewerNotification if
needed, and call super to avoid duplicating any logic?
> John
Re: emf batch delete very slow [message #427111 is a reply to message #427104] Mon, 02 February 2009 10:23 Go to previous messageGo to next message
Ed,
You are right. The logic can be simplified by calling super implementation:
else {
super.notifyChanged(notification);
I am not sure if there are side effects of always using a
ViewerNotification.
John
Ed Merks wrote:
> John,
> Comments below.
>> UniqueEList.
>> warnings.
>> } else {
>> notification)) {
>> Thanks,
>> John
Re: emf batch delete very slow [message #427115 is a reply to message #427111] Mon, 02 February 2009 12:00 Go to previous messageGo to next message
John,
The design is how it currently is because ViewerNotification was added
later so you'd only have them if you regenerated your *.edit projects.
So we decided to leave existing behavior just as it was so that existing
applications would definitely be unaffected. So I wouldn't anticipate
any problems from what you've done.
John Ye wrote:
> Ed,
> implementation:
> } else {
> ViewerNotification.
> John
> Ed Merks wrote:
>> John,
>> Comments below.
>>> using UniqueEList.
>>> is not an instance of IViewerNotification.
>>> warnings.
>>> } else {
>>> notification)) {
>>> Thanks,
>>> John
Re: emf batch delete very slow [message #427122 is a reply to message #427111] Mon, 02 February 2009 14:21 Go to previous message
Ed,
Thanks a lot for your help!
Best,
John
Previous Topic:[Teneo] Use of constrained=true for 1 to 1?
Next Topic:generate an rcp application with emf
Current Time: Sat Jul 19 01:16:05 EDT 2025
Powered by FUDForum. Page generated in 0.04953 seconds
