Home » Modeling » EMF » Hide specific elements in tree editor
Hide specific elements in tree editor [message #426896] Fri, 23 January 2009 15:36 Go to next message
I have created a tree editor with emf. I want to hide specific elements in
the tree editor.
But not all!!
example:
-parent element
-element 1
-element 2 <-how to hide this?
-element 3
Is it possible to decide maybe with the name of the element or elements
with the same name only one time shown or hidden?
Thank you for your help!
Matthias
Re: Hide specific elements in tree editor [message #426900 is a reply to message #426896] Fri, 23 January 2009 21:44 Go to previous messageGo to next message
Matthias,
Comments below.
Matthias wrote:
> elements in the tree editor.
> But not all!!
> example:
> -parent element
> -element 1
> -element 3
> elements with the same name only one time shown or hidden?
It's certainly not trivial. In the end, it's AbcItemProvider's
getChildren/getElements that determines what's shown, so you can
certainly alter what's returned by those. But things like drag and drop
and other things based on child position will need specialization as well...
> Matthias
Re: Hide specific elements in tree editor [message #426901 is a reply to message #426900] Sat, 24 January 2009 03:30 Go to previous messageGo to next message
thank you for your fast reply.
This is what I was thinking about...
You mean this function:
public Collection<?> getChildren(Object object) {
// TODO Auto-generated method stub
return super.getChildren(object);
But how I can hide elements, when I remove childs from this object the
childs will also removed from the file.
object is the parent object of the children. When I go thru all his
children, how can I temp delete one or two?
Thank you a lot
Re: Hide specific elements in tree editor [message #426904 is a reply to message #426901] Sat, 24 January 2009 06:33 Go to previous messageGo to next message
Matthias,
Comments below.
Matthias wrote:
> @Override
It sounds like you've just assumed this but not confirmed it. The item
providers are purely for viewing and have no impact on the model itself.
Simply return a collection that doesn't contain them.
> Thank you a lot
Re: Hide specific elements in tree editor [message #426905 is a reply to message #426904] Sat, 24 January 2009 07:13 Go to previous messageGo to next message
BUT!
If I try this:
EObject eo = (EObject) object;
Collection<?> collectionVar = (Collection<?>) eo.eGet(containments...);
collectionVar.clear();
return collectionVar;
It works and the editor doesn't show the children, but if I do something
in the editor and save after this, the model WITHOUT the not shown childs
will be saved to the file. And this is a big problem.
Maybe you have a workaround?
Thanks a lot
Matthias
Ed Merks wrote:
> Matthias,
> Comments below.
> Matthias wrote:
>> Hi,
>> @Override
>> Thank you a lot
Re: Hide specific elements in tree editor [message #426906 is a reply to message #426905] Sat, 24 January 2009 07:56 Go to previous messageGo to next message
Matthias,
Comments below.
Matthias wrote:
> BUT!
> If I try this:
> @Override
It's obviously better to make a copy of the collection rather than
modifying the model itself.
> something in the editor and save after this, the model WITHOUT the not
> shown childs will be saved to the file. And this is a big problem.
Are you just trying not to show any children for certain features (i.e.,
filtering out entire features, which you can do on the properties for
the GenFeature) or are you trying to filter the children down to a
subset of some specific feature's larger set of children?
Don't change the model if you don't want it to change...
> Thanks a lot
> Matthias
> Ed Merks wrote:
>> Matthias,
>> Comments below.
>> Matthias wrote:
>>> Hi,
>>> @Override
>>> the childs will also removed from the file.
>> item providers are purely for viewing and have no impact on the model
>> itself.
>>> Thank you a lot
Re: Hide specific elements in tree editor [message #426907 is a reply to message #426906] Sat, 24 January 2009 08:08 Go to previous messageGo to next message
yes my example looks like I try to hide ALL of them, but this was just a
try.
I want to hide only ab subset of them, so it is not possible to do it in
the genmodel. Thats easy.
But how to distinguish the elements between document and view. Thats the
main problem.
At the moment I stay at an end point and I don't know how to solve the
problem.
Matthias
Re: Hide specific elements in tree editor [message #426908 is a reply to message #426907] Sat, 24 January 2009 09:09 Go to previous messageGo to next message
Matthias,
Comments below.
Matthias wrote:
> a try.
> in the genmodel. Thats easy.
> the main problem.
The collection returned by getChildren should be the ones you want in
the view.
> problem.
I'm not sure how else to explain it. Return the children you want in
the view. Don't modify the model's collections because that modifies
the state of the model. Make a copy of the list and modify that. Or
make a new list and add only the ones you want in the view.
> Matthias
Re: Hide specific elements in tree editor [message #426909 is a reply to message #426908] Sat, 24 January 2009 09:27 Go to previous messageGo to next message
Why not setting a ViewerFilter on the TreeViewer?
Tom
Ed Merks schrieb:
> Matthias,
> Comments below.
> Matthias wrote:
>> Hi,
>> a try.
>> the main problem.
> the view.
>> problem.
>> Thanks,
>> Matthias
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Hide specific elements in tree editor [message #426910 is a reply to message #426909] Sat, 24 January 2009 13:39 Go to previous messageGo to next message
this sounds good, how can I set such a filter?
Can I say to the filter-> elemet with attribute C don't show?
Matthias
> Tom
> Ed Merks schrieb:
>> Matthias,
>> Comments below.
>> Matthias wrote:
>>> Hi,
>>> a try.
>>> the main problem.
>> the view.
>>> problem.
>>> Thanks,
>>> Matthias
Re: Hide specific elements in tree editor [message #426911 is a reply to message #426910] Sat, 24 January 2009 15:45 Go to previous messageGo to next message
Matthias,
StructuredViewer has this method and then you'd implement a ViewerFilter
to pass in
public void setFilters(ViewerFilter[] filters)
Matthias wrote:
> Thanks
> Matthias
>> Tom
>> Ed Merks schrieb:
>>> Matthias,
>>> Comments below.
>>> Matthias wrote:
>>>> Hi,
>>>> a try.
>>>> the main problem.
>>> the view.
>>>> problem.
>>>> Thanks,
>>>> Matthias
Re: Hide specific elements in tree editor [message #426971 is a reply to message #426911] Tue, 27 January 2009 09:09 Go to previous messageGo to next message
Hi Ed,
I'm too stupid at the moment.
My problem at the moment is where I have to implement this?
Is it in MyElementItemProvider.java or somewhere in the Editor.java.
The problem is I need a object of the viewer and I only can get it
somewhere in the editor part and not edit part. Is this correct?
Or how I get the StructuredViewer of the actual object?
Thank's a lot.
Matthias
Ed Merks wrote:
> Matthias,
> to pass in
> Matthias wrote:
>> Hi,
>> Thanks
>> Matthias
>>> Tom
>>> Ed Merks schrieb:
>>>> Matthias,
>>>> Comments below.
>>>> Matthias wrote:
>>>>> Hi,
>>>>> a try.
>>>>> the main problem.
>>>> the view.
>>>>> problem.
>>>>> Thanks,
>>>>> Matthias
Re: Hide specific elements in tree editor [message #426982 is a reply to message #426971] Tue, 27 January 2009 11:36 Go to previous messageGo to next message
Matthias,
Comments below.
Matthias wrote:
> Hi Ed,
Your stupidity is beyond my control. :-P
You have to set it on the viewer and the view is created in the editor,
so yes, look for the Viewer creation in the editor.
Yes, in the editor.
> Thank's a lot.
> Matthias
> Ed Merks wrote:
>> Matthias,
>> ViewerFilter to pass in
>> Matthias wrote:
>>> Hi,
>>> Thanks
>>> Matthias
>>>> Tom
>>>> Ed Merks schrieb:
>>>>> Matthias,
>>>>> Comments below.
>>>>> Matthias wrote:
>>>>>> Hi,
>>>>>> just
>>>>>> a try.
>>>>>> do it
>>>>>> the main problem.
>>>>> the view.
>>>>>> solve the
>>>>>> problem.
>>>>>> Thanks,
>>>>>> Matthias
Re: Hide specific elements in tree editor [message #427013 is a reply to message #426982] Wed, 28 January 2009 04:05 Go to previous messageGo to next message
Ok,
now I implemented following code in ...Editor.java
ViewerFilter newFilter = new ViewerFilter() {
public boolean select(Viewer viewer, Object parentElement,
Object element) {
EObject eo = (EObject) element;
if((element.getClass().toString()).contains("TypeOfElement")) {
return true;
} else {
return false;
public boolean isFilterProperty(Object element, String property) {
return true;
if (property.equals("status"))
return true;
else
return super.isFilterProperty(element, property);
// Create a page for the parent tree view.
ViewerPane viewerPane =
new ViewerPane(getSite().getPage(), MSCEditor.this) {
public Viewer createViewer(Composite composite) {
Tree tree = new Tree(composite, SWT.MULTI);
TreeViewer newTreeViewer = new TreeViewer(tree);
return newTreeViewer;
public void requestActivation() {
super.requestActivation();
setCurrentViewerPane(this);
viewerPane.createControl(getContainer());
parentViewer = (TreeViewer)viewerPane.getViewer();
parentViewer.setAutoExpandLevel(30);
parentViewer.setContentProvider(new
ReverseAdapterFactoryContentProvider(adapterFactory));
parentViewer.setLabelProvider(new
AdapterFactoryLabelProvider(adapterFactory));
parentViewer.addFilter(newFilter);
createContextMenuFor(parentViewer);
int pageIndex = addPage(viewerPane.getControl());
setPageText(pageIndex, getString("_UI_ParentPage_label"));
I added the Filter before the tree is setted with:
I have added the filter with:
I have tried to create the select() and isFilterProperty() with my needs,
but when this functions will be called, or must I call them?
This point is still confusing to me.
Thanks a lot
Matthias
But
Ed Merks wrote:
> Matthias,
> Comments below.
> Matthias wrote:
>> Hi Ed,
> Yes, in the editor.
>> Thank's a lot.
>> Matthias
>> Ed Merks wrote:
>>> Matthias,
>>> Matthias wrote:
>>>> Hi,
>>>> Thanks
>>>> Matthias
>>>>> Tom
>>>>> Ed Merks schrieb:
>>>>>> Matthias,
>>>>>> Comments below.
>>>>>> Matthias wrote:
>>>>>>> Hi,
>>>>>>> just
>>>>>>> a try.
>>>>>>> do it
>>>>>>> the main problem.
>>>>>> the view.
>>>>>>> solve the
>>>>>>> problem.
>>>>>>> Thanks,
>>>>>>> Matthias
Re: Hide specific elements in tree editor [message #427018 is a reply to message #427013] Wed, 28 January 2009 06:49 Go to previous messageGo to next message
Matthias,
It sounds like you're ignoring your best friend, the debugger: set a
breakpoint in your select method and see when/if it's called. This
would reveal that of course the framework calls it.
Matthias wrote:
> Ok,
> @Override
> parentElement,
> Object element) {
> element;
> return true;
> } else {
> return false;
> @Override
> String property) {
> element;
> return true;
> return true;
> else
> property);
> @Override
> TreeViewer(tree);
> @Override
> needs, but when this functions will be called, or must I call them?
> Thanks a lot
> Matthias
> But
> Ed Merks wrote:
>> Matthias,
>> Comments below.
>> Matthias wrote:
>>> Hi Ed,
>> editor, so yes, look for the Viewer creation in the editor.
>> Yes, in the editor.
>>> Thank's a lot.
>>> Matthias
>>> Ed Merks wrote:
>>>> Matthias,
>>>> Matthias wrote:
>>>>> Hi,
>>>>> Thanks
>>>>> Matthias
>>>>>> Tom
>>>>>> Ed Merks schrieb:
>>>>>>> Matthias,
>>>>>>> Comments below.
>>>>>>> Matthias wrote:
>>>>>>>> Hi,
>>>>>>>> was just
>>>>>>>> a try.
>>>>>>>> do it
>>>>>>>> Thats
>>>>>>>> the main problem.
>>>>>>> want in
>>>>>>> the view.
>>>>>>>> solve the
>>>>>>>> problem.
>>>>>>> want in
>>>>>>> modifies
>>>>>>> that. Or
>>>>>>>> Thanks,
>>>>>>>> Matthias
Re: Hide specific elements in tree editor [message #427032 is a reply to message #427018] Wed, 28 January 2009 14:52 Go to previous messageGo to next message
Hi Ed,
thank you very much. Your right, the debugger knows everything!!
It works.
Thanks a lot.
Matthias
Ed Merks wrote:
> Matthias,
> Matthias wrote:
>> Ok,
>> @Override
>> parentElement,
>> Object element) {
>> element;
>> return true;
>> } else {
>> return false;
>> @Override
>> String property) {
>> element;
>> return true;
>> return true;
>> else
>> property);
>> @Override
>> TreeViewer(tree);
>> @Override
>> Thanks a lot
>> Matthias
>> But
>> Ed Merks wrote:
>>> Matthias,
>>> Comments below.
>>> Matthias wrote:
>>>> Hi Ed,
>>> Yes, in the editor.
>>>> Thank's a lot.
>>>> Matthias
>>>> Ed Merks wrote:
>>>>> Matthias,
>>>>> Matthias wrote:
>>>>>> Hi,
>>>>>> Thanks
>>>>>> Matthias
>>>>>>> Tom
>>>>>>> Ed Merks schrieb:
>>>>>>>> Matthias,
>>>>>>>> Comments below.
>>>>>>>> Matthias wrote:
>>>>>>>>> Hi,
>>>>>>>>> was just
>>>>>>>>> a try.
>>>>>>>>> do it
>>>>>>>>> Thats
>>>>>>>>> the main problem.
>>>>>>>> want in
>>>>>>>> the view.
>>>>>>>>> solve the
>>>>>>>>> problem.
>>>>>>>> want in
>>>>>>>> modifies
>>>>>>>> that. Or
>>>>>>>>> Thanks,
>>>>>>>>> Matthias
Re: Hide specific elements in tree editor [message #1815060 is a reply to message #426896] Wed, 25 September 2019 01:42 Go to previous message
//add a filter in tree viewer
treeViewer.addFilter(new ViewerFilter() {
public boolean select(Viewer viewer, Object parentElement, Object element) {
if (element instanceof MyObj) {
Myobj srmObj = (Myobj ) element;
if(srmObj .equals("element2")
return false;
else
return true;
Previous Topic:Hook to prevent command execution
Next Topic:I create an xml element by right click to EMF editor. Default values appear but not get saved to xml
Current Time: Sat Jul 26 23:22:15 EDT 2025
Powered by FUDForum. Page generated in 0.07928 seconds
