Home » Eclipse Projects » Nebula » How to provide tooltip text for images in grid view?
How to provide tooltip text for images in grid view? [message #42280] Mon, 29 October 2007 10:29 Go to next message
I am using GridColumnLabelProvider to put a image in one of the columns of
my grid view. But am not able to put (return) a tooltip text for the
image. I tried with getTooltipText but no use. Is there any API to put the
tooltip for images?
BG
Re: How to provide tooltip text for images in grid view? [message #42415 is a reply to message #42280] Mon, 29 October 2007 13:12 Go to previous messageGo to next message
Grid does have the ability to show cell specific tooltips but I don't
believe that functionality is in the viewer. You should be able to call
GridItem.setToolTipText(index,String) in your GCLP.update(ViewerCell)
method.
-Chris
BG wrote:
> Hello,
> of my grid view. But am not able to put (return) a tooltip text for the
> the tooltip for images?
> BG
Re: How to provide tooltip text for images in grid view? [message #42471 is a reply to message #42415] Mon, 29 October 2007 13:31 Go to previous messageGo to next message
are there no hover-events generated by the Grid when one moves the
mouse. The ToolTip support build into ever viewer inheriting from JFace
listens to those events and opens a SWT-Shell to present the ToolTip
which could be very fancy.
If this is not working for Grid like it does for SWT I think we need a
bug with a snippet and track the problem down.
Tom
> method.
> Regards,
> -Chris
> BG wrote:
>> Hello,
>> columns of my grid view. But am not able to put (return) a tooltip
>> text for the image. I tried with getTooltipText but no use. Is there
>> any API to put the tooltip for images?
>> Thanks,
>> BG
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: How to provide tooltip text for images in grid view? [message #42486 is a reply to message #42471] Mon, 29 October 2007 14:43 Go to previous messageGo to next message
for me tooltips simply work as designed (I've tested on OS-X) only
please take a look at the nebula-snippets available in CVS (Snippet5 is
holds the code).
I suppose you simply forgot to add this line to your Viewer-Setup :-)
-----8<-----
ColumnViewerToolTipSupport.enableFor(v,ToolTip.NO_RECREATE);
-----8<-----
which is required to get ToolTips working for ColumnViewer and it's
friends :-)
We should try to port more JFace-Snippets and make a dedicated wiki page
(any volunteers :-) most of the time the only task is to copy the
existing JFace-Snippet and replace the Table/TreeViewer for their grid
counter parts.
Tom
Tom Schindl schrieb:
> Tom
>> call GridItem.setToolTipText(index,String) in your
>> GCLP.update(ViewerCell) method.
>> Regards,
>> -Chris
>> BG wrote:
>>> Hello,
>>> Thanks,
>>> BG
Re: How to provide tooltip text for images in grid view? [message #42616 is a reply to message #42486] Tue, 30 October 2007 13:46 Go to previous message
You're right Tom. I only meant that the viewer work doesn't use the
built-in cell tooltip support in Grid. That wouldn't be very difficult
to do by modifying GridColumnLabelProvider. Anyway, the existing
support should be more than sufficient.
-Chris
Tom Schindl wrote:
> holds the code).
> -----8<-----
> -----8<-----
> friends :-)
> counter parts.
> Tom
>> Hi,
>> JFace listens to those events and opens a SWT-Shell to present the
>> ToolTip which could be very fancy.
>> Tom
>>> Regards,
>>> -Chris
>>> BG wrote:
>>>> Hello,
>>>> Thanks,
>>>> BG
Re: How to provide tooltip text for images in grid view? [message #585948 is a reply to message #42280] Mon, 29 October 2007 13:12 Go to previous message
method.
-Chris
BG wrote:
> Hello,
> BG
Re: How to provide tooltip text for images in grid view? [message #585984 is a reply to message #42415] Mon, 29 October 2007 13:31 Go to previous message
Tom
> method.
> Regards,
> -Chris
> BG wrote:
>> Hello,
>> Thanks,
>> BG
Re: How to provide tooltip text for images in grid view? [message #585993 is a reply to message #42471] Mon, 29 October 2007 14:43 Go to previous message
holds the code).
-----8<-----
-----8<-----
friends :-)
counter parts.
Tom
> Tom
>> Regards,
>> -Chris
>> BG wrote:
>>> Hello,
>>> Thanks,
>>> BG
Re: How to provide tooltip text for images in grid view? [message #586061 is a reply to message #42486] Tue, 30 October 2007 13:46 Go to previous message
-Chris
Tom Schindl wrote:
> holds the code).
> -----8<-----
> -----8<-----
> friends :-)
> counter parts.
> Tom
>> Hi,
>> Tom
>>> Regards,
>>> -Chris
>>> BG wrote:
>>>> Hello,
>>>> Thanks,
>>>> BG
Previous Topic:Extending Grid & GridViewer
Next Topic:Custom data model for cells in grid
Current Time: Thu Jul 24 18:02:03 EDT 2025
Powered by FUDForum. Page generated in 0.04858 seconds
