Home » Modeling » EMF » [CDO] CDOObject containment problems
[CDO] CDOObject containment problems [message #425915] Thu, 11 December 2008 12:11 Go to next message
Hi all,
I have a problem with resources in CDO. I have the following EMF model :
Data
Folder -> Datas
contents : 0..* Datas (containment = true)
File -> Data
The model is composed of Datas, a Data can be a Folder or a File. A
Folder can contains Datas, i.e. Files and Folders
I have a first resource : resource1 wich contains a instance of a File :
myFile
I have a second resource : resource2 which contains a instance of a
Folder : myFolder.
When I add myFile (of resource1) in myFolder (of resource2) it is
automatically removed from resource1. It is done in eBasicSetContainer
method of CDOObjectImpl class.
It seems that it works with pure EMF Resources. How can I manage this
kind of containment with CDO ?
David
Re: [CDO] CDOObject containment problems [message #425918 is a reply to message #425915] Thu, 11 December 2008 15:10 Go to previous messageGo to next message
David,
I think you're asking for "containment proxy" support, i.e. the ability
of an object to be directly contained in both a Resource and another
EObject, right?
In CDO 2.0 this should be supported:
246705: Support containment proxies
https://bugs.eclipse.org/bugs/show_bug.cgi?id=246705
But not in CDO 1.0.x!
Personally I never used this feature of EMF but isn't it done via
eSetDirectResource() or so?
Cheers
/Eike
David Bonneau schrieb:
> Hi all,
> Data
> Folder -> Datas
> File -> Data
> : myFile
> Folder : myFolder.
> David
Re: [CDO] CDOObject containment problems [message #425919 is a reply to message #425918] Thu, 11 December 2008 15:47 Go to previous messageGo to next message
Based on the work I've done you don't need to do anything special..
Here an example:
resource.getContent().add(objectA);
container.getElements().add(objectA);
if containment proxy is turned on... objectsA will not be removed from
resource when you add it to container....
(if I remember correctly).
Simon
Eike Stepper wrote:
> David,
> EObject, right?
> Cheers
> /Eike
> http://thegordian.blogspot.com
>> Hi all,
>> Data
>> Folder -> Datas
>> File -> Data
>> : myFile
>> Folder : myFolder.
>> David
Re: [CDO] CDOObject containment problems [message #425920 is a reply to message #425915] Thu, 11 December 2008 15:54 Go to previous messageGo to next message
It should be supported:
In your genmodel be sure you have the following set:
..genmodel
containment proxies = true
..ecore (under your relation)
resolve proxy should be true
containment = true
(maybe some of them doesn't need to be set... )
Let me know if it is working.
Simon
David Bonneau wrote:
> Hi all,
> Data
> Folder -> Datas
> File -> Data
> myFile
> Folder : myFolder.
> David
Re: [CDO] CDOObject containment problems [message #425931 is a reply to message #425920] Fri, 12 December 2008 05:21 Go to previous messageGo to next message
Simon, Eike, thanks for your help !
In my genmodel Containment Proxies property was false. I set it to true
and now it works :)
Now I have an exception : Unable to provideCDOID. I think it's me, I'm
doing things wrong.
I have on transaction where I create
- a Folder : myFolder
- a Resource : fileResource
- a File : myFile
- I add myFile in fileResource : fileResource -> myFile
- commit : OK
- I add myFile in myFolder : fileResource -> myFile <- myFolder
- commit : ! OK : unable to provideCDOID: fr.exemple.FolderImpl
I think, I understand why I have an exception : the CDOObject myFolder
doesn't belong to a Resource, if I do it, it works.
Is it a bug ?
David
Re: [CDO] CDOObject containment problems [message #425932 is a reply to message #425931] Fri, 12 December 2008 07:33 Go to previous messageGo to next message
hi David,
Does containment = true is set for the relationship: myFolder->myFile ?
Simon
> and now it works :)
> doing things wrong.
> - a File : myFile
> - commit : OK
> Is it a bug ?
> David
Re: [CDO] CDOObject containment problems [message #425934 is a reply to message #425932] Fri, 12 December 2008 08:38 Go to previous messageGo to next message
Simon McDuff a écrit :
> hi David,
Yes
> Simon
>> true and now it works :)
>> doing things wrong.
>> - a File : myFile
>> - commit : OK
>> Is it a bug ?
>> David
Re: [CDO] CDOObject containment problems [message #425936 is a reply to message #425934] Fri, 12 December 2008 09:08 Go to previous messageGo to next message
I've created a testcases and it worked... so I don't know what is
missing... Could you send me your .ecore and .genmodel ? (or the all
project) (you can open a buzilla :-))
Can you tell me which version of CDO you are using ?
Simon
>> hi David,
> Yes
>> Simon
>>> I'm doing things wrong.
>>> - a File : myFile
>>> - commit : OK
>>> myFolder doesn't belong to a Resource, if I do it, it works.
>>> Is it a bug ?
>>> David
Re: [CDO] CDOObject containment problems [message #425977 is a reply to message #425936] Mon, 15 December 2008 03:25 Go to previous message
I created a bugzilla with a Junit Test Case :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=258780
David
> Simon
>>> hi David,
>> Yes
>>> Simon
>>>> - a File : myFile
>>>> - commit : OK
>>>> Is it a bug ?
>>>> David
Previous Topic:Auto-create node's children
Next Topic:Creating EMap Entries
Current Time: Sun Jul 27 16:17:32 EDT 2025
Powered by FUDForum. Page generated in 0.04012 seconds
