Home » Modeling » EMF » Reflective API (eSet) in multiple (parent/child) models
Reflective API (eSet) in multiple (parent/child) models [message #425870] Wed, 10 December 2008 09:59 Go to next message
Dear NG,
I have asked this already but thought I found the solution. Hence I did
not. So I am asking again hereby:
I have a model structure that exist of several ECore models (one root,
several children). Now I am writing an import filter for an external
format that would create a model accordingly. I want to "eSet" all
sub-elements but I receive a "IllegalCastException" when I try to create
the cildren.
Assume this structure:
Resource
- Root (first EObject)
- A (child of Root, but own ecore model)
- B (child of Root, but own ecore model)
- B1 (child of B, inside "B" ecore model)
- B2 (child of B, inside "B" ecore model)
What I am doing is this:
- Creating the ResourceSet / Resource "Resource"
- Obtaining the root structural feature (RootSF)
- Obtaining the root ECLass (RootEC)
.....then:
- Root = RootFactory.create(RootEC)
- Root.eSet(RootSF, EcoreUtil.create((EClass)RootSF.getEType()));
- Resource.getContents().add(Root);
Up to here it's just "copied" from the default (generated) wizard. Now
comes my part accordingly:
- EReference B = RootPackage.eINSTANCE.getB();
- EObject B_O = EcoreUtil.create(B.getEReferenceType());
- Root.eSet(B, B_O);
- This works, I see the child "B" in the model instance if I stop here.
Now I want to add the B1/B2, too the same way:
- EReference B1 = BPackage.eINSTANCE.getB1();
- EObject B1_O = EcoreUtil.create(B1.getEReferenceType());
- B.eSet(B1, B1_O);
But this fails with the "IllegalCastException". :-( Any idea what I am
doing wrong?
Probably I should mention that B is of type "many". But it also fails if
it is not.
The point is: How would I "fill" a model recursively using the
reflective API? I searched so many examples - but all I try just stops
at a certain point, especially if the child is another ECore model (thus
another package, another factory etc...). It works smooth from the
generated editor (obviously) but when I try to emulate this not using
commands (I don't have an editing domain) I am stuck.
Re: Reflective API (eSet) in multiple (parent/child) models [message #425873 is a reply to message #425870] Wed, 10 December 2008 11:55 Go to previous message
Morten,
Comments below.
Morten MacFly wrote:
> Dear NG,
> the cildren.
> Resource
It generally makes little difference how classes are distributed across
packages.
> ....then:
RooPackage.Literals.A__B would be more efficient.
And given you know the feature statically, you also know the class
statically...
Is B1 a feature of B?
> - B.eSet(B1, B1_O);
> doing wrong?
This result seems to indicate that it is not.
> it is not.
If it's a many you'd need to do ((List<EObject>)B.eGet(B1)).add(B1_O).
> reflective API?
Pretty much like you're doing, but of course in general the reference's
type could be abstract so you can't directly create an instance of that.
The EcoreUtil utility makes sure you use the right factory (the class'
package's factory) so this package decomposition shouldn't matter.
Previous Topic:CDO 1.0 and 1 to many two way references
Next Topic:Editable emf objects properties
Current Time: Sun Jul 20 14:07:03 EDT 2025
Powered by FUDForum. Page generated in 0.05936 seconds
