Re: Springsource objectweb tree and attribute bundle versions [message #425809 is a reply to message #425797] |
Tue, 09 December 2008 03:39  |
JF,
Fortunately there's currently not so much traffic in the newsgroup,
otherwise I could have overlooked your question due to missing [CDO] prefix.
The question which ASM version is the best and which are possible looks
like a Hibernate question and should be answered by Martin (cc).
That said, it looks like they split ASM into several bundles. I changed
our setup script to use 2.2.0/2.2.3 versions and the installation now works.
In case you're using CDO with Hibernate, can you confirm that it works
at runtime, too?
Cheers
/Eike
JF schrieb:
> BTW, the ObjectWeb ASM Tree bundle has as its lowest rev 2.2.0
> depending on ObjectWeb ASM 2.0 as does ObjectWeb ASM Attributes 2.2.0.
> So perhaps I should also move up to ObjectWeb ASM 2.0 ?
FUDForum. Page generated in 0.03600 seconds
