Home » Language IDEs » Java Development Tools (JDT) » Error state remains after a problem is fixed
Error state remains after a problem is fixed [message #42413] Wed, 28 May 2003 15:49 Go to next message
Over the last week I have been having a problem with updates when a file is
changed. The change does not seem to be accurately reflected in dependant
files. For example if filea.java uses a class in fileb.java, but the method
is missing an error is correctly flagged. If I now add that method
filea.java still as an error marked against it. In the file itself the red
cross is now a black cross and the error is still marked as a red cross in
the package explorer. I can remove the error by cutting and pasting the
line on which the error was initially flagged. As anyone else witnessed
this on V2.1. Obviously something as changed, just don't know what, I've
tried clearing the bin directory, but no success.
Re: Error state remains after a problem is fixed [message #42449 is a reply to message #42413] Wed, 28 May 2003 16:43 Go to previous messageGo to next message
Originally posted by: richkulp.NOSPAM.us.ibm.com
Do you have Build on Resource modication turned on?
Rich
Re: Error state remains after a problem is fixed [message #42573 is a reply to message #42449] Wed, 28 May 2003 19:12 Go to previous message
Thanks, that fixed it.
John.
"Richard L. Kulp" <richkulp@NOSPAM.us.ibm.com> wrote in message
news:bb3731$ov9$2@rogue.oti.com...
> Rich
Previous Topic:Adding all jars in a folder to the build path
Next Topic:Avoiding Eclipse top-bit-set "mangling"
Current Time: Sat Nov 01 20:33:41 EDT 2025
Powered by FUDForum. Page generated in 0.04249 seconds
