Home » Modeling » EMF » Dynamic EMF examples
Dynamic EMF examples [message #425609] Wed, 03 December 2008 07:30 Go to next message
Ed,
Are there any examples on dynamic EMF in the repository? Apart from a
couple of articles, by you and your colleagues, back to a few years ago
I was not able to find any more resources on dynamic EMF. Perhaps an up
to date example can demonstrate new dynamic features.
-Ali
Re: Dynamic EMF examples [message #425613 is a reply to message #425609] Wed, 03 December 2008 07:42 Go to previous messageGo to next message
Ali,
Many of the JUnit tests use dynamic models, but there's really nothing
tricky beyond what's in those articles. Even in the Sample Ecore
Editor, you can right click on an EClass and invoke "Create Dynamic
Instance..." to see dynamic EMF in action, so that's definitely an
example...
Ali wrote:
> Ed,
> ago I was not able to find any more resources on dynamic EMF. Perhaps
> an up to date example can demonstrate new dynamic features.
> -Ali
Re: Dynamic EMF examples [message #425618 is a reply to message #425613] Wed, 03 December 2008 08:20 Go to previous messageGo to next message
Ed,
I am not sure if the xmi document generated by "create dynamic instance"
can help me.
My application involves wrapping an existing java library by EMF (the
old topic we have discussed over the past 2 years). Since EMF is not
reverse-engineering-aware, here is the approach I decided to work on:
(1) The classes in the existing library are extracted using java
reflection and given to the user in the GUI.
(2) Once the user chooses a class to create an object from, an EMF
meta-model is created dynamically, wrapping the existing code. Since the
code is well defined, eg it comes with Set/Get methods, the attributes
can be generated programmatically at run time.
(3) I assume that this result is equivalent of having the static model
and the corresponding generated code and the user should be able to
create instances of the model in an ecore editor.
Does this approach make sense? Are there any examples describing a
similar problem?
Ed Merks wrote:
> Ali,
> example...
> Ali wrote:
>> Ed,
>> -Ali
Re: Dynamic EMF examples [message #425620 is a reply to message #425618] Wed, 03 December 2008 08:38 Go to previous messageGo to next message
Ed,
Just to add, here is our last conversation on this:
http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg3 1748.html
It seems you suggested the use of DynamicEObjectImpl, does this method
still require the creation of a meta-model? Again, any examples around
demonstrating the use of DynamicEObjectImpl?
Ali wrote:
> Ed,
> can help me.
> similar problem?
> Ed Merks wrote:
>> Ali,
>> example...
>> Ali wrote:
>>> Ed,
>>> -Ali
Re: Dynamic EMF examples [message #425625 is a reply to message #425618] Wed, 03 December 2008 08:57 Go to previous messageGo to next message
Ali,
Comments below.
Ali wrote:
> Ed,
> instance" can help me.
You're just asking for examples, so that's an example. Given you've
seen several examples now, it's not clear what exactly more you'd need
to see. I think you should just start writing some code and seeing how
it works out.
> the code is well defined, eg it comes with Set/Get methods, the
> attributes can be generated programmatically at run time.
Well, it seems trickier to try to do it dynamically. At least with
generated code, you could write the methods to delegate data access onto
some other object. You'll certainly need some type of specialized
EDynamicEObjectImpl that delegates using reflection into some other Java
object. You won't find any examples of that...
> similar problem?
Given all the cool stuff CDO is doing, another approach I can imagine is
treating your legacy object's you're trying to wrap as kind of a
repository or backing store.
> Ed Merks wrote:
>> Ali,
>> nothing tricky beyond what's in those articles. Even in the Sample
>> Ecore Editor, you can right click on an EClass and invoke "Create
>> Dynamic Instance..." to see dynamic EMF in action, so that's
>> definitely an example...
>> Ali wrote:
>>> Ed,
>>> a couple of articles, by you and your colleagues, back to a few
>>> years ago I was not able to find any more resources on dynamic EMF.
>>> Perhaps an up to date example can demonstrate new dynamic features.
>>> -Ali
Re: Dynamic EMF examples [message #425630 is a reply to message #425625] Wed, 03 December 2008 09:28 Go to previous messageGo to next message
Ed,
Comments below.
Ed Merks wrote:
> Ali,
> Comments below.
> Ali wrote:
>> Ed,
> it works out.
> some other object.
What do you mean by 'writing methods'? The wrapping process is supposed
to be automated.
>> similar problem?
Does this mean that CDO can act as a wrapper in this way?
May I also ask, why is that EMF, with all its rich features, is not able
to perform simple name conventions for existing code as JavaBean does?
Simple get/set accessor methods in a java class are enough to make java
beans which are ready to be visually edited by a property view which, in
my view, is equivalent of EMF/GMF. Is performing this simple task really
this complicated in EMF or am I missing a point? This is the reason I am
asking for examples before investing time on coding based on the wrong
design.
>> Ed Merks wrote:
>>> Ali,
>>> Ali wrote:
>>>> Ed,
>>>> -Ali
Re: Dynamic EMF examples [message #425634 is a reply to message #425630] Wed, 03 December 2008 09:44 Go to previous messageGo to next message
Ali,
Comments below.
Ali wrote:
> Ed,
> Comments below.
> Ed Merks wrote:
>> Ali,
>> Comments below.
>> Ali wrote:
>>> Ed,
>> need to see. I think you should just start writing some code and
>> seeing how it works out.
>>> (the old topic we have discussed over the past 2 years). Since EMF
>>> is not reverse-engineering-aware, here is the approach I decided to
>>> work on:
>>> model and the corresponding generated code and the user should be
>>> able to create instances of the model in an ecore editor.
>> onto some other object.
> supposed to be automated.
That would be nice yes, but I could also imagine doing it as a
development time thing up front rather than a runtime time thing on the fly.
>> You'll certainly need some type of specialized EDynamicEObjectImpl
>> that delegates using reflection into some other Java object. You
>>> similar problem?
>> is treating your legacy object's you're trying to wrap as kind of a
Yes. CDO EObject act as a facade that communicate with a server to
access data. In general EStoreEObjectImpl can be used in that way to
delegate all data access onto an InternalEObject.EStore. I hesitate to
point this out because you're likely to ask for all kinds of examples
that don't exist.
> able to perform simple name conventions for existing code as JavaBean
> does?
We can produce a model from annotated Java, but Java doesn't generally
have enough information. Before Java 5.0, you couldn't even know what
type of object a list contained.
> java beans which are ready to be visually edited by a property view
> which, in my view, is equivalent of EMF/GMF.
Sure, simple features in an EClass serve the same purpose.
> Is performing this simple task really this complicated in EMF or am I
> missing a point?
How would you use Java Beans to wrap some existing hand-written
classes? That would be just as much work and there's no solution for
that either, right?
> This is the reason I am asking for examples before investing time on
> coding based on the wrong design.
It's not so clear what you're trying to get from EMF. If you already
have beans and are happy with them, then you don't really need EMF.
Sure you can wrap existing classes with EMF, but if anything interacts
directly with the existing classes, the wrappers won't know about that
and won't produce notification. No one has ever worked on producing
such wrappers and contributed that work to open source, so that's why
you don't see it here.
>>> Ed Merks wrote:
>>>> Ali,
>>>> Ali wrote:
>>>>> Ed,
>>>>> from a couple of articles, by you and your colleagues, back to a
>>>>> few years ago I was not able to find any more resources on dynamic
>>>>> EMF. Perhaps an up to date example can demonstrate new dynamic
>>>>> features.
>>>>> -Ali
Re: Dynamic EMF examples [message #425636 is a reply to message #425634] Wed, 03 December 2008 10:08 Go to previous messageGo to next message
Ed,
Comments below.
Ed Merks wrote:
> Ali,
> Comments below.
> Ali wrote:
>> Ed,
>> Comments below.
>> Ed Merks wrote:
>>> Ali,
>>> Comments below.
>>> Ali wrote:
>>>> Ed,
>>>> work on:
> fly.
>>>> similar problem?
> that don't exist.
Thanks for pointing this out, I'll have a look at this and surely will
get back to you to ask about examples :)
>> does?
>> missing a point?
> that either, right?
Wrong, all we have to do to create Beans is to follow the name
convention, the existing java code is actually generated by SWIG to wrap
c++ objects. So, it is simple to automatically generate the naming
convention and have the Beans *without* any code generation:
[c++] -> [SWIG] -> [JavaBeans] -> [visual editor]
I can also generate java annotations using SWIG to be used by EMF to
generate static models:
[c++] -> [SWIG] -> [annotated java] -> [ecore] -> [genmodel] ->
[generated static code] -> [visual editor]
I guess we both agree that automatic generation of annotated java is not
as simple as following accessor naming convention. I was hoping the
dynamic approach to be a work around for this longer process:
[c++] -> [SWIG] -> [dynamic EMF] -> [visual editor]
, but, as you wrote, it is trickier. So, back to square one.
Needless to say, I am trying to use EMF as a gate to automatically
import the objects to the eclipse platform. As far as I know there is no
support for Beans in eclipse and, conversely, there is no equivalent of
eclipse for Beans.
>>>> Ed Merks wrote:
>>>>> Ali,
>>>>> Ali wrote:
>>>>>> Ed,
>>>>>> features.
>>>>>> -Ali
Re: Dynamic EMF examples [message #425639 is a reply to message #425636] Wed, 03 December 2008 10:29 Go to previous messageGo to next message
Ali,
Comments below.
Ali wrote:
> Ed,
> Comments below.
> Ed Merks wrote:
>> Ali,
>> Comments below.
>> Ali wrote:
>>> Ed,
>>> Comments below.
>>> Ed Merks wrote:
>>>> Ali,
>>>> Comments below.
>>>> Ali wrote:
>>>>> Ed,
>>>> you've seen several examples now, it's not clear what exactly more
>>>> you'd need to see. I think you should just start writing some code
>>>> and seeing how it works out.
>>>>> to work on:
>>>>> Since the code is well defined, eg it comes with Set/Get methods,
>>>>> the attributes can be generated programmatically at run time.
>> the fly.
>>>>> similar problem?
>>>> imagine is treating your legacy object's you're trying to wrap as
>>>> kind of a repository or backing store.
>> to point this out because you're likely to ask for all kinds of
>> examples that don't exist.
>>> JavaBean does?
>> generally have enough information. Before Java 5.0, you couldn't
>> even know what type of object a list contained.
>>> I missing a point?
>> that either, right?
> wrap c++ objects. So, it is simple to automatically generate the
> naming convention and have the Beans *without* any code generation:
So SWIG could have generated EMF object instead of JavaBeans but doesn't.
> not as simple as following accessor naming convention.
It seems you could do SWIG -> Ecore?
> I was hoping the dynamic approach to be a work around for this longer
> process:
So that's SWIG to Ecore but I don't know what SWIG is. Given that Java
bean solution is static code generation, it makes me wonder again why
you are taking a dynamic approach...
> no support for Beans in eclipse and, conversely, there is no
> equivalent of eclipse for Beans.
The data binding framework supports beans. But beans don't do much all
on their own.
>> interacts directly with the existing classes, the wrappers won't know
>> about that and won't produce notification. No one has ever worked on
>> producing such wrappers and contributed that work to open source, so
>> that's why you don't see it here.
>>>>> Ed Merks wrote:
>>>>>> Ali,
>>>>>> Sample Ecore Editor, you can right click on an EClass and invoke
>>>>>> "Create Dynamic Instance..." to see dynamic EMF in action, so
>>>>>> that's definitely an example...
>>>>>> Ali wrote:
>>>>>>> Ed,
>>>>>>> dynamic EMF. Perhaps an up to date example can demonstrate new
>>>>>>> dynamic features.
>>>>>>> -Ali
Re: Dynamic EMF examples [message #425646 is a reply to message #425639] Wed, 03 December 2008 12:15 Go to previous messageGo to next message
Ed,
Comments below.
Ed Merks wrote:
> Ali,
> Comments below.
>>> that either, right?
SWIG is an automated c/c++ wrapper to many languages including java.
SWIG cannot generate EMF objects directly, unless someone develops an
extension of it to generate ecore xml files *directly*. However, like I
mentioned this a couple of times, JavaBean objects may be generated
*directly* from SWIG by simply following the name conventions. Eg, you
can write a simple SWIG script which maps any c++ public methods
starting with Get/Set to get/set and that should be enough to generate
the accessors for the beans. This is not so straightforward in EMF. One
could write a SWIG script to map any c++ public methods starting with
Get/Set to Get/Set in java with an annotation before the java method to
be used with EMF later. I have tried this approach once and encountered
some unforeseen problems such as EMF crashing when generating code for
10^3 classes.
>> process:
The above comment explains one of the reasons why I am trying to
consider the dynamic approach now, as the dynamic approach skips code
generation. In practice, the user would not generate thousands of
objects and only a small sub-sample from the pool of objects will be
used in an EMF document--from this point of view, it makes sense to
generate the model for that small sub-sample at run-time and leave the
rest of the pool. Section 13.6 of the EMF book explains how to create a
dynamic model at run-time as well as instantiating it programmatically.
However, it does not say how it is possible to have the editor to use
the dynamic model. Am I missing a point here?
As you have been developing EMF for years, it could be difficult for you
to feel the fuzziness of implementing the dynamic approach without much
documentation or examples for outsiders. I do appreciate the prompt help
in the newsgroup though.
> on their own.
Re: Dynamic EMF examples [message #425648 is a reply to message #425646] Wed, 03 December 2008 12:26 Go to previous messageGo to next message
--------------070703050702070902060509
Ali,
Comments below.
Ali wrote:
> Ed,
> Comments below.
> Ed Merks wrote:
>> Ali,
>> Comments below.
>>>> for that either, right?
>> doesn't.
> I mentioned this a couple of times, JavaBean objects may be generated
It should be just as straight forward, but just doesn't exist yet.
> One could write a SWIG script to map any c++ public methods starting
> with Get/Set to Get/Set in java with an annotation before the java
> method to be used with EMF later. I have tried this approach once and
> encountered some unforeseen problems such as EMF crashing when
> generating code for 10^3 classes.
Crashing?
>>> longer process:
>> Java bean solution is static code generation, it makes me wonder
>> again why you are taking a dynamic approach...
> a dynamic model at run-time as well as instantiating it
> programmatically. However, it does not say how it is possible to have
> the editor to use the dynamic model. Am I missing a point here?
The reflective editor uses a dynamic model.
> you to feel the fuzziness of implementing the dynamic approach without
> much documentation or examples for outsiders.
Yes, it's hard to keep track of what's obvious and what's totally not.
> I do appreciate the prompt help in the newsgroup though.
Probably it would be good to start to dive in and ask more specific
focused questions. For example, I'm sure you will need to create your
own derived EObject implementation and hence you'll end up wanting a
derived EFactoryImpl that overrides this method:
protected EObject basicCreate(EClass eClass)
return
eClass.getInstanceClassName() == "java.util.Map$Entry" ?
new DynamicEObjectImpl.BasicEMapEntry<String, String>(eClass) :
new DynamicEObjectImpl(eClass);
And you'll want to set this into your EPackage. I would focus first on
getting your scenario working in a simple non-GUI scenario and build up
from there...
>>>>> on coding based on the wrong design.
>>>> already have beans and are happy with them, then you don't really
>>>> need EMF.
>>> is no support for Beans in eclipse and, conversely, there is no
>> all on their own.
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Ali,<br>
<br>
Comments below.<br>
<br>
<br>
Ali wrote:
<blockquote cite="mid:gh6er1$4rl$1@build.eclipse.org" type="cite">Ed,
<br>
<br>
Comments below.
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Ali,
<br>
<br>
Comments below.
<br>
<br>
<blockquote type="cite">How would you use Java Beans to wrap some
existing hand-written classes?&nbsp; That would be just as much work and
there's no solution for that either, right?
<br>
</blockquote>
<br>
wrap c++ objects. So, it is simple to automatically generate the naming
<br>
<br>
[c++] -&gt; [SWIG] -&gt; [JavaBeans] -&gt; [visual editor]
<br>
</blockquote>
doesn't.
<br>
</blockquote>
<br>
the accessors for the beans. This is not so straightforward in EMF.</blockquote>
It should be just as straight forward, but just doesn't exist yet.<br>
<blockquote cite="mid:gh6er1$4rl$1@build.eclipse.org" type="cite"> One
10^3 classes.
<br>
</blockquote>
Crashing?<br>
<blockquote cite="mid:gh6er1$4rl$1@build.eclipse.org" type="cite"><br>
<blockquote type="cite"><br>
<br>
<br>
[c++] -&gt; [SWIG] -&gt; [annotated java] -&gt; [ecore] -&gt;
[genmodel] -&gt; [generated static code] -&gt; [visual editor]
<br>
<br>
not as simple as following accessor naming convention. </blockquote>
It seems you could do SWIG -&gt; Ecore?
<br>
<blockquote type="cite">I was hoping the dynamic approach to be a
<br>
<br>
[c++] -&gt; [SWIG] -&gt; [dynamic EMF] -&gt; [visual editor]
<br>
</blockquote>
So that's SWIG to Ecore but I don't know what SWIG is.&nbsp; Given that Java
<br>
</blockquote>
<br>
<br>
</blockquote>
The reflective editor uses a dynamic model.&nbsp;&nbsp; <br>
much documentation or examples for outsiders.</blockquote>
Yes, it's hard to keep track of what's obvious and what's totally not.<br>
<blockquote cite="mid:gh6er1$4rl$1@build.eclipse.org" type="cite"> I do
<br>
</blockquote>
focused questions.&nbsp; For example, I'm sure you will need to create your
derived EFactoryImpl that overrides this method:<small><br>
</small>
<blockquote><small>&nbsp; protected EObject basicCreate(EClass eClass) </small><br>
<small>&nbsp; {</small><br>
<small>&nbsp;&nbsp;&nbsp; return</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; eClass.getInstanceClassName() == "java.util.Map$Entry" ?</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; new DynamicEObjectImpl.BasicEMapEntry&lt;String,
String&gt;(eClass) :</small><br>
<small> &nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp;&nbsp; new DynamicEObjectImpl(eClass);</small><br>
<small>&nbsp; }</small><br>
</blockquote>
And you'll want to set this into your EPackage.&nbsp; I would focus first on
from there...<br>
<br>
<br>
<blockquote type="cite">This is the reason I am asking for
examples before investing time on coding based on the wrong design.
<br>
</blockquote>
It's not so clear what you're trying to get from EMF.&nbsp; If you already
<br>
</blockquote>
<br>
no support for Beans in eclipse and, conversely, there is no equivalent
<br>
</blockquote>
The data binding framework supports beans.&nbsp; But beans don't do much all
on their own.
<br>
</blockquote>
<br>
</blockquote>
</body>
</html>
--------------070703050702070902060509--
Re: Dynamic EMF examples [message #425655 is a reply to message #425648] Wed, 03 December 2008 16:02 Go to previous messageGo to next message
Ed,
Thanks for making some points clear. Following your advice, here is a
minimal simplified problem:
Let's consider a simple thin wrapper java class as the existing code:
public class WrapperClass {
public void SetSomething(int value) {
// Some call to JNI
public int GetSomething() {
// Some call to JNI
For now, we ignore how this class and its package can be automatically
looked up and provided to the user. Given the above class, all we want
is to:
(1) Automatically detect the attributes and their types by simply
matching SetX/GetX. Even this part is not EMF-related and may be ignored.
(2) Based on the class name and its attributes names and types, create a
dynamic model where the user can instantiate the class in a reflective
editor.
Your suggestion involves starting from sub-classing EObject. How can
this fit into the above? Does DynamicSet/DynamicGet have any use in this?
I hope the question is concrete and focused enough now. If this can be
answered, I will have a base to continue.
Ed Merks wrote:
> Ali,
> Comments below.
> Ali wrote:
>> Ed,
>> Comments below.
>> Ed Merks wrote:
>>> Ali,
>>> Comments below.
>>> doesn't.
> Crashing?
>>>> longer process:
> return
> from there...
>>>>> need EMF.
>>> all on their own.
Re: Dynamic EMF examples [message #425657 is a reply to message #425655] Wed, 03 December 2008 16:53 Go to previous messageGo to next message
Ali,
Comments below.
Ali wrote:
> Ed,
Sorry that I've been slightly less than my diplomatic best...
> Following your advice, here is a minimal simplified problem:
> // Some call to JNI
> // Some call to JNI
> is to:
Probably you mean setX and getX, right?
> a dynamic model where the user can instantiate the class in a
> reflective editor.
Yes, I could certainly imagine using Java reflection to gather such
information directly from the instance.
From what I understand, I think the following is a good start. I
imagine when you create objects you'll need to decide how to make them
wrap something and you'll need to make the reflectively method do the
JNI thing...
package org.example;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EAttribute;
import org.eclipse.emf.ecore.EClass;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.EPackage;
import org.eclipse.emf.ecore.EcoreFactory;
import org.eclipse.emf.ecore.EcorePackage;
import org.eclipse.emf.ecore.impl.DynamicEObjectImpl;
import org.eclipse.emf.ecore.impl.EFactoryImpl;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.util.Diagnostician;
import org.eclipse.emf.ecore.xmi.impl.XMLResourceFactoryImpl;
public class Dynamic
interface Wrapper extends EObject
void setWrappedObject(Object object);
static class MyDynamicEObjectImpl extends DynamicEObjectImpl
implements Wrapper
Object wrappedObject;
public MyDynamicEObjectImpl(EClass eClass)
super(eClass);
public void setWrappedObject(Object object)
wrappedObject = object;
public Object eGet(int featureID, boolean resolve, boolean coreType)
System.out.println("how to use JNI to get " +
eClass().getEStructuralFeature(featureID).getName());
return super.eGet(featureID, resolve, coreType);
public void eSet(int featureID, Object newValue)
System.out.println("how to use JNI to set " +
super.eSet(featureID, newValue);
public static void main(String[] args) throws Exception
EPackage ePackage = EcoreFactory.eINSTANCE.createEPackage();
ePackage.setName("dynamic");
ePackage.setNsPrefix("dynamic");
ePackage.setNsURI("http://www.example.org/dynamic");
EClass eClass = EcoreFactory.eINSTANCE.createEClass();
eClass.setName("WrapperClass");
EAttribute eAttribute = EcoreFactory.eINSTANCE.createEAttribute();
eAttribute.setName("something");
eAttribute.setEType(EcorePackage.Literals.EINT);
eClass.getEStructuralFeatures().add(eAttribute);
ePackage.getEClassifiers().add(eClass);
System.out.println(Diagnostician.INSTANCE.validate(ePackage) );
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(Resource.Factory.Registry.DEFAULT_EXTENSION,
new XMLResourceFactoryImpl());
Resource resource =
resourceSet.createResource(URI.createURI("file:/c:/dynamic.xml "));
EObject eObject = ePackage.getEFactoryInstance().create(eClass);
eObject.eSet(eAttribute, 10);
resource.getContents().add(eObject);
resource.save(System.out, null);
ePackage.setEFactoryInstance
(new EFactoryImpl()
return new MyDynamicEObjectImpl(eClass);
Resource resource =
Wrapper wrapper =
(Wrapper)ePackage.getEFactoryInstance().create(eClass);
wrapper.setWrappedObject(null);
wrapper.eSet(eAttribute, 10);
resource.getContents().add(wrapper);
It sounds like an interesting problem. Hopefully you'll share some of
your progress.
> Ed Merks wrote:
>> Ali,
>> Comments below.
>> Ali wrote:
>>> Ed,
>>> Comments below.
>>> Ed Merks wrote:
>>>> Ali,
>>>> Comments below.
>>>>> to wrap c++ objects. So, it is simple to automatically generate
>>>>> the naming convention and have the Beans *without* any code
>>>>> generation:
>>>> doesn't.
>>> an extension of it to generate ecore xml files *directly*. However,
>>> like I mentioned this a couple of times, JavaBean objects may be
>>> generated *directly* from SWIG by simply following the name
>>> conventions. Eg, you can write a simple SWIG script which maps any
>>> c++ public methods starting with Get/Set to get/set and that should
>>> be enough to generate the accessors for the beans. This is not so
>>> and encountered some unforeseen problems such as EMF crashing when
>> Crashing?
>>>>> to generate static models:
>>>>> is not as simple as following accessor naming convention.
>>>>> longer process:
>>> code generation. In practice, the user would not generate thousands
>>> of objects and only a small sub-sample from the pool of objects will
>>> be used in an EMF document--from this point of view, it makes sense
>>> to generate the model for that small sub-sample at run-time and
>>> leave the rest of the pool. Section 13.6 of the EMF book explains
>>> how to create a dynamic model at run-time as well as instantiating
>>> it programmatically. However, it does not say how it is possible to
>>> have the editor to use the dynamic model. Am I missing a point here?
>>> without much documentation or examples for outsiders.
>> your own derived EObject implementation and hence you'll end up
>> wanting a derived EFactoryImpl that overrides this method:
>> return
>> String>(eClass) :
>> on getting your scenario working in a simple non-GUI scenario and
>> build up from there...
>>>>>> need EMF.
>>>> all on their own.
Re: Dynamic EMF examples [message #425689 is a reply to message #425657] Thu, 04 December 2008 13:21 Go to previous messageGo to next message
--------------000606050300040802090407
Ed,
Thanks a lot, that was the 'example' I was looking for. I have started
mapping the JNI wrapping structure to the EMF one, please see attached.
To answer your question about set/get, I did meant Set/Get. To avoid
confusion, I changed it to MySet/MyGet. While we have the control over
the accessor name pattern, it would be good to generalise it in the case
of wrapping a third party code.
With the current design, we are actually double-wrapping:
[EMF] --(wraps)--> [existing JNI wrapper] --(wraps)--> [c++ code]
In long term, it would be a good idea to have a SWIG extension which
generates direct EMF wrapper--I am sure there will be a lot of interest
in this.
Some questions:
(1) The performance sacrifice of the dynamic approach is well known. Let
us consider creating a dynamic model and using EMFWrapperClass to create
20 - 40 objects on the fly.
(1.1) Would the dynamic performance loss be substantial in the case of
this thin wrapper?
(1.2) Let us compare this case to the case of having about 1,000
classes where the EMF wrapper code has been statistically generated for
them. Even with the lazy-loading strategy in the static case, would we
not actually *gain* some performance by the dynamic approach as we wrap
those few classes that we require? This is literally a genuine`
'lazy'-loading scheme.
(2) What would be the right way of setting the default values of the
attributes in EMFWrapperClass automatically? It is desirable to have the
EMF attributes initialised by the default values in the c++ object.
(3) Having the ResourceSet instance, how is it possible to present it in
the EMF editor just like the static case?
Ed Merks wrote:
> Ali,
> Comments below.
> Ali wrote:
>> Ed,
>> // Some call to JNI
>> // Some call to JNI
>> is to:
>> reflective editor.
> JNI thing...
> static class MyDynamicEObjectImpl extends DynamicEObjectImpl implements
> Wrapper
> super(eClass);
> @Override
> @Override
> Resource resource =
> (new EFactoryImpl()
> @Override
> Resource resource =
> Wrapper wrapper =
> your progress.
>> Ed Merks wrote:
>>> Ali,
>>> Comments below.
>>> Ali wrote:
>>>> Ed,
>>>> Comments below.
>>>> Ed Merks wrote:
>>>>> Ali,
>>>>> Comments below.
>>>>>> generation:
>>>>> doesn't.
>>> Crashing?
>>>>>> longer process:
>>> return
>>> String>(eClass) :
>>>>>>> need EMF.
>>>>> all on their own.
name="EMFWrapperClass.java"
Content-Disposition: inline;
filename="EMFWrapperClass.java"
import java.lang.reflect.*;
public class EMFWrapperClass {
interface WrapperEObject extends EObject {
void setAccessorSetString(String str);
void setAccessorGetString(String str);
WrapperEObject {
String accessorSetString = "set";
String accessorGetString = "get";
public MyDynamicEObjectImpl(EClass eClass) {
super(eClass);
public void setWrappedObject(Object object) {
public void setAccessorSetString(String str) {
accessorSetString = str;
public void setAccessorGetString(String str) {
accessorGetString = str;
public Object eGet(int featureID, boolean resolve, boolean coreType) {
String getString = accessorGetString
+ eClass().getEStructuralFeature(featureID).getName();
System.out.println("[EMFWrapperClass] eGet, " + getString);
public void eSet(int featureID, Object newValue) {
String setMethodName = accessorSetString
Class attribType = eClass().getEStructuralFeature(featureID).getEType().getInst anceClass();
System.out.println("[EMFWrapperClass] eGet, " + setMethodName + "("
+ attribType.getName() + ")");
// call the jni wrapper method
try {
Method mth = wrappedObject.getClass().getMethod(setMethodName, attribType);
mth.invoke(wrappedObject, newValue);
} catch (Exception e) {
e.printStackTrace();
public static void main(String[] args) throws Exception {
ePackage.setName("EMFWrapper");
ePackage.setNsPrefix("EMFWrapper");
ePackage.setNsURI("http://www.example.org/EMFWrapper");
eAttribute.setName("Something");
System.out.println("-------");
Resource resource = resourceSet.createResource(URI
.createURI("file:/c:/dynamic.xml"));
ePackage.setEFactoryInstance(new EFactoryImpl() {
protected EObject basicCreate(EClass eClass) {
WrapperEObject wrapper = (WrapperEObject) ePackage
JNIWrapperClass jniWrapper = new JNIWrapperClass();
wrapper.setWrappedObject(jniWrapper);
wrapper.setAccessorSetString("MySet");
wrapper.setAccessorGetString("MyGet");
name="JNIWrapperClass.java"
filename="JNIWrapperClass.java"
// JNIWrapperClass is assumed to be the existing code to
// be double-wrapped
public class JNIWrapperClass {
int something = 7;
public void MySetSomething(int value) {
System.out.println("[JNIWrapperClass] MySetSomething, Something = " + something + " -> " + value);
something = value;
public int MyGetSomething() {
System.out.println("[JNIWrapperClass] MyGetSomething, Something = " + something);
return something;
--------------000606050300040802090407--
Re: Dynamic EMF examples [message #425690 is a reply to message #425689] Thu, 04 December 2008 13:46 Go to previous message
Ali,
Comments below.
Ali wrote:
> Ed,
> in this.
> Some questions:
> Let us consider creating a dynamic model and using EMFWrapperClass to
> create 20 - 40 objects on the fly.
> case of this thin wrapper?
When it comes to performance all I can suggest is measure, measure, and
measure it again. You might find that performance is irrelevant in your
context.
> for them. Even with the lazy-loading strategy in the static case,
> would we not actually *gain* some performance by the dynamic approach
> as we wrap those few classes that we require? This is literally a
> genuine` 'lazy'-loading scheme.
Given that the meta data process is a one-time cost verses processing
each instance which is done n times for n instances, I doubt that the
one time meta data costs will be significant compared to the scaling the
number of instances either way. Far more likely to be a performance
problem is the method lookup each time a feature is looked up for each
instance, i.e., all this is likely to add up and dominate your time (and
of course it's information that can be cached once per EStructuralFeature):
Class attribType =
setMethodName + "("
try {
Method mth =
The EAttribute itself can have a default, but doesn't the getter always
return the value in the wrapped object hence making default irrelevant?
> It is desirable to have the EMF attributes initialised by the default
It's likely good for the EAttribute's default to match the default of
the object, but I'm not sure you would have such meta data.
> in the EMF editor just like the static case?
Have you looked at a generated editor? They all look pretty much the
same...
> Ed Merks wrote:
>> Ali,
>> Comments below.
>> Ali wrote:
>>> Ed,
>>> // Some call to JNI
>>> // Some call to JNI
>>> automatically looked up and provided to the user. Given the above
>>> class, all we want is to:
>>> ignored.
>>> create a dynamic model where the user can instantiate the class in a
>>> reflective editor.
>>> this?
>> them wrap something and you'll need to make the reflectively method
>> do the JNI thing...
>> implements Wrapper
>> super(eClass);
>> @Override
>> @Override
>> Resource resource =
>> EObject eObject =
>> (new EFactoryImpl()
>> @Override
>> Resource resource =
>> Wrapper wrapper =
>>> be answered, I will have a base to continue.
>> your progress.
>>> Ed Merks wrote:
>>>> Ali,
>>>> Comments below.
>>>> Ali wrote:
>>>>> Ed,
>>>>> Comments below.
>>>>> Ed Merks wrote:
>>>>>> Ali,
>>>>>> Comments below.
>>>>>>> generation:
>>>>>> doesn't.
>>>>> java. SWIG cannot generate EMF objects directly, unless someone
>>>>> develops an extension of it to generate ecore xml files
>>>>> *directly*. However, like I mentioned this a couple of times,
>>>>> JavaBean objects may be generated *directly* from SWIG by simply
>>>>> following the name conventions. Eg, you can write a simple SWIG
>>>>> script which maps any c++ public methods starting with Get/Set to
>>>>> get/set and that should be enough to generate the accessors for
>>>>> starting with Get/Set to Get/Set in java with an annotation before
>>>>> the java method to be used with EMF later. I have tried this
>>>>> approach once and encountered some unforeseen problems such as EMF
>>>>> crashing when generating code for 10^3 classes.
>>>> Crashing?
>>>>>>> EMF to generate static models:
>>>>>>> java is not as simple as following accessor naming convention.
>>>>>>> longer process:
>>>>>> that Java bean solution is static code generation, it makes me
>>>>>> wonder again why you are taking a dynamic approach...
>>>>> thousands of objects and only a small sub-sample from the pool of
>>>>> objects will be used in an EMF document--from this point of view,
>>>>> it makes sense to generate the model for that small sub-sample at
>>>>> run-time and leave the rest of the pool. Section 13.6 of the EMF
>>>>> book explains how to create a dynamic model at run-time as well as
>>>>> instantiating it programmatically. However, it does not say how it
>>>>> is possible to have the editor to use the dynamic model. Am I
>>>>> for you to feel the fuzziness of implementing the dynamic approach
>>>> return
>>>> String>(eClass) :
>>>> first on getting your scenario working in a simple non-GUI scenario
>>>> and build up from there...
>>>>>>>> really need EMF.
>>>>>>> automatically import the objects to the eclipse platform. As far
>>>>>>> as I know there is no support for Beans in eclipse and,
>>>>>>> conversely, there is no equivalent of eclipse for Beans.
>>>>>> much all on their own.
Previous Topic:[CDO] Problem with EMF content adapter
Next Topic:Problem with URIs in XMIResource
Current Time: Sun Jul 27 16:23:39 EDT 2025
Powered by FUDForum. Page generated in 0.06579 seconds
