Home » Modeling » EMF » createXXX parameters in Factories
createXXX parameters in Factories [message #425568] Mon, 01 December 2008 12:03 Go to next message
Is it possible to generate factories with parameters in the createXXX
methods? The idea would be to pre-set the necessary parameters when the
object is instantiated, and this should normally happen in the factory.
To be more precise the pattern now looks like this:
MyObject obj = MyModelFactory.createMyObject();
obj.setParameter1(param1);
obj.setParameter2(param2);
The issue is that param1 and param2 might be mandatory for the contruction
of the object, so this pattern is not enforcing it (somebody might forget to
set one of them).
A better way would be:
MyObject obj = MyModelFactory.createMyObject(param1, param2);
with its implementation as
MyObjectImpl obj = new MyObjectImpl();
Can this be automated through the code generation?
In this second pattern, we also want to prevent the setParameter() methods
to surface on the API , but they must still be available on the
implementation. Is there any way to do this? the changeable attribute seems
to remove the generated setXXX at the implementation level too.
David
Re: createXXX parameters in Factories [message #425569 is a reply to message #425568] Mon, 01 December 2008 12:27 Go to previous message
David,
Comments below.
David Michonneau wrote:
> methods?
No.
It would be sort of just a convenience...
> set one of them).
Keep in mind that when you deserialize or create a copy, you might not
be in a position to provide all the arguments up front.
No.
You can already do the suppression of the accessors in the API with an
EAnnotation (as produced by EcoreUtil.setSuppresssedVisibility), and you
can add methods to the factory by hand.
Yes.
> David
Previous Topic:Two way references and Dyanmic Feature Delegation
Next Topic:[CDO] NPE when removing an object in containment tree
Current Time: Fri Jul 25 20:37:22 EDT 2025
Powered by FUDForum. Page generated in 0.03707 seconds
