Home » Modeling » EMF » Underscore rules in generated values
Underscore rules in generated values [message #425502] Fri, 28 November 2008 05:31 Go to next message
Originally posted by: neko.ticino.com
I've some problems understanding how emg generates names for
Diagnostic's values. How are the rules for placing 'underscores'?
I've found these rules:
- place underscore between lowercase and uppercase chars
- place underscore before the last uppercase char in a row of at least 3
uppercase chars, if it is not the last one in the string.
But how it works if in the name there is already an underscore? And if
there are numbers? These are neither lowercase or uppercase...
Here's an example this is what emf generates:
* The {@link org.eclipse.emf.common.util.Diagnostic#getCode() code} for
* constraint 'Validate Compatible Gates Containing Correct Values' of 'Gate
* Definition'. <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
public static final int
GATE_DEFINITION__VALIDATE_COMPATIBLE_GATES_CONTAINING_CORREC T_VALUES =
71;
To generate the name
GATE_DEFINITION__VALIDATE_COMPATIBLE_GATES_CONTAINING_CORREC T_VALUES emf
uses entities names (in this case Gate, Definition and
CompatibleGatesContainingCorrectValues). And this is ok, I can replicate
what emf does...
But...:
- if the name of the entity is 'Gate_' the result is still
GATE_DEFINITION (it seems the underscore is removed)
- If the name is Gate_7 the result is 'GATE_7DEFINITION'...
- If the name is already uppercase like 'GATE' the result is still
GATE_DEFINITION, but according to the second rule it should be
GAT_EDEFINITION...
Thanks for helping!
Alex
Re: Underscore rules in generated values [message #425506 is a reply to message #425502] Fri, 28 November 2008 07:15 Go to previous messageGo to next message
Alex,
Comments below.
Alex Nekoti wrote:
> Hello,
When generating constant names, we generally use an _ to separate words
(which are determined by where lower case letters become upper case
again, i.e, where the transitions in the camel case occur).
Yes, since it's quite common for acronyms to be used, i.e., XSDComponent
would become XSD_COMPONENT.
Generally one should not be using _ in feature or type names when
following Java's language naming conventions...
> And if
An _ will represent a word break. A number will not result in a word break.
> * @generated
> 71;
> what emf does...
> But...:
Yes.
Gross name. The _ causes a word break and the 7 being neutral just
associates with the next word.
> GAT_EDEFINITION...
The gory details of word breaking are in
org.eclipse.emf.codegen.util.CodeGenUtil.format.
> Thanks for helping!
> Alex
Re: Underscore rules in generated values [message #425507 is a reply to message #425506] Fri, 28 November 2008 08:33 Go to previous messageGo to next message
Thank you Ed for the answers, but I still have some troubles
Ed Merks wrote:
> Alex,
> Comments below.
> Alex Nekoti wrote:
>> Hello,
That's ok.
This is ok too.
I know. But I still have to consider cases where someone uses names not
according to java conventions.
>> And if
>> * @generated
>> 71;
>> what emf does...
>> But...:
> Yes.
But it is removed only if it is at the end of a word? Underscores in the
middle of a word are considered word breaks, that's right?
So, 'Gate_' is like 'Gate', but 'Gate_A' is not like 'GateA' ?
Ok, let's try something more difficult (sorry Ed!):
Gate_1A3Definition generates as Gate_1A3_Definition. Why A3 is not
separated but 3D it is?
What does mean that 7 is neutral? The rule says 'place underscore
before the last uppercase char in a row of at least 3', but a digit does
affect the row count o not?
GATEDefinition is a row of 5 uppercase letters so it becomes
GATE_Definition, but GA6EDefinition?
>> GAT_EDEFINITION...
>> Thanks for helping!
>> Alex
Thank you again!
Alex
Re: Underscore rules in generated values [message #425509 is a reply to message #425507] Fri, 28 November 2008 09:11 Go to previous messageGo to next message
--------------010704050705020500000209
Alex,
Comments below.
> Ed Merks wrote:
>> Alex,
>> Comments below.
>> Alex Nekoti wrote:
>>> Hello,
> That's ok.
> This is ok too.
If you use unconventional names it's reasonable that the results aren't
so conventional either. Where are such names coming from anyway that
they're beyond anyone's control?
>>> And if
>>> * @generated
>>> 71;
>>> what emf does...
>>> But...:
>> Yes.
Well I think Gate_A is like GateA because both will become "Gate", "A"
in the parsed word list.
Because it's assumed that words might contain or end with numbers, but
that they don't start with them.
It's treated more like a lower case letter.
I could answer many questions but in the end, what I say must match
exactly the logic in the code.
Unfortunately I don't think any syntactic rule will every get is all
exactly right, e.g., XSDXPath is really intended to be XSD XPath. Or
EJBRDBMapping is maybe supposed to be ERJ_RDB_Mapping...
>>> GAT_EDEFINITION...
>>> Thanks for helping!
>>> Alex
> Thank you again!
If you don't like the name that's generated, you can always add by hand
a nicer variant; of course the generated code will always use the
generated form...
> Alex
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Alex,<br>
<br>
Comments below.<br>
<br>
Alex Nekoti wrote:
<blockquote cite="mid:ggorv3$5t0$1@build.eclipse.org" type="cite">
<pre wrap="">Thank you Ed for the answers, but I still have some troubles
Ed Merks wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Alex,
Comments below.
Alex Nekoti wrote:
</pre>
<pre wrap="">Hello,
</pre>
</blockquote>
<pre wrap="">When generating constant names, we generally use an _ to separate words
</pre>
</blockquote>
<pre wrap=""><!---->That's ok.
</pre>
<pre wrap="">I've found these rules:
</pre>
</blockquote>
<pre wrap="">Yes, since it's quite common for acronyms to be used, i.e., XSDComponent
</pre>
</blockquote>
<pre wrap=""><!---->This is ok too.
</pre>
<pre wrap="">But how it works if in the name there is already an underscore?
</pre>
</blockquote>
<pre wrap="">Generally one should not be using _ in feature or type names when
</pre>
</blockquote>
<pre wrap=""><!---->I know. But I still have to consider cases where someone uses names not
</pre>
</blockquote>
so conventional either.&nbsp;&nbsp; Where are such names coming from anyway that
they're beyond anyone's control?<br>
<pre wrap="">
</pre>
<pre wrap=""> And if
</pre>
</blockquote>
<pre wrap="">An _ will represent a word break. A number will not result in a word break.
</pre>
<pre wrap="">Here's an example this is what emf generates:
* Definition'. &lt;!-- begin-user-doc --&gt; &lt;!-- end-user-doc --&gt;
* @generated
71;
what emf does...
But...:
</pre>
</blockquote>
<pre wrap="">Yes.
</pre>
</blockquote>
<pre wrap=""><!---->But it is removed only if it is at the end of a word? Underscores in the
</pre>
</blockquote>
in the parsed word list.<br>
<pre wrap="">
</pre>
<pre wrap="">- If the name is Gate_7 the result is 'GATE_7DEFINITION'...
</pre>
</blockquote>
<pre wrap="">Gross name. The _ causes a word break and the 7 being neutral just
</pre>
</blockquote>
<pre wrap=""><!---->Ok, let's try something more difficult (sorry Ed!):
</pre>
</blockquote>
that they don't start with them.<br>
<pre wrap="">
What does mean that 7 is neutral? </pre>
</blockquote>
It's treated more like a lower case letter.<br>
<pre wrap="">The rule says 'place underscore
</pre>
</blockquote>
exactly the logic in the code.<br>
<pre wrap="">GATEDefinition is a row of 5 uppercase letters so it becomes
</pre>
</blockquote>
exactly right, e.g., XSDXPath is really intended to be XSD XPath.&nbsp; Or
EJBRDBMapping is maybe supposed to be ERJ_RDB_Mapping...<br>
<pre wrap="">
</pre>
<pre wrap="">- If the name is already uppercase like 'GATE' the result is still
GAT_EDEFINITION...
</pre>
</blockquote>
<pre wrap="">The gory details of word breaking are in
</pre>
<pre wrap="">Thanks for helping!
Alex
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->Thank you again!
</pre>
</blockquote>
generated form...<br>
<pre wrap="">Alex
</pre>
</blockquote>
</body>
</html>
--------------010704050705020500000209--
Re: Underscore rules in generated values [message #425512 is a reply to message #425509] Fri, 28 November 2008 09:36 Go to previous messageGo to next message
Ed Merks wrote:
> Alex,
> Comments below.
>> Ed Merks wrote:
>>> Alex,
>>> Comments below.
>>> Alex Nekoti wrote:
>>>> Hello,
>> That's ok.
>> This is ok too.
From users! Sure, it's possible to suggest to use conventional names,
but if emf allows to have not standard conventions I should be able to
match the emf generation.
>>>> And if
>>>> * @generated
>>>> 71;
>>>> what emf does...
>>>> But...:
>>> Yes.
>>>> GAT_EDEFINITION...
>>>> Thanks for helping!
>>>> Alex
>> Thank you again!
> generated form...
That's not the case, generated names are perfectly suitables. The fact
is that I can't replicate them! The goal is to match generated names
with my own generator.
Thank you Ed!
Alex
Re: Underscore rules in generated values [message #425513 is a reply to message #425512] Fri, 28 November 2008 09:42 Go to previous message
--------------070906010209020301050103
Alex,
Comments below.
Alex Nekoti wrote:
> Ed Merks wrote:
>> Alex,
>> Comments below.
>>> Ed Merks wrote:
>>>> Alex,
>>>> Comments below.
>>>> Alex Nekoti wrote:
>>>>> Hello,
>>> That's ok.
>>> This is ok too.
Assuming that one algorithm can handle all possible inputs in a way that
humans consider ideal. But I don't think that's 100% possible.
>>>>> And if
>>>>> * @generated
>>>>> 71;
>>>>> what emf does...
>>>>> But...:
>>>> Yes.
>>>>> GAT_EDEFINITION...
>>>>> Thanks for helping!
>>>>> Alex
>>> Thank you again!
>> generated form...
Ah, I see. :-) Reusing the GenModel's methods that return the names
it's using would be best. Reusing CodeGenUtil would be best second
best. And reimplementing the same algorithms by copy and paste would be
a last resort.
> Thank you Ed!
> Alex
<html>
<head>
</head>
Alex,<br>
<br>
Comments below.<br>
<br>
<br>
Alex Nekoti wrote:
<blockquote cite="mid:ggovlh$ng7$1@build.eclipse.org" type="cite">
<pre wrap="">Ed Merks wrote:
</pre>
<pre wrap="">Alex,
Comments below.
Alex Nekoti wrote:
</pre>
Ed Merks wrote:
</pre>
<pre wrap="">Alex,
Comments below.
Alex Nekoti wrote:
</pre>
<pre wrap="">Hello,
</pre>
</blockquote>
</pre>
</blockquote>
<pre wrap="">That's ok.
</pre>
</pre>
</blockquote>
</pre>
</blockquote>
<pre wrap="">This is ok too.
</pre>
</pre>
</blockquote>
</pre>
</blockquote>
<pre wrap="">I know. But I still have to consider cases where someone uses names not
</pre>
</blockquote>
<pre wrap="">If you use unconventional names it's reasonable that the results aren't
</pre>
</blockquote>
<pre wrap=""><!---->From users! Sure, it's possible to suggest to use conventional names,
</pre>
</blockquote>
that humans consider ideal.&nbsp; But I don't think that's 100% possible.<br>
<pre wrap="">
</pre>
<pre wrap="">
</pre>
</pre>
</blockquote>
</pre>
* @generated
71;
what emf does...
But...:
</pre>
</blockquote>
<pre wrap="">Yes.
</pre>
</blockquote>
<pre wrap="">But it is removed only if it is at the end of a word? Underscores in the
</pre>
</blockquote>
<pre wrap="">Well I think Gate_A is like GateA because both will become "Gate", "A"
</pre>
<pre wrap="">
</pre>
</pre>
</blockquote>
</pre>
</blockquote>
<pre wrap="">Ok, let's try something more difficult (sorry Ed!):
</pre>
</blockquote>
<pre wrap="">Because it's assumed that words might contain or end with numbers, but
</pre>
<pre wrap="">What does mean that 7 is neutral?
</pre>
</blockquote>
<pre wrap="">It's treated more like a lower case letter.
</pre>
</pre>
</blockquote>
<pre wrap="">I could answer many questions but in the end, what I say must match
</pre>
</pre>
</blockquote>
<pre wrap="">Unfortunately I don't think any syntactic rule will every get is all
</pre>
<pre wrap="">
</pre>
GAT_EDEFINITION...
</pre>
</blockquote>
</pre>
Alex
</pre>
</blockquote>
</blockquote>
<pre wrap="">Thank you again!
</pre>
</blockquote>
<pre wrap="">If you don't like the name that's generated, you can always add by hand
generated form...
</pre>
</blockquote>
<pre wrap=""><!---->That's not the case, generated names are perfectly suitables. The fact
</pre>
</blockquote>
Ah, I see. :-)&nbsp; Reusing the GenModel's methods that return the names
it's using would be best.&nbsp; Reusing CodeGenUtil would be best second
best.&nbsp; And reimplementing the same algorithms by copy and paste would
be a last resort.<br>
<pre wrap="">
Thank you Ed!
Alex
</pre>
</blockquote>
</body>
</html>
--------------070906010209020301050103--
Previous Topic:emf 2.3.1 plugins
Next Topic:CDO Server crashes at startup with MySQL adapter
Current Time: Sun Jul 27 09:34:39 EDT 2025
Powered by FUDForum. Page generated in 0.17152 seconds
