Home » Modeling » EMF » CDO view does not start correct model editor
CDO view does not start correct model editor [message #425489] Thu, 27 November 2008 08:46 Go to next message
I am having trouble using the CDO viewer in Eclipse to start the correct
model editor. I register the workspace .ecore file before opening a
transaction and then load/create a resource. In some scenarios it
doesn't seem to find an editor and shows the root package with an
incorrect icon. In other scenarios it seems to be the wrong version of
the model editor.
How does the CDO view in Eclipse know which model editor (EMF.Editor) to
use?
Anders
Re: CDO view does not start correct model editor [message #425490 is a reply to message #425489] Thu, 27 November 2008 10:05 Go to previous messageGo to next message
Hi Andres,
currently CDO View opens a generic editor for all your models.
This editor uses the ItemProvider defined in the .edit project of your
model. If you have customized your .edit, the generic editor should show
the custom icons/labels. Is your model .edit loaded in the Eclipse
instance you are using, or you only have it as a project in your
workspace? In that case you should launch a second instance of the
workbench, so it loads your model and .edit plugins.
Have you generated you models code as CDO Native? The current 2.0 branch
does not have support for it :( But it will arrive, sooner or later! :P
If it's native, you can use "automatic package registry", so you won't
need to register the .ecore model. Otherwise, dynamic registration (the
way you are currently doing) should do the trick as well.
Anders Forsell escribió:
> the model editor.
> use?
> Anders
Re: CDO view does not start correct model editor [message #425491 is a reply to message #425490] Thu, 27 November 2008 16:36 Go to previous message
Thanks for the clarification of the use of the generic editor for the CDO
View.
It seems my problem was due to an old version of the .ecore file being
registered in the DB.
After cleaning the DB, it actually works both when using the CDO viewer in
the same workspace as the model/edit code, and when running a runtime
workbench.
Anders
"Víctor Roldán Betancort" <vroldan@opencanarias.com> skrev i meddelandet
news:ggmcvk$k38$1@build.eclipse.org...
> Hi Andres,
>> Hi,
>> transaction and then load/create a resource. In some scenarios it doesn't
>> seem to find an editor and shows the root package with an incorrect icon.
>> In other scenarios it seems to be the wrong version of the model editor.
>> use?
>> Anders
Previous Topic:Re: Deleting child reference deletes referent?
Next Topic:How to change the name of the CreateChildAction once created
Current Time: Sun Jul 27 02:29:29 EDT 2025
Powered by FUDForum. Page generated in 0.03070 seconds
