Home » Modeling » EMF » [CDO] "Auto commit"
[CDO] "Auto commit" [message #425435] |
Wed, 26 November 2008 05:01  |
I'm working on an application that manages very large model. For this,
I use CDO 1.0.x.
I have one transaction (only one client), and I have to commit often
this transaction, if I don't want to use too memory (to prevent
OutOfMemoryException). I would like this commit is automatic. I don't
want to have to add everywhere in my code : myTransaction.commit.
I try to add a listener (a CDOTransactionHandler) to my transaction.
I'm able to known if an object is added or modified in the transaction.
Every X add or modification I try to commit the transaction. But if I
commit in the addedObject method, I have the following exception :
java.lang.IllegalStateException: Failing event COMMIT in state PREPARED
for MyObject@oid679
(data= org.eclipse.emf.internal.cdo.protocol.CommitTransactionResul t @614695)
at
org.eclipse.net4j.util.fsm.FiniteStateMachine.process(Finite StateMachine.java:152)
at
org.eclipse.emf.internal.cdo.CDOStateMachine.commit(CDOState Machine.java:275)
at
org.eclipse.emf.internal.cdo.CDOTransactionImpl.postCommit(C DOTransactionImpl.java:492)
at
org.eclipse.emf.internal.cdo.CDOTransactionImpl.commit(CDOTr ansactionImpl.java:250)
I understand why I have this exception : the object will be added in the
transaction, the state of the transaction changes, and I try to commit !
I would like to know, if it's possible to add a listener after (and not
before) the object is added in a transaction. Is there another solution ?
David
Re: [CDO] "Auto commit" [message #425439 is a reply to message #425435] |
Wed, 26 November 2008 05:34   |
David,
This is an interesting idea, please file an enhancement request!
Cheers
/Eike
David Bonneau schrieb:
> Hi
> this, I use CDO 1.0.x.
> transaction. Every X add or modification I try to commit the
> transaction. But if I commit in the addedObject method, I have the
> PREPARED for MyObject@oid679
> at
> at
> at
> at
> the transaction, the state of the transaction changes, and I try to
> commit !
> not before) the object is added in a transaction. Is there another
> solution ?
> David
Re: [CDO] "Auto commit" [message #425440 is a reply to message #425435] |
Wed, 26 November 2008 05:39   |
David,
I imagine you could add an adapter to your objects to track changes and
perform a commit, or you could add also an adapter to the resource that
contains your objects and listen to Resource.RESOURCE__IS_MODIFIED
events. Unfortunately, we still need to complete bug #252242 (to have an
adapter capable of tracking changes of loaded objects the same way
ResourceImpl$ModificationTrackingAdapter does).
HTH,
Víctor.
David Bonneau escribió:
> Hi
> I use CDO 1.0.x.
> for MyObject@oid679
> at
> at
> at
> at
> David
Re: [CDO] "Auto commit" [message #425529 is a reply to message #425435] |
Sun, 30 November 2008 19:14   |
Hey David,
It looks as though by attempting to commit directly from the
addingObject() method you're catching the CDOStateMachine in the
intermediate PREPARED state that exists between TRANSIENT and NEW; the
only valid states for an object to be committed are NEW and DIRTY. This is
probably happening because the CDOTransactionHandler gets to hear about
added objects before ordinary adapters, one of which I believe is
responsible for making the (almost immediate) transition from PREPARED to
NEW.
I have a similar need for auto-commit in my own project, except that we
are using EMF Transactions, and we commit upon hearing of any (EMF)
transaction finishing. I can tell you from experience that one thing you
will definitely want to implement is some form of coalescing events, so
that 20 changes to various EObjects does not result in 20 separate commits
for each of the deltas. That would be Very Bad :) I would recommend
something like the following:
synchronized void scheduleCommit() {
if (!alreadyCommitting) {
alreadyCommitting = true;
new Thread("commit thread") {
public void run() {
try {
Thread.sleep(500);
transaction.commit();
} catch (InterruptedException) {
} finally {
alreadyCommitting = false;
}.start();
Doing something like this would also more or less take care of the
exception you're seeing, because the actual commit would take place at a
later date, when the state machine had had plenty of time to transition
from PREPARED to NEW. I'm not sure if there's a chance that the resulting
commit would take place in that very brief PREPARED state, but it seems
very unlikely at the least, and perhaps Eike has put in place some
synchronization to prevent that.
Hope that helps,
Tom
David Bonneau wrote:
> Hi
> I use CDO 1.0.x.
> for MyObject@oid679
> at
> at
> at
> at
> David
Since no one as answered the original question about the exception, I'll
take a crack at it.
Re: [CDO] "Auto commit" [message #425535 is a reply to message #425529] |
Mon, 01 December 2008 05:38   |
Tom, David and Vik,
I think you should not be required to add commit operations only for
"technical" reasons, i.e. to avoid OutOfMemoryExceptions. This is not
only inconvenient but also blurs the logical view of a possible commit
history but also dramatically increases the size in auditing back-ends.
I filed the following bugs:
257050: Better client-side scalability of transactions
https://bugs.eclipse.org/bugs/show_bug.cgi?id=257050
257048: Better server-side scalability of transactions
https://bugs.eclipse.org/bugs/show_bug.cgi?id=257048
More comments below...
Tom Crockett schrieb:
> Hey David,
> This is probably happening because the CDOTransactionHandler gets to
> hear about added objects before ordinary adapters, one of which I
> believe is responsible for making the (almost immediate) transition
Correct. This is because a concrete CDOTransactionHandler should be able
to *prevent* subsequent commit operations rather than bringing it forward.
> we are using EMF Transactions, and we commit upon hearing of any (EMF)
> you will definitely want to implement is some form of coalescing
> events, so that 20 changes to various EObjects does not result in 20
> separate commits for each of the deltas. That would be Very Bad :) I
> would recommend something like the following:
> public void run() {
> try {
> Thread.sleep(500);
> } finally {
> }.start();
> a later date, when the state machine had had plenty of time to
> transition from PREPARED to NEW. I'm not sure if there's a chance that
> the resulting commit would take place in that very brief PREPARED
> state, but it seems very unlikely at the least, and perhaps Eike has
> put in place some synchronization to prevent that.
Do you think that we need such coalescing even when we have transparent
support for transactions of arbitrary sizes? If so, please file a
bugzilla so that we don't forget about it.
Cheers
/Eike
> Hope that helps,
> Tom
>> Hi
>> often this transaction, if I don't want to use too memory (to prevent
>> transaction. I'm able to known if an object is added or modified in
>> the transaction. Every X add or modification I try to commit the
>> at
>> at
>> at
>> at
>> commit !
>> solution ?
>> David
> I'll take a crack at it.
Re: [CDO] "Auto commit" [message #425595 is a reply to message #425579] |
Tue, 02 December 2008 16:57  |
Done: https://bugs.eclipse.org/bugs/show_bug.cgi?id=257274
Eike Stepper wrote:
> Tom,
> This should be comparingly easy to achieve. Can you please file an
> enhancement request?
> Cheers
> /Eike
> http://thegordian.blogspot.com
>>> transparent support for transactions of arbitrary sizes? If so,
>>> please file a bugzilla so that we don't forget about it.
>> I see coalescing as being necessary primarily in an auto-commit scheme
>> where you need to schedule a commit every time someone dirties the
>> transaction, either by adding new objects or dirtying old objects. You
>> don't want to actually DO a commit, synchronously, every time you hear
>> of a dirtied transaction--you just want to schedule one for a little
>> bit later, so that if n changes happen in quick succession, you won't
>> trigger n synchronous commits one after the other. If you plan to add
>> API support for auto-committing, I think it would be good to add an
>> asynchronous commit scheduling mechanism like this.
>> Tom
Current Time: Sat Jul 26 11:18:23 EDT 2025
Powered by FUDForum. Page generated in 0.11557 seconds
