Home » Modeling » EMF » [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALUE, &
[Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALUE, & [message #425174] Tue, 18 November 2008 04:44 Go to next message
I have a set of columns that I need to be timestamps. So I use this
<xsd:simpleType name="javaDate" ecore:instanceClass="java.util.Date">
<xsd:restriction base="xsd:dateTime">
</xsd:restriction>
</xsd:simpleType>
<xsd:attribute name="snapTime" type="gensec:javaDate" >
<xsd:annotation>
<xsd:appinfo
source="teneo.jpa">@Temporal(TIMESTAMP)</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
The hibernate.hbm.xml shows this
<property name="snapTime" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="timestamp">
<column not-null="false" unique="false" name="`snaptime`"/>
</property>
But the schema generated creates Date columns, not Timestamp?
Thx.
David
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #425176 is a reply to message #425174] Tue, 18 November 2008 04:58 Go to previous messageGo to next message
Hi David,
For many cases the java.util.Date works fine (as it is detailed to the millis level).
If you want TimeStamp then you need to introduce a simpleType for timestamp with the specific
java.sql.TimeStamp instanceclass. You can also place the annotation in the timestamp simpletype,
then you don't need to repeat it every time in the xsd:
<xsd:simpleType name="javaTimeStamp" ecore:instanceClass="java.sql.TimeStamp">
<xsd:annotation>
<xsd:appinfo
</xsd:annotation>
</xsd:restriction>
</xsd:simpleType>
and then use this datatype (without annotation):
<xsd:attribute name="snapTime" type="gensec:javaTimeStamp"/>
gr. Martin
David Wynter wrote:
> </xsd:restriction>
> </xsd:simpleType>
> <xsd:annotation>
> <xsd:appinfo
> </xsd:annotation>
> </xsd:attribute>
> update="true" not-null="false" unique="false" type="timestamp">
> </property>
> Thx.
> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
[Teneo - Spring] No property 'ePackageClasses' found [message #425291 is a reply to message #425176] Fri, 21 November 2008 14:58 Go to previous messageGo to next message
I'm trying out Teneo with Spring. I noticed that using ePackageClasses to set the ePackages does not work, but if I change the property name to EPackageClasses it does.
Anyone know if this is a Spring bug? I looked at the method:
public void setEPackageClasses(java.util.List<String> ePackageClasses) {
if (ePackageConstructor == null) {
ePackageConstructor = new EPackageConstructor();
ePackageConstructor.setModelClasses(ePackageClasses);
It looks fine. I also tried a simpler mockup version of setting a property via setter injection, when the property is not present on the class, and it works.
Thoughts?
- Ole
Re: [Teneo - Spring] No property 'ePackageClasses' found [message #425363 is a reply to message #425291] Sat, 22 November 2008 11:27 Go to previous messageGo to next message
Hi Ole,
No other thoughts then that I have noticed with Hibernate also a similar thing (as I remember it),
apparently the second upper-cased character (the P) gives confusion.
gr. Martin
Ole Ersoy wrote:
> ePackageClasses) {
> Thoughts?
> - Ole
The Netherlands
Re: [Teneo - Spring] No property 'ePackageClasses' found [message #425407 is a reply to message #425363] Tue, 25 November 2008 10:46 Go to previous messageGo to next message
Hi Martin,
You're right. I tried it out with a simple setup like so:
METHOD
public void setMYList(List myList)
System.out.println("MY LIST IS: " + myList);
CONTEXT
<bean
id="mockSetterInjection"
class="mock.beans.MockSetterInjection">
<property
name="mYList">
<list>
<value>
org.example.impl.ExamplePackageImpl
</value>
</list>
</property>
</bean>
RESULT
When I load the above context, I also get:
Error creating bean with name 'mockSetterInjection' defined in file [src/test/resources/context2.xml]: Initialization of bean failed; nested exception is org.springframework.beans.InvalidPropertyException: Invalid property 'mYList' of bean class [mock.beans.MockSetterInjection]: No property 'mYList' found
But if I change the name of the propety mYList to MYList, then the test runs fine.
- Ole
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652707 is a reply to message #425176] Sat, 05 February 2011 13:10 Go to previous messageGo to next message
Hi Martin,
Not sure what is happening here, as I followed your advice over 2years
ago and I seem to remember it working.
Using org.eclipse.emf.teneo.hibernate 1.1.1
I use
<xsd:simpleType name="javaDateTime"
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@Temporal(TIMESTAMP)</xsd:appinfo>
</xsd:annotation>
</xsd:restriction>
</xsd:simpleType>
and
<xsd:complexType name="CleansingException">
<xsd:attribute name="id" type="xsd:int">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@Id
@GeneratedValue(strategy=IDENTITY)</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
<xsd:attribute name="timeReported" type="datamanager:javaDateTime" />
</xsd:complexType>
<xsd:element name="cleansingException"
type="datamanager:CleansingException"/>
and yet I get the following after reloading genmodel, regenerating the
code and running my HibernateUtil.
2011-02-0518:01:15.321 GMT+0000 21354 [main] ERROR org.mortbay.log -
failed HibernateSessionRequestFilter
org.hibernate.HibernateException: Wrong column type in
DMANAGER.PUBLIC.cleansingexception for column timereported. Found:
timestamp, expected: date
at org.hibernate.mapping.Table.validateColumns(Table.java:284)
at org.hibernate.cfg.Configuration.validateSchema(Configuration .java:1130)
at
org.hibernate.tool.hbm2ddl.SchemaValidator.validate(SchemaVa lidator.java:139)
at
org.hibernate.impl.SessionFactoryImpl.<init>(SessionFactoryImpl.java:359)
at
org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1341)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.buildSess ionFactory(HbSessionDataStore.java:218)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:93)
at
org.eclipse.emf.teneo.hibernate.HbBaseSessionDataStore.getSe ssionFactory(HbBaseSessionDataStore.java:74)
at com.example.something.HibernateUtil.init(HibernateUtil.java: 94)
I only need millisecond precision but it is not clear how you get a
timestamp column type from annotations, any examples? So I tried the
full timestamp route and it failed. Any ideas?
Thx,
David
On 18/11/08 09:58, Martin Taal wrote:
> Hi David,
> millis level).
> timestamp with the specific java.sql.TimeStamp instanceclass. You can
> also place the annotation in the timestamp simpletype, then you don't
> <xsd:annotation>
> <xsd:appinfo
> </xsd:annotation>
> </xsd:restriction>
> </xsd:simpleType>
> gr. Martin
> David Wynter wrote:
>> Hi,
>> </xsd:restriction>
>> </xsd:simpleType>
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:attribute>
>> </property>
>> Thx.
>> David
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652708 is a reply to message #652707] Sat, 05 February 2011 13:36 Go to previous messageGo to next message
On 05/02/11 18:10, David Wynter wrote:
> Hi Martin,
> I use
> <xsd:annotation>
> </xsd:annotation>
> </xsd:restriction>
> </xsd:simpleType>
> and
> <xsd:annotation>
> </xsd:annotation>
> </xsd:attribute>
> </xsd:complexType>
> at
> at
> at
> at
> at
> at
> Thx,
> David
>> Hi David,
>> millis level).
>> <xsd:annotation>
>> <xsd:appinfo
>> </xsd:annotation>
>> </xsd:restriction>
>> </xsd:simpleType>
>> gr. Martin
>> David Wynter wrote:
>>> Hi,
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> </property>
>>> Thx.
>>> David
I also tried this
<xsd:attribute name="attemptDate" type="xsd:dateTime">
<xsd:annotation>
<xsd:appinfo
</xsd:annotation>
</xsd:attribute>
with the same results.
So am unable to use a millisecond precision.
David
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652749 is a reply to message #652708] Sun, 06 February 2011 04:48 Go to previous messageGo to next message
Hi David,
How does the generated hbm look like? (datastore.getMappingXML())
You are not using a fixed hbm file are you (so the hbm is generated in-memory)?
gr. Martin
>> Hi Martin,
>> I use
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:restriction>
>> </xsd:simpleType>
>> and
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:attribute>
>> </xsd:complexType>
>> at
>> at
>> at
>> at
>> at
>> at
>> Thx,
>> David
>>> Hi David,
>>> millis level).
>>> <xsd:annotation>
>>> <xsd:appinfo
>>> </xsd:annotation>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> gr. Martin
>>> David Wynter wrote:
>>>> Hi,
>>>> </xsd:restriction>
>>>> </xsd:simpleType>
>>>> <xsd:annotation>
>>>> </xsd:annotation>
>>>> </xsd:attribute>
>>>> </property>
>>>> Thx.
>>>> David
> I also tried this
> <xsd:annotation>
> </xsd:annotation>
> </xsd:attribute>
> David
The Netherlands
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652752 is a reply to message #652749] Sun, 06 February 2011 06:05 Go to previous messageGo to next message
I thought I'd try the 1.2.0 version of Teneo before I got your reply. So
updated EMF to 2.6.0 and Teneo to 1.2.0, and the dependencies you
provide but when I try to add V1.2.0 as a dependent plugin, it does not
appear, V1.1.2 does. I have org.eclipse.emf.ecore selected as V2.6.0.
V1.2.0 of Teneo hibernate does appear in the installation dialog for
Eclipse 3.6.
What else do I need to do to update?
I'll downgrade back to EMF V2.5.0 and get the hbm detail.
Thx.
David
On 06/02/11 09:48, Martin Taal wrote:
> Hi David,
> in-memory)?
> gr. Martin
>>> Hi Martin,
>>> I use
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:restriction>
>>> </xsd:simpleType>
>>> and
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> </xsd:complexType>
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Thx,
>>> David
>>>> Hi David,
>>>> millis level).
>>>> <xsd:annotation>
>>>> <xsd:appinfo
>>>> </xsd:annotation>
>>>> </xsd:restriction>
>>>> </xsd:simpleType>
>>>> gr. Martin
>>>> David Wynter wrote:
>>>>> Hi,
>>>>> </xsd:restriction>
>>>>> </xsd:simpleType>
>>>>> <xsd:annotation>
>>>>> </xsd:annotation>
>>>>> </xsd:attribute>
>>>>> </property>
>>>>> Thx.
>>>>> David
>> I also tried this
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:attribute>
>> David
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652758 is a reply to message #652752] Sun, 06 February 2011 07:26 Go to previous messageGo to next message
Yes you can take v1.1.2 in this case.
gr. Martin
On 02/06/2011 12:05 PM, David Wynter wrote:
> I thought I'd try the 1.2.0 version of Teneo before I got your reply. So updated EMF to 2.6.0 and Teneo to 1.2.0, and
> the dependencies you provide but when I try to add V1.2.0 as a dependent plugin, it does not appear, V1.1.2 does. I have
> org.eclipse.emf.ecore selected as V2.6.0. V1.2.0 of Teneo hibernate does appear in the installation dialog for Eclipse 3.6.
> Thx.
> David
>> Hi David,
>> in-memory)?
>> gr. Martin
>>>> Hi Martin,
>>>> I use
>>>> <xsd:annotation>
>>>> </xsd:annotation>
>>>> </xsd:restriction>
>>>> </xsd:simpleType>
>>>> and
>>>> <xsd:annotation>
>>>> </xsd:annotation>
>>>> </xsd:attribute>
>>>> </xsd:complexType>
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Thx,
>>>> David
>>>>> Hi David,
>>>>> millis level).
>>>>> <xsd:annotation>
>>>>> <xsd:appinfo
>>>>> </xsd:annotation>
>>>>> </xsd:restriction>
>>>>> </xsd:simpleType>
>>>>> gr. Martin
>>>>> David Wynter wrote:
>>>>>> Hi,
>>>>>> </xsd:restriction>
>>>>>> </xsd:simpleType>
>>>>>> <xsd:annotation>
>>>>>> </xsd:annotation>
>>>>>> </xsd:attribute>
>>>>>> </property>
>>>>>> Thx.
>>>>>> David
>>> I also tried this
>>> <xsd:annotation>
>>> </xsd:annotation>
>>> </xsd:attribute>
>>> David
The Netherlands
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652847 is a reply to message #652758] Mon, 07 February 2011 06:02 Go to previous messageGo to next message
Sadly, Eclipse delivers the usual DLL hell. I uninstalled EMF 2.6.0 and
it will not allow me to install EMF V2.5.0 due to other borken
dependencies now, several of them. I have learnt from experience it is
better to scrap this Eclipse install rather than spend days trying to
sort out the DLL hell that is Eclipse whenever you don't use a complete
installation.
I assume I could not see the Teneo V1.2.0 ias an available dependency
because some versioning in the plugin manifest is wrong?
David
> gr. Martin
>> Hi,
>> Thx.
>> David
>>> Hi David,
>>> in-memory)?
>>> gr. Martin
>>>>> Hi Martin,
>>>>> I use
>>>>> <xsd:annotation>
>>>>> </xsd:annotation>
>>>>> </xsd:restriction>
>>>>> </xsd:simpleType>
>>>>> and
>>>>> <xsd:annotation>
>>>>> </xsd:annotation>
>>>>> </xsd:attribute>
>>>>> </xsd:complexType>
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Thx,
>>>>> David
>>>>>> Hi David,
>>>>>> the
>>>>>> millis level).
>>>>>> <xsd:annotation>
>>>>>> <xsd:appinfo
>>>>>> </xsd:annotation>
>>>>>> </xsd:restriction>
>>>>>> </xsd:simpleType>
>>>>>> gr. Martin
>>>>>> David Wynter wrote:
>>>>>>> Hi,
>>>>>>> </xsd:restriction>
>>>>>>> </xsd:simpleType>
>>>>>>> <xsd:annotation>
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:attribute>
>>>>>>> </property>
>>>>>>> Thx.
>>>>>>> David
>>>> I also tried this
>>>> <xsd:annotation>
>>>> </xsd:annotation>
>>>> </xsd:attribute>
>>>> David
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652849 is a reply to message #652847] Mon, 07 February 2011 06:15 Go to previous messageGo to next message
It is different, the Teneo 1.2.0 version contains plugins at 1.1.2, that's all.
gr. Martin
On 02/07/2011 12:02 PM, David Wynter wrote:
> Sadly, Eclipse delivers the usual DLL hell. I uninstalled EMF 2.6.0 and it will not allow me to install EMF V2.5.0 due
> to other borken dependencies now, several of them. I have learnt from experience it is better to scrap this Eclipse
> install rather than spend days trying to sort out the DLL hell that is Eclipse whenever you don't use a complete
> installation.
> I assume I could not see the Teneo V1.2.0 ias an available dependency because some versioning in the plugin manifest is
> wrong?
> David
>> gr. Martin
>>> Hi,
>>> Thx.
>>> David
>>>> Hi David,
>>>> in-memory)?
>>>> gr. Martin
>>>>>> Hi Martin,
>>>>>> I use
>>>>>> <xsd:annotation>
>>>>>> </xsd:annotation>
>>>>>> </xsd:restriction>
>>>>>> </xsd:simpleType>
>>>>>> and
>>>>>> <xsd:annotation>
>>>>>> </xsd:annotation>
>>>>>> </xsd:attribute>
>>>>>> </xsd:complexType>
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Thx,
>>>>>> David
>>>>>>> Hi David,
>>>>>>> the
>>>>>>> millis level).
>>>>>>> <xsd:annotation>
>>>>>>> <xsd:appinfo
>>>>>>> </xsd:annotation>
>>>>>>> </xsd:restriction>
>>>>>>> </xsd:simpleType>
>>>>>>> gr. Martin
>>>>>>> David Wynter wrote:
>>>>>>>> Hi,
>>>>>>>> </xsd:restriction>
>>>>>>>> </xsd:simpleType>
>>>>>>>> <xsd:annotation>
>>>>>>>> </xsd:annotation>
>>>>>>>> </xsd:attribute>
>>>>>>>> </property>
>>>>>>>> Thx.
>>>>>>>> David
>>>>> I also tried this
>>>>> <xsd:annotation>
>>>>> </xsd:annotation>
>>>>> </xsd:attribute>
>>>>> David
The Netherlands
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652862 is a reply to message #652849] Mon, 07 February 2011 07:34 Go to previous messageGo to next message
Ok, Finally got there with V1.2.0 (or V1.1.2?)
To have it all in one place, here is the annotation in the XSD
<xsd:annotation>
<xsd:appinfo
source="teneo.jpa">@TemporalType(TIMESTAMP)</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
Here is the mapping, which show type="date" for the above
<!DOCTYPE hibernate-mapping PUBLIC "-//Hibernate/Hibernate Mapping DTD
3.0//EN" "http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd">
<hibernate-mapping auto-import="false">
<class name="com.example.application.impl.ChangeAttemptImpl"
entity-name="ChangeAttempt" abstract="false" lazy="false"
table="`changeattempt`">
<meta attribute="eclassName" inherit="false">ChangeAttempt</meta>
<meta attribute="epackage"
inherit="false">http://www.example.com/application</meta>
<id name="id" type="int" unsaved-value="0">
<column not-null="true" unique="false" name="`id`"/>
<generator class="identity"/>
</id>
<property name="attemptDate" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="date">
<column not-null="false" unique="false" name="`attemptdate`"/>
</property>
<property name="changeSource" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`changesource`"/>
</property>
<property name="changeValue" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`changevalue`"/>
</property>
<many-to-one name="userProtectedValues"
entity-name="UserProtectedValues" lazy="false"
cascade="merge,persist,save-update,lock,refresh"
foreign-key="chngeattempt_serprtectedvles" insert="true" update="true"
not-null="false">
<column not-null="false" unique="false" name="`userprotectedvalues`"/>
</many-to-one>
</class>
<class name="com.example.application.impl.CleansingExceptionImpl"
entity-name="CleansingException" abstract="false" lazy="false"
table="`cleansingexception`">
<meta attribute="eclassName" inherit="false">CleansingException</meta>
</id>
<bag name="exceptionValue" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="clensingexceptin_exceptinvle">
<column name="`exceptionid`" not-null="false" unique="false"/>
</key>
<one-to-many entity-name="ExceptionValue"/>
</bag>
<property name="description" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`description`"/>
</property>
<property name="destFieldId" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="int">
<column not-null="false" unique="false" name="`destfieldid`"/>
</property>
<property name="endDate" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`enddate`"/>
</property>
<property name="name" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`name`"/>
</property>
<property name="ownerId" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`ownerid`"/>
</property>
<property name="timeReported" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`timereported`"/>
</property>
<many-to-one name="exceptionType" entity-name="ExceptionType"
lazy="false" cascade="merge,persist,save-update,lock,refresh"
foreign-key="clnsingexceptin_exceptintype" insert="true" update="true"
not-null="false">
<column not-null="false" unique="false" name="`exceptiontype`"/>
</many-to-one>
</class>
<class name="com.example.application.impl.ExceptionTypeImpl"
entity-name="ExceptionType" abstract="false" lazy="false"
table="`exceptiontype`">
<meta attribute="eclassName" inherit="false">ExceptionType</meta>
</id>
<bag name="cleansingException" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="excptintype_clensingexceptin">
<column name="`typeid`" not-null="false" unique="false"/>
</key>
<one-to-many entity-name="CleansingException"/>
</bag>
</property>
</property>
<property name="typeOwnerId" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`typeownerid`"/>
</property>
<property name="validFrom" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`validfrom`"/>
</property>
<property name="validTo" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`validto`"/>
</property>
</class>
<class name="com.example.application.impl.ExceptionValueImpl"
entity-name="ExceptionValue" abstract="false" lazy="false"
table="`exceptionvalue`">
<meta attribute="eclassName" inherit="false">ExceptionValue</meta>
</id>
<bag name="userProtectedValues" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="exceptinvle_serprtectedvales">
<column name="`exceptionvalue`" not-null="false" unique="false"/>
</key>
<one-to-many entity-name="UserProtectedValues"/>
</bag>
<property name="partOfPK" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="boolean">
<column not-null="false" unique="false" name="`partofpk`"/>
</property>
<property name="replacementValue" lazy="false" insert="true"
update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`replacementvalue`"/>
</property>
<property name="sourceFieldId" lazy="false" insert="true"
update="true" not-null="false" unique="false" type="int">
<column not-null="false" unique="false" name="`sourcefieldid`"/>
</property>
<property name="sourceTag" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`sourcetag`"/>
</property>
<property name="sourceValue" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`sourcevalue`"/>
</property>
<property name="timeRepaired" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`timerepaired`"/>
</property>
<many-to-one name="cleansingException"
entity-name="CleansingException" lazy="false"
foreign-key="exceptinvle_clensingexceptin" insert="true" update="true"
not-null="false">
<column not-null="false" unique="false" name="`cleansingexception`"/>
</many-to-one>
</class>
<class name="com.example.application.impl.UserProtectedValuesImpl"
entity-name="UserProtectedValues" abstract="false" lazy="false"
table="`userprotectedvalues`">
<meta attribute="eclassName" inherit="false">UserProtectedValues</meta>
</id>
<bag name="changeAttempt" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="userprtectedvles_chngettempt">
<column name="`userprotectedvalues`" not-null="false" unique="false"/>
</key>
<one-to-many entity-name="ChangeAttempt"/>
</bag>
<property name="columnName" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`columnname`"/>
</property>
<property name="correctionValue" lazy="false" insert="true"
<column not-null="false" unique="false" name="`correctionvalue`"/>
</property>
</property>
<property name="pkCol1Name" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`pkcol1name`"/>
</property>
<property name="pkCol1Value" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`pkcol1value`"/>
</property>
<property name="pkCol2Name" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`pkcol2name`"/>
</property>
<property name="pkCol2Value" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`pkcol2value`"/>
</property>
<property name="pkCol3Name" la...
Thx.
David
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652889 is a reply to message #652862] Mon, 07 February 2011 08:17 Go to previous messageGo to next message
Found the problem. This line of code not only makes the default Date but
also overrides any annotations for timestamp
props.setProperty(PersistenceOptions.DEFAULT_TEMPORAL_VALUE,
"DATE");
I thought it would be the other way around, that the annotation
over-rode the default.
Thx.
David
> <xsd:annotation>
> <xsd:appinfo source="teneo.jpa">@TemporalType(TIMESTAMP)</xsd:appinfo>
> </xsd:annotation>
> </xsd:attribute>
> </id>
> </property>
> </property>
> </property>
> not-null="false">
> </many-to-one>
> </class>
> </id>
> </key>
> </bag>
> </property>
> </property>
> </property>
> </property>
> </property>
> </property>
> not-null="false">
> </many-to-one>
> </class>
> </id>
> </key>
> </bag>
> </property>
> </property>
> </property>
> </property>
> </property>
> </class>
> </id>
> </key>
> </bag>
> </property>
> </property>
> <property name="sourceFieldId" lazy="false" insert="true" update="true"
> </property>
> </property>
> </property>
> </property>
> <many-to-one name="cleansingException" entity-name="CleansingException"
> not-null="false">
> </many-to-one>
> </class>
> </id>
> </key>
> </bag>
> </property>
> </property>
> </property>
> </property>
> </property>
> </property>
> </property>
> Thx.
> David
Re: [Teneo] Forcing a Timestamp data type for a column when PersistenceOptions.DEFAULT_TEMPORAL_VALU [message #652901 is a reply to message #652889] Mon, 07 February 2011 08:23 Go to previous message
Hi David,
Indeed incorrect... Can you enter a bugzilla for this?
gr. Martin
On 02/07/2011 02:17 PM, David Wynter wrote:
> Found the problem. This line of code not only makes the default Date but also overrides any annotations for timestamp
> props.setProperty(PersistenceOptions.DEFAULT_TEMPORAL_VALUE, "DATE");
> I thought it would be the other way around, that the annotation over-rode the default.
> Thx.
> David
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:attribute>
>> <?xml version="1.0" encoding="UTF-8"?>
>> </id>
>> </property>
>> </property>
>> </property>
>> not-null="false">
>> </many-to-one>
>> </class>
>> </id>
>> </key>
>> </bag>
>> </property>
>> </property>
>> </property>
>> </property>
>> </property>
>> </property>
>> not-null="false">
>> </many-to-one>
>> </class>
>> </id>
>> </key>
>> </bag>
>> </property>
>> </property>
>> </property>
>> </property>
>> </property>
>> </class>
>> </id>
>> </key>
>> </bag>
>> </property>
>> </property>
>> </property>
>> </property>
>> </property>
>> </property>
>> not-null="false">
>> </many-to-one>
>> </class>
>> </id>
>> </key>
>> </bag>
>> </property>
>> </property>
>> </property>
>> </property>
>> </property>
>> </property>
>> </property>
>> Thx.
>> David
The Netherlands
Previous Topic:extend Ecore-Editor
Next Topic:[Teneo] HbDataStore - several schemas
Current Time: Fri Jul 25 22:16:09 EDT 2025
Powered by FUDForum. Page generated in 0.08271 seconds
