[Transactions] Deadlock using WorkspaceSynchronizer.Delegate [message #425362] |
Sat, 22 November 2008 10:52  |
I'm having a problem with the Synchronizer Delegate. In the
handleResourceChanged() the code reloads the changed resource and calls
setInput() on an JFace viewer in order to update itself. The viewer uses
a TransactionalContentPRovider. Now this is where I encounter a
deadlock. The content provider executes runExclusive(), but the
execution blocks in org.eclipse.emf.transaction.util.Lock:
jobmgr.beginRule(jobRule, null);
jobRule is an instanceof AcquireRule.
handleResourceChanged() gets called within a ResourceSynchJob whose
scheduling rule is just a combined rule of all affected resources.
I don't see why the two scheduling jobs are conflicting each other.
The code looks similar to the following:
public boolean handleResourceChanged(Resource resource) {
// reload resource
Display.getCurrent().syncExec(new Runnable() {
public void run() {
viewer.setInput(reloadedInput);
return true;
Any ideas?
Ömer
Re: [Transactions] Deadlock using WorkspaceSynchronizer.Delegate [message #425386 is a reply to message #425362] |
Sun, 23 November 2008 19:11   |
Originally posted by: cdamus.zeligsoft.com
Hi, Ömer,
Can you do an asyncExec(...) in your handleResourceChanged(...) instead
of syncExec(...) ?
In general, Eclipse discourages synchronization with the UI thread in a
resource-change listener or, indeed, doing anything else that might
acquire resources (such as locks, incnluding the UI-thread lock) or take
a non-trivial amount of time.
On the subject of lock conflict: are you sure that it is the AcquireJob
that is conflicting? I don't see now it can, as its rule doesn't
intersect with any other. I suspect, rather, that it is simply waiting
for the transaction lock, which is currently held by another thread that
is waiting for a workspace resource.
HTH,
Christian
Ömer Yildiz wrote:
> Hello,
> // reload resource
> public void run() {
> return true;
> Any ideas?
> Best regards,
> Ömer
FUDForum. Page generated in 0.07220 seconds
