Home » Modeling » EMF » [CDO]Model update
[CDO]Model update [message #425256] Thu, 20 November 2008 20:56 Go to next message
Hi Ed,
I have a problem that I can't resolve. I create a database for my model
with CDO2.0M3. When I update my model, for example, I add an attribute for
one class, I can't reload the old data from database. The exception is
following:
java.lang.IllegalStateException: range.size() != metaIDRange.size()
at
org.eclipse.emf.internal.cdo.CDOSessionImpl.registerEPackage (CDOSessionImpl.java:544)
at
org.eclipse.emf.internal.cdo.util.CDOPackageRegistryImpl$Rem otePackageDescriptor.getEPackage(CDOPackageRegistryImpl.java :182)
at
org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage( EPackageRegistryImpl.java:133)
at
org.eclipse.emf.internal.cdo.CDOSessionPackageManagerImpl.lo adPackage(CDOSessionPackageManagerImpl.java:152)
at
org.eclipse.emf.cdo.internal.common.model.CDOPackageImpl.loa d(CDOPackageImpl.java:401)
at
org.eclipse.emf.cdo.internal.common.model.CDOPackageImpl.loo kupClass(CDOPackageImpl.java:288)
at
org.eclipse.emf.cdo.internal.common.model.CDOClassRefImpl.re solve(CDOClassRefImpl.java:71)
at
org.eclipse.emf.cdo.internal.common.CDODataInputImpl.readCDO ClassRefAndResolve(CDODataInputImpl.java:218)
at
org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl . <init>(CDORevisionImpl.java:114)
at
org.eclipse.emf.cdo.internal.common.CDODataInputImpl.readCDO Revision(CDODataInputImpl.java:309)
at
org.eclipse.emf.internal.cdo.protocol.LoadRevisionRequest.co nfirming(LoadRevisionRequest.java:116)
at
org.eclipse.emf.internal.cdo.protocol.LoadRevisionRequest.co nfirming(LoadRevisionRequest.java:1)
at
org.eclipse.emf.internal.cdo.protocol.CDOClientRequest.confi rming(CDOClientRequest.java:103)
at
org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedI nput(RequestWithConfirmation.java:118)
at org.eclipse.net4j.signal.Signal.doInput(Signal.java:317)
at
org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(R equestWithConfirmation.java:98)
at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.jav a:68)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:237)
at
org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalPr otocol.java:392)
at
org.eclipse.net4j.signal.RequestWithConfirmation.send(Reques tWithConfirmation.java:82)
at
org.eclipse.net4j.signal.RequestWithConfirmation.send(Reques tWithConfirmation.java:73)
at
org.eclipse.emf.internal.cdo.CDORevisionManagerImpl.send(CDO RevisionManagerImpl.java:149)
at
org.eclipse.emf.internal.cdo.CDORevisionManagerImpl.loadRevi sion(CDORevisionManagerImpl.java:104)
at
org.eclipse.emf.cdo.internal.common.revision.CDORevisionReso lverImpl.getRevision(CDORevisionResolverImpl.java:94)
at
org.eclipse.emf.cdo.internal.common.revision.CDORevisionReso lverImpl.getRevision(CDORevisionResolverImpl.java:1)
at
org.eclipse.emf.internal.cdo.CDOViewImpl.getRevision(CDOView Impl.java:714)
at
org.eclipse.emf.internal.cdo.CDOViewImpl.createObject(CDOVie wImpl.java:857)
at org.eclipse.emf.internal.cdo.CDOViewImpl.getObject(CDOViewIm pl.java:752)
at
org.eclipse.emf.internal.cdo.CDOTransactionImpl.getObject(CD OTransactionImpl.java:449)
at
org.eclipse.emf.internal.cdo.CDOViewImpl.convertIDToObject(C DOViewImpl.java:1023)
at org.eclipse.emf.internal.cdo.CDOStore.convertToEMF(CDOStore. java:381)
at org.eclipse.emf.internal.cdo.CDOStore.get(CDOStore.java:175)
at
org.eclipse.emf.ecore.impl.EStoreEObjectImpl$BasicEStoreELis t.delegateGet(EStoreEObjectImpl.java:225)
at
org.eclipse.emf.common.util.DelegatingEList.get(DelegatingEL ist.java:396)
at
org.eclipse.emf.common.util.DelegatingEList$EIterator.doNext (DelegatingEList.java:1075)
at
org.eclipse.emf.common.util.DelegatingEList$EIterator.next(D elegatingEList.java:1062)
at
org.eclipse.emf.edit.provider.ItemProviderAdapter.getChildre n(ItemProviderAdapter.java:340)
at
org.eclipse.emf.edit.provider.ItemProviderAdapter.getElement s(ItemProviderAdapter.java:310)
at
org.eclipse.emf.edit.ui.provider.AdapterFactoryContentProvid er.getElements(AdapterFactoryContentProvider.java:160)
What should I do?
Re: [CDO]Model update [message #425258 is a reply to message #425256] Thu, 20 November 2008 23:49 Go to previous messageGo to next message
At the moment CDO does not support evolving classes.
Currently in CDO, a package with a given URI (X) should never be
modified. If you do so, a new URI(for the package) should be given.
If you follow this your objects will still be available using the old model.
Does CDO should do more ? (Let me think about it during the night (it is
around 23:48 here :-))
This is a very complicated question that needs to be think deeply!
Usually you will need to change the URI of your package.. and migrate
your databases...
Maybe Eike will have another idea.
Simon
xxlu wrote:
> Hi Ed,
> following:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> What should I do?
Re: [CDO]Model update [message #425260 is a reply to message #425258] Fri, 21 November 2008 01:13 Go to previous messageGo to next message
I think this is a very complicated question, too. : (
In my project, model will be updated frequently. It's so discommodious to
migrate my database everytime. ;(
"Simon McDuff" <smcduff@hotmail.com>
> Currently in CDO, a package with a given URI (X) should never be modified.
> model.
> your databases...
> Simon
> xxlu wrote:
>> Hi Ed,
>> model with CDO2.0M3. When I update my model, for example, I add an
>> attribute for one class, I can't reload the old data from database. The
>> exception is following:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> What should I do?
Re: [CDO]Model update [message #425261 is a reply to message #425260] Fri, 21 November 2008 04:14 Go to previous messageGo to next message
xxlu, Simon,
maybe you could take look at this:
"COPE - Coupled Evolution of Metamodels and Models"
http://cope.in.tum.de
Quite impressive stuff. I allows you to modify a model, record the
changes you've made on it and then generate a plugin capable of update
old model instances to the new version.
Still, you would need to change your model URI (for instance, changing
the version: from http://foo.bar.org/example/1.0 to
http://foo.bar.org/example/2.0), but the generated migration plugin
should help you dealing with it!
We just need to execute that transformation with a CDOResource. We could
probably add the context menu migration action (which is currently only
available at package explorer/resource navigator context menu) to
CDOSession View by passing to their migration API a CDOResource instead.
And I think this would be a cool experiment :)
I've read It's going to be probably contributed to Eclipse.
>> model.
>> your databases...
>> Simon
>> xxlu wrote:
>>> Hi Ed,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> What should I do?
Re: [CDO]Model update [message #425270 is a reply to message #425261] Fri, 21 November 2008 07:19 Go to previous messageGo to next message
Guys,
Indeed, model evolution is a very interesting problem and certainly hard
to solve in the context of a persistent model repository with support
for temporality. I'd also appreciate to start discussion and see if we
can do something constructive in this area.
I also think that COPE is an interesting first step to look at. But in
the long term I'd like to see an approach that doesn't go through a
regular user transaction at client side but rather modifies the
repository directly at the server side. For huge models this seems to be
the only appropriate way and models seem to grow constantly.
Here are some points to consider:
1) Would COPE be able to help us at the server side? We don't have EMF
there...
2) Should there be a new protocol (signals) to implement API like
CDOSessionPackageManager::evolvePackage(String oldURI, EPackage
newPackage, CDODataMigrationRules rules) ?
3) Should these data migration rules operate on the CDORevision level or
on back-end concepts level?
4) What about on-demand migration per instance (as opposed to one huge
migration process for the whole repository)?
Cheers
/Eike
Víctor Roldán Betancort schrieb:
> xxlu, Simon,
> could probably add the context menu migration action (which is
> currently only available at package explorer/resource navigator
> context menu) to CDOSession View by passing to their migration API a
>> discommodious to migrate my database everytime. ;(
>>> old model.
>>> (it is around 23:48 here :-))
>>> migrate your databases...
>>> Simon
>>> xxlu wrote:
>>>> Hi Ed,
>>>> my model with CDO2.0M3. When I update my model, for example, I add
>>>> an attribute for one class, I can't reload the old data from
>>>> database. The exception is following:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> What should I do?
Re: [CDO]Model update [message #425275 is a reply to message #425261] Fri, 21 November 2008 07:43 Go to previous messageGo to next message
Víctor Roldán Betancort wrote:
> xxlu, Simon,
I saw it few days ago while reading Ed blogs!! Very interesting!!
It will work lovely with CDO since the URI will change!
Good to know!
>>> model.
>>> Simon
>>> xxlu wrote:
>>>> Hi Ed,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> What should I do?
Re: [CDO]Model update [message #425276 is a reply to message #425275] Fri, 21 November 2008 07:45 Go to previous messageGo to next message
Didn't refresh my newsgroup!! Eike already answered!!
>> xxlu, Simon,
> Good to know!
>>>> old model.
>>>> Simon
>>>> xxlu wrote:
>>>>> Hi Ed,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> What should I do?
Re: [CDO/Teneo]Model update [message #425473 is a reply to message #425276] Wed, 26 November 2008 20:24 Go to previous messageGo to next message
I experimentalize this with Teneo. I found Teneo can automatically
update database by modified model. I think this feature is necessary. I
should not migrate our database once my model modified. :(
"Simon McDuff" <smcduff@hotmail.com> :
> Simon McDuff wrote:
>> V
Re: [CDO/Teneo]Model update [message #425475 is a reply to message #425473] Thu, 27 November 2008 00:45 Go to previous messageGo to next message
Xxlu,
Please notice that Martin Taal from the Teneo project developed a CDO
back-end integration based on Teneo.
So you might be able to enjoy the advantages of both CDO and Teneo.
Cheers
/Eike
xxlu schrieb:
>>>> xxlu, Simon,
>>> Good to know!
>>>>>> model.
>>>>>> your databases...
>>>>>> Simon
>>>>>> xxlu wrote:
>>>>>>> Hi Ed,
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> What should I do?
Re: [CDO/Teneo]Model update [message #425477 is a reply to message #425475] Thu, 27 November 2008 02:17 Go to previous messageGo to next message
I am interested in Teneo CDO Integration very much, but I don't know if it
can support this feature. I will try it later.
"Eike Stepper" <stepper@esc-net.de>
> Xxlu,
> Cheers
> /Eike
> http://thegordian.blogspot.com
> xxlu schrieb:
>> Hi,
>>> Simon McDuff wrote:
>>>> V
Re: [CDO]Model update [message #425495 is a reply to message #425258] Thu, 27 November 2008 21:34 Go to previous messageGo to next message
I want to know how can I migrate my databases. Thanks. :)
> model.
> your databases...
> Simon
> xxlu wrote:
>> Hi Ed,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> What should I do?
Re: [CDO]Model update [message #425496 is a reply to message #425495] Thu, 27 November 2008 21:58 Go to previous messageGo to next message
Shoud I rebuild a database, then use ecore2ecore or other methods migrate my
database? Any suggestion?
"xxlu" <lu.xingxiao@gmail.com>
>> model.
>> your databases...
>> Simon
>> xxlu wrote:
>>> Hi Ed,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> What should I do?
Re: [CDO]Model update [message #425497 is a reply to message #425496] Fri, 28 November 2008 02:39 Go to previous messageGo to next message
Xxlu,
I've opened this bugzilla:
256856: Support model evolution
https://bugs.eclipse.org/bugs/show_bug.cgi?id=256856
My comment 1 in this bugzilla explains a possible *manual* way to
migrate data instances after model evolution...
Cheers
/Eike
>>> model.
>>> your databases...
>>> Simon
>>> xxlu wrote:
>>>> Hi Ed,
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> What should I do?
Re: [CDO]Model update [message #425498 is a reply to message #425497] Fri, 28 November 2008 03:04 Go to previous messageGo to next message
Eike,
Thank you very much!
But I think it's impossible to migrate the objects in the same schema.
For example:
test.ecroe V1 and test.ecore V2 both have classA. When excute migration,
exception will be throwed:
org.eclipse.net4j.db.DBException: DBTable exists classA. :(
> Xxlu,
> My comment 1 in this bugzilla explains a possible *manual* way to migrate
> Cheers
> /Eike
>> my database? Any suggestion?
>>>> model.
>>>> your databases...
>>>> Simon
>>>> xxlu wrote:
>>>>> Hi Ed,
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> What should I do?
Re: [CDO]Model update [message #425499 is a reply to message #425498] Fri, 28 November 2008 03:11 Go to previous messageGo to next message
--------------010201080901010004000704
Xxlu,
Please try the following option in the cdo-server.xml (given, you're
using the DBStore!):
<cdoServer>
<repository name="repo1">
<property name="overrideUUID"
value="1ff5d226-b1f0-40fb-aba2-0c31b38c764f"/>
<property name="supportingAudits" value="true"/>
<property name="verifyingRevisions" value="false"/>
<property name="currentLRUCapacity" value="10000"/>
<property name="revisedLRUCapacity" value="100"/>
<store type="db">
<mappingStrategy type="horizontal">
_<property name="qualifiedNames" value="*true*"/>_
<property name="toManyReferences"
value="ONE_TABLE_PER_REFERENCE"/>
<property name="toOneReferences" value="LIKE_ATTRIBUTES"/>
</mappingStrategy>
See also:
http://wiki.eclipse.org/CDO_Server_Configuration_Reference#P roperty_qualifiedNames
Cheers
/Eike
xxlu schrieb:
> Eike,
> For example:
>> Xxlu,
>> Cheers
>> /Eike
>>>>> model.
>>>>> your databases...
>>>>> Simon
>>>>> xxlu wrote:
>>>>>> Hi Ed,
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> What should I do?
<html>
<head>
http-equiv="Content-Type">
</head>
Xxlu,<br>
<br>
using the DBStore!):<br>
<br>
&lt;?xml version="1.0" encoding="UTF-8"?&gt;<br>
&lt;cdoServer&gt;<br>
Re: [CDO]Model update [message #425501 is a reply to message #425499] Fri, 28 November 2008 04:55 Go to previous message
------=_NextPart_000_014B_01C95182.73E9A4A0
charset="ISO-8859-15"
Content-Transfer-Encoding: quoted-printable
En...I think I must modify the EPackage's name.
"Eike Stepper" <stepper@esc-net.de>=20
Xxlu,
Please try the following option in the cdo-server.xml (given, you're =
<?xml version=3D"1.0" encoding=3D"UTF-8"?>
<cdoServer>
<repository name=3D"repo1">
<property name=3D"overrideUUID" =
value=3D"1ff5d226-b1f0-40fb-aba2-0c31b38c764f"/>
<property name=3D"supportingAudits" value=3D"true"/>
<property name=3D"verifyingRevisions" value=3D"false"/>
<property name=3D"currentLRUCapacity" value=3D"10000"/>
<property name=3D"revisedLRUCapacity" value=3D"100"/>
=20
<store type=3D"db">
<mappingStrategy type=3D"horizontal">
<property name=3D"qualifiedNames" value=3D"true"/>
<property name=3D"toManyReferences" =
value=3D"ONE_TABLE_PER_REFERENCE"/>
<property name=3D"toOneReferences" =
value=3D"LIKE_ATTRIBUTES"/>
</mappingStrategy>
See also: =
http://wiki.eclipse.org/CDO_Server_Configuration_Reference#P roperty_quali=
fiedNames
Cheers
/Eike
xxlu schrieb:=20
Eike,
But I think it's impossible to migrate the objects in the same =
schema.=20
For example:
test.ecroe V1 and test.ecore V2 both have classA. When excute =
migration,=20
Xxlu,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D256856
My comment 1 in this bugzilla explains a possible *manual* way to =
migrate=20
Cheers
/Eike
xxlu schrieb:
Shoud I rebuild a database, then use ecore2ecore or other methods =
migrate=20
Currently in CDO, a package with a given URI (X) should never be=20
If you follow this your objects will still be available using the old=20
model.
Does CDO should do more ? (Let me think about it during the night (it=20
Usually you will need to change the URI of your package.. and migrate=20
your databases...
Simon
xxlu wrote:
Hi Ed,
I have a problem that I can't resolve. I create a database for my=20
model with CDO2.0M3. When I update my model, for example, I add an=20
attribute for one class, I can't reload the old data from database.=20
java.lang.IllegalStateException: range.size() !=3D metaIDRange.size()
at=20
org.eclipse.emf.internal.cdo.CDOSessionImpl.registerEPackage (CDOSessionIm=
pl.java:544)
at=20
org.eclipse.emf.internal.cdo.util.CDOPackageRegistryImpl$Rem otePackageDes=
criptor.getEPackage(CDOPackageRegistryImpl.java:182)
at=20
org.eclipse.emf.ecore.impl.EPackageRegistryImpl.getEPackage( EPackageRegis=
tryImpl.java:133)
at=20
org.eclipse.emf.internal.cdo.CDOSessionPackageManagerImpl.lo adPackage(CDO=
at=20
org.eclipse.emf.cdo.internal.common.model.CDOPackageImpl.loa d(CDOPackageI=
mpl.java:401)
at=20
org.eclipse.emf.cdo.internal.common.model.CDOPackageImpl.loo kupClass(CDOP=
at=20
org.eclipse.emf.cdo.internal.common.model.CDOClassRefImpl.re solve(CDOClas=
sRefImpl.java:71)
at=20
org.eclipse.emf.cdo.internal.common.CDODataInputImpl.readCDO ClassRefAndRe=
at=20
org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl . <init>(CDORe=
at=20
org.eclipse.emf.cdo.internal.common.CDODataInputImpl.readCDO Revision(CDOD=
at=20
org.eclipse.emf.internal.cdo.protocol.LoadRevisionRequest.co nfirming(Load=
at=20
at=20
org.eclipse.emf.internal.cdo.protocol.CDOClientRequest.confi rming(CDOClie=
ntRequest.java:103)
at=20
org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedI nput(RequestW=
at=20
org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(R equestWithCon=
firmation.java:98)
at=20
org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalPr otocol.java:3=
92)
at=20
org.eclipse.net4j.signal.RequestWithConfirmation.send(Reques tWithConfirma=
tion.java:82)
at=20
tion.java:73)
at=20
org.eclipse.emf.internal.cdo.CDORevisionManagerImpl.send(CDO RevisionManag=
erImpl.java:149)
at=20
org.eclipse.emf.internal.cdo.CDORevisionManagerImpl.loadRevi sion(CDORevis=
at=20
org.eclipse.emf.cdo.internal.common.revision.CDORevisionReso lverImpl.getR=
at=20
at=20
org.eclipse.emf.internal.cdo.CDOViewImpl.getRevision(CDOView Impl.java:714=
at=20
org.eclipse.emf.internal.cdo.CDOViewImpl.createObject(CDOVie wImpl.java:85=
7)
at=20
at=20
org.eclipse.emf.internal.cdo.CDOTransactionImpl.getObject(CD OTransactionI=
mpl.java:449)
at=20
org.eclipse.emf.internal.cdo.CDOViewImpl.convertIDToObject(C DOViewImpl.ja=
va:1023)
at=20
at=20
org.eclipse.emf.ecore.impl.EStoreEObjectImpl$BasicEStoreELis t.delegateGet=
at=20
org.eclipse.emf.common.util.DelegatingEList.get(DelegatingEL ist.java:396)=
at=20
org.eclipse.emf.common.util.DelegatingEList$EIterator.doNext (DelegatingEL=
ist.java:1075)
at=20
org.eclipse.emf.common.util.DelegatingEList$EIterator.next(D elegatingELis=
t.java:1062)
at=20
org.eclipse.emf.edit.provider.ItemProviderAdapter.getChildre n(ItemProvide=
rAdapter.java:340)
at=20
org.eclipse.emf.edit.provider.ItemProviderAdapter.getElement s(ItemProvide=
rAdapter.java:310)
at=20
org.eclipse.emf.edit.ui.provider.AdapterFactoryContentProvid er.getElement=
What should I do?
=20
=20
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type =
content=3Dtext/html;charset=3DISO-8859-15>
<META content=3D"MSHTML 6.00.6000.16735" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY text=3D#000000 bgColor=3D#ffffff>
<DIV><FONT face=3D&#23435;&#20307; size=3D3>En...I think I must modify =
the EPackage's=20
name.</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; =
BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<DIV>"Eike Stepper" &lt;<A=20
href=3D"mailto:stepper@esc-net.de">stepper@esc-net.de</A>&gt;=20
</DIV>Xxlu,<BR><BR>Please try the following option in the =
cdo-server.xml=20
(given, you're using the DBStore!):<BR><BR>&lt;?xml version=3D"1.0"=20
encoding=3D"UTF-8"?&gt;<BR>&lt;cdoServer&gt; <BR>&nbsp;&nbsp;&nbsp;=20
&lt;repository name=3D"repo1"&gt;<BR>&nbsp;&nbsp;&nbsp; =
&lt;property name=3D"overrideUUID"=20
value=3D"1ff5d226-b1f0-40fb-aba2-0c31b38c764f"/&gt;<BR >&nbsp;&nbsp;&nbsp;=
=20
&nbsp;&nbsp;&nbsp; &lt;property name=3D"supportingAudits"=20
value=3D"true"/&gt;<BR>&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; =
&lt;property=20
name=3D"verifyingRevisions" value=3D"false"/&gt;<BR>&nbsp;&nbsp;&nbsp; =
&nbsp;&nbsp;&nbsp; &lt;property name=3D"currentLRUCapacity"=20
value=3D"10000"/&gt;<BR>&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; =
&lt;property=20
name=3D"revisedLRUCapacity" value=3D"100"/&gt;<BR>&nbsp;&nbsp;&nbsp;=20
&nbsp;&nbsp;&nbsp; <BR>&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &lt;store =
type=3D"db"&gt;<BR>&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; =
&lt;mappingStrategy type=3D"horizontal"&gt;<BR>&nbsp;&nbsp;&nbsp;=20
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; =
<U>&lt;property=20
name=3D"qualifiedNames" =
value=3D"<B>true</B>"/&gt;</U><BR>&nbsp;&nbsp;&nbsp;=20
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &lt;property=20
name=3D"toManyReferences"=20
value=3D"ONE_TABLE_PER_REFERENCE"/&gt;<BR>&nbsp;&nbsp;&nbsp; =
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; &lt;property =
name=3D"toOneReferences"=20
value=3D"LIKE_ATTRIBUTES"/&gt;<BR>&nbsp;&nbsp;&nbsp; =
&nbsp;&nbsp;&nbsp; &lt;/mappingStrategy&gt;<BR>[...]<BR><BR><BR>See =
also: <A=20
class=3Dmoz-txt-link-freetext=20
href=3D" http://wiki.eclipse.org/CDO_Server_Configuration_Reference#P roper=
ty_qualifiedNames">http://wiki.eclipse.org/CDO_Server_Configuration_Refer=
ence#Property_qualifiedNames</A><BR><BR>Cheers<BR>/Eike <BR><BR>----<BR><A=
=20
href=3D"http://thegordian.blogspot.com">http://thegordian.blogspot.com</A=
><BR><BR><BR><BR>xxlu=20
schrieb:=20
<BLOCKQUOTE cite=3Dmid:ggo8n5$cjf$1@build.eclipse.org =
type=3D"cite"><PRE wrap=3D"">Eike,
schema.=20
For example:
migration,=20
"Eike Stepper" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:stepper@esc-net.de">&lt;stepper@esc-net.de&gt;</A>
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Xxlu,
<A class=3Dmoz-txt-link-freetext =
href=3D"https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D256856">https://b=
ugs.eclipse.org/bugs/show_bug.cgi?id=3D256856</A>
migrate=20
Cheers
/Eike
xxlu schrieb:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Shoud I rebuild a =
database, then use ecore2ecore or other methods migrate=20
"xxlu" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:lu.xingxiao@gmail.com">&lt;lu.xingxiao@gmail.com&gt;</A>
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">I want to know how can =
"Simon McDuff" <A class=3Dmoz-txt-link-rfc2396E =
href=3D"mailto:smcduff@hotmail.com">&lt;smcduff@hotmail.com&gt;</A>
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">At the moment CDO =
model.
your databases...
Simon
xxlu wrote:
</PRE>
<BLOCKQUOTE type=3D"cite"><PRE wrap=3D"">Hi Ed,
at=20
pl.java:544)
at=20
at=20
tryImpl.java:133)
at=20
at=20
mpl.java:401)
at=20
at=20
sRefImpl.java:71)
at=20
at=20
org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl .&lt;init&gt;=
at=20
at=20
at=20
at=20
ntRequest.java:103)
at=20
at=20
firmation.java:98)
at=20
92)
at=20
tion.java:82)
at=20
tion.java:73)
at=20
erImpl.java:149)
at=20
at=20
at=20
at=20
at=20
7)
at=20
at=20
mpl.java:449)
at=20
va:1023)
at=20
at=20
at=20
at=20
ist.java:1075)
at=20
t.java:1062)
at=20
rAdapter.java:340)
at=20
rAdapter.java:310)
at=20
What should I do?
</PRE></BLOCKQUOTE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D"">
</PRE></BLOCKQUOTE></BLOCKQUOTE><PRE wrap=3D""><!---->
</PRE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_014B_01C95182.73E9A4A0--
Previous Topic:UUID with no resource available?
Next Topic:emf 2.3.1 plugins
Current Time: Sun Jul 27 09:40:29 EDT 2025
Powered by FUDForum. Page generated in 0.07034 seconds
