Home » Modeling » EMF » Existing genmodel not picked up
Existing genmodel not picked up [message #425201] Wed, 19 November 2008 07:51 Go to next message
Dear all,
I defined a UML profile, and generated code through ecore and a genmodel
description.
In plugin.xml, I have
<package
class="RCOSPrimitiveTypesPackageImpl"
genModel="libraries/RCOSPrimitiveTypes.library.genmodel"
uri="http://rcos.iist.unu.edu/RCOSPrimitiveTypes.ecore">
</package>
The URI is the same as in the .ecore-file. The corresponding UML file is
also exported. In the second Eclipse instance that uses this plugin, I
create a UML model that references the UML profile and I use one of the
defined datatypes as an attribute in a class.
When then I want to generate an EMF model from the UML file, the wizard
wants to create RCOSPrimitiveTypes.ecore in the current directory and
doesn't even offer me to select the one with the .genmodel defined
through the plugin!
After a day of struggling, I found that the wizard is actually looking
for a generated_package with URI http:///RCOSPrimitiveTypes.ecore (note
the missing host-part). The
UML->Ecore step produces an ecore file that doesn't reference the
existing package, but rather wants to produce a copy.
I'm glad for any suggestion on how to make EMF pick up the existing
files. I'm guessing there must be a way of specifying in the plugin
which ecore belongs to which UML file?
Volker
United Nations University -
Re: Existing genmodel not picked up [message #425207 is a reply to message #425201] Wed, 19 November 2008 08:51 Go to previous messageGo to next message
Volker,
Comments below.
Volker Stolz wrote:
> Dear all,
> description.
> <package
How can the class have no package qualification?
> </package>
I don't know much about profiles.
> through the plugin!
Did the plugin with the above registration successfully install in the
runtime environment?
I don't understand where http:///RCOSPrimitiveTypes.ecore would come from.
This sounds more like a UML2 question I've added their newsgroup to the
"to" list of the reply..
> Volker
Re: Existing genmodel not picked up [message #425212 is a reply to message #425207] Wed, 19 November 2008 11:11 Go to previous messageGo to next message
Some coments below ...
"Ed Merks" <Ed.Merks@gmail.com> wrote in message
news:gg15kk$jbf$1@build.eclipse.org...
> Volker,
> Comments below.
> Volker Stolz wrote:
>> Dear all,
>> description.
One doesn't typically generate code from a profile unless you intend on
using static profile definition. Please ensure that this is what you
intended.
Otherwise consider "defining" your profile.
>> <package
That doesn't look right ... how was this created?
>> </package>
>> through the plugin!
>> the missing host-part). The UML->Ecore step produces an ecore file that
>> doesn't reference the existing package, but rather wants to produce a
>> copy.
>> files. I'm guessing there must be a way of specifying in the plugin which
Perhaps attaching the files in question would help in getting to the bottom
of this.
A systematic way of reproducing the problem would also be helpful.
>> Volker
Re: Existing genmodel not picked up [message #425225 is a reply to message #425212] Thu, 20 November 2008 01:30 Go to previous message
In article <gg1doa$v5b$1@build.eclipse.org>,
> > Volker,
> > Comments below.
> > Volker Stolz wrote:
> >> Dear all,
> >> description.
> intended.
> >> <package
That was me cutting the qualification to shorten the line in this
article, sorry.
> of this.
Ed, James, thanks for your answers. It turned out that I didn't have the
Ecore::ePackage stereotype applied and thus couldn't pin down the nsURI.
Now I set it to http://rcos.iist.unu.edu/RCOSPrimitiveTypes.library.uml,
and it is preserved when generating the .ecore (I need the ecore to map
some of our primitive types to Java types). I also put this URI in the
generated_package-entry of plugin.xml and it is now picked up properly
in the 2nd Eclipse instance and everything works as expected.
James, as for the reason why we don't use a dynamic profile: we had some
trouble with duplicate Ecore annotations when you update the profile and
re-define it that went away when we switched to the generated
profile-code (and the references of stereotyped elements to the profile
would break). That's probably our fault for not using dynamic profiles
properly that I'll look into next now that this obstacle is sorted out.
Volker
Previous Topic:[Teneo/JPA] can an @EmbeddedId use type=xsd:IDREF?
Next Topic:Load portion of xml file
Current Time: Mon Jul 21 11:33:20 EDT 2025
Powered by FUDForum. Page generated in 0.14221 seconds
