[Teneo] Problem in using Named Queries [message #425194] |
Wed, 19 November 2008 04:45  |
Originally posted by: kalkar.prashant.gmail.com
I am working on an application using Teneo (v 0.8.0), hibernate and EMF.
The application model is generated from XML schema, and the hibernate
mapping file is generated by using teneo plugin in eclipse.
I am trying to use the Named queries in the application but I am getting
following exception:
org.hibernate.MappingException: Named query not known:
getCustomerEventsQuery
at
org.hibernate.impl.AbstractSessionImpl.getNamedQuery(Abstrac tSessionImpl.java:70)
at org.hibernate.impl.SessionImpl.getNamedQuery(SessionImpl.jav a:1260)
at
com.giki.server.service.impl.CalendarServiceImpl.getNamedEve ntQuery(CalendarServiceImpl.java:153)
at
com.giki.server.service.impl.CalendarServiceImpl.getCustomer Events(CalendarServiceImpl.java:74)
.... 24 more
I have defined the named query as follows in hibernate.hbm.xml file:
</hibernate-mapping>
<query name="getCustomerEventsQuery">
<![CDATA[
from EventType event where event.timeReceived >=:fromDate and
event.timeReceived <= :toDate and event.customer.userToken = :userToken
order by event.timeReceived
</query>
The query is correct and work properly when I used it to create
hibernate query object. I also tried to use the named queries in other
application using just hibernate (without teneo) it worked fine with
above steps.
Please help.
Prashant
Re: [Teneo] Problem in using Named Queries [message #425229 is a reply to message #425224] |
Thu, 20 November 2008 05:25   |
Hi Prashant,
There should be a class PersistenceOptions which should have an option like USE_MAPPING_FILE, you
have to set this option to "true" and pass it on to the datastore (setPersistenceProperties method).
The datastore is not a very big class, there is a piece of code which uses the above option and
calls another method to retrieve the hbm file and pass it on to the configuration object. There is a
utility method which is called whcih walks through the classpath of the model classes, so if your
generated model package is in org.my.model.package.impl then teneo will search here:
org.my.model
org.my
org
So your hibernate.hbm.xml should be in the above path somewhere.
Be sure to have the hibernate.hbm.xml checked in the build.properties so that it is copied to the
build path.
Btw, the exact naming of the methods I refer to maybe slightly different as I don't have the 0.8.0
source code directly available where I am now.
gr. Martin
Prashant Kalkar wrote:
> Hi Martin,
> Thanks for your reply.
> I am not generating the mapping file at runtime. I generate the mapping
> file using the eclipse Teneo plugin using the ecore file.
> How to direct teneo to use the mapping file? I just put the mapping file
> in the application classpath (in the source directory).
> Also can you tell me what option need to set in Teneo and how to set
> them? And how can I debug the datastore to find out the problem.
> I am using hibernate.properties file and its contents are as follows (it
> also present in the application source directory):
> hibernate.connection.driver_class=com.mysql.jdbc.Driver
> hibernate.connection.url=jdbc:mysql://127.0.0.1:3306/myapp
> hibernate.connection.username=<username>
> hibernate.connection.password=<password>
> hibernate.dialect=org.hibernate.dialect.MySQLDialect
> Following is the code used to create the hibernate session factory:
> final String dataStoreName = "dataStoreName";
> final HbDataStore dataStore =
> HbHelper.INSTANCE.createRegisterDataStore(dataStoreName);
> // Configure the EPackages used by this DataStore.
> dataStore.setEPackages(new EPackage[] {
> GikidocPackage.eINSTANCE });
> // Initialize the DataStore. This sets up the Hibernate
> mapping and
> // creates the corresponding tables in the database.
> dataStore.initialize();
> sessionFactory = dataStore.getSessionFactory();
> Please help me to resolve the issue.
> Thanks & Regards,
> Prashant
> Martin Taal wrote:
>> Hi Prashant,
>> If you direct Teneo to use a mapping file and not generate the mapping
>> at runtime then it just passes the hbm.xml directly on to Hibernate
>> without modifying it. So my first guess is that Teneo is not picking
>> up the mapping file. Did you set the correct option in Teneo? Can you
>> debug the datastore to see if it reads the mapping file and passes it
>> on to hibernate?
>> gr. Martin
>>> Hi,
>>> EMF. The application model is generated from XML schema, and the
>>> hibernate mapping file is generated by using teneo plugin in eclipse.
>>> getting following exception:
>>> at
>>> at
>>> at
>>> .... 24 more
>>> <![CDATA[
>>> :userToken order by event.timeReceived
>>> </query>
>>> other application using just hibernate (without teneo) it worked fine
>>> with above steps.
>>> Please help.
>>> Regards,
>>> Prashant
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Problem in using Named Queries [message #425298 is a reply to message #425229] |
Fri, 21 November 2008 23:52  |
Hi Martin,
It worked. I made the required changes in the code to initialize the
datastore and the application can now read the hibernate.hbm.xml file.
Thanks for your help.
Thanks & Regards,
Prashant
Martin Taal wrote:
> Hi Prashant,
> like USE_MAPPING_FILE, you have to set this option to "true" and pass it
> on to the datastore (setPersistenceProperties method). The datastore is
> option and calls another method to retrieve the hbm file and pass it on
> to the configuration object. There is a utility method which is called
> search here:
> org.my.model
> org.my
> org
> that it is copied to the build path.
> as I don't have the 0.8.0 source code directly available where I am now.
> gr. Martin
>> Hi Martin,
>> mapping file using the eclipse Teneo plugin using the ecore file.
>> file in the application classpath (in the source directory).
>> (it also present in the application source directory):
>> mapping and
>> Thanks & Regards,
>> Prashant
>> Martin Taal wrote:
>>> Hi Prashant,
>>> mapping at runtime then it just passes the hbm.xml directly on to
>>> Hibernate without modifying it. So my first guess is that Teneo is
>>> not picking up the mapping file. Did you set the correct option in
>>> Teneo? Can you debug the datastore to see if it reads the mapping
>>> file and passes it on to hibernate?
>>> gr. Martin
>>>> Hi,
>>>> at
>>>> at
>>>> at
>>>> .... 24 more
>>>> <![CDATA[
>>>> </query>
>>>> fine with above steps.
>>>> Please help.
>>>> Regards,
>>>> Prashant
FUDForum. Page generated in 0.29315 seconds
