Home » Modeling » EMF » Retrieve EditingModel from EObject
Retrieve EditingModel from EObject [message #425142] Sun, 16 November 2008 15:53 Go to next message
Originally posted by: nuclearpsyche.gmail.com
Is it possible to find out which EditingDomain a certain EObject belongs
to? (for example can I get the EditingDomain by only knowing the root
object?)
tamer
Re: Retrieve EditingModel from EObject [message #425143 is a reply to message #425142] Sun, 16 November 2008 19:47 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Tamer,
If you are working with a TransactionalEditingDomain, then you can use
TransactionUtil::getEditingDomain(EObject) to find your answer.
In a non-transactional editing domain, I don't think that there is
traceability from the ResourceSet to the EditingDomain, though. You
will need to know the workbench part that you're dealing with and adapt
it to IEditingDomainProvider to get the editing domain from it.
HTH,
Christian
Tamer wrote:
> Hello,
> object?)
> tamer
Re: Retrieve EditingModel from EObject [message #425169 is a reply to message #425143] Tue, 18 November 2008 01:54 Go to previous messageGo to next message
Guys,
You can use AdapterFactoryEditingDomain.getEditingDomainFor...
Christian W. Damus wrote:
> Hi, Tamer,
> adapt it to IEditingDomainProvider to get the editing domain from it.
> HTH,
> Christian
> Tamer wrote:
>> Hello,
>> belongs to? (for example can I get the EditingDomain by only knowing
>> the root object?)
>> Thanks,
>> tamer
Re: Retrieve EditingModel from EObject [message #425180 is a reply to message #425169] Tue, 18 November 2008 09:20 Go to previous messageGo to next message
Ah! The same adapter approach. Silly me; I should have looked more
closely.
cW
Ed Merks wrote:
> Guys,
-----8<-----
Re: Retrieve EditingModel from EObject [message #425217 is a reply to message #425143] Wed, 19 November 2008 17:20 Go to previous message
Thank you very much Christian,
That's exactly what I needed.
tamer
> Hi, Tamer,
> HTH,
> Christian
> Tamer wrote:
>> Hello,
>> the root object?)
>> Thanks,
>> tamer
Previous Topic:Exchanging templates for generation from GenModel
Next Topic:HibernateResource vs XmiResourceImpl performances ?
Current Time: Sun Jul 27 08:17:48 EDT 2025
Powered by FUDForum. Page generated in 0.04070 seconds
