Home » Modeling » EMF » Problem with unresolvable cross references
Problem with unresolvable cross references [message #425036] |
Thu, 13 November 2008 15:56  |
Originally posted by: eike.thaden.offis.de
I have a problem with cross references which are not resovable.
I have two resources (two distinct files in the same
directory): "Project4_with_Task_only.hrc":
<?xml version="1.0" encoding="ASCII"?>
<hrcK:System xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:hrcK="http://www.speeds.eu.com/2007/hrc/kernel"
name="Project4_with_Tasks_only">
<subPackage name="RhpProperties"/>
<subPackage name="Project4_with_Task_only">
<declared xsi:type="hrcK:RichComponent"
href="Project4_with_Task_only.SpeedSmoothing.hrc#/"/>
</subPackage>
</hrcK:System>
and "Project4_with_Task_only.SpeedSmoothing.hrc":
<hrcK:RichComponent xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
name="SpeedSmoothing">
<declarationZone xsi:type="hrcK:Package"
href="Project4_with_Tasks_only.hrc#//@subPackage.1"/>
</hrcK:RichComponent>
Starting with the RichComponent named "SpeedSmoothing", I can get its
subPackage by following the "declarationZone" href. But in this subPackage
I cannot follow the "declared" href back to the original RichComponent. Is
there a general problem with this?
Accidently (and for me unchangeable) the declared relation is a containment
relation. Does that maybe cause the problems with splitting the parts into
two resources?
Sorry for the quite bad explanation of the problem, but I don't know how to
better explain it.
Best regards
Eike
Re: Problem with unresolvable cross references [message #425049 is a reply to message #425038] |
Fri, 14 November 2008 06:53   |
Originally posted by: Eike.Thaden.offis.de
Ed Merks wrote:
> Eike,
> Comments below.
> Eike Thaden wrote:
>> Hello,
> So a nice relative reference to the root object of a file in the same
> folder...
>> </subPackage>
>> </hrcK:System>
> And a reference back...
>> subPackage I cannot follow the "declared" href back to the original
>> RichComponent. Is there a general problem with this?
> No, that should work.
>> containment relation. Does that maybe cause the problems with splitting
>> the parts into two resources?
> Is resolve proxies true for that reference? Did you set GenModel
> Containment Proxies to true?
There are other references between different resources where proxy
resolution works well (not contained in my example).
However the generated code for the "declared" reference looks like this:
public EList<ReusableElement> getDeclared() {
if (declared == null) {
declared = new
EObjectContainmentWithInverseEList<ReusableElement>(ReusableElement.class,
this, KernelPackage.DECLARATION_ZONE__DECLARED,
KernelPackage.REUSABLE_ELEMENT__DECLARATION_ZONE);
return declared;
There should be some proxy resolution code, right? If this is reason for all
my problems, I'll have to talk to those responsible for modeling in our
project...
>> to better explain it.
>> Best regards
>> Eike
Re: Problem with unresolvable cross references [message #425061 is a reply to message #425049] |
Fri, 14 November 2008 08:42   |
--------------080106040704090404000309
Eike,
Comments below.
Eike Thaden wrote:
> Ed Merks wrote:
>> Eike,
>> Comments below.
>> Eike Thaden wrote:
>>> Hello,
>> folder...
>>> </subPackage>
>>> </hrcK:System>
> declared = new
> return declared;
No, it would use EObjectContainmentWithInverseEList.Resolving.
> project...
I'm still not sure if I've fully understood the problem. I'm not sure
how you'd have proxies if the feature wouldn't try to resolve them.
>>> Best regards
>>> Eike
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Eike,<br>
<br>
Comments below.<br>
<br>
<br>
Eike Thaden wrote:
<blockquote cite="mid:gfjorv$u6u$1@build.eclipse.org" type="cite">
<pre wrap="">Ed Merks wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Eike,
Comments below.
Eike Thaden wrote:
</pre>
<pre wrap="">Hello,
<hrcK:System xmi:version="2.0" xmlns:xmi=<a class="moz-txt-link-rfc2396E" href="http://www.omg.org/XMI">"http://www.omg.org/XMI"</a>
xmlns:xsi=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema-instance">"http://www.w3.org/2001/XMLSchema-instance"</a>
xmlns:hrcK=<a class="moz-txt-link-rfc2396E" href="http://www.speeds.eu.com/2007/hrc/kernel">"http://www.speeds.eu.com/2007/hrc/kernel"</a>
</pre>
</blockquote>
<pre wrap="">So a nice relative reference to the root object of a file in the same
folder...
</pre>
<pre wrap=""> </subPackage>
</hrcK:System>
<hrcK:RichComponent xmi:version="2.0" xmlns:xmi=<a class="moz-txt-link-rfc2396E" href="http://www.omg.org/XMI">"http://www.omg.org/XMI"</a>
href=<a class="moz-txt-link-rfc2396E" href="mailto:Project4_with_Tasks_only.hrc#//@subPackage.1"> "Project4_with_Tasks_only.hrc#//@subPackage.1"</a>/>
</pre>
</blockquote>
<pre wrap="">And a reference back...
</pre>
<pre wrap=""></hrcK:RichComponent>
</pre>
</blockquote>
<pre wrap="">No, that should work.
</pre>
<pre wrap="">Accidently (and for me unchangeable) the declared relation is a
</pre>
</blockquote>
<pre wrap="">Is resolve proxies true for that reference? Did you set GenModel
</pre>
</blockquote>
<pre wrap=""><!---->There are other references between different resources where proxy
declared = new
EObjectContainmentWithInverseEList<ReusableElement&am p;gt;(ReusableElement.class,
return declared;
There should be some proxy resolution code, right? </pre>
</blockquote>
<pre wrap="">If this is reason for all
project...
</pre>
</blockquote>
how you'd have proxies if the feature wouldn't try to resolve them.<br>
<pre wrap="">
</pre>
<pre wrap="">Sorry for the quite bad explanation of the problem, but I don't know how
Best regards
Eike
</pre>
</blockquote>
</blockquote>
</pre>
</blockquote>
</body>
</html>
--------------080106040704090404000309--
Re: Problem with unresolvable cross references [message #425140 is a reply to message #425061] |
Sat, 15 November 2008 12:57  |
Ed Merks wrote:
> Eike,
> Comments below.
> Eike Thaden wrote:
>> Ed Merks wrote:
>>> Eike,
>>> Comments below.
>>> Eike Thaden wrote:
>>>> Hello,
>>> folder...
>>>> </subPackage>
>>>> </hrcK:System>
>> declared = new
>> return declared;
>> project...
I finally checked the genmodel file. The reason for my problems is obviously
that "Containment Proxies" was set to false. Thank you for your help. I
think I can now ask our model guys to fix that problem as soon as possible.
For EMF experts this bug is easy to find. But for beginners like me, it even
takes a long time to understand the basic concepts of EMF, especially the
proxy stuff. And if you are not directly involved in the modeling and code
generation part, you just see unexpected java behaviours when using the
generated code.
>>>> how to better explain it.
>>>> Best regards
>>>> Eike
Current Time: Sun Jul 20 21:29:14 EDT 2025
Powered by FUDForum. Page generated in 0.20634 seconds
