Home » Eclipse Projects » Subversive » Slow update from SVN
Slow update from SVN [message #41968] Wed, 18 February 2009 06:20 Go to next message
Our project recently switched from CVS to SVN, using subversive 0.7.3 and
eclipse 3.4.1. Project is large - ~20000 files. Still, command line update
from SVN takes 2-3 minutes while updating from eclipse takes 15 minutes
(even if the change is in 1 file). Running "kill -3" on eclipse shows that
it refreshes all resources after update (not sure, but looks like it...).
Is there a way to prevent this refresh / make it more quick? Even after
disabling "Compte deep outgoing state" - still no change.
Any help with this is greatly appreciated.
Re: Slow update from SVN [message #42202 is a reply to message #41968] Thu, 26 February 2009 05:45 Go to previous messageGo to next message
Hello Noam,
During update operation Subversive refreshes resources in order to reflect
changes from file system to workspace's resource tree and this is a
long-running operation. There's no way to prevent this action, but this
action provides a progress monitor and you can pass it to background. As a
workaround you can do synchronize and update only necessary files, but note
that you may have problems during future commits/updates because of folders'
revisions incompatibilities.
Re: Slow update from SVN [message #42333 is a reply to message #42202] Thu, 26 February 2009 08:17 Go to previous messageGo to next message
Igor Burilo napsal(a):
> Hello Noam,
Hi Igor,
and support Subversive eclipse's Spell Checking ?
Re: Slow update from SVN [message #42428 is a reply to message #42333] Thu, 26 February 2009 10:07 Go to previous messageGo to next message
> Hi Igor,
sry i have posted this in bad thread
Re: Slow update from SVN [message #42458 is a reply to message #42202] Thu, 26 February 2009 10:26 Go to previous messageGo to next message
Originally posted by: igor.ifedorenko.com
Igor,
There are couple of places where Subversive implementation is suboptimal.
I believe slow refresh after update is caused by inefficient
implementation of FileUtility#getPathNodes. It uses ArrayList#contains
method which is slow for large collections. Simply switching to HashSet
makes update much much faster (I am running patched version for several
months now).
The other problem I found is reported in bugzilla # 259287. This causes
problems with refresh from local filesystem after out-of-eclipse
changes. I did not have time to look if there is an easy fix, unfortunately.
Igor
Igor Burilo wrote:
> Hello Noam,
Re: Slow update from SVN [message #42489 is a reply to message #42458] Fri, 27 February 2009 03:50 Go to previous messageGo to next message
Hello Igor,
I'll check it. I added your comments to bug #259287. Thanks for your help.
> Igor,
> months now).
> problems with refresh from local filesystem after out-of-eclipse changes.
> Regards,
> Igor
> Igor Burilo wrote:
>> Hello Noam,
>> reflect changes from file system to workspace's resource tree and this is
>> a long-running operation. There's no way to prevent this action, but this
>> a workaround you can do synchronize and update only necessary files, but
>> note that you may have problems during future commits/updates because of
>> folders' revisions incompatibilities.
>>> and eclipse 3.4.1. Project is large - ~20000 files. Still, command line
>>> update from SVN takes 2-3 minutes while updating from eclipse takes 15
>>> minutes (even if the change is in 1 file). Running "kill -3" on eclipse
>>> shows that it refreshes all resources after update (not sure, but looks
>>> like it...). Is there a way to prevent this refresh / make it more
>>> quick? Even after disabling "Compte deep outgoing state" - still no
>>> change.
Re: Slow update from SVN [message #42686 is a reply to message #42489] Fri, 27 February 2009 09:50 Go to previous message
Sorry, looks like I was not clear enough. There are at least two
separate performance problems.
I do not have a solution for problem described in #259287
(SVNRemoteStorage#refreshLocalResourceImpl).
I have possible solution for another problem in
FileUtility#getPathNodes. I've opened new #266492 to track and attached
proposed fix to the bug.
Igor
Igor Burilo wrote:
> Hello Igor,
>> Igor,
>> months now).
>> Regards,
>> Igor
>> Igor Burilo wrote:
>>> Hello Noam,
>>>> change.
Previous Topic:Eclipse bug 264772: Synchronization empties outgoing changes if SVN Changesets model is selected
Next Topic:Feature Request: Password saving for a session or timeout
Current Time: Sat Jul 26 19:08:50 EDT 2025
Powered by FUDForum. Page generated in 0.04249 seconds
