Home » Modeling » EMF » Building UML2-approximated Model in EMF
Building UML2-approximated Model in EMF [message #424074] Wed, 15 October 2008 15:20 Go to next message
Hi all,
i've a question concerning the generation of an Ecore model from an UML
model. How are features like Subsets and Union realized during the
converting mechanism from UML to Ecore?
Here is a concrete scenario:
In my department, i have to adopt a complete UML Class model, defined in
MagicDraw with subsets, unions and redefinitions, and have to create an
EMF-Model out of it. MagicDraw provides a good exporter to EMF, that's not
the problem. But how are the subsets and union features are treated during
the process of converting it to an Ecore and generating an genmodel and of
course the sources. I hoped, that the converte would produce something
similiar to the UML2-API for my specific metamodel.
In the wonderful article from Ken Hussey
https://bugs.eclipse.org/bugs/attachment.cgi?id=55337 there is explained,
that EMF doesn't support these concepts. However, fro the UML2-Project, it
seems, that the subsets/union-things are working. Currently, i'm a bit
confusing of the topic.
Thx
Timothy
Re: Building UML2-approximated Model in EMF [message #424077 is a reply to message #424074] Wed, 15 October 2008 16:22 Go to previous messageGo to next message
Originally posted by: cdamus.zeligsoft.com
Hi, Timothy,
All of this is implemented by the UML2 project in a layer on top of the
EMF run-time and code-generation components.
The UML2 project defines a custom EList mini-framework, in the
org.eclipse.uml2 plug-in, for subsetting, derived unions, and derived
subsets. See, for example, the SubsetSupersetEObjectEList and
DerivedUnionEObjectEList classes.
For redefinitions, there are two cases. In the case that the redefining
property has has a different name than all of the redefined properties,
UML2's conversion to Ecore can create a corresponding EStructuralFeature
in the specializing EClass. This EStructuralFeature is decorated with
an EAnnotation that references the EStructuralFeatures corresponding to
the redefined properties.
In the case that the redefining property does have the same name as any
of the redefined properties, UML2 cannot create a corresponding
EStructuralFeature in the specializing EClass. Instead, it creates an
EAnnotation and adds the EStructuralFeature to it, in its contents list.
The annotation referencing the redefined features is as in the first
case.
I think I got this right ... I am including the UML2 newsgroup in my
reply for their input.
Christian
Timothy Marc wrote:
> Hi all,
> Thx
> Timothy
Re: Building UML2-approximated Model in EMF [message #424098 is a reply to message #424077] Thu, 16 October 2008 07:28 Go to previous messageGo to next message
Dear Christian,
so the EMF code generator ignores all the UML2 special things, when it
converts my model, that make use of these concepts, into an Ecore model? Is
this right?
But i need those crucial functionality, and i guess, that it is possible to
reuse the UML2 code generator instead of the EMF default one in some way?
Does anyone has some experiences with this?
Thx
Timothy
"Christian W. Damus" <cdamus@zeligsoft.com> schrieb im Newsbeitrag
news:gd5jdv$79p$1@build.eclipse.org...
> Hi, Timothy,
> in the specializing EClass. This EStructuralFeature is decorated with an
> EAnnotation that references the EStructuralFeatures corresponding to the
> In the case that the redefining property does have the same name as any of
> The annotation referencing the redefined features is as in the first case.
> I think I got this right ... I am including the UML2 newsgroup in my reply
> for their input.
> Cheers,
> Christian
> Timothy Marc wrote:
>> Hi all,
>> not the problem. But how are the subsets and union features are treated
>> during the process of converting it to an Ecore and generating an
>> genmodel and of course the sources. I hoped, that the converte would
>> produce something similiar to the UML2-API for my specific metamodel.
>> it seems, that the subsets/union-things are working. Currently, i'm a bit
>> Thx
>> Timothy
Re: Building UML2-approximated Model in EMF [message #424099 is a reply to message #424098] Thu, 16 October 2008 09:09 Go to previous messageGo to next message
Hi, Timothy,
That's right, it is the templates provided by UML2-n codegen extensions
that have the knowledge of these custom run-time bits. It wouldn't make
sense for EMF to have dependencies on UML-isms.
You will need to use the UML2 code generation instead of EMF. It should
be re-usable in your context in the same way as EMF's code generator,
though I wouldn't know the details of that ...
Christian
Timothy Marc wrote:
> Dear Christian,
> this right?
> Thx
> Timothy
>> Hi, Timothy,
>> for their input.
>> Cheers,
>> Christian
>> Timothy Marc wrote:
>>> Hi all,
>>> Thx
>>> Timothy
Re: Building UML2-approximated Model in EMF [message #424108 is a reply to message #424099] Thu, 16 October 2008 11:18 Go to previous messageGo to next message
Hey,
it is me again.
Now, i'm really confused because it seems, that the generation of these UML
concepts work. I've created an EMF Project, pointed to the UML model and
generated an genmodel out of that. The resulting Ecore model provides all
the union, subsets as EAnnotations. After generating the code, i found that
EReferences that subsets another one, return a SubsetSupersetEList.
I've tested it with a little JUnit Test, and it seems to work fine....
however?!
Timothy
news:gd7eer$t3u$1@build.eclipse.org...
> Hi, Timothy,
> Cheers,
> Christian
> Timothy Marc wrote:
>> Dear Christian,
>> Is this right?
>> to reuse the UML2 code generator instead of the EMF default one in some
>> way? Does anyone has some experiences with this?
>> Thx
>> Timothy
>>> Hi, Timothy,
>>> case.
>>> Cheers,
>>> Christian
>>> Timothy Marc wrote:
>>>> Hi all,
>>>> in MagicDraw with subsets, unions and redefinitions, and have to create
>>>> an EMF-Model out of it. MagicDraw provides a good exporter to EMF,
>>>> that's not the problem. But how are the subsets and union features are
>>>> treated during the process of converting it to an Ecore and generating
>>>> an genmodel and of course the sources. I hoped, that the converte would
>>>> explained, that EMF doesn't support these concepts. However, fro the
>>>> UML2-Project, it seems, that the subsets/union-things are working.
>>>> Currently, i'm a bit confusing of the topic.
>>>> Thx
>>>> Timothy
Re: Building UML2-approximated Model in EMF [message #424110 is a reply to message #424108] Thu, 16 October 2008 11:30 Go to previous message
Hi, Timothy,
That's because, when you imported your genmodel from UML, EMF discovered
the UML2 project's extensions to the code generation framework via the
registered UML model importer.
If you had first converted the UML model to Ecore and then imported your
genmodel from that using the Ecore importer, then you would have gotten
the default Ecore code generation.
Christian
Timothy Marc wrote:
> Hey,
> it is me again.
> however?!
> Timothy
>> Hi, Timothy,
>> Cheers,
>> Christian
>> Timothy Marc wrote:
>>> Dear Christian,
>>> Is this right?
>>> Thx
>>> Timothy
>>>> Hi, Timothy,
>>>> case.
>>>> Cheers,
>>>> Christian
>>>> Timothy Marc wrote:
>>>>> Hi all,
>>>>> Thx
>>>>> Timothy
Previous Topic:Supressing notifications for individual attributes and maps?
Next Topic:AbstractTreeIterator is both Iterator and Collection
Current Time: Wed Nov 05 10:57:13 EST 2025
Powered by FUDForum. Page generated in 0.03678 seconds
