Home » Modeling » EMF » One-to-one references in Teneo 1.0.1
One-to-one references in Teneo 1.0.1 [message #423824] Tue, 07 October 2008 11:15 Go to next message
I have two objects referencing each other. The reference in both of them
has lower bound and upper bound set to 1. Also, EOpposite is set to the
referenced object in both references.
With Teneo 1.0.0 in Eclipse 3.4.0 this worked fine, but after updating to
Eclipse 3.4.1 and Teneo 1.0.1 I get this error:
3819 [main] DEBUG org.hibernate.util.JDBCExceptionReporter - could not
insert: [ToolComposite] [insert into "myobject1" (e_id, e_version, "name",
"dtype") values (null, ?, ?, 'MyObjects')]
java.sql.SQLException: Attempt to insert null into a non-nullable column:
column: MYOBJECT2 table: myobject1 in statement [insert into "myobject1"
(e_id, e_version, "name", "dtype") values (null, ?, ?, 'MyObjects')]
at org.hsqldb.jdbc.Util.throwError(Unknown Source)
at org.hsqldb.jdbc.jdbcPreparedStatement.executeUpdate(Unknown Source)
at
org.hibernate.id.insert.AbstractSelectingDelegate.performIns ert(AbstractSelectingDelegate.java:57)
at
org.hibernate.persister.entity.AbstractEntityPersister.inser t(AbstractEntityPersister.java:2186)
at
org.hibernate.persister.entity.AbstractEntityPersister.inser t(AbstractEntityPersister.java:2666)
at
org.hibernate.action.EntityIdentityInsertAction.execute(Enti tyIdentityInsertAction.java:71)
at org.hibernate.engine.ActionQueue.execute(ActionQueue.java:27 9)
at
org.hibernate.event.def.AbstractSaveEventListener.performSav eOrReplicate(AbstractSaveEventListener.java:321)
at
org.hibernate.event.def.AbstractSaveEventListener.performSav e(AbstractSaveEventListener.java:204)
at
org.hibernate.event.def.AbstractSaveEventListener.saveWithGe neratedId(AbstractSaveEventListener.java:130)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.sav eWithGeneratedOrRequestedId(DefaultSaveOrUpdateEventListener .java:210)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.ent ityIsTransient(DefaultSaveOrUpdateEventListener.java:195)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.per formSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:117)
at
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.onS aveOrUpdate(DefaultSaveOrUpdateEventListener.java:93)
at org.hibernate.impl.SessionImpl.fireSaveOrUpdate(SessionImpl. java:534)
at org.hibernate.impl.SessionImpl.saveOrUpdate(SessionImpl.java :526)
at org.hibernate.impl.SessionImpl.saveOrUpdate(SessionImpl.java :522)
at
org.eclipse.emf.teneo.hibernate.HbSessionWrapper.saveOrUpdat e(HbSessionWrapper.java:161)
at
A comparison of the database schemes generated by Teneo shows, that the
foreign key field is generated in the table for myobject1 in Teneo 1.0.1,
whereas the reference was the other way round in Teneo 1.0.0.
Did I find a new bug in Teneo here, or am I doing something wrong?
Roland
Re: One-to-one references in Teneo 1.0.1 [message #423839 is a reply to message #423824] Tue, 07 October 2008 15:18 Go to previous messageGo to next message
Hi Roland,
Indeed the mapping of the one-to-one has changed since 1.0.0, before it was not working correctly in
some cases. You can influence the location of the foreign key by setting a
@OneToOne(mappedBy="otherside") on one side, then the foreign key will be placed on the other side.
Regarding your exception, I have seen this before in the following situation. Hibernate first saves
a set of objects with the foreign key fields set to null, even for fk fields which are mandatory.
Then when the objects are saved and the ids are determined an update is used to update the foreign
key fields. However often Hibernate is smart enough to do the persist in the correct order and then
this saving with null is not happening.
How does the mapping look like for the one-to-ones on both sides?
gr. Martin
Roland Brand wrote:
> to Eclipse 3.4.1 and Teneo 1.0.1 I get this error:
> column: column: MYOBJECT2 table: myobject1 in statement [insert into
> "myobject1" (e_id, e_version, "name", "dtype") values (null, ?, ?,
> 'MyObjects')]
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at [...]
> 1.0.1, whereas the reference was the other way round in Teneo 1.0.0.
> Roland
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: One-to-one references in Teneo 1.0.1 [message #423877 is a reply to message #423839] Wed, 08 October 2008 11:00 Go to previous messageGo to next message
Hi Martin
This is exactly, what is happening. The exception is thrown, because the
fk field is declared as non-null.
In the hibernate mapping, which is generated by EMF, I see, that the
relationship is declared as many-to-one in one direction and as one-to-one
in the other direction.
<subclass name="MyObject1" ...>
<many-to-one name="myobject2" entity-name="MyObject2"
cascade="merge,persist,save-update,lock,refresh" not-null="true"
lazy="false" insert="true" update="true"/>
</subclass>
<subclass name="MyObject2" ...>
<one-to-one name="myobjectt1" entity-name="MyObject1"
cascade="merge,persist,save-update,lock,refresh" lazy="false"
property-ref="myobject2" constrained="true"/>
</subclass>
Is this the expected mapping?
Thanks for your help.
Roland
Re: One-to-one references in Teneo 1.0.1 [message #423889 is a reply to message #423877] Wed, 08 October 2008 20:58 Go to previous messageGo to next message
Hi Roland,
Yes this is the correct mapping for a non-pk one-to-one. You can influence where the many-to-one is
placed by setting a @OneToOne(mappedBy="theotherefeature") on one side, then the many-to-one will be
on the other side (which does not have the mappedBy defined).
gr. Martin
Roland Brand wrote:
> Hi Martin
>> fields
>> is used
>> in the
> one-to-one in the other direction.
> </subclass>
> </subclass>
> Roland
The Netherlands
Re: One-to-one references in Teneo 1.0.1 [message #423900 is a reply to message #423889] Thu, 09 October 2008 07:18 Go to previous messageGo to next message
Hi Martin
Adding the annotation you mentioned solved the problem for this special
case. But now a non-null reference field was generated in the database.
This leads to new problems when I try to save other objects derived from
the same super-class.
It looks like one-to-one references are possible with inheritance mapping
set to the default value SINGLE_TABLE.
Greetings, Roland
Re: One-to-one references in Teneo 1.0.1 [message #423901 is a reply to message #423900] Thu, 09 October 2008 07:28 Go to previous messageGo to next message
Hi Roland,
Yes with single table, all columns from subtypes are made nullable...
gr. Martin
Roland Brand wrote:
> Hi Martin
> mapping set to the default value SINGLE_TABLE.
> Greetings, Roland
The Netherlands
Re: One-to-one references in Teneo 1.0.1 [message #423904 is a reply to message #423901] Thu, 09 October 2008 07:57 Go to previous messageGo to next message
Oh sorry, an important NOT is missing in my sentence. It seems like
one-to-one references are NOT possible in single table.
This is, what I would have expected, but it is declared non-null in the
database.
Greets, Roland
Re: One-to-one references in Teneo 1.0.1 [message #423911 is a reply to message #423904] Thu, 09 October 2008 11:00 Go to previous messageGo to next message
Yes that makes a difference :-), does it work in case of join table inheritance strategy?
Because then this error is related on how the inheritance mapping is done and not on how hibernate
works with nullable references.
gr. Martin
> database.
> Greets, Roland
The Netherlands
Re: One-to-one references in Teneo 1.0.1 [message #423930 is a reply to message #423911] Fri, 10 October 2008 02:58 Go to previous message
Hi Martin
Yes it works with join tables. I have some other exceptions then, but I
don't know yet, if the new ones are related to teneo.
Greets, Roland
Previous Topic:[CDO] Duplicate ID problem – Can a CDO model have multiple non-containment references to an external
Next Topic:[CDO 1.0] CDOInvalidationNotification
Current Time: Sun Jul 27 03:25:18 EDT 2025
Powered by FUDForum. Page generated in 0.05028 seconds
