Home » Modeling » EMF » [CDO] SQLException when loading cross CDO models
[CDO] SQLException when loading cross CDO models [message #423825] Tue, 07 October 2008 11:36 Go to next message
I have two CDO models and they are different models (different kinds of objects in them, not just
different instances of the same model). Model One has a non-containment reference to an object in
Model Two. I can save and load Model One without problem, but if I try to access the node that has
the reference to an object in Model Two I get this exception:
[ERROR] java.sql.SQLException: Invalid character string format for type long.
org.eclipse.net4j.db.DBException: java.sql.SQLException: Invalid character string format for type long.
at org.eclipse.emf.cdo.server.internal.db.MappingStrategy.readR esourceInfo(MappingStrategy.java:330)
at org.eclipse.emf.cdo.server.internal.db.MappingStrategy.readR esourcePath(MappingStrategy.java:284)
at org.eclipse.emf.cdo.server.internal.db.DBStoreReader.readRes ourcePath(DBStoreReader.java:283)
at org.eclipse.emf.cdo.internal.server.ResourceManager.loadPath (ResourceManager.java:98)
at org.eclipse.emf.cdo.internal.server.ResourceManager.getResou rcePath(ResourceManager.java:68)
at
org.eclipse.emf.cdo.internal.server.protocol.ResourcePathInd ication.indicating(ResourcePathIndication.java:52)
at org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:46)
at org.eclipse.emf.cdo.internal.server.protocol.CDOReadIndicati on.execute(CDOReadIndication.java:38)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:143)
at org.eclipse.net4j.signal.Signal.run(Signal.java:124)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:665)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:690)
at java.lang.Thread.run(Thread.java:810)
Caused by: java.sql.SQLException: Invalid character string format for type long.
at org.apache.derby.impl.jdbc.SQLExceptionFactory.getSQLExcepti on(Unknown Source)
at org.apache.derby.impl.jdbc.Util.generateCsSQLException(Unkno wn Source)
at org.apache.derby.impl.jdbc.TransactionResourceImpl.wrapInSQL Exception(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedResultSet.noStateChangeExcep tion(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedResultSet.getLong(Unknown Source)
at org.eclipse.emf.cdo.server.internal.db.MappingStrategy.readR esourceInfo(MappingStrategy.java:325)
... 12 more
Caused by: ERROR 22018: Invalid character string format for type long.
at org.apache.derby.iapi.error.StandardException.newException(U nknown Source)
at org.apache.derby.iapi.types.SQLChar.getLong(Unknown Source)
... 14 more
However, it all works correctly, if I load the referenced object in Model Two (by means of an editor
for Model Two) before I access the node in Model One with the reference.
It seems the problem is that CDO doesn't correctly load object across models unless the object has
already been loaded by some other means.
Is there something I can do to ensure that Model One will correctly load the referenced object in
Model Two even if Model Two hasn't been "preloaded"?
Also, should I open a bug report on this problem? Or is this the same as
https://bugs.eclipse.org/bugs/show_bug.cgi?id=244000 ?
Thanks for your help!
Sincerely,
Stephen McCants
Re: [CDO] SQLException when loading cross CDO models [message #423828 is a reply to message #423825] Tue, 07 October 2008 12:26 Go to previous messageGo to next message
Hi Steven,
From the stack trace I get the impression that you are not using the
latest sources, right? (MappingStrategy.readResourceInfo() does not
exist anymore)
Since Ganymede we have resolved approximately 100 Bugzillas, some also
in the maintenance branch, but most of them in HEAD.
Can you please tell which version exactly you are using? And is it
possible that you also try your use case with the HEAD sources or a late
2.0 I-build?
Btw. the Bugzilla you mentioned is an EMFT Compare bug. I don't see any
relation with CDO.
Generally (in both CDO streams) inter-resource cross references are
supported.
Cheers
/Eike
Stephen McCants schrieb:
> Hello,
> of objects in them, not just different instances of the same model).
> Model One has a non-containment reference to an object in Model Two.
> the node that has the reference to an object in Model Two I get this
> exception:
> type long.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> type long.
> at
> Source)
> Source)
> at
> Source)
> at
> Source)
> at
> ... 12 more
> at
> Source)
> ... 14 more
> Model Two (by means of an editor for Model Two) before I access the
> models unless the object has already been loaded by some other means.
> load the referenced object in Model Two even if Model Two hasn't been
> "preloaded"?
> as https://bugs.eclipse.org/bugs/show_bug.cgi?id=244000 ?
> Sincerely,
> Stephen McCants
Re: [CDO] SQLException when loading cross CDO models [message #423921 is a reply to message #423828] Thu, 09 October 2008 17:30 Go to previous message
Hello Eike,
> And is it
> 2.0 I-build?
We pulled the source from HEAD about two days ago and that resolved the problem. Thanks so much for
your help!
Sincerely,
Stephen McCants
Previous Topic:feature change notification fails while using transactional editing domain
Next Topic:[CDO] Duplicate ID problem – Can a CDO model have multiple non-containment references to an external
Current Time: Sat Jul 26 08:49:27 EDT 2025
Powered by FUDForum. Page generated in 0.04107 seconds
