Home » Modeling » EMF » EMF Stand-alone main application
EMF Stand-alone main application [message #423565] |
Thu, 02 October 2008 08:20  |
i tried to load my XML-File which based on EMF Model in a stand-alone
apllication. The apllication is a simple Java main programm.
With EMF 2.3 all works fine now with EMF 2.4.1 it doesnt work.
What did i wrong? Big thanks for you help
Code:
URI fileURI = null;
if(file != null) {
fileURI = URI.createFileURI(new File(file).getAbsolutePath()); }else {
return null;
Resource poResource = null;
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().
put(Resource.Factory.Registry.DEFAULT_EXTENSION,
new XYZBuildResourceFactoryImpl());
resourceSet.getPackageRegistry().put(XYZBuildPackage.eNS_URI ,
TSMBuildPackage.eINSTANCE);
try {
poResource = resourceSet.getResource(fileURI, true);
docRoot = (DocumentRoot) poResource.getContents().get(0);
} catch (Exception ex) {
System.out.println(ex.toString());
I become this Exeception:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException:
org.xml.sax.SAXNotRecognizedException: Feature:
http://xml.org/sax/properties/lexical-handler
Re: EMF Stand-alone main application [message #423803 is a reply to message #423789] |
Tue, 07 October 2008 07:13   |
--------------070605000009060604030405
As I said, the exception looks to me like an issue related to the JAXP
implementation you have installed as part of the JR. If you follow the
stack trace for this exception
you'll see that EMF is trying to set up a lexical handler on the SAX
parser. That should just work, and clearly works most of the time (all
the time in my experience) except in this stand-alone environment your
running. What JRE are you using?
exquisitus wrote:
> Thanks for the quick answer. But I use the code from the generated
> Example but it still doesnt work. I get a acception from SAX.
> I my GUI all works fine. I use a xml-File with a dtd file which
> contains Entities. Maybe this is the problem. How can i set some load
> options?
> Thanks
> Load:
> URI fileURI fileURI = URI.createFileURI(new
> new TSMBuildResourceFactoryImpl());
> resourceSet.getPackageRegistry().put(TSMBuildPackage.eNS_URI ,
> try {
> Resource resource = resourceSet.getResource(fileURI, true);
> } catch (RuntimeException exception) {
> Ed Merks schrieb:
>> Comments below.
>> exquisitus wrote:
>>> Hi
>>> stand-alone apllication. The apllication is a simple Java main
>>> programm.
>> Is it just like the one that's generated if you invoke "Generate Test
>> Code" and look at the generated XyzExample.java?
>>> Code:
>>> URI fileURI = null;
>>> if(file != null) {
>>> }else {
>>> return null;
>>> try {
>> This sounds like an issue related to the JRE you are using not
>> directly an EMF issue.
<html>
<head>
http-equiv="Content-Type">
</head>
Re: EMF Stand-alone main application [message #423807 is a reply to message #423805] |
Tue, 07 October 2008 07:56   |
--------------020301020201050608050200
It sounds like it should be fine, but clearly it isn't. Given you have
both a context where it works and one where it doesn't, and you have a
stack trace for the point of failure, you're the one in the best
position to figure out why it would work in one case but not the other.
I seems to me this exception implies your JAXP implementation doesn't
support lexical handlers so you might look at the implement class being
used to implement the SAXParser interface in each case. You might try
this option to avoid needing lexical handler support:
* Determines whether comments and CDATA will be preserved in any
mixed text processing.
* This option is applicable for loading XML resources (from DOM
node or an InputStream)
String OPTION_USE_LEXICAL_HANDLER = "USE_LEXICAL_HANDLER";
exquisitus wrote:
> My Enviorment is
> Eclipse 3.4 with EMF 2.4.1
> Java Version is latest 1.5 Version (1.5.0_15-b04)
>> JAXP implementation you have installed as part of the JR. If you
>> follow the stack trace for this exception
>> (all the time in my experience) except in this stand-alone
>> environment your running. What JRE are you using?
>>> load options?
>>> Thanks
>>> Load:
>>> try {
>>> Ed Merks schrieb:
>>>> Comments below.
>>>> exquisitus wrote:
>>>>> Hi
>>>>> programm.
>>>> Test Code" and look at the generated XyzExample.java?
>>>>> Code:
>>>>> URI fileURI = null;
>>>>> if(file != null) {
>>>>> return null;
>>>>> try {
<html>
<head>
</head>
Re: EMF Stand-alone main application [message #423811 is a reply to message #423807] |
Tue, 07 October 2008 08:13   |
First big big thanks. I tried to use my load options for the
editingDomain but i dont know to get it run?
try {
Resource resource = null;
Map options = new HashMap();
options.put(XMLResource.OPTION_EXTENDED_META_DATA, Boolean.TRUE);
options.put(XMLResource.OPTION_USE_ENCODED_ATTRIBUTE_STYLE, Boolean.TRUE);
options.put(XMLResource.OPTION_USE_LEXICAL_HANDLER, Boolean.TRUE);
try {
resource.load(options);
resource.resourceSet.getResource(fileURI, true);
} catch (IOException e) {
This wont work because resource is null. So how can i set the load
options? Must i use a XMLMap?
> exquisitus wrote:
>> My Enviorment is
>>>> load options?
>>>> Thanks
>>>> Load:
>>>> try {
>>>> Ed Merks schrieb:
>>>>> Comments below.
>>>>> exquisitus wrote:
>>>>>> Hi
>>>>>> programm.
>>>>>> Code:
>>>>>> URI fileURI = null;
>>>>>> if(file != null) {
>>>>>> return null;
>>>>>> try {
Re: EMF Stand-alone main application [message #423812 is a reply to message #423811] |
Tue, 07 October 2008 08:29   |
Mike,
Typically you set options in the resource factory that's used to create
the resource, but a resource set also getLoadOptions that will be
applied to all resources demand loaded in that resource set. Don't
specify more options than you actually need. You wanted to try
Boolean.FALSE for the lexical handler right?
> try {
> Boolean.TRUE);
> try {
>> have both a context where it works and one where it doesn't, and you
>> have a stack trace for the point of failure, you're the one in the
>> best position to figure out why it would work in one case but not the
>> other. I seems to me this exception implies your JAXP implementation
>> doesn't support lexical handlers so you might look at the implement
>> class being used to implement the SAXParser interface in each case.
>> You might try this option to avoid needing lexical handler support:
>> exquisitus wrote:
>>> My Enviorment is
>>>> SAX parser. That should just work, and clearly works most of the
>>>> time (all the time in my experience) except in this stand-alone
>>>>> load options?
>>>>> Thanks
>>>>> Load:
>>>>> try {
>>>>> Ed Merks schrieb:
>>>>>> Comments below.
>>>>>> exquisitus wrote:
>>>>>>> Hi
>>>>>>> programm.
>>>>>>> Code:
>>>>>>> URI fileURI = null;
>>>>>>> if(file != null) {
>>>>>>> return null;
>>>>>>> try {
Re: EMF Stand-alone main application [message #423814 is a reply to message #423812] |
Tue, 07 October 2008 08:44   |
I change OPTION_USE_LEXICAL_HANDLER in the
XYZBuildResourceFactoryImpl() to False. Works fine now. Thanks.
But cant i set the load optins in my Standalone Application? A
code Example would be useful?
Again big thanks
Ed Merks schrieb:
> Mike,
>> try {
>> Boolean.TRUE);
>> Boolean.TRUE);
>> try {
>>> exquisitus wrote:
>>>> My Enviorment is
>>>>>> load options?
>>>>>> Thanks
>>>>>> Load:
>>>>>> try {
>>>>>> Ed Merks schrieb:
>>>>>>> Comments below.
>>>>>>> exquisitus wrote:
>>>>>>>> Hi
>>>>>>>> programm.
>>>>>>>> Code:
>>>>>>>> URI fileURI = null;
>>>>>>>> if(file != null) {
>>>>>>>> return null;
>>>>>>>> try {
Re: EMF Stand-alone main application [message #423815 is a reply to message #423814] |
Tue, 07 October 2008 08:59   |
Mike,
Using
resourceSet.getLoadOptions().put(XMLResource.OPTION_USE_LEXI CAL_HANDLER,
Boolean.FALSE) should do the trick.
> Again big thanks
> Ed Merks schrieb:
>> Mike,
>> create the resource, but a resource set also getLoadOptions that will
>> be applied to all resources demand loaded in that resource set.
>> Don't specify more options than you actually need. You wanted to try
>>> try {
>>> Boolean.TRUE);
>>> Boolean.TRUE);
>>> try {
>>>> you have a stack trace for the point of failure, you're the one in
>>>> the best position to figure out why it would work in one case but
>>>> not the other. I seems to me this exception implies your JAXP
>>>> implementation doesn't support lexical handlers so you might look
>>>> at the implement class being used to implement the SAXParser
>>>> interface in each case. You might try this option to avoid
>>>> any
>>>> exquisitus wrote:
>>>>> My Enviorment is
>>>>>>> generated Example but it still doesnt work. I get a acception
>>>>>>> from SAX.
>>>>>>> load options?
>>>>>>> Thanks
>>>>>>> Load:
>>>>>>> try {
>>>>>>> Ed Merks schrieb:
>>>>>>>> Comments below.
>>>>>>>> exquisitus wrote:
>>>>>>>>> Hi
>>>>>>>>> programm.
>>>>>>>> "Generate Test Code" and look at the generated XyzExample.java?
>>>>>>>>> Code:
>>>>>>>>> URI fileURI = null;
>>>>>>>>> if(file != null) {
>>>>>>>>> return null;
>>>>>>>>> try {
Re: EMF Stand-alone main application [message #423817 is a reply to message #423815] |
Tue, 07 October 2008 09:02  |
Ok you are now my special EMF hero. Thanks. Now all works fine.
Ed Merks schrieb:
> Mike,
> Using
>> Again big thanks
>> Ed Merks schrieb:
>>> Mike,
>>>> try {
>>>> Boolean.TRUE);
>>>> Boolean.TRUE);
>>>> try {
>>>>> any
>>>>> exquisitus wrote:
>>>>>> My Enviorment is
>>>>>>>> from SAX.
>>>>>>>> load options?
>>>>>>>> Thanks
>>>>>>>> Load:
>>>>>>>> try {
>>>>>>>> Ed Merks schrieb:
>>>>>>>>> Comments below.
>>>>>>>>> exquisitus wrote:
>>>>>>>>>> Hi
>>>>>>>>>> programm.
>>>>>>>>>> Code:
>>>>>>>>>> URI fileURI = null;
>>>>>>>>>> if(file != null) {
>>>>>>>>>> return null;
>>>>>>>>>> try {
Current Time: Sat Jul 26 12:45:01 EDT 2025
Powered by FUDForum. Page generated in 0.03544 seconds
