Home » Modeling » EMF » [CDO] why getCreationIme is Unsupported in HibernateStore
[CDO] why getCreationIme is Unsupported in HibernateStore [message #423669] Mon, 06 October 2008 08:38 Go to next message
Hi I'm trying CDO with HibernateStore via Mapping file generated by Teneo
I have the org.eclipse.emf.cdo.server.hibernate version from CVS
my server is running
and when I try to connect to my CDO repository from CDO UI i have an
unsupportedOperationException from getCreationTime () method in
HibernateStore :
[ERROR] UnsupportedOperationException
java.lang.UnsupportedOperationException
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore .getCreationTime(HibernateStore.java:183)
at
org.eclipse.emf.cdo.internal.server.Repository.getCreationTi me(Repository.java:376)
at
org.eclipse.emf.cdo.internal.server.protocol.OpenSessionIndi cation.responding(OpenSessionIndication.java:114)
at
org.eclipse.emf.cdo.internal.server.protocol.CDOServerIndica tion.responding(CDOServerIndication.java:150)
at
org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:48)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:186)
at org.eclipse.net4j.signal.Signal.run(Signal.java:167)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:650)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:675)
at java.lang.Thread.run(Thread.java:595)
In the HibernateStore code i Have
public long getCreationTime()
throw new UnsupportedOperationException();
so why this function is unsupported ?
Re: [CDO] why getCreationIme is Unsupported in HibernateStore [message #423764 is a reply to message #423669] Tue, 07 October 2008 04:25 Go to previous messageGo to next message
Hi Tristan,
Currently the hibernate store does not keep the time when the repository was created. I am not sure
if this is really required or that returning a default date should also work. I have sent a question
about this to Eike. If I know more I will let you know.
You can also enter a bugzilla for this, then I have something to attach a solution to it.
gr. Martin
> HibernateStore :
> at
> at
> at
> at
> at
> at
> at
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [CDO] why getCreationIme is Unsupported in HibernateStore [message #423771 is a reply to message #423764] Tue, 07 October 2008 05:25 Go to previous messageGo to next message
Hi Martin
thank you for your answer
In fact it's not a problem for me I modify the code to return a default
value but it's a strange behaviour for a user who want to make a little
try of the techno and getting an unsupportingoperationexception.
An other thing is it normal to access to
org.eclipse.emf.cdo.server.hibernate just via CVS ? i didn't see a build
version
Martin Taal a écrit :
> Hi Tristan,
> was created. I am not sure if this is really required or that returning
> a default date should also work. I have sent a question about this to
> a solution to it.
> gr. Martin
>> HibernateStore :
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: [CDO] why getCreationIme is Unsupported in HibernateStore [message #423774 is a reply to message #423771] Tue, 07 October 2008 05:35 Go to previous messageGo to next message
Hi Tristan,
The cdo.server.hibernate is included in the cdo builds which are published regularly.
http://www.eclipse.org/modeling/emf/downloads/?project=cdo&a mp;showAll=1&hlbuild=S200809300511#S200809300511
gr. Martin
> Hi Martin
> version
>> Hi Tristan,
>> repository was created. I am not sure if this is really required or
>> gr. Martin
>>> Teneo
>>> HibernateStore :
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
The Netherlands
Re: [CDO] why getCreationIme is Unsupported in HibernateStore [message #423775 is a reply to message #423771] Tue, 07 October 2008 05:39 Go to previous messageGo to next message
Tristan FAURE schrieb:
> Hi Martin
> default value but it's a strange behaviour for a user who want to make
> a little try of the techno and getting an unsupportingoperationexception.
Sorry, we're still working on including the HibernateStore into our
regular test suites so that such regressions don't happen anymore.
This method is mostly for setups that support auditing (historical
views) to constrain the "valid past". If it's not possible to detect the
time of the *first* creation of the store/repository then I think that
CDORevision.UNSPECIFIED_TIME is better than an exception. Martin told me
that this particular issue is fixed now (also by returning a the default
value CDORevision.UNSPECIFIED_TIME).
> build version
Can you please file a Bugzilla so that we can finally include the
hibernate feature into the regular distro?
Cheers
/Eike
>> Hi Tristan,
>> question about this to Eike. If I know more I will let you know.
>> gr. Martin
>>> Teneo
>>> HibernateStore :
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
Re: [CDO] why getCreationIme is Unsupported in HibernateStore [message #423779 is a reply to message #423775] Tue, 07 October 2008 05:41 Go to previous message
>> Hi Martin
>> make a little try of the techno and getting an
> the time of the *first* creation of the store/repository then I think
> that CDORevision.UNSPECIFIED_TIME is better than an exception. Martin
> told me that this particular issue is fixed now (also by returning a
> the default value CDORevision.UNSPECIFIED_TIME).
>> build version
Sorry, Martin is right: The hibernate feature is included in the CDO SDK!
With your Bugzilla we could include it into the cdo.server feature as
well...
Cheers
/Eike
> Cheers
> /Eike
>>> Hi Tristan,
>>> gr. Martin
>>>> Teneo
>>>> an unsupportedOperationException from getCreationTime () method in
>>>> HibernateStore :
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
Previous Topic:XSD ID -> EMF ID -> hibernate id
Next Topic:[CDO] Tutorial on writing org.eclipse.emf.cdo.server.IStore implementation?
Current Time: Sun Jul 27 13:49:14 EDT 2025
Powered by FUDForum. Page generated in 0.24498 seconds
