Home » Modeling » EMF » XSD ID -> EMF ID -> hibernate id
XSD ID -> EMF ID -> hibernate id [message #423612] |
Thu, 02 October 2008 19:58  |
As discussed in
http://www.eclipse.org/newsportal/article.php?id=36086&g roup=eclipse.tools.emf#36086
I started with some XSD's, generated EMF models and then persisted with
Teneo. Fields that were declared in XSD as ID fields went into EMF as ID
fields and then as id elements in the hibernate mappings. i.e. these
fields became primary key fields.
However, the XSD authors never intended them to be globally unique, just
unique within a single document. They use IDREF fields elsewhere in the
doc to refer to them.
Consequently they are not suitable as id fields in the hibernate mappings.
I fixed this with Martin's help by turning off the mapping from EMF ID to
hibernate id.
However, its not clear to me whether this was the best place to fix it. Is
the semantics of ID in EMF that the field is intended to be a unique
primary key for that class?
If so then I should probably sever the mapping of XSD ID to EMF ID for
these fields instead? If so how do I do that?
Thoughts?
Re: XSD ID -> EMF ID -> hibernate id [message #423613 is a reply to message #423612] |
Thu, 02 October 2008 20:10   |
Originally posted by: cdamus.zeligsoft.com
Hi, Andrew,
EMF's EObject IDs are intended to be resource-unique, as in XSD. The
UUID utility is a convenience for generating IDs that probably are
universally unique, but nothing in EMF expects this property.
HTH,
Christian
Andrew H wrote:
> As discussed in
> to hibernate id.
> Is the semantics of ID in EMF that the field is intended to be a unique
> Thoughts?
Re: XSD ID -> EMF ID -> hibernate id [message #423648 is a reply to message #423613] |
Fri, 03 October 2008 21:08   |
Thanks Christian
So I guess it comes down to what a resource is. In some cases it might
be a document, in others a table in a DB.
Christian W. Damus wrote:
> Hi, Andrew,
> HTH,
> Christian
> Andrew H wrote:
>> As discussed in
>> with Teneo. Fields that were declared in XSD as ID fields went into
>> EMF as ID fields and then as id elements in the hibernate mappings.
>> i.e. these fields became primary key fields.
>> just unique within a single document. They use IDREF fields elsewhere
>> in the doc to refer to them.
>> mappings.
>> to hibernate id.
>> it. Is the semantics of ID in EMF that the field is intended to be a
>> unique primary key for that class?
>> Thoughts?
Re: XSD ID -> EMF ID -> hibernate id [message #423650 is a reply to message #423648] |
Sat, 04 October 2008 05:34   |
Hi Andres,
Or the resource represents the whole database, with Teneo a resource is connected to the database as
a whole, i.e. a Teneo EMF resource uses a hibernate session and with queries you can load data from
all the tables into the resource.
gr. Martin
andrew987650000@yahoo.com.au wrote:
> Thanks Christian
>> Hi, Andrew,
>> HTH,
>> Christian
>> Andrew H wrote:
>>> As discussed in
>>> mappings.
>>> ID to hibernate id.
>>> for these fields instead? If so how do I do that?
>>> Thoughts?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: XSD ID -> EMF ID -> hibernate id [message #423651 is a reply to message #423650] |
Sat, 04 October 2008 05:36   |
And here with the correct spelling of your name, sorry (the s and w are too close to eachother for
my fingers apparently :-)
Hi Andrew,
connected to the database as a whole, i.e. a Teneo EMF resource uses a
hibernate session and with queries you can load data from all the tables
into the resource.
gr. Martin
>> Thanks Christian
>>> Hi, Andrew,
>>> HTH,
>>> Christian
>>> Andrew H wrote:
>>>> As discussed in
>>>> elsewhere in the doc to refer to them.
>>>> mappings.
>>>> ID to hibernate id.
>>>> Thoughts?
The Netherlands
Re: XSD ID -> EMF ID -> hibernate id [message #423654 is a reply to message #423651] |
Sat, 04 October 2008 12:49   |
Hi, Martin,
Perhaps Andrew would enjoy being Spanish for a day?
You should use the Dvorak layout, as I do. There is a greater
separation between the S and the W. My own problem is between the N and
S, and the A and O. I sometimes sign my own name as Christios ... looks
vaguely Greek.
:-D
On a more serious note, I think the mapping of EMF's resource do the
database as a whole is very intuitive. It's convenient to have a closed
universe containing everything, and external references modeled simply
as URIs, which makes for a very explicit proxy concept.
cW
> too close to eachother for my fingers apparently :-)
> Hi Andrew,
> into the resource.
> gr. Martin
>>> Thanks Christian
>>> might be a document, in others a table in a DB.
>>>> Hi, Andrew,
>>>> The UUID utility is a convenience for generating IDs that probably
>>>> are universally unique, but nothing in EMF expects this property.
>>>> HTH,
>>>> Christian
>>>> Andrew H wrote:
>>>>> As discussed in
>>>>> mappings.
>>>>> ID to hibernate id.
>>>>> a unique primary key for that class?
>>>>> Thoughts?
Re: XSD ID -> EMF ID -> hibernate id [message #423759 is a reply to message #423654] |
Tue, 07 October 2008 02:16  |
Thanks Christios & Marten :-)
So I think the problem then in this case is the association with XSD ID
and EMF ID. The XSD's that I originally imported are for B2B applications.
They use XML ID for references within a document. I should stop these
mapping to EMF ID fields as this implies uniqueness withing our database
for these objects.
thanks for everyones thoughts
> Hi, Martin,
> vaguely Greek.
> :-D
> cW
>> Hi Andrew,
>> into the resource.
>> gr. Martin
>>>> Thanks Christian
>>>>> Hi, Andrew,
>>>>> HTH,
>>>>> Christian
>>>>> Andrew H wrote:
>>>>>> As discussed in
>>>>>> mappings.
>>>>>> ID to hibernate id.
>>>>>> Thoughts?
Current Time: Sat Jul 26 21:12:27 EDT 2025
Powered by FUDForum. Page generated in 0.03409 seconds
