Home » Modeling » EMF » [EMF] [Teneo] : benchmarks ? And Return of Experience ?
[EMF] [Teneo] : benchmarks ? And Return of Experience ? [message #423625] Fri, 03 October 2008 10:48 Go to next message
where can i found some information about EMF benchmarks ?
Do you know if there is a model limit size (using XMI) ?
For a teneo use is there some speed benchmarks ?
Is somebody try to use EMF and Teneo for very huge models (Actually i
can't quantify what is the limit between models and huge models ;)) ?
what kind of problem do you have ? Do you need to apply a process to
avoid performance problem ?
Re: [EMF] [Teneo] : benchmarks ? And Return of Experience ? [message #423629 is a reply to message #423625] Fri, 03 October 2008 11:15 Go to previous messageGo to next message
--------------090005060204000809040208
Tristan,
Comments below.
Tristan FAURE wrote:
> Hi
We used to run micro benchmark performance tests, but we've not been
doing that for a while. Loading performance depends a lot on options,
the complexity of the model, not just the size, i.e,. lots of cross
references will make things slower.
The size of the heap?
Searching the newsgroups will turn up previous discussions (the second
search both lower down):
http://www.eclipse.org/newsportal/thread.php?group=eclipse.t ools.emf
http://www.eclipse.org/newsportal/thread.php?group=eclipse.t echnology.emft
> (Actually i can't quantify what is the limit between models and huge
> models ;)) ?
Exactly. It's relative.
Eventually you run out of memory.
> Do you need to apply a process to avoid performance problem ?
> /EMF Performance Tips/
> < http://www.google.ca/url?sa=t&source=web&ct=res& cd=1&url=http%3A%2F%2Fwww.eclipse.org%2Fmodeling%2Femf%2 Fdocs%2Fperformance%2FEMFPerformanceTips.html&ei=-jbmSMT PJIqO8wTn5735Cw&usg=AFQjCNH8hcsWZ-j-8MfFwYjl_reru_wU_w&a mp;sig2=7pxIPBkobe-P3D0nz3jK4Q>
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Tristan,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:gc5bbl$1hc$1@build.eclipse.org" type="cite">Hi
<br>
<br>
<br>
</blockquote>
doing that for a while.&nbsp; Loading performance depends a lot on options,
references will make things slower.<br>
<blockquote cite="mid:gc5bbl$1hc$1@build.eclipse.org" type="cite">Do
<br>
</blockquote>
The size of the heap?<br>
<blockquote cite="mid:gc5bbl$1hc$1@build.eclipse.org" type="cite">For a
<br>
<br>
Is somebody try to use EMF and Teneo for very huge models </blockquote>
search both lower down):<br>
<blockquote><a
href=" http://www.eclipse.org/newsportal/thread.php?group=eclipse.t ools.emf"> http://www.eclipse.org/newsportal/thread.php?group=eclipse.t ools.emf</a><br>
<a
href=" http://www.eclipse.org/newsportal/thread.php?group=eclipse.t echnology.emft"> http://www.eclipse.org/newsportal/thread.php?group=eclipse.t echnology.emft</a><br>
</blockquote>
<br>
<blockquote cite="mid:gc5bbl$1hc$1@build.eclipse.org" type="cite">(Actually
i can't quantify what is the limit between models and huge models ;)) ?
</blockquote>
Exactly.&nbsp; It's relative.<br>
<blockquote cite="mid:gc5bbl$1hc$1@build.eclipse.org" type="cite">what
kind of problem do you have ?</blockquote>
Eventually you run out of memory.<br>
<br>
<h3 class="r"><a
href="http://www.google.ca/url?sa=t&amp ;source=web&amp;ct=res&amp;cd=1&amp;url=http%3A% 2F%2Fwww.eclipse.org%2Fmodeling%2Femf%2Fdocs%2Fperformance%2 FEMFPerformanceTips.html&amp;ei=-jbmSMTPJIqO8wTn5735Cw&a mp;amp;usg=AFQjCNH8hcsWZ-j-8MfFwYjl_reru_wU_w&amp;sig2=7 pxIPBkobe-P3D0nz3jK4Q "
class="l"
onmousedown="return rwt(this,'','','res','1','AFQjCNH8hcsWZ-j-8MfFwYjl_reru_wU_w ','&sig2=7pxIPBkobe-P3D0nz3jK4Q') "><em>EMF
Performance Tips</em></a></h3>
</blockquote>
</body>
</html>
--------------090005060204000809040208--
Re: [EMF] [Teneo] : benchmarks ? And Return of Experience ? [message #423630 is a reply to message #423629] Fri, 03 October 2008 11:21 Go to previous messageGo to next message
tahnk you ed for you remarks and maybe sorry for my question a little
bit too evasive
I'll check your links and if anybody has some experience return he is
welcome.
And about model limit size it doens't depends on the physical size ?
Does EMF loads models incrementally ?
Ed Merks a écrit :
> Tristan,
> Comments below.
>> Hi
>> models ;)) ?
Re: [EMF] [Teneo] : benchmarks ? And Return of Experience ? [message #423632 is a reply to message #423630] Fri, 03 October 2008 11:28 Go to previous messageGo to next message
Tristan,
IBM uses UML which is based on EMF to load massive models. Of course
clients feed in models until the system runs out of memory. But that
happens for massive models. Sometimes I joke that Java doesn't scale
because while I have 4G of physical RAM, I can't build more than a 2G
heap...
EMF's XML deserializer loads an entire resource at once, but cross
resources references are loaded on demand as you visit the data.
Nothing will automatically unload them if you stop using them. The fact
that ResourceSet, Resource, and EObject form a containment tree with two
way references means that general a reference to any EObject or Resource
will keep the entire tree in memory...
> bit too evasive
> welcome.
> Ed Merks a écrit :
>> Tristan,
>> Comments below.
>>> Hi
>> options, the complexity of the model, not just the size, i.e,. lots
>> of cross references will make things slower.
>> second search both lower down):
>>> models ;)) ?
Re: [EMF] [Teneo] : benchmarks ? And Return of Experience ? [message #423635 is a reply to message #423630] Fri, 03 October 2008 11:58 Go to previous messageGo to next message
Maybe it can help but I know some technology are built to access big graphs.
With CDO, you can load a big graph as big as you want. While you are
crawling the graph, objects that are not used anymore will be evict from the
cache automatically. This is possible because objects are never linked
together. Garbage collector can do its work.
I'm able to load 4 gig of data even if my JVM maxsize is at 260 megs !!!
What it is nice is while you are crawling.. you don't need to do anything
special. (e.g.: clean objects, remove object from cache, etc...)
Simon
"Tristan FAURE" <tristan.faure@atosorigin.com> wrote in message
news:48E6386E.8000608@atosorigin.com...
> tahnk you ed for you remarks and maybe sorry for my question a little bit
> too evasive
> welcome.
> And about model limit size it doens't depends on the physical size ? Does
> Ed Merks a écrit :
>> Tristan,
>> Comments below.
>>> Hi
>>> models ;)) ?
Re: [EMF] [Teneo] : benchmarks ? And Return of Experience ? [message #423636 is a reply to message #423630] Fri, 03 October 2008 11:59 Go to previous messageGo to next message
Hi Tristan,
As Ed pointed out, it always depends. You should use one of the later versions of Teneo as the 1.0.0
release had a performance issue with large sets of data (10000s of objects in mem).
If you have performance issues then I would definitely enable hibernate sql logging so you can see
what queries are fired by hibernate at which point. This has helped me a lot to find issues here and
there.
EMF uses EMF proxying to prevent eager loading. However Teneo/Hibernate does not use that at the
moment, Teneo/hibernate uses the standard lazy loading mechanism of hibernate (cglib and lazy loaded
lists). So both native EMF and EMF/Teneo/Hibernate support incremental loading.
gr. Martin
> bit too evasive
> welcome.
> Ed Merks a écrit :
>> Tristan,
>> Comments below.
>>> Hi
>>> models ;)) ?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [EMF] [Teneo] : benchmarks ? And Return of Experience ? [message #423646 is a reply to message #423636] Fri, 03 October 2008 20:59 Go to previous messageGo to next message
We have a pretty large model ( > 800 classifiers). I've been playing
around with persistence via teneo this last week. I've just now got the
basic thing working and need to look at some of the bottlenecks I've
hit. Most I think revolve around eager fetching.
The DB schema that teneo / hibernate have generated has > 500 tables
which is pretty large model in my book.
This is currently hurting on start up as hibernate evaluates what needs
to change. I'm assuming hibernate has a way to turn that off but haven't
pursued that yet.
On the performance front I'm about to look into tweaking a few things
such as:
- selectively turning off eager fetching of containment on queries. In
general I want it to do this as each object we will pull out of the db
is a pretty large (and diverse) tree. If I needed to specify what to
fetch in each query I would get a very large amount of querying code.
- However, on some operations (particularly when I persist new
versions of these objects) I need to navigate some one to many
containment relationships to add this one to the list. I think it is
eager fetching all the data on every version at the moment which is
causing it to grind. I think hibernate allows you to set fetch
strategies on individual criteria.
- large inheritance trees. I have one class in particular - Product -
that has many subtypes. Hibernate is doing a query on product that joins
on to every subtype. Since its only ever one of these this is wasteful.
I set the MAX_FETCH_DEPTH to 0 to try to stop this but it still does it.
I suspect I may need custom mappings on Product somehow to turn this off.
- Denormalising some classes. I believe there is an Embeddable concept
in EMF that may help this. Also I may choose different inheritance
strategies for different hierarchies.
Hopefully next week I will have more info on my experiences working with
a large model
cheers
Andrew
Martin Taal wrote:
> Hi Tristan,
> versions of Teneo as the 1.0.0 release had a performance issue with
> sql logging so you can see what queries are fired by hibernate at which
> point. This has helped me a lot to find issues here and there.
> does not use that at the moment, Teneo/hibernate uses the standard lazy
> loading mechanism of hibernate (cglib and lazy loaded lists). So both
> gr. Martin
>> bit too evasive
>> welcome.
>> Ed Merks a écrit :
>>> Tristan,
>>> Comments below.
>>>> Hi
>>>> models ;)) ?
Re: [EMF] [Teneo] : benchmarks ? And Return of Experience ? [message #423647 is a reply to message #423636] Fri, 03 October 2008 21:00 Go to previous messageGo to next message
pursued that yet.
such as:
a large model
cheers
Andrew
Martin Taal wrote:
> Hi Tristan,
> gr. Martin
>> bit too evasive
>> welcome.
>> Ed Merks a écrit :
>>> Tristan,
>>> Comments below.
>>>> Hi
>>>> models ;)) ?
Re: [EMF] [Teneo] : benchmarks ? And Return of Experience ? [message #423649 is a reply to message #423647] Sat, 04 October 2008 05:17 Go to previous messageGo to next message
Hi Andrew,
See my comments inline.
gr. Martin
> pursued that yet.
MT>> As a default if you don't set the Environment.HBM2DDL_AUTO hibernate property then Teneo will
set it to update, so if you set it to none (undocumented feature of hibernate afaik) it should
prevent teneo from setting it.
I am working with a 425 table model and hibernate is initialized in about 10 seconds.
In my case I don't update the database schema so probably this is were the time is spend by hibernate.
> such as:
MT>> depends on how much time you want to spend on this but an idea I got when reading this is that
you can write your own query generator using your model which is available at runtime. Then you can
parameter control your query generator to use eager fetching or not in different locations.
MT>> I am not sure if you use bags or lists but you should maybe try hibernates idbag or persist
lists as bags (so non-ordered). Lists are slower to persist/update than bags and much slower than
idbags.
Another thing to watch for is that EMF sends notifications on the basis of changes in objects,
sometimes these notifications result in loading of data at unexpected moments in time. Although it
can't be prevented always (EMF sends the notifications for a reason) it can be good to be aware of it.
MT>> Afaik the fetch_depth is related to associations and not so much depth of the inheritance tree.
Another option would be to use single table inheritance for this inheritance tree. Hibernate has a
limitation though that a whole inheritance tree should use one inheritance strategy for the whole
tree. So you can do join_table for the top of the tree and single table for branches. But if your
product inheritance tree is an independent tree then it can be set to single table using the
inheritance annotation.
MT>> Yes, that was also my idea.
> a large model
> cheers
> Andrew
> Martin Taal wrote:
>> Hi Tristan,
>> hibernate sql logging so you can see what queries are fired by
>> and there.
>> Teneo/Hibernate does not use that at the moment, Teneo/hibernate uses
>> loaded lists). So both native EMF and EMF/Teneo/Hibernate support
>> gr. Martin
>>> bit too evasive
>>> welcome.
>>> Ed Merks a écrit :
>>>> Tristan,
>>>> Comments below.
>>>>> Hi
>>>>> huge models ;)) ?
The Netherlands
Re: [EMF] [Teneo] : benchmarks ? And Return of Experience ? [message #423660 is a reply to message #423649] Mon, 06 October 2008 04:13 Go to previous messageGo to next message
Hi thank you all for your comments
all of them will be very useful for my study
Martin Taal a écrit :
> Hi Andrew,
> gr. Martin
>> the basic thing working and need to look at some of the bottlenecks
>> I've hit. Most I think revolve around eager fetching.
>> needs to change. I'm assuming hibernate has a way to turn that off but
>> haven't pursued that yet.
> hibernate property then Teneo will set it to update, so if you set it to
> none (undocumented feature of hibernate afaik) it should prevent teneo
> from setting it.
> about 10 seconds.
>> such as:
> got when reading this is that you can write your own query generator
> using your model which is available at runtime. Then you can parameter
> locations.
> hibernates idbag or persist lists as bags (so non-ordered). Lists are
> slower to persist/update than bags and much slower than idbags.
> of changes in objects, sometimes these notifications result in loading
> of data at unexpected moments in time. Although it can't be prevented
> aware of it.
>> joins on to every subtype. Since its only ever one of these this is
>> wasteful. I set the MAX_FETCH_DEPTH to 0 to try to stop this but it
>> still does it. I suspect I may need custom mappings on Product somehow
>> to turn this off.
> inheritance tree. Hibernate has a limitation though that a whole
> inheritance tree should use one inheritance strategy for the whole tree.
> branches. But if your product inheritance tree is an independent tree
> then it can be set to single table using the inheritance annotation.
>> with a large model
>> cheers
>> Andrew
>> Martin Taal wrote:
>>> Hi Tristan,
>>> here and there.
>>> gr. Martin
>>>> little bit too evasive
>>>> is welcome.
>>>> Ed Merks a écrit :
>>>>> Tristan,
>>>>> Comments below.
>>>>>> Hi
>>>>> been doing that for a while. Loading performance depends a lot on
>>>>>> huge models ;)) ?
Re: [EMF] [Teneo] : benchmarks ? And Return of Experience ? [message #423755 is a reply to message #423649] Tue, 07 October 2008 01:51 Go to previous messageGo to next message
Thanks for the help Martin.
See inline
Martin Taal wrote:
> Hi Andrew,
> gr. Martin
>> pursued that yet.
seconds.
That did the trick. Starts much quicker now.
>> such as:
Interesting. How would I go about doing that?
> idbags.
changes in objects,
Good to know. I'll keep these options in mind when tuning collections.
table using the
I actually started with single table but changed it to join when I saw
what was generated. I had naively hoped that hibernate would change
approach in this case and not do the extra joins, buy was wrong. Having
all the product heirarchy flattened in this case is pretty ugly so I'm
going to leave it as it is now. Annoying that there doesn't seem to be a
way to stop hibernate doing the queries like this. But I think we can
probably live with it.
>> a large model
>> cheers
>> Andrew
>> Martin Taal wrote:
>>> Hi Tristan,
>>> and there.
>>> gr. Martin
>>>> bit too evasive
>>>> welcome.
>>>> Ed Merks a écrit :
>>>>> Tristan,
>>>>> Comments below.
>>>>>> Hi
>>>>>> huge models ;)) ?
Re: [EMF] [Teneo] : benchmarks ? And Return of Experience ? [message #423767 is a reply to message #423755] Tue, 07 October 2008 04:38 Go to previous messageGo to next message
Hi Andrew,
To write your own query generator you have to traverse the in-memory model and create a query on the
basis of the in-memory model.
For example this piece of code (not necessarily syntacticallly correct) will do a query for each
eclass in the system:
Session s = dataStore.getSessionFactory().getSession();
for (EClass eClass : ePackage.getEClasses()) {
final Query qry = s.createQuery("from " + eClass.getName());
System.err.println("Querying for " + eClass.getName());
for (Object o : qry.list()) {
System.err.println(o);
and the following code will generate an eager join with each many-to-one of an eclass. So for your
query generator you have to find some parameters to control what gets joined. Note that you can for
example add an eannotation in your model to classify the ereferences and use that classification
(the annotation) in the query generator to generate the correct eager joins.
public List<Object> queryEagerly(EClass eClass, Session session) {
final StringBuilder sb = new StringBuilder();
sb.append("select e from " + eClass.getName() + "
for (EReference eref : eClass.getEAllReferences()) {
if (!eref.isMany()) {
sb.append(" left outer join fetch e." + eref.getName());
// add the where clause here
final Query qry = session.createQuery(sb.toString());
return qry.list();
Hope this helps.
gr. Martin
> See inline
> Martin Taal wrote:
>> Hi Andrew,
>> gr. Martin
>>> but haven't pursued that yet.
>> about 10
> seconds.
>> the
>>> such as:
>>> In general I want it to do this as each object we will pull out of
>>> the db is a pretty large (and diverse) tree. If I needed to specify
>>> what to fetch in each query I would get a very large amount of
>>> querying code.
>> available
>> than bags
>> idbags.
>> basis of
> changes in objects,
>> it can
>> depth
>> inheritance
>> inheritance
>> table for
>> single
> table using the
>>> concept in EMF that may help this. Also I may choose different
>>> inheritance strategies for different hierarchies.
>>> with a large model
>>> cheers
>>> Andrew
>>> Martin Taal wrote:
>>>> Hi Tristan,
>>>> later versions of Teneo as the 1.0.0 release had a performance issue
>>>> here and there.
>>>> lazy loaded lists). So both native EMF and EMF/Teneo/Hibernate
>>>> gr. Martin
>>>>> is welcome.
>>>>> ? Does EMF loads models incrementally ?
>>>>> Ed Merks a écrit :
>>>>>> Tristan,
>>>>>> Comments below.
>>>>>>> Hi
>>>>>> lots of cross references will make things slower.
>>>>>>> huge models ;)) ?
The Netherlands
Re: [EMF] [Teneo] : benchmarks ? And Return of Experience ? [message #423846 is a reply to message #423767] Tue, 07 October 2008 19:19 Go to previous message
Thanks Martin
That's a very interesting idea. I think that will be very helpful for
implementing some of the searches I need to do
cheers
Andrew
Martin Taal wrote:
> Hi Andrew,
do a query for each
that classification
> return qry.list();
> Hope this helps.
> gr. Martin
>> See inline
>> Martin Taal wrote:
>>> Hi Andrew,
>>> gr. Martin
>>> about 10
>> seconds.
>>> the
>>>> such as:
>>>> querying code.
>>> available
>>> than bags
>>> idbags.
>>> basis of
>> changes in objects,
>>> it can
>>> depth
>>> inheritance
>>> inheritance
>>> table for
>>> single
>> table using the
>>>> with a large model
>>>> cheers
>>>> Andrew
>>>> Martin Taal wrote:
>>>>> Hi Tristan,
>>>>> here and there.
>>>>> gr. Martin
>>>>>> is welcome.
>>>>>> Ed Merks a écrit :
>>>>>>> Tristan,
>>>>>>> Comments below.
>>>>>>>> Hi
>>>>>>>> huge models ;)) ?
Previous Topic:Feature not found loading serialized resource
Next Topic:[EMF] Loading UML Magicdraw models
Current Time: Sun Jul 27 03:49:10 EDT 2025
Powered by FUDForum. Page generated in 0.07929 seconds
