[CDO] CDO fails to generate ID for non-CDO EMF object [message #423607] |
Thu, 02 October 2008 16:11  |
I have a CDO-ized EMF model that has a non-containment, non-transient
reference to an object in a different non-CDO EMF model. This works fine until I
try to save the CDO model and then I get a IllegalStateException:
java.lang.IllegalStateException: Unable to provideCDOID: <non-CDO EMF object>
at org.eclipse.emf.internal.cdo.CDOViewImpl.provideCDOID(CDOVie wImpl.java:473)
at
org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl .writeValues(CDORevisionImpl.java:777)
at org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl .write(CDORevisionImpl.java:160)
at
org.eclipse.emf.internal.cdo.protocol.CommitTransactionReque st.writeRevisions(CommitTransactionRequest.java:181)
at
org.eclipse.emf.internal.cdo.protocol.CommitTransactionReque st.requesting(CommitTransactionRequest.java:98)
at org.eclipse.net4j.signal.RequestWithConfirmation.execute(Req uestWithConfirmation.java:48)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:143)
at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalPr otocol.java:236)
at org.eclipse.net4j.signal.SignalActor.send(SignalActor.java:5 0)
at org.eclipse.net4j.signal.failover.NOOPFailOverStrategy.send( NOOPFailOverStrategy.java:34)
at org.eclipse.emf.internal.cdo.CDOTransactionImpl.commit(CDOTr ansactionImpl.java:239)
at org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.save(CDOR esourceImpl.java:369)
CDOViewImpl.provideCDOID(Object idOrObject) calls the function CDOViewImpl.convertObjectToID(Object
potentialObject) that creates and returns a CDOAdapterImpl. Unfortunately, the provideCDOID(..)
function doesn't do anything with the adapter returned to it and so it throws the
IllegalStateException above.
Is there something I should do to allow it to generate an ID for a normal EMF object
stored outside the CDO model? Do we need to implement our own adapter somehow?
Thanks in advanced!
Sincerely,
Stephen McCants
Re: [CDO] CDO fails to generate ID for non-CDO EMF object [message #423626 is a reply to message #423614] |
Fri, 03 October 2008 11:06   |
Hello Eike,
Thank you for your quick reply. Yes, I am using 1.0 of CDO and I am talking about "external
references". For now, we are working without external references, but if we decide we really do
need them (and I expect we will), we'll move to 2.x.
Thanks again for your help!
Sincerely,
Stephen McCants
Eike Stepper wrote:
> Hi Stephen,
> I have the feeling that you are using a 1.0.x version of CDO, right?
> What you are describing sounds like what we call "external references" and
> support for them has only been added to the 2.0 stream of CDO after
> Ganymede:
> 213402: Support external references
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=213402
> Btw. this feature was neither proposed nor developed by me.
> For respective questions I really hope that Simon's new computer
> will work wonders soon again ;-)
> Simon, at some convenient occasion I need to know how this feature
> impacts the existing IStores (if at all) and what I need to do in the
> DBStore!
> Cheers
> /Eike
> Stephen McCants schrieb:
>> Hello,
>> fine until I
>> object>
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> CDOViewImpl.convertObjectToID(Object potentialObject) that creates and
>> throws the IllegalStateException above.
>> normal EMF object
>> somehow?
>> Thanks in advanced!
>> Sincerely,
>> Stephen McCants
FUDForum. Page generated in 0.04208 seconds
