Home » Modeling » EMF » [CDO] CDO fails to generate ID for non-CDO EMF object
[CDO] CDO fails to generate ID for non-CDO EMF object [message #423607] Thu, 02 October 2008 16:11 Go to next message
I have a CDO-ized EMF model that has a non-containment, non-transient
reference to an object in a different non-CDO EMF model. This works fine until I
try to save the CDO model and then I get a IllegalStateException:
java.lang.IllegalStateException: Unable to provideCDOID: <non-CDO EMF object>
at org.eclipse.emf.internal.cdo.CDOViewImpl.provideCDOID(CDOVie wImpl.java:473)
at
org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl .writeValues(CDORevisionImpl.java:777)
at org.eclipse.emf.cdo.internal.common.revision.CDORevisionImpl .write(CDORevisionImpl.java:160)
at
org.eclipse.emf.internal.cdo.protocol.CommitTransactionReque st.writeRevisions(CommitTransactionRequest.java:181)
at
org.eclipse.emf.internal.cdo.protocol.CommitTransactionReque st.requesting(CommitTransactionRequest.java:98)
at org.eclipse.net4j.signal.RequestWithConfirmation.execute(Req uestWithConfirmation.java:48)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:143)
at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalPr otocol.java:236)
at org.eclipse.net4j.signal.SignalActor.send(SignalActor.java:5 0)
at org.eclipse.net4j.signal.failover.NOOPFailOverStrategy.send( NOOPFailOverStrategy.java:34)
at org.eclipse.emf.internal.cdo.CDOTransactionImpl.commit(CDOTr ansactionImpl.java:239)
at org.eclipse.emf.cdo.eresource.impl.CDOResourceImpl.save(CDOR esourceImpl.java:369)
CDOViewImpl.provideCDOID(Object idOrObject) calls the function CDOViewImpl.convertObjectToID(Object
potentialObject) that creates and returns a CDOAdapterImpl. Unfortunately, the provideCDOID(..)
function doesn't do anything with the adapter returned to it and so it throws the
IllegalStateException above.
Is there something I should do to allow it to generate an ID for a normal EMF object
stored outside the CDO model? Do we need to implement our own adapter somehow?
Thanks in advanced!
Sincerely,
Stephen McCants
Re: [CDO] CDO fails to generate ID for non-CDO EMF object [message #423614 is a reply to message #423607] Fri, 03 October 2008 03:10 Go to previous messageGo to next message
Hi Stephen,
I have the feeling that you are using a 1.0.x version of CDO, right?
What you are describing sounds like what we call "external references" and
support for them has only been added to the 2.0 stream of CDO after
Ganymede:
213402: Support external references
https://bugs.eclipse.org/bugs/show_bug.cgi?id=213402
Btw. this feature was neither proposed nor developed by me.
For respective questions I really hope that Simon's new computer
will work wonders soon again ;-)
Simon, at some convenient occasion I need to know how this feature
impacts the existing IStores (if at all) and what I need to do in the
DBStore!
Cheers
/Eike
Stephen McCants schrieb:
> Hello,
> fine until I
> object>
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> CDOViewImpl.convertObjectToID(Object potentialObject) that creates and
> throws the IllegalStateException above.
> normal EMF object
> somehow?
> Thanks in advanced!
> Sincerely,
> Stephen McCants
Re: [CDO] CDO fails to generate ID for non-CDO EMF object [message #423616 is a reply to message #423614] Fri, 03 October 2008 04:43 Go to previous messageGo to next message
Eike,
> DBStore!
Isn't external references implemented for DBStore? I thought it was.
Re: [CDO] CDO fails to generate ID for non-CDO EMF object [message #423617 is a reply to message #423616] Fri, 03 October 2008 05:05 Go to previous messageGo to next message
Víctor Roldán Betancort schrieb:
> Eike,
>> DBStore!
As I said, I was not too deeply involved in this whole feature.
Particularly I didn't change any code in DBStore (IIRC).
Either Simon has done it or it was not necessary at all (what I don't
believe).
Cheers
/Eike
Re: [CDO] CDO fails to generate ID for non-CDO EMF object [message #423626 is a reply to message #423614] Fri, 03 October 2008 11:06 Go to previous messageGo to next message
Hello Eike,
Thank you for your quick reply. Yes, I am using 1.0 of CDO and I am talking about "external
references". For now, we are working without external references, but if we decide we really do
need them (and I expect we will), we'll move to 2.x.
Thanks again for your help!
Sincerely,
Stephen McCants
Eike Stepper wrote:
> Hi Stephen,
> Ganymede:
> DBStore!
> Cheers
> /Eike
>> Hello,
>> fine until I
>> object>
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> normal EMF object
>> somehow?
>> Thanks in advanced!
>> Sincerely,
>> Stephen McCants
Re: [CDO] CDO fails to generate ID for non-CDO EMF object [message #423627 is a reply to message #423614] Fri, 03 October 2008 11:07 Go to previous message
Hi Eike,
It was my mistake, I should have create new bugzilla for that.
CDOIDExternal needs to be kept in the persistence space.
I've created 2 bugzilla for them for Hibernate and for DBStore.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=249611
https://bugs.eclipse.org/bugs/show_bug.cgi?id=249610
The testcases are failing for them!!!
Simon
"Eike Stepper" <stepper@esc-net.de> a
Previous Topic:EMF eclipsecon07 tutorial materials ?
Next Topic:OCL validation example - live vs. batch validation
Current Time: Sun Jul 27 16:22:39 EDT 2025
Powered by FUDForum. Page generated in 0.05995 seconds
