Home » Modeling » EMF » NPE in EPackageImpl.initializeFromLoadedEPackage when loadInitialization="true"
NPE in EPackageImpl.initializeFromLoadedEPackage when loadInitialization="true" [message #423408] Tue, 30 September 2008 03:48 Go to next message
I would raise a bugzilla for this if I could get bugzilla to work...
I get a NPE when trying referring to a package via MyPackage.eInstance as
a result of a loadInitialization="true" being set in the genmodel.
The genmodel that was created using the wizard had
loadInitialization="true" on one of the packages. I did not set this, it
was automatically set by the wizard.
The package in question was one of the packages generated from some
industry XSD's so the reason for the wizard setting this flag may relate
to this origin.
This has resulted in a NullPointerException when I try to reference
MyPackage.eInstance.
I have been able to reproduce this in a very simple model by explicitly
setting loadInitialization="true". That example is included below.
A workaround for me is to set this flag to false, but I am unsure what the
implications of this might be. Presumably the wizard set this flag for a
reason.
I don't believe this is the same as
https://bugs.eclipse.org/bugs/show_bug.cgi?id=179561 but I could be wrong.
Simple example to reproduce the problem
<ecore:EPackage xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="a"
nsURI="urn:a/1.0" nsPrefix="a">
<eClassifiers xsi:type="ecore:EDataType" name="DummyDataType"
instanceClassName="java.lang.String"/>
<eSubpackages href="a/b.ecore#/"/>
<eSubpackages href="a/c.ecore#/"/>
</ecore:EPackage>
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="b"
nsURI="urn:b/1.0" nsPrefix="b">
<eClassifiers xsi:type="ecore:EClass" name="B">
<eAnnotations
source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="B"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="d"
eType="ecore:EClass c/d.ecore#//D"/>
</eClassifiers>
</ecore:EPackage>
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="c"
nsURI="urn:c/1.0" nsPrefix="c">
<eSubpackages href="c/d.ecore#/"/>
</ecore:EPackage>
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="d"
nsURI="urn:d/1.0" nsPrefix="d">
<eClassifiers xsi:type="ecore:EClass" name="D"/>
</ecore:EPackage>
<genmodel:GenModel xmi:version="2.0"
xmlns:genmodel="http://www.eclipse.org/emf/2002/GenModel"
modelDirectory="/TestLibaryModel/src"
modelPluginID="TestLibaryModel" modelName="A"
importerID="org.eclipse.emf.importer.ecore"
complianceLevel="5.0" copyrightFields="false">
<foreignModel>a.ecore</foreignModel>
<genPackages prefix="A" disposableProviderFactory="true"
ecorePackage="a.ecore#/">
<genDataTypes ecoreDataType="a.ecore#//DummyDataType"/>
<nestedGenPackages prefix="B" basePackage="a"
ecorePackage="a/b.ecore#/">
<genClasses ecoreClass="a/b.ecore#//B">
<genFeatures notify="false" createChild="false"
propertySortChoices="true"
ecoreFeature="ecore:EReference a/b.ecore#//B/d"/>
</genClasses>
</nestedGenPackages>
<nestedGenPackages prefix="C" basePackage="a"
ecorePackage="a/c.ecore#/">
<genDataTypes ecoreDataType="a/c.ecore#//DummyDataType"/>
<nestedGenPackages prefix="D" basePackage="a.c"
ecorePackage="a/c/d.ecore#/">
<genClasses ecoreClass="a/c/d.ecore#//D"/>
</genPackages>
</genmodel:GenModel>
The exception is
Exception in thread "main" java.lang.ExceptionInInitializerError
at a.c.impl.CPackageImpl.init(CPackageImpl.java:101)
at a.c.CPackage.<clinit>(CPackage.java:58)
at a.b.impl.BPackageImpl.init(BPackageImpl.java:97)
at a.b.BPackage.<clinit>(BPackage.java:59)
at a.impl.APackageImpl.init(APackageImpl.java:111)
at a.APackage.<clinit>(APackage.java:58)
at testa.TestA.main(TestA.java:8)
at
org.eclipse.emf.ecore.impl.EPackageImpl.initializeFromLoaded EPackage(EPackageImpl.java:1582)
at
org.eclipse.emf.ecore.impl.EPackageImpl.initializeFromLoaded EPackage(EPackageImpl.java:1592)
at a.impl.APackageImpl.loadPackage(APackageImpl.java:180)
at a.c.d.impl.DPackageImpl.init(DPackageImpl.java:100)
at a.c.d.DPackage.<clinit>(DPackage.java:58)
... 7 more
Re: NPE in EPackageImpl.initializeFromLoadedEPackage when loadInitialization="true" [message #423414 is a reply to message #423408] Tue, 30 September 2008 05:05 Go to previous messageGo to next message
Andrew,
What version of EMF are you using? It sounds similar to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=242494 though I see you
have dummy classifiers which should avoid the problem. However, note
that load initialization is a GenPackage setting and you've set it true
on only one of the packages. I think the above bugzilla fixed the
problems associated with not having a consistent setting for that across
the contains subpackages. In any case, you should be able to avoid this
by setting it to false (given that you are creating smaller packages).
> as a result of a loadInitialization="true" being set in the genmodel.
> it was automatically set by the wizard.
> relate to this origin.
> explicitly setting loadInitialization="true". That example is included
> below.
> the implications of this might be. Presumably the wizard set this flag
> for a reason.
> wrong.
> xmlns:xmi="http://www.omg.org/XMI"
> </ecore:EPackage>
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
> </ecore:EPackage>
> </ecore:EPackage>
> </genClasses>
> </genPackages>
> The exception is
> at
> at
> ... 7 more
Re: NPE in EPackageImpl.initializeFromLoadedEPackage when loadInitialization="tr [message #423479 is a reply to message #423414] Tue, 30 September 2008 19:59 Go to previous messageGo to next message
Yeah I'd say it definitely relates in some way to that issue.
At least I understand now what causes the switch to loading an ecore file
vs creating the contents in Java - its the size of the package.
Unsurprisingly the package in question is one of the larger ones from my
initial refactoring of the model generated from the industry XSD's.
And since it compiled OK after I changed this flag to false I can be
comfortable that there are no other side effects. As I did not know why
the different approaches were used I had no idea whether there would be a
price to pay for changing this flag.
Note in my real application I never set this flag. It was set by the
wizard somehow. It was only set on the one package there so I did a
similar thing in my example gen model.
So it would appear that there is still a bug here somewhere but I can move
on with this workaround. Like you said, we will only make the packages
smaller over time never bigger.
thanks
Andrew
Ed Merks wrote:
> Andrew,
>> below.
>> for a reason.
>> wrong.
>> <?xml version="1.0" encoding="UTF-8"?>
>> </ecore:EPackage>
>> <eAnnotations
>> </eAnnotations>
>> </eClassifiers>
>> </ecore:EPackage>
>> </ecore:EPackage>
>> </ecore:EPackage>
>> </genClasses>
>> </genPackages>
>> The exception is
>> at
>> at
>> ... 7 more
Re: NPE in EPackageImpl.initializeFromLoadedEPackage when loadInitialization="tr [message #423489 is a reply to message #423479] Wed, 01 October 2008 06:52 Go to previous messageGo to next message
Andrew,
Comments below.
> file vs creating the contents in Java - its the size of the package.
> my initial refactoring of the model generated from the industry XSD's.
> why the different approaches were used I had no idea whether there
> would be a price to pay for changing this flag.
Yes, it's set automatically based on the huge size. For some reason,
only XML Schema based models seem to generate such huge models. I'm not
sure what it is about schemas that tempts people into making a single
massive namespace. From this basis, one never ends up with nested
EPackages though, so it wouldn't ever lead to this kind of issue...
> It was set by the wizard somehow. It was only set on the one package
> there so I did a similar thing in my example gen model.
> move on with this workaround.
Yes, and I think the related changes addressed that...
> Like you said, we will only make the packages smaller over time never
> bigger.
> thanks
> Andrew
> Ed Merks wrote:
>> Andrew,
>> true on only one of the packages. I think the above bugzilla fixed
>> the problems associated with not having a consistent setting for that
>> across the contains subpackages. In any case, you should be able to
>> avoid this by setting it to false (given that you are creating
>> smaller packages).
>>> MyPackage.eInstance as a result of a loadInitialization="true" being
>>> this, it was automatically set by the wizard.
>>> included below.
>>> what the implications of this might be. Presumably the wizard set
>>> this flag for a reason.
>>> wrong.
>>> </ecore:EPackage>
>>> <eAnnotations
>>> </eAnnotations>
>>> </eClassifiers>
>>> </ecore:EPackage>
>>> </ecore:EPackage>
>>> </ecore:EPackage>
>>> </genClasses>
>>> </genPackages>
>>> The exception is
>>> at
>>> at
>>> ... 7 more
Re: NPE in EPackageImpl.initializeFromLoadedEPackage when loadInitialization="tr [message #423545 is a reply to message #423489] Wed, 01 October 2008 20:10 Go to previous messageGo to next message
I think the problem with XML is that it is human readable. Of course that
is part of its benefit too.
The problem is that because its human readable people author XML directly
in a text editor. Obviously this is not practical for binary serialisation
schemes.
Consequently, XSD authors aim to make authoring XML documents based on
those schemas easy in text editors. Having everything in one namespace
simplifies this.
It also leads to people obsessing about exactly how the XML looks and
introducing annoying concepts like substitution groups.
Personally, I think if the world moved away from this mentality with XML
to thinking in terms of a model and XML simply as a serialisation
mechanism for that model, we'd all be better off.
IMO how a model is broken down into a hierarchy of packages is as an
important part of domain modeling for a large domain model. One that is
often overlooked
my 2c
Re: NPE in EPackageImpl.initializeFromLoadedEPackage when loadInitialization="tr [message #423559 is a reply to message #423545] Thu, 02 October 2008 07:47 Go to previous messageGo to next message
--------------040708020206060701080105
Andrew,
I agree. The obsession with pretty XML is detrimental in my opinion.
If your model has substitution groups, I'd suggest reading
http://ed-merks.blogspot.com/2007/12/winters-icy-grip.html
As you say, large schema size is likely driven by issues related to
namespaces in instance documents, rather than the overall design being
driven by a focus on decomposition into a hierarchy of logically related
groupings.
>> not sure what it is about schemas that tempts people into making a
>> single massive namespace. From this basis, one never ends up with
>> nested EPackages though, so it wouldn't ever lead to this kind of
>> issue...
> that is part of its benefit too.
> directly in a text editor. Obviously this is not practical for binary
> serialisation schemes.
> simplifies this.
> XML to thinking in terms of a model and XML simply as a serialisation
> is often overlooked
> my 2c
<html>
<head>
http-equiv="Content-Type">
</head>
Andrew,<br>
<br>
I agree.
Re: NPE in EPackageImpl.initializeFromLoadedEPackage when loadInitialization="tr [message #423610 is a reply to message #423559] Thu, 02 October 2008 19:48 Go to previous message
Thanks Ed. I have followed that blog a few weeks ago to get things
working. Since that I have built some auto refactoring for this XSD
originated model to break it into a package hierarchy and rid it of some
of the useless XML baggage like substitution groups. We can still import
from compliant documents that use substitution groups, but our internal
model is now cleaner.
Ed Merks wrote:
> Andrew,
> groupings.
>>> issue...
>> simplifies this.
>> is often overlooked
>> my 2c
Previous Topic:Trouble with Proxy Resolution
Next Topic:[Teneo] Invalid Hibernate Mappings for subclasses w/ ID Fields (bugzilla 176821)
Current Time: Thu Jul 24 21:34:04 EDT 2025
Powered by FUDForum. Page generated in 0.26805 seconds
