Home » Modeling » EMF » Handling Resource moves in Workspace
Handling Resource moves in Workspace [message #423360] Mon, 29 September 2008 09:55 Go to next message
Originally posted by: twominutehate.joinpoint.org
I'd like to know what the preferred way is to handle a move of a
resource, which is contained in a resource set, to a different location.
A WorkspaceSynchronizer looks out for such changes.
Is it better to use Resource.setURI() on the moved Resource, so I don't
have to reload anything?
Or should I rather create a fresh Resource instance at the destination
URI and move the contents from the old Resource to the new one?
Cheers Ömer
Re: Handling Resource moves in Workspace [message #423366 is a reply to message #423360] Mon, 29 September 2008 10:46 Go to previous messageGo to next message
Ömer,
Comments below.
Ömer Yildiz wrote:
It's an interesting question because while the workspace has a notion of
moving something, it's not something that's directly supported by EMF's
APIs...
> don't have to reload anything?
Changing the resource's URI to the new URI, saving it, and using the
URIConverter's delete method on the old URI would certainly do the
trick. If you need an actual workspace delta that's a move as opposed
to and add and a remove you'd have to use the workspace APIs directly...
It's probably easier to change the URI of the resource and do the save
and delete thing... It all depends on whether the details of the
resource delta that result are important...
> Cheers Ömer
Re: Handling Resource moves in Workspace [message #423396 is a reply to message #423366] Mon, 29 September 2008 16:16 Go to previous messageGo to next message
Hi Ed,
there's an issue using any of both methods.
Consider the following situation:
- Instance x* of class X.
- x* is contained in Resource R1.
- Instance y* of class Y.
- Y has a multi-valued containment reference "REF" to X.
- X has a opposite reference to its container.
- y* is contained in Resource R2.
Assume, that currently only R2 is loaded and the user moves R1 to
another directory. To set R1's new URI I first have to load it, of
course. But saving both Resources after that isn't enough, as REF
only contains a proxy object for x* in its list. The proxy's URI
doesn't get updated automatically, so saving R2 doesn't have any effect.
I could iterate through REF to resolve all proxies before saving, but
that seems somehow hacky and not generic enough for me.
Ed Merks schrieb:
> Ömer,
> Comments below.
> Ömer Yildiz wrote:
>> Hi,
> APIs...
>> Cheers Ömer
Re: Handling Resource moves in Workspace [message #423398 is a reply to message #423396] Mon, 29 September 2008 16:22 Go to previous message
Ömer,
Comments below.
Ömer Yildiz wrote:
> Hi Ed,
EcoreUtil.resolveAll applied to the resource set will ensure that all
resources are loaded and all proxies in them are resolved. You can use
the OPTION_SAVE_ONLY_IF_CHANGED so that only if the resource actually
needs to be saved will it be saved...
> Ed Merks schrieb:
> > Ömer,
> > Comments below.
> > Ömer Yildiz wrote:
> >> Hi,
> location.
> notion of
> > APIs...
> directly...
> >> Cheers Ömer
Previous Topic:EMF and JET generating a new package.
Next Topic:Manual Notificatios
Current Time: Sun Jul 27 14:07:44 EDT 2025
Powered by FUDForum. Page generated in 0.04395 seconds
