Home » Modeling » EMF » EMF + API Tools
EMF + API Tools [message #423331] Sun, 28 September 2008 16:46 Go to next message
Originally posted by: cdamus.zeligsoft.com
I have recently begun using the PDE's very cool API Tools in the Eclipse
OCL project. I am quite satisfied with the API tooling, but it raised a
problem that worries me, in the binary compatibility of EMF-generated
models.
The package meta-data interface has hordes of static int constants
identifying feature IDs. Users of a model API commonly use these in
switch statements in Adapters and related listener mechanisms. The API
tooling pointed out a binary-incompatible change when I re-generated
after adding a new attribute to one of the base classes in my model.
The problem is, that virtually all of the feature-ID constants in my
model changed because the feature-count of a base class was incremented,
and all of these feature IDs are based on the count of inherited
features. The reason why this is a binary compatibility issue is that
the Java compiler in-lined all of these constants into users' Adapter
code when they compiled against the previous OCL version.
What can I do to have the generator just assign new IDs in a
binary-compatible way?
Christian
Re: EMF + API Tools [message #423332 is a reply to message #423331] Sun, 28 September 2008 18:58 Go to previous messageGo to next message
Christian,
Comments below.
Christian W. Damus wrote:
> Eclipse OCL project. I am quite satisfied with the API tooling, but
> it raised a problem that worries me, in the binary compatibility of
> EMF-generated models.
> API tooling pointed out a binary-incompatible change when I
> re-generated after adding a new attribute to one of the base classes
> in my model.
Indeed, that's the "cost" of using a highly efficient switch mechanism...
> incremented, and all of these feature IDs are based on the count of
> inherited features.
Certainly all derived feature IDs will change when the base has a
feature added.
> The reason why this is a binary compatibility issue is that the Java
> compiler in-lined all of these constants into users' Adapter code when
Indded.
Nothing. The IDs are by designed offsets into the list of all
features. In the models we have "Binary Compatible Reflective Methods"
but we've done nothing for the switches on an adapter. After more than
6 years with this situation, no one has even expressed a concern about
the item provider issue. Go figure... :-P
> Christian
Re: EMF + API Tools [message #423334 is a reply to message #423332] Sun, 28 September 2008 21:47 Go to previous messageGo to next message
Hi, Ed,
So, you're saying that the feature IDs are an internal implementation
detail and should not be published in the package interface. Certainly,
it is an error for client code to reference the feature ID constants.
Is this widely known?
Luckily, the API tooling gives us the means to impose that restriction,
using the @noreference tag in the doc comments. I can apply that to my
OCL models as they change (currently, changes contributed to the
concrete-syntax model are throwing up red flags).
In the mean-time, perhaps EMF can help by any one of:
- optionally not publishing the feature IDs in the package interface
- optionally including an @noreference tag in the doc comment
for every feature ID. I should be able to do this for myself
with a dynamic template, for now
- adding the @noreference tag to the getFeatureID() method of the
Notifier class, so that clients will be discourage from a common
cause of referencing these constants
The problem with relying on the API tooling, of course, is that it
depends on a client using it and on having the API metadata available
(which generally isn't in an OCL build that one might have the target
environment). Even this change in the contract is, technically, a
breaking API change. However, that contract has already been broken in
every release ...
Christian
Ed Merks wrote:
> Christian,
> Comments below.
>> Hi,
>> in my model.
>> inherited features.
> feature added.
> Indded.
>> Thanks,
>> Christian
Re: EMF + API Tools [message #423350 is a reply to message #423334] Mon, 29 September 2008 08:03 Go to previous messageGo to next message
Christian,
Comments below.
> Hi, Ed,
I didn't hear me say that! :-P
> Certainly, it is an error for client code to reference the feature
> ID constants.
No, it's not. It all comes down to expectations. If you look at the
generated code for the binary compatible reflective methods you'll see
that such constants can be safely used even if their values change in a
binary incompatible way.
Don't you find it telling that this has not been raised as an issue in
the last 7 years? Binary compatibility is one of those holy grails that
no one questions and yet mostly folks build new versions of the software
and recompile... It's very easy after all to put a tight version range
bound to address an issue like this. You remember some of your reasons
for tight version range bounds on your Ecore dependencies? :-P
> restriction, using the @noreference tag in the doc comments. I can
> apply that to my OCL models as they change (currently, changes
> contributed to the concrete-syntax model are throwing up red flags).
Or you could just not change your model. Or add things only to leaf
classes... Just a like joke. :-P
Where to publish them then? They're needed in downstream derived
models. And even if we move them, the problem associated with them
doesn't change, it just moves...
We could have such an option.
It's not this method that has a problem. It could very well be compared
to dynamic computed feature IDs.
> in every release ...
Again, doesn't this tell you something?
The only other generated place the constants are used is in the item
providers, where we could do something similar to what we did for the
reflective methods or we could compare against feature instances instead
(optionally of course).
> Cheers,
> Christian
> Ed Merks wrote:
>> Christian,
>> Comments below.
>>> Hi,
>>> in my model.
>> mechanism...
>>> inherited features.
>> feature added.
>> Indded.
>> Methods" but we've done nothing for the switches on an adapter.
>> After more than 6 years with this situation, no one has even
>> expressed a concern about the item provider issue. Go figure... :-P
>>> Thanks,
>>> Christian
Re: EMF + API Tools [message #423371 is a reply to message #423350] Mon, 29 September 2008 10:52 Go to previous messageGo to next message
Hi, Ed,
More replies in-line, below.
Christian
Ed Merks wrote:
> Christian,
> Comments below.
>> Hi, Ed,
Oh, but I did. :-D You said that the IDs are offsets into the lists of
features. That's an implementation choice, and is the only reason why
they have to change when new features are added.
>> ID constants.
Yes, but that's a code pattern generated by EMF to work around its own
binary-incompatible changes. According to Eclipse's development
practices vis-a-vis API, this needs to be flagged to clients as an
exception to the rules of API evolution.
Folks have been lucky, I guess, that they haven't tried to upgrade the
plug-in that deploys an EMF-generated model while continuing to use a
plug-in that was compiled against an older version. I have seen code
that uses the feature IDs in switch statements, and which would
definitely break in an upgrade scenario.
Binary compatibility isn't a holy grail. It's quite practically
realizable. Especially with tools like the PDE available to help :-)
I did that because I knowingly implemented the discouraged practice of
extending Ecore. I wouldn't have, otherwise. A reasonable defence
mechanism for clients would be to treat the feature IDs as internal API
and use these narrow dependency ranges, yes.
Heh heh ... good one. :-)
Publish them on the package implementation class. Clients are already
discouraged from using it, so it's a natural home.
Oo! I would be happy to work on such an enhancement, if you're
interested. A GenModel option for API Tools support could add several
useful annotations:
- @noreference on the feature IDs
- @noimplement on all of the generated interfaces. Otherwise, API
Tools rightly flags additions of any new features (i.e., their
accessor methods) as incompatible changes
- @noreference on the *Impl classes, to formalize this convention
- @since tags on new API elements, being smart to determine the new
plug-in version number
There may be more, of course. I'm gradually discovering all of the API
flags that crop up when re-generating a model with new content.
Right, not a good idea.
That some of us have, for years, been missing an obvious problem that
PDE's API Tools have shone a big spotlight on. :-D
The item providers aren't a problem, though, are they? Because they are
regenerated and, hence, recompiled and redeployed together with the
model API.
>> Cheers,
>> Christian
>> Ed Merks wrote:
>>> Christian,
>>> Comments below.
>>>> Hi,
>>>> in my model.
>>> mechanism...
>>>> inherited features.
>>> feature added.
>>> Indded.
>>>> Thanks,
>>>> Christian
Re: EMF + API Tools [message #423374 is a reply to message #423371] Mon, 29 September 2008 11:43 Go to previous messageGo to next message
--------------090703000802080307080302
Christian,
Comments below.
> Hi, Ed,
> Christian
> Ed Merks wrote:
>> Christian,
>> Comments below.
>>> Hi, Ed,
>>> implementation detail and should not be published in the package
>>> interface.
> of features. That's an implementation choice,
I'd call it a design choice.
> and is the only reason why they have to change when new features are
> added.
They are designed to change...
>>> ID constants.
>> see that such constants can be safely used even if their values
>> change in a binary incompatible way.
It's a design that performs well.
> According to Eclipse's development practices vis-a-vis API, this
> needs to be flagged to clients as an exception to the rules of API
> evolution.
Contributions will be considered. :-P
>> in the last 7 years? Binary compatibility is one of those holy
>> grails that
100% lucky so far...
It's an ideal. I didn't say it's not achievable.
>> software and recompile... It's very easy after all to put a tight
>> version range bound to address an issue like this. You remember some
>> of your reasons for tight version range bounds on your Ecore
>> dependencies? :-P
> API and use these narrow dependency ranges, yes.
Yep.
Again, it just moves them.
> Clients are already discouraged from using it, so it's a natural home.
But clients with derived models need them.
> useful annotations:
> API flags that crop up when re-generating a model with new content.
This sounds cool. Sounds like a lot of work!
>> compared to dynamic computed feature IDs.
>>> available (which generally isn't in an OCL build that one might have
>>> the target environment). Even this change in the contract is,
>>> technically, a breaking API change. However, that contract has
>>> already been broken in every release ...
Yes, and also that potential problems often are *not *manifested as real
problems.
>> instead (optionally of course).
> are regenerated and, hence, recompiled and redeployed together with
> the model API.
Not if only the base class from a different model is changed. The
problem is the same as with the reflective accessors...
>>> Cheers,
>>> Christian
>>> Ed Merks wrote:
>>>> Christian,
>>>> Comments below.
>>>>> Hi,
>>>>> but it raised a problem that worries me, in the binary
>>>>> compatibility of EMF-generated models.
>>>>> in switch statements in Adapters and related listener mechanisms.
>>>>> The API tooling pointed out a binary-incompatible change when I
>>>> mechanism...
>>>>> my model changed because the feature-count of a base class was
>>>>> of inherited features.
>>>> feature added.
>>>> Indded.
>>>>> Thanks,
>>>>> Christian
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Christian,<br>
<br>
Comments below.<br>
<br>
<br>
<blockquote cite="mid:gbqq3c$kht$1@build.eclipse.org" type="cite">Hi,
Ed,
<br>
<br>
<br>
<br>
<br>
<br>
Christian
<br>
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Christian,
<br>
<br>
Comments below.
<br>
<br>
<br>
<blockquote type="cite">Hi, Ed,
<br>
<br>
<br>
</blockquote>
<br>
</blockquote>
<br>
Oh, but I did.&nbsp; :-D&nbsp; You said that the IDs are offsets into the lists
of features.&nbsp; That's an implementation choice, </blockquote>
I'd call it a design choice.<br>
<blockquote cite="mid:gbqq3c$kht$1@build.eclipse.org" type="cite">and
is the only reason why they have to change when new features are added.
<br>
</blockquote>
They are designed to change...<br>
<blockquote cite="mid:gbqq3c$kht$1@build.eclipse.org" type="cite"><br>
<br>
<blockquote type="cite">&nbsp; Certainly, it is an error for client code
<br>
</blockquote>
No, it's not.&nbsp; It all comes down to expectations.&nbsp; If you look at the
<br>
</blockquote>
<br>
binary-incompatible changes.</blockquote>
It's a design that performs well.<br>
<blockquote cite="mid:gbqq3c$kht$1@build.eclipse.org" type="cite">&nbsp;
According to Eclipse's development practices vis-a-vis API, this needs
to be flagged to clients as an exception to the rules of API evolution.
<br>
</blockquote>
Contributions will be considered. :-P<br>
<br>
<blockquote type="cite">Is this widely known?
<br>
</blockquote>
the last 7 years?&nbsp; Binary compatibility is one of those holy grails
that </blockquote>
<br>
plug-in that was compiled against an older version.&nbsp; I have seen code
<br>
</blockquote>
100% lucky so far...<br>
Binary compatibility isn't a holy grail.&nbsp; It's quite practically
realizable.&nbsp; Especially with tools like the PDE available to help&nbsp; :-)
<br>
</blockquote>
It's an ideal.&nbsp; I didn't say it's not achievable.&nbsp; <br>
<br>
<blockquote type="cite">no one questions and yet mostly folks build
new versions of the software and recompile...&nbsp; It's very easy after all
to put a tight version range bound to address an issue like this.&nbsp; You
remember some of your reasons for tight version range bounds on your
<br>
</blockquote>
<br>
extending Ecore.&nbsp; I wouldn't have, otherwise.&nbsp; A reasonable defence
<br>
</blockquote>
Yep.<br>
<br>
<blockquote type="cite">Luckily, the API tooling gives us the means
to impose that restriction, using the @noreference tag in the doc
comments.&nbsp; I can apply that to my OCL models as they change (currently,
changes contributed to the concrete-syntax model are throwing up red
flags).
<br>
</blockquote>
Or you could just not change your model.&nbsp; Or add things only to leaf
classes...&nbsp; Just a like joke. :-P
<br>
</blockquote>
<br>
Heh heh ... good one.&nbsp; :-)
<br>
<br>
<br>
<blockquote type="cite">In the mean-time, perhaps EMF can help by
any one of:
<br>
<br>
&nbsp; - optionally not publishing the feature IDs in the package interface
<br>
</blockquote>
Where to publish them then?&nbsp; They're needed in downstream derived
models.&nbsp; And even if we move them, the problem associated with them
<br>
</blockquote>
<br>
Publish them on the package implementation class. <br>
</blockquote>
Again, it just moves them.<br>
<br>
</blockquote>
But clients with derived models need them.<br>
<br>
<blockquote type="cite">&nbsp; - optionally including an @noreference
<br>
&nbsp;&nbsp;&nbsp; for every feature ID.&nbsp; I should be able to do this for myself
<br>
&nbsp;&nbsp;&nbsp; with a dynamic template, for now
<br>
</blockquote>
<br>
</blockquote>
<br>
Oo!&nbsp; I would be happy to work on such an enhancement, if you're
interested.&nbsp; A GenModel option for API Tools support could add several
useful annotations:
<br>
<br>
&nbsp; - @noreference on the feature IDs
<br>
&nbsp; - @noimplement on all of the generated interfaces.&nbsp; Otherwise, API
<br>
&nbsp;&nbsp;&nbsp; Tools rightly flags additions of any new features (i.e., their
<br>
&nbsp;&nbsp;&nbsp; accessor methods) as incompatible changes
<br>
&nbsp; - @noreference on the *Impl classes, to formalize this convention
<br>
&nbsp; - @since tags on new API elements, being smart to determine the new
<br>
&nbsp;&nbsp;&nbsp; plug-in version number
<br>
<br>
There may be more, of course.&nbsp; I'm gradually discovering all of the API
<br>
</blockquote>
This sounds cool.&nbsp; Sounds like a lot of work!<br>
<br>
<blockquote type="cite">&nbsp; - adding the @noreference tag to the
<br>
&nbsp;&nbsp;&nbsp; Notifier class, so that clients will be discourage from a common
<br>
&nbsp;&nbsp;&nbsp; cause of referencing these constants
<br>
</blockquote>
It's not this method that has a problem.&nbsp; It could very well be
<br>
</blockquote>
<br>
<br>
<br>
<br>
<blockquote type="cite">The problem with relying on the API
tooling, of course, is that it depends on a client using it and on
having the API metadata available (which generally isn't in an OCL
build that one might have the target environment).&nbsp; Even this change in
the contract is, technically, a breaking API change.&nbsp; However, that
contract has already been broken in every release ...
<br>
</blockquote>
<br>
</blockquote>
<br>
PDE's API Tools have shone a big spotlight on.&nbsp; :-D
<br>
</blockquote>
Yes, and also that potential problems often are <b>not </b>manifested
as real problems.<br>
<br>
<blockquote type="cite">The only other generated place the constants
are used is in the item providers, where we could do something similar
to what we did for the reflective methods or we could compare against
feature instances instead (optionally of course).
<br>
</blockquote>
<br>
The item providers aren't a problem, though, are they?&nbsp; Because they
are regenerated and, hence, recompiled and redeployed together with the
model API.
<br>
</blockquote>
Not if only the base class from a different model is changed.&nbsp; The
problem is the same as with the reflective accessors...<br>
<blockquote type="cite"><br>
<br>
<br>
Christian
<br>
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
Comments below.
<br>
<br>
<br>
<br>
<br>
<br>
Eclipse OCL project.&nbsp; I am quite satisfied with the API tooling, but it
<br>
<br>
identifying feature IDs.&nbsp; Users of a model API commonly use these in
switch statements in Adapters and related listener mechanisms.&nbsp; The API
<br>
</blockquote>
mechanism...
<br>
inherited features.
<br>
</blockquote>
feature added.
<br>
<blockquote type="cite">The reason why this is a binary
compatibility issue is that the Java compiler in-lined all of these
constants into users' Adapter code when they compiled against the
<br>
</blockquote>
Indded.
<br>
<br>
</blockquote>
Nothing.&nbsp; The IDs are by designed offsets into the list of all
features.&nbsp; In the models we have "Binary Compatible Reflective Methods"
but we've done nothing for the switches on an adapter.&nbsp; After more than
the item provider issue.&nbsp; Go figure... :-P
<br>
<br>
<br>
Christian
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------090703000802080307080302--
Re: EMF + API Tools [message #423380 is a reply to message #423374] Mon, 29 September 2008 12:27 Go to previous messageGo to next message
I know this sounds strange but how much does this inlining bring if you
don't declare them as literals?
E.g. Databinding uses the following trick.
-------8<-------
public static int POLICY_NEVER = notInlined(1);
private static int notInlined(int i) {
return i;
-------8<-------
Tom
Ed Merks schrieb:
> Christian,
> Comments below.
>> Hi, Ed,
>> Thanks,
>> Christian
>> Ed Merks wrote:
>>> Christian,
>>> Comments below.
>>>> Hi, Ed,
>>>> interface.
>> added.
>>>> ID constants.
>> evolution.
>>> grails that
>>> dependencies? :-P
> Yep.
>> useful annotations:
> problems.
>> the model API.
>>>> Cheers,
>>>> Christian
>>>> Ed Merks wrote:
>>>>> Christian,
>>>>> Comments below.
>>>>>> Hi,
>>>>> mechanism...
>>>>> feature added.
>>>>> Indded.
>>>>>> Thanks,
>>>>>> Christian
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: EMF + API Tools [message #423381 is a reply to message #423380] Mon, 29 September 2008 12:32 Go to previous messageGo to next message
--------------080405040507040203060300
Tom,
Comments below.
> -------8<-------
The values are used in a switch, which requires a compile time
constant. The intent is to provide constant time dispatch on features...
> return i;
> -------8<-------
> Tom
> Ed Merks schrieb:
>> Christian,
>> Comments below.
>>> Hi, Ed,
>>> Thanks,
>>> Christian
>>> Ed Merks wrote:
>>>> Christian,
>>>> Comments below.
>>>>> Hi, Ed,
>>>>> interface.
>>> added.
>>>>> ID constants.
>>> evolution.
>>>> grails that
>>>> dependencies? :-P
>> Yep.
>>> useful annotations:
>> problems.
>>> the model API.
>>>>> Cheers,
>>>>> Christian
>>>>> Ed Merks wrote:
>>>>>> Christian,
>>>>>> Comments below.
>>>>>>> Hi,
>>>>>> mechanism...
>>>>>> feature added.
>>>>>> Indded.
>>>>>>> Thanks,
>>>>>>> Christian
<html>
<head>
</head>
Tom,<br>
<br>
Comments below.<br>
<br>
Tom Schindl wrote:
<blockquote cite="mid:gbqvm9$gd5$1@build.eclipse.org" type="cite">
<pre wrap="">I know this sounds strange but how much does this inlining bring if you
-------8&lt;-------
</pre>
</blockquote>
constant.&nbsp; The intent is to provide constant time dispatch on
features...<br>
<pre wrap="">
return i;
-------8&lt;-------
Tom
Ed Merks schrieb:
</pre>
<pre wrap="">Christian,
Comments below.
</pre>
<pre wrap="">Hi, Ed,
Christian
Ed Merks wrote:
</pre>
Comments below.
</pre>
interface.
</pre>
</blockquote>
<pre wrap="">I didn't hear me say that! :-P
</pre>
</blockquote>
<pre wrap="">Oh, but I did. :-D You said that the IDs are offsets into the lists
</pre>
</blockquote>
<pre wrap="">I'd call it a design choice.
</pre>
<pre wrap="">and is the only reason why they have to change when new features are
added.
</pre>
</blockquote>
<pre wrap="">They are designed to change...
</pre>
<pre wrap="">
</pre>
<pre wrap=""> Certainly, it is an error for client code to reference the feature
ID constants.
</pre>
</blockquote>
<pre wrap="">No, it's not. It all comes down to expectations. If you look at the
</pre>
</blockquote>
<pre wrap="">Yes, but that's a code pattern generated by EMF to work around its own
</pre>
</blockquote>
<pre wrap="">It's a design that performs well.
</pre>
<pre wrap=""> According to Eclipse's development practices vis-a-vis API, this
evolution.
</pre>
</blockquote>
<pre wrap="">Contributions will be considered. :-P
</pre>
<pre wrap="">
</pre>
<pre wrap="">Is this widely known?
</pre>
</blockquote>
<pre wrap="">Don't you find it telling that this has not been raised as an issue
grails that
</pre>
</blockquote>
<pre wrap="">Folks have been lucky, I guess, that they haven't tried to upgrade the
</pre>
</blockquote>
<pre wrap="">100% lucky so far...
</pre>
<pre wrap="">Binary compatibility isn't a holy grail. It's quite practically
</pre>
</blockquote>
<pre wrap="">It's an ideal. I didn't say it's not achievable.
</pre>
<pre wrap="">
</pre>
<pre wrap="">no one questions and yet mostly folks build new versions of the
dependencies? :-P
</pre>
</blockquote>
<pre wrap="">I did that because I knowingly implemented the discouraged practice of
</pre>
</blockquote>
<pre wrap="">Yep.
</pre>
<pre wrap="">
</pre>
<pre wrap="">Luckily, the API tooling gives us the means to impose that
</pre>
</blockquote>
<pre wrap="">Or you could just not change your model. Or add things only to leaf
</pre>
</blockquote>
<pre wrap="">Heh heh ... good one. :-)
</pre>
<pre wrap="">In the mean-time, perhaps EMF can help by any one of:
</pre>
</blockquote>
<pre wrap="">Where to publish them then? They're needed in downstream derived
</pre>
</blockquote>
<pre wrap="">Publish them on the package implementation class.
</pre>
</blockquote>
<pre wrap="">Again, it just moves them.
</pre>
<pre wrap="">Clients are already discouraged from using it, so it's a natural home.
</pre>
</blockquote>
<pre wrap="">But clients with derived models need them.
</pre>
<pre wrap="">
</pre>
<pre wrap=""> - optionally including an @noreference tag in the doc comment
</pre>
</blockquote>
<pre wrap="">We could have such an option.
</pre>
</blockquote>
<pre wrap="">Oo! I would be happy to work on such an enhancement, if you're
useful annotations:
</pre>
</blockquote>
<pre wrap="">This sounds cool. Sounds like a lot of work!
</pre>
<pre wrap="">
</pre>
<pre wrap=""> - adding the @noreference tag to the getFeatureID() method of the
</pre>
</blockquote>
<pre wrap="">It's not this method that has a problem. It could very well be
</pre>
</blockquote>
<pre wrap="">Right, not a good idea.
</pre>
<pre wrap="">The problem with relying on the API tooling, of course, is that it
</pre>
</blockquote>
<pre wrap="">Again, doesn't this tell you something?
</pre>
</blockquote>
<pre wrap="">That some of us have, for years, been missing an obvious problem that
</pre>
</blockquote>
<pre wrap="">Yes, and also that potential problems often are *not *manifested as real
problems.
</pre>
<pre wrap="">
</pre>
<pre wrap="">The only other generated place the constants are used is in the item
</pre>
</blockquote>
<pre wrap="">The item providers aren't a problem, though, are they? Because they
the model API.
</pre>
</blockquote>
<pre wrap="">Not if only the base class from a different model is changed. The
</pre>
<pre wrap="">Cheers,
Christian
Ed Merks wrote:
</pre>
Comments below.
</pre>
<pre wrap="">Hi,
</pre>
</blockquote>
<pre wrap="">Indeed, that's the "cost" of using a highly efficient switch
mechanism...
</pre>
<pre wrap="">The problem is, that virtually all of the feature-ID constants in
</pre>
</blockquote>
<pre wrap="">Certainly all derived feature IDs will change when the base has a
feature added.
</pre>
<pre wrap="">The reason why this is a binary compatibility issue is that the
</pre>
</blockquote>
<pre wrap="">Indded.
</pre>
<pre wrap="">What can I do to have the generator just assign new IDs in a
</pre>
</blockquote>
<pre wrap="">Nothing. The IDs are by designed offsets into the list of all
</pre>
<pre wrap="">Thanks,
Christian
</pre>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
</body>
</html>
--------------080405040507040203060300--
Re: EMF + API Tools [message #423383 is a reply to message #423380] Mon, 29 September 2008 12:39 Go to previous messageGo to next message
Hi, Tom,
The problem with this pattern is that the compiler won't allow
POLICY_NEVER in a switch statement, which requires a constant value.
It's in switches that these values are commonly used.
cW
> -------8<-------
> return i;
> -------8<-------
> Tom
> Ed Merks schrieb:
>> Christian,
>> Comments below.
>>> Hi, Ed,
>>> Thanks,
>>> Christian
>>> Ed Merks wrote:
>>>> Christian,
>>>> Comments below.
>>>>> Hi, Ed,
>>>>> interface.
>>> added.
>>>>> ID constants.
>>> evolution.
>>>> grails that
>>>> dependencies? :-P
>> Yep.
>>> useful annotations:
>> problems.
>>> the model API.
>>>>> Cheers,
>>>>> Christian
>>>>> Ed Merks wrote:
>>>>>> Christian,
>>>>>> Comments below.
>>>>>>> Hi,
>>>>>> mechanism...
>>>>>> feature added.
>>>>>> Indded.
>>>>>>> Thanks,
>>>>>>> Christian
Re: EMF + API Tools [message #423384 is a reply to message #423374] Mon, 29 September 2008 12:46 Go to previous message
Hi, Ed,
Thanks for being patient with me. I know it's a game of probabilities
.... I'm on a bit of an API kick at the moment.
I'll scope out the effort of the generator enhancements for API tooling
integration before I decide whether I can commit to it. I'd really like
to see it happen, because it'll be a win/win for usability of both EMF
and the API Tools in the same context.
cW
Ed Merks wrote:
> Christian,
> Comments below.
>> Hi, Ed,
>> Thanks,
>> Christian
>> Ed Merks wrote:
>>> Christian,
>>> Comments below.
>>>> Hi, Ed,
>>>> interface.
>> added.
>>>> ID constants.
>> evolution.
>>> grails that
>>> dependencies? :-P
> Yep.
>> useful annotations:
> problems.
>> the model API.
>>>> Cheers,
>>>> Christian
>>>> Ed Merks wrote:
>>>>> Christian,
>>>>> Comments below.
>>>>>> Hi,
>>>>> mechanism...
>>>>> feature added.
>>>>> Indded.
>>>>>> Thanks,
>>>>>> Christian
Previous Topic:How can i poof an elis datat?
Next Topic:EMF and JET generating a new package.
Current Time: Wed Jul 23 18:25:24 EDT 2025
Powered by FUDForum. Page generated in 0.05070 seconds
