Handling Resource moves in Workspace [message #423360] |
Mon, 29 September 2008 09:55  |
Originally posted by: twominutehate.joinpoint.org
I'd like to know what the preferred way is to handle a move of a
resource, which is contained in a resource set, to a different location.
A WorkspaceSynchronizer looks out for such changes.
Is it better to use Resource.setURI() on the moved Resource, so I don't
have to reload anything?
Or should I rather create a fresh Resource instance at the destination
URI and move the contents from the old Resource to the new one?
Cheers Ömer
Re: Handling Resource moves in Workspace [message #423396 is a reply to message #423366] |
Mon, 29 September 2008 16:16   |
Hi Ed,
there's an issue using any of both methods.
Consider the following situation:
- Instance x* of class X.
- x* is contained in Resource R1.
- Instance y* of class Y.
- Y has a multi-valued containment reference "REF" to X.
- X has a opposite reference to its container.
- y* is contained in Resource R2.
Assume, that currently only R2 is loaded and the user moves R1 to
another directory. To set R1's new URI I first have to load it, of
course. But saving both Resources after that isn't enough, as REF
only contains a proxy object for x* in its list. The proxy's URI
doesn't get updated automatically, so saving R2 doesn't have any effect.
I could iterate through REF to resolve all proxies before saving, but
that seems somehow hacky and not generic enough for me.
Ed Merks schrieb:
> Ömer,
> Comments below.
> Ömer Yildiz wrote:
>> Hi,
> It's an interesting question because while the workspace has a notion of
> moving something, it's not something that's directly supported by EMF's
> APIs...
>> don't have to reload anything?
> Changing the resource's URI to the new URI, saving it, and using the
> URIConverter's delete method on the old URI would certainly do the
> trick. If you need an actual workspace delta that's a move as opposed
> to and add and a remove you'd have to use the workspace APIs directly...
> It's probably easier to change the URI of the resource and do the save
> and delete thing... It all depends on whether the details of the
> resource delta that result are important...
>> Cheers Ömer
Re: Handling Resource moves in Workspace [message #423398 is a reply to message #423396] |
Mon, 29 September 2008 16:22  |
Ömer,
Comments below.
Ömer Yildiz wrote:
> Hi Ed,
EcoreUtil.resolveAll applied to the resource set will ensure that all
resources are loaded and all proxies in them are resolved. You can use
the OPTION_SAVE_ONLY_IF_CHANGED so that only if the resource actually
needs to be saved will it be saved...
> Ed Merks schrieb:
> > Ömer,
> > Comments below.
> > Ömer Yildiz wrote:
> >> Hi,
> location.
> notion of
> > APIs...
> directly...
> >> Cheers Ömer
FUDForum. Page generated in 0.25829 seconds
