Home » Modeling » EMF » Programatically refactoring ecore models
Programatically refactoring ecore models [message #423283] |
Fri, 26 September 2008 04:00  |
I am in the process of splitting a large ecore model into several ecore
models. I am doing this in a number of steps and hit something odd.
For one step I am basically moving packages into subpackages and also
moving some classes into different packages.
I am using the ecore to ecore mappings mainly cause I could use the UI to
do the mapping but am reading and processing the mappings myself.
On the target ecore side is a skeleton package hierarchy. The mappings map
either a package or a set of classes from the source model into a pacakge
on the target model.
The main processing code looks somewhat like this
private void process(Mapping mapping) {
EList<EObject> inputs = mapping.getInputs();
for (EObject i : inputs) {
if (i instanceof EPackage) {
EPackage inputPackage = (EPackage)i;
outPackage.getESubpackages().add(inputPackage);
else if (i instanceof EClassifier) {
EClassifier inputClassifier = (EClassifier)i;
outPackage.getEClassifiers().add(inputClassifier);
After this has finished I then split the target model up so that every
package is in its own ecore file as follows
public void createResources(EPackage pkg, String baseNSURI, String
ecoreFileDirPath) throws IOException {
String packagePath = ecoreFileDirPath + "/" + pkg.getName();
String packageNSURI = baseNSURI + "/" + pkg.getName();
pkg.setNsURI(packageNSURI);
pkg.setNsPrefix(pkg.getName());
createFileResourceFor(packagePath + ".ecore", pkg);
EList<EPackage> subpackages = pkg.getESubpackages();
for (EPackage child : subpackages) {
createResources(child, packageNSURI, packagePath);
And then I save it. It works but many of the serialised references are
pointing to the old ecore files.
e.g.
<eClassifiers xsi:type="ecore:EClass" name="Foo"
eSuperTypes="../../oldecorefile.ecore#//Bar">
However, when I tried to debug this by doing the following from inside
process method, the problem went away for many of the cases. So it seems
there must be a cached reference somewhere that gets reevaluated when I
access the classes.
private void touch(EClassifier classifier) {
System.err.println("touching classifier " + classifier);
if (classifier instanceof EClass) {
EClass c = (EClass)classifier;
EList<EClass> superTypes = c.getESuperTypes();
for (EClass parent : superTypes) {
System.out.println("supertype " + parent);
EList<EStructuralFeature> features = c.getEStructuralFeatures();
for (EStructuralFeature sf : features) {
System.out.println("feature " + sf);
sf.getEType();
So what am I doing wrong and what should I be doing to get this to work?
Re: Programatically refactoring ecore models [message #423292 is a reply to message #423283] |
Fri, 26 September 2008 07:42   |
--------------070709020409040504060807
Andrew,
Comments below.
> ecore models. I am doing this in a number of steps and hit something odd.
I imagine this is fairly painful!
> moving some classes into different packages. I am using the ecore to
> ecore mappings mainly cause I could use the UI to do the mapping but
I see. (It didn't help that there was a bug in the recipe, which is now
fixed.)
> map either a package or a set of classes from the source model into a
> pacakge on the target model.
Keep in mind that adding the inputPackage as child of the outPackage
will remove it from any container it currently has. So if
inputPackage.eContainer() != null before, this might well be a bad approach.
Note that EPackage.eSubpackages supports cross resource containment
(resolveProxies is true) and hence adding the subpackage to a different
resource doesn't remove it from its container...
Are you saving after having put *everything *in a new resource?
> e.g. <eClassifiers xsi:type="ecore:EClass" name="Foo"
> seems there must be a cached reference somewhere that gets reevaluated
> when I access the classes.
Keep in mind too that proxies are resolve on demand. So if you don't do
something to resolve them, they'll indeed cache exactly the URI
(although resolved against the URI of the containing document to make it
absolute) as it had in the file.
> sf.getEType();
Calling EcoreUtil.resolveAll on the resource set or resource before you
being tearing it apart will ensure that all proxies are resolve and that
no objects will be holding references to proxies with cached old URIs.
<html>
<head>
http-equiv="Content-Type">
</head>
Andrew,<br>
<br>
Comments below.<br>
<br>
Andrew H wrote:
<blockquote
cite="mid:b9830b772b7fae8fb1ed26dbb33537c5$1@www.eclipse.org"
type="cite">I am in the process of splitting a large ecore model into
several ecore models. I am doing this in a number of steps and hit
something odd.
<br>
</blockquote>
I imagine this is fairly painful!<br>
<blockquote
type="cite"><br>
ecore mappings mainly cause I could use the UI to do the mapping but am
<br>
</blockquote>
I see.
Re: Programatically refactoring ecore models [message #423335 is a reply to message #423292] |
Sun, 28 September 2008 21:48   |
Thanks Ed
The EcoreUtil.resolveAll seemed to fix the problem.
BTW I haven't been able to find any doco on how to execute an ecore2ecore
mapping. i.e. once I have created an ecore2ecore mapping then how do I run
that on a source model?
Further comments inline
Ed Merks wrote:
> Andrew,
> Comments below.
Somewhat. Would have been much easier if the original schemas were broken
down well into a hierarchy of packages.
> I see. (It didn't help that there was a bug in tEcoreUtil.resolveAllhe
> fixed.)
Wasn't aware of that. I don't think I ran into a bug??
Yeah I'm aware of that and in fact relying on it. Its really a trick for
minimising the amount of work I need to do to do the refactoring.
Basically I load the ecore files in one resource set, then manipulate them
and save them in a different resource set. The first resource set is then
tossed.
The intent is actually to treat them as copies but it cuts down on a fair
bit of code this way I believe. i.e. I can just pick up a package with all
its children and stick it in a new ecore file and make it the child of
another package.
I do concede though that it would be cleaner to actually make copies.
I put every package in a new ecore file (one package per file). I am
assuming that when I do resource.getContents().add(pkg), that it will be
unplugged from the old resource and plugged into the new.
Yes. Every package is now in a separate resource in the one resource set.
Then I save the whole resource set.
This must have been what bit me.
>> sf.getEType();
This did the trick. thanks
Re: Programatically refactoring ecore models [message #423347 is a reply to message #423335] |
Mon, 29 September 2008 07:30  |
--------------070803030904050004000809
Andrew,
This recipe show one use of ecore2ecore mapping.
<http://wiki.eclipse.org/EMF/Recipes#Recipe:_Data_Migration>
By themselves, mappings are purely declarative. They don't do or mean
anything, but can act as input to something else that gives them
specific meaning...
Andrew H wrote:
> Thanks Ed
> ecore2ecore mapping. i.e. once I have created an ecore2ecore mapping
> then how do I run that on a source model?
> Ed Merks wrote:
>> Andrew,
>> Comments below.
>>> odd.
> broken down well into a hierarchy of packages.
>>> also moving some classes into different packages. I am using the
>>> ecore to ecore mappings mainly cause I could use the UI to do the
>> fixed.)
>>> mappings map either a package or a set of classes from the source
>>> model into a pacakge on the target model.
>> approach.
> for minimising the amount of work I need to do to do the refactoring.
> them and save them in a different resource set. The first resource set
> is then tossed.
> fair bit of code this way I believe. i.e. I can just pick up a package
> with all its children and stick it in a new ecore file and make it the
> child of another package.
>>> every package is in its own ecore file as follows
>> different resource doesn't remove it from its container...
> be unplugged from the old resource and plugged into the new.
>>> are pointing to the old ecore files.
> set. Then I save the whole resource set.
>>> reevaluated when I access the classes.
>> do something to resolve them, they'll indeed cache exactly the URI
>> it absolute) as it had in the file.
>>> sf.getEType();
>>> work?
>> you being tearing it apart will ensure that all proxies are resolve
>> and that no objects will be holding references to proxies with cached
>> old URIs.
<html>
<head>
</head>
Andrew,<br>
<br>
This recipe show one use of ecore2ecore mapping.<a
href="http://wiki.eclipse.org/EMF/Recipes#Recipe:_Data_Migration"><br>
</a>
<blockquote><a
href="http://wiki.eclipse.org/EMF/Recipes#Recipe:_Data_Migration">http://wiki.eclipse.org/EMF/Recipes#Recipe:_Data_Migration</a><br>
</blockquote>
Current Time: Sat Jul 26 03:57:25 EDT 2025
Powered by FUDForum. Page generated in 0.05683 seconds
