Detecting unresolvable Resources [message #423239] |
Thu, 25 September 2008 07:42  |
Originally posted by: andreas-scharf.gmx.de
In my model I have two objects A and B, where A is referencing (not
containing!) B's. The A's and B's are serialized into different files.
In my GEF based editor I can open and edit A's and B's. Now I'm fighting
a bit with this scenario: Let's say the user created A.xmi and B.xmi. in
A.xmi he referenced B.xmi. Then (maybe outside my editor or even outside
the workbench of my rcp) he deletes B.xmi.
What's the best way to detect the unresolvable B instance in A.xmi
during loading A.xmi into my GEF based editor? Something like
allResolvable(eObject) would be great which returns something like a
status which objects cannot be resolved (since their underlying file
doesn't exist anymore). Then I could clean A.xmi to no longer reference
the missing B and display a message to the user.
Any hints a greatly appreciated.
Andreas
Re: Detecting unresolvable Resources [message #423266 is a reply to message #423265] |
Thu, 25 September 2008 11:51   |
Originally posted by: cdamus.zeligsoft.com
Hi, Andreas,
I think that should be safe: check for resources that are !isLoaded and
that have errors, and just remove them. For good measure, cleare their
eAdapters() lists, too.
As you're in a transactional context, you should do that in a
runExclusive() to ensure that somebody doesn't concurrently attempt any
proxy resolutions on the same unresolved proxies.
HTH,
Christian
Andreas Scharf wrote:
> Ed,
> I've got another question: Currently I'm trying to keep the resourceset
> of my TransactionalEditingDomain as clean as possible. Due to the check
> of the EcoreUtil.UnresolvedProxyCrossReferencer, the unresolvable
> resourcres are now contained in the resourceset. Is there any option to
> tell the CrossReferencer (or something else) to remove the unresolvable
> resources from the resourceset? Or do I have to do that manually after
> the call EcoreUtil.UnresolvedProxyCrossReferencer.find(r)? I would
> remove all resources from the resourceset which contain errors. Is that
> safe?
> Andreas
> Andreas Scharf schrieb:
>> Ed,
>> that's exactly what I was looking for. Many thanks for the fast reply.
>> Andreas
>> Ed Merks schrieb:
>>> Andreas,
>>> Comments below.
>>>> Hi,
>>>> fighting a bit with this scenario: Let's say the user created A.xmi
>>>> and B.xmi. in A.xmi he referenced B.xmi. Then (maybe outside my
>>>> editor or even outside the workbench of my rcp) he deletes B.xmi.
>>>> reference the missing B and display a message to the user.
>>> EcoreUtil.UnresolvedProxyCrossReferencer is useful for that.
>>>> Cheers,
>>>> Andreas
Re: Detecting unresolvable Resources [message #423268 is a reply to message #423265] |
Thu, 25 September 2008 12:01   |
Andreas,
Comments below.
> Ed,
> resourceset of my TransactionalEditingDomain as clean as possible. Due
> to the check of the EcoreUtil.UnresolvedProxyCrossReferencer, the
> unresolvable resourcres are now contained in the resourceset. Is there
> any option to tell the CrossReferencer (or something else) to remove
> the unresolvable resources from the resourceset? Or do I have to do
> that manually after the call
> EcoreUtil.UnresolvedProxyCrossReferencer.find(r)? I would remove all
> resources from the resourceset which contain errors. Is that safe?
Each time you access the proxy via the instance model, the framework
will try to resolve it and hence will demand load a resource for it
again. When you're cleaning up the proxies you can cast each one to
InternalEObject to call eProxyURI. If the resource referenced by that
proxy URI is empty (and the Resource.getErrors() isn't empty) you could
remove it from the resource set as part of the cleanup phase.
> Andreas
>> Ed,
>> Andreas
>> Ed Merks schrieb:
>>> Andreas,
>>> Comments below.
>>>> Hi,
>>>> a status which objects cannot be resolved (since their underlying
>>>> file doesn't exist anymore). Then I could clean A.xmi to no longer
>>>> Cheers,
>>>> Andreas
Re: Detecting unresolvable Resources [message #423285 is a reply to message #423268] |
Fri, 26 September 2008 06:10  |
Christan and Ed,
thanks for the hints. I'll try that out.
Andreas
Ed Merks schrieb:
> Andreas,
> Comments below.
>> Ed,
>> Thanks,
>> Andreas
>>> Ed,
>>> Andreas
>>> Ed Merks schrieb:
>>>> Andreas,
>>>> Comments below.
>>>>> Hi,
>>>>> Cheers,
>>>>> Andreas
FUDForum. Page generated in 0.07122 seconds
