Home » Modeling » EMF » NullPointerException in XMLSaveImpl.saveDataTypeMany
NullPointerException in XMLSaveImpl.saveDataTypeMany [message #423245] |
Thu, 25 September 2008 08:36  |
This error comes up when I run the XYZExample test code, disguised as/copied to a UnitTest in maven. (ie outside the eclipse editor).
It runs fine from within eclipse/junit. I figured it must have something to do with
http://wiki.eclipse.org/index.php/EMF-FAQ#How_do_I_use_EMF_i n_standalone_applications_.28such_as_an_ordinary_main.29.3F,
does it?
The error is
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveDataTypeMany( XMLSaveImpl.java:1742)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1485)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.writeTopObject(XM LSaveImpl.java:678)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:588)
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:256)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:205)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:1344)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:986)
Code:
MyModel1Package.eINSTANCE.eClass();
MyModel2Package.eINSTANCE.eClass();
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put
("ext1", new MyModel1ResourceFactoryImpl());
(Resource.Factory.Registry.DEFAULT_EXTENSION,
new MyModel2ResourceFactoryImpl());
Resource resource = resourceSet.createResource(URI.createURI("http:///My.model.uri"));
DocumentRoot documentRoot = MyModel2Factory.eINSTANCE.createDocumentRoot();
// ---- Removing the next two lines makes it work from maven too.
ActivitiesType root = MyModel2Factory.eINSTANCE.createActivitiesType();
documentRoot.setActivities(root);
resource.getContents().add(documentRoot);
resource.save(System.out, null);
Many thanks,
Ronaldo
Ed Merks wrote:
> Ronaldo,
> Comments below.
> Ronaldo wrote:
>> Hi Ed,
>> Thanks for the quick answer. Yes, I have 2 models in 2 different
>> eclipse projects.
>> They both use a null target namespace, in order to eliminate the
>> prefixes in the xml.
> XML documents with at least a namespace for the root element are
> generally more consumable because they identify their schema...
>> I was just wondering what (which setting) causes the code
>> result.getDefaultSaveOptions().put(
>> XMLResource.OPTION_EXTENDED_META_DATA, extendedMetaData);
> A null target namespace schema produces an annotation on the EPackage to
> indicate the package is not qualified.
>> to be generated. (as opposed to
>> XMLResource.OPTION_EXTENDED_META_DATA, Boolean.TRUE);
> This package doesn't have such an annotation.
> Note that you can't have two different packages that both want to be the
> one for the null namespace both working at the same time.
>> Ronaldo
Re: NullPointerException in XMLSaveImpl.saveDataTypeMany [message #423246 is a reply to message #423245] |
Thu, 25 September 2008 09:01   |
> does it?
> The error is
It's dying because the data type doesn't have a containing package and
hence we get a null pointer exception trying to get the factory for that
package?
EDataType d = (EDataType)f.getEType();
EPackage ePackage = d.getEPackage();
EFactory fac = ePackage.getEFactoryInstance();
> Code:
> Resource resource =
This looks much like the generated XyzExample you get when you invoke
"Generate Test Code". Does that have the same problem?
> Many thanks,
> Ronaldo
> Ed Merks wrote:
> > Ronaldo,
> > Comments below.
> > Ronaldo wrote:
> >> Hi Ed,
> >> eclipse projects.
> EPackage to
> the
> >> Ronaldo
Re: NullPointerException in XMLSaveImpl.saveDataTypeMany [message #423248 is a reply to message #423246] |
Thu, 25 September 2008 09:55   |
Hi Ed,
I guess you're saying I'm messing around with a null namespace :0
Point is, it has worked and somehow I changed something and it doesn't work any more.
I feel I'm losing control ...
Anyway, I'll step back, and use proper namespaces ;)
My package is now only annotated with @model kind="package". (Unqualified is removed)
The generated XYZExample now generates
<Activities/>
So the question is, which piece of code is responsible for hiding the namespace prefix?
I'd expect something like
<prefix:Activities xmlns:prefix="yadiyadi" />
Fun part is, after unloading the created and saved resource,
I reload it using the same resourceSet. But then, I get the famous "Package with uri null not found" message...
because the prefix is missing...
Ronaldo
>> does it?
>> The error is
> package?
>> Code:
>> Resource resource =
>> Many thanks,
>> Ronaldo
>> Ed Merks wrote:
>> > Ronaldo,
>> > Comments below.
>> > Ronaldo wrote:
>> >> Hi Ed,
>> >> eclipse projects.
>> EPackage to
>> the
>> >> Ronaldo
Re: NullPointerException in XMLSaveImpl.saveDataTypeMany [message #423251 is a reply to message #423248] |
Thu, 25 September 2008 10:13   |
Ronaldo,
Comments below.
Ronaldo wrote:
> Hi Ed,
> work any more.
Something worked, but only you know what...
You've relaoaded the model?
> <Activities/>
> namespace prefix?
And has the resource factory been regenerated so it's using "TRUE"? It
doesn't look that way...
Me too. What's the nsURI of your EPackage?
Something's is a little screwed up for sure... What does the resource
factory look like?
> Ronaldo
>>> does it?
>>> The error is
>> and hence we get a null pointer exception trying to get the factory
>> for that package?
>>> Code:
>>> Resource resource =
>>> Many thanks,
>>> Ronaldo
>>> Ed Merks wrote:
>>> > Ronaldo,
>>> > Comments below.
>>> > Ronaldo wrote:
>>> >> Hi Ed,
>>> >> eclipse projects.
>>> EPackage to
>>> be the
>>> >> Ronaldo
Re: NullPointerException in XMLSaveImpl.saveDataTypeMany [message #423257 is a reply to message #423251] |
Thu, 25 September 2008 10:41   |
I have something that might be noteworthy:
Somehow, I noticed that my genmodel consists of 4 models:
Xpdl1 - Deprecated xpdl format
Xpdl2 - Current xpdl format
Ecore - (Icon contains a little arrow/referenced?)
XMLType - (Icon contains a little arrow/referenced?)
The util package also contains an Xpdl2XMLProcessor class:
public class Xpdl2XMLProcessor extends XMLProcessor {
public Xpdl2XMLProcessor() {
super((EPackage.Registry.INSTANCE));
Xpdl2Package.eINSTANCE.eClass();
protected Map<String, Resource.Factory> getRegistrations() {
if (registrations == null) {
super.getRegistrations();
registrations.put(XML_EXTENSION, new Xpdl2ResourceFactoryImpl());
registrations.put(STAR_EXTENSION, new Xpdl2ResourceFactoryImpl());
return registrations;
which seems a little odd. I hadn't noticed this before.
Here's the EPackage source:
public interface Xpdl2Package extends EPackage {
String eNS_URI = "http://www.wfmc.org/2008/XPDL2.1";
String eNS_PREFIX = "xpdl2";
Xpdl2Package eINSTANCE = org.wfmc.xpdl21.xpdl2.impl.Xpdl2PackageImpl.init();
And the resourceFactory source:
public class Xpdl2ResourceFactoryImpl extends ResourceFactoryImpl {
* @generated
public Xpdl2ResourceFactoryImpl() {
super();
* @generated
public Resource createResourceGen(URI uri) {
XMLResource result = new Xpdl2ResourceImpl(uri);
result.getDefaultSaveOptions().put(XMLResource.OPTION_EXTEND ED_META_DATA, Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_EXTEND ED_META_DATA, Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_SCHEMA _LOCATION, Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_EN CODED_ATTRIBUTE_STYLE, Boolean.TRUE);
result.getDefaultSaveOptions().put(XMLResource.OPTION_USE_EN CODED_ATTRIBUTE_STYLE, Boolean.TRUE);
result.getDefaultLoadOptions().put(XMLResource.OPTION_USE_LE XICAL_HANDLER, Boolean.TRUE);
return result;
public Resource createResource(URI uri) {
XMLResource result = (XMLResource)createResourceGen(uri);
result.getDefaultLoadOptions().put(XMLResource.OPTION_ENCODI NG, "UTF-8");
result.getDefaultSaveOptions().put(XMLResource.OPTION_ENCODI NG, "UTF-8");
// // Where do we turn this off in the genmodel? What is the name of the option?
// result.getDefaultSaveOptions().put(XMLResource.OPTION_SCHEMA _LOCATION, Boolean.TRUE);
// result.getDefaultLoadOptions().put(XMLResource.OPTION_LAX_FE ATURE_PROCESSING, Boolean.TRUE);
// result.getDefaultSaveOptions().put(XMLResource.OPTION_LAX_FE ATURE_PROCESSING, Boolean.TRUE);
//result.getDefaultSaveOptions().put(XMLResource.OPTION_SKIP _ESCAPE, Boolean.TRUE);
// result.getDefaultSaveOptions().put(XMLResource.OPTION_ESCAPE _USING_CDATA, Boolean.TRUE);
// result.getDefaultSaveOptions().put(XMLResource.OPTION_FORMAT TED, Boolean.TRUE);
return result;
} //Xpdl2ResourceFactoryImpl
I hope this helps.
Ronaldo
Ed Merks wrote:
> Ronaldo,
> Comments below.
> Ronaldo wrote:
>> Hi Ed,
>> work any more.
>> <?xml version="1.0" encoding="UTF-8"?>
>> <Activities/>
>> namespace prefix?
> factory look like?
>> Ronaldo
>>>> does it?
>>>> The error is
>>> for that package?
>>>> Code:
>>>> Resource resource =
>>>> Many thanks,
>>>> Ronaldo
>>>> Ed Merks wrote:
>>>> > Ronaldo,
>>>> > Comments below.
>>>> > Ronaldo wrote:
>>>> >> Hi Ed,
>>>> >> eclipse projects.
>>>> EPackage to
>>>> be the
>>>> >> Ronaldo
Re: NullPointerException in XMLSaveImpl.saveDataTypeMany [message #423258 is a reply to message #423257] |
Thu, 25 September 2008 10:56   |
Ronaldo,
What EAnnotations does the "activities" feature of the DocumentRoot have
on it?
> @Override
> * @generated
> super();
> * @generated
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> return result;
> @Override
> name of the option?
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> return result;
> I hope this helps.
> Ronaldo
> Ed Merks wrote:
>> Ronaldo,
>> Comments below.
>> Ronaldo wrote:
>>> Hi Ed,
>>> <Activities/>
>> It doesn't look that way...
>> factory look like?
>>> Ronaldo
>>>>> does it?
>>>>> The error is
>>>> for that package?
>>>>> Code:
>>>>> Resource resource =
>>>> invoke "Generate Test Code". Does that have the same problem?
>>>>> Many thanks,
>>>>> Ronaldo
>>>>> Ed Merks wrote:
>>>>> > Ronaldo,
>>>>> > Comments below.
>>>>> > Ronaldo wrote:
>>>>> >> Hi Ed,
>>>>> >> eclipse projects.
>>>>> EPackage to
>>>>> to be the
>>>>> >> Ronaldo
Re: NullPointerException in XMLSaveImpl.saveDataTypeMany [message #423259 is a reply to message #423257] |
Thu, 25 September 2008 10:58   |
And another observation:
I get:
<xpdl2:Package xmlns:xpdl2="http://www.wfmc.org/2008/XPDL2.1" Id="1"/>
When adding the PackageType (a model element) directly to the resource.getContents(),
as in:
Resource resource = xpdl2ResourceSet.createResource(uri);
PackageType packageType = xpdl2Factory.createPackageType();
resource.getContents().add(packageType);
Before I used:
DocumentRoot documentRoot = xpdl2Factory.createDocumentRoot();
documentRoot.setPackage(packageType);
Ronaldo
> @Override
> * @generated
> super();
> * @generated
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> return result;
> @Override
> "UTF-8");
> "UTF-8");
> of the option?
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> Boolean.TRUE);
> return result;
> I hope this helps.
> Ronaldo
> Ed Merks wrote:
>> Ronaldo,
>> Comments below.
>> Ronaldo wrote:
>>> Hi Ed,
>>> <Activities/>
>>> namespace prefix?
>> factory look like?
>>> Ronaldo
>>>>> does it?
>>>>> The error is
>>>> for that package?
>>>>> Code:
>>>>> Resource resource =
>>>>> Many thanks,
>>>>> Ronaldo
>>>>> Ed Merks wrote:
>>>>> > Ronaldo,
>>>>> > Comments below.
>>>>> > Ronaldo wrote:
>>>>> >> Hi Ed,
>>>>> >> eclipse projects.
>>>>> EPackage to
>>>>> be the
>>>>> >> Ronaldo
Re: NullPointerException in XMLSaveImpl.saveDataTypeMany [message #423261 is a reply to message #423258] |
Thu, 25 September 2008 11:07   |
This is the generated code for the getActivities method in the DocumentRoot interface.
* @model containment="true" upper="-2" transient="true" volatile="true" derived="true"
* extendedMetaData="kind='element' name='Activities'"
* @generated
ActivitiesType getActivities();
Ed Merks wrote:
> Ronaldo,
> on it?
>> @Override
>> * @generated
>> super();
>> * @generated
>> Boolean.TRUE);
>> Boolean.TRUE);
>> Boolean.TRUE);
>> Boolean.TRUE);
>> Boolean.TRUE);
>> Boolean.TRUE);
>> return result;
>> @Override
>> // // // Where do we turn this off in the genmodel? What
>> Boolean.TRUE);
>> Boolean.TRUE);
>> Boolean.TRUE);
>> Boolean.TRUE);
>> Boolean.TRUE);
>> Boolean.TRUE);
>> // return result;
>> I hope this helps.
>> Ronaldo
>> Ed Merks wrote:
>>> Ronaldo,
>>> Comments below.
>>> Ronaldo wrote:
>>>> Hi Ed,
>>>> <Activities/>
>>> factory look like?
>>>> Ronaldo
>>>>>> does it?
>>>>>> The error is
>>>>> for that package?
>>>>>> Code:
>>>>>> Resource resource =
>>>>>> Many thanks,
>>>>>> Ronaldo
>>>>>> Ed Merks wrote:
>>>>>> > Ronaldo,
>>>>>> > Comments below.
>>>>>> > Ronaldo wrote:
>>>>>> >> Hi Ed,
>>>>>> >> eclipse projects.
>>>>>> EPackage to
>>>>>> to be the
>>>>>> >> Ronaldo
Re: NullPointerException in XMLSaveImpl.saveDataTypeMany [message #423262 is a reply to message #423261] |
Thu, 25 September 2008 11:14   |
--------------000904030009000904070908
Ronaldo,
For the library mode it looks like this:
* extendedMetaData="kind='element' name='library'*
namespace='##targetNamespace'"*
I assume these models originated from a schema. Do that schema have a
target namespace?
> * @generated
> Ed Merks wrote:
>> Ronaldo,
>> have on it?
>>> @Override
>>> * @generated
>>> super();
>>> * @generated
>>> Boolean.TRUE);
>>> Boolean.TRUE);
>>> Boolean.TRUE);
>>> Boolean.TRUE);
>>> Boolean.TRUE);
>>> Boolean.TRUE);
>>> return result;
>>> @Override
>>> "UTF-8");
>>> "UTF-8");
>>> Boolean.TRUE);
>>> Boolean.TRUE);
>>> Boolean.TRUE);
>>> Boolean.TRUE);
>>> Boolean.TRUE);
>>> Boolean.TRUE);
>>> // return result;
>>> I hope this helps.
>>> Ronaldo
>>> Ed Merks wrote:
>>>> Ronaldo,
>>>> Comments below.
>>>> Ronaldo wrote:
>>>>> Hi Ed,
>>>>> <Activities/>
>>>> "TRUE"? It doesn't look that way...
>>>> resource factory look like?
>>>>> Ronaldo
>>>>>>> eclipse editor).
>>>>>>> does it?
>>>>>>> The error is
>>>>>> package and hence we get a null pointer exception trying to get
>>>>>> the factory for that package?
>>>>>>> Code:
>>>>>>> Resource resource =
>>>>>>> Many thanks,
>>>>>>> Ronaldo
>>>>>>> Ed Merks wrote:
>>>>>>> > Ronaldo,
>>>>>>> > Comments below.
>>>>>>> > Ronaldo wrote:
>>>>>>> >> Hi Ed,
>>>>>>> >> eclipse projects.
>>>>>>> EPackage to
>>>>>>> to be the
>>>>>>> >> Ronaldo
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
</head>
Ronaldo,<br>
<br>
For the library mode it looks like this:<br>
<blockquote> * @model containment="true" upper="-2" transient="true"
volatile="true" derived="true"<br>
*   ; extendedMetaData="kind='element' name='library'<b>
namespace='##targetNamespace'"</b><br>
</blockquote>
target namespace?<br>
<br>
<br>
Ronaldo wrote:
<blockquote cite="mid:gbg9ga$r4s$1@build.eclipse.org" type="cite"><br>
<br>
<br>
<br>
*   ; extendedMetaData="kind='element' name='Activities'"
<br>
* @generated
<br>
<br>
<br>
<br>
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Ronaldo,
<br>
<br>
have on it?
<br>
<br>
<br>
Ronaldo wrote:
<br>
<blockquote type="cite">I have something that might be noteworthy:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
String eNS_URI = <a class="moz-txt-link-rfc2396E" href="http://www.wfmc.org/2008/XPDL2.1">"http://www.wfmc.org/2008/XPDL2.1"</a>;
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
* @generated
<br>
<br>
<br>
super();
<br>
<br>
<br>
* @generated
<br>
<br>
<br>
<br>
Boolean.TRUE);
<br>
Boolean.TRUE);
<br>
<br>
Boolean.TRUE);
<br>
<br>
Boolean.TRUE);
<br>
Boolean.TRUE);
<br>
<br>
Boolean.TRUE);
<br>
return result;
<br>
<br>
<br>
<br>
<br>
"UTF-8");
<br>
"UTF-8");
<br>
// &nbs p; // &nbs p; // Where do we turn this off in the genmodel? What
<br>
// &nbs p;
Boolean.TRUE);
<br>
Boolean.TRUE);
<br>
// &nbs p;
Boolean.TRUE);
<br>
<br>
Boolean.TRUE);
<br>
// &nbs p;
Boolean.TRUE);
<br>
// &nbs p;
Boolean.TRUE);
<br>
// &nbs p; &nbs p; return result;
<br>
<br>
<br>
<br>
<br>
I hope this helps.
<br>
Ronaldo
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
Comments below.
<br>
<br>
Ronaldo wrote:
<br>
<blockquote type="cite">Hi Ed,
<br>
<br>
<br>
work any more.
<br>
<br>
</blockquote>
<br>
<blockquote type="cite"><br>
<br>
<br>
<br>
</blockquote>
<br>
<blockquote type="cite">The generated XYZExample now generates
<br>
<br>
<br>
<Activities/>
<br>
<br>
namespace prefix?
<br>
</blockquote>
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
</blockquote>
factory look like?
<br>
Ronaldo
<br>
<br>
<br>
<br>
<br>
Ronaldo wrote:
<br>
<blockquote type="cite">This error comes up when I run the
<br>
<br>
<a class="moz-txt-link-freetext" href=" http://wiki.eclipse.org/index.php/EMF-FAQ#How_do_I_use_EMF_i n_standalone_applications_.28such_as_an_ordinary_main.29.3F"> http://wiki.eclipse.org/index.php/EMF-FAQ#How_do_I_use_EMF_i n_standalone_applications_.28such_as_an_ordinary_main.29.3F</a>,
<br>
does it?
<br>
<br>
The error is
<br>
<br>
<br>
<br>
</blockquote>
that package?
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite"> org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1485)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Code:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Resource resource =
resourceSet.createResource(URI.createURI(<a class="moz-txt-link-rfc2396E" href="http:///My.model.uri">"http:///My.model.uri"</a>));
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
<br>
Many thanks,
<br>
Ronaldo
<br>
<br>
Ed Merks wrote:
<br>
> Ronaldo,
<br>
<br>
> Comments below.
<br>
<br>
> Ronaldo wrote:
<br>
>> Hi Ed,
<br>
<br>
different
<br>
>> eclipse projects.
<br>
the
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
EPackage to
<br>
<br>
<br>
<br>
<br>
<br>
>> & ;nbsp; XMLResource.OPTION_EXTENDED_META_DATA, Boolean.TRUE);
<br>
<br>
<br>
be the
<br>
<br>
<br>
<br>
>> Ronaldo
<br>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</blockquote>
</body>
</html>
--------------000904030009000904070908--
Re: NullPointerException in XMLSaveImpl.saveDataTypeMany [message #423263 is a reply to message #423259] |
Thu, 25 September 2008 11:16   |
Ronaldo,
Class names are always qualified but element and attributes may or may
not be depending on things like elementForm/elementFormDefault...
If you just set the target namespace on the schema and reloaded that
schema, everything would be more consistent than messing with the Ecore
or the @model stuff...
> I get:
> as in:
> Before I used:
> Ronaldo
>> @Override
>> * @generated
>> super();
>> * @generated
>> Boolean.TRUE);
>> Boolean.TRUE);
>> Boolean.TRUE);
>> Boolean.TRUE);
>> Boolean.TRUE);
>> Boolean.TRUE);
>> return result;
>> @Override
>> "UTF-8");
>> "UTF-8");
>> Boolean.TRUE);
>> Boolean.TRUE);
>> Boolean.TRUE);
>> Boolean.TRUE);
>> Boolean.TRUE);
>> Boolean.TRUE);
>> // return result;
>> I hope this helps.
>> Ronaldo
>> Ed Merks wrote:
>>> Ronaldo,
>>> Comments below.
>>> Ronaldo wrote:
>>>> Hi Ed,
>>>> <Activities/>
>>>> Ronaldo
>>>>>> eclipse editor).
>>>>>> does it?
>>>>>> The error is
>>>>>> Code:
>>>>>> Resource resource =
>>>>>> Many thanks,
>>>>>> Ronaldo
>>>>>> Ed Merks wrote:
>>>>>> > Ronaldo,
>>>>>> > Comments below.
>>>>>> > Ronaldo wrote:
>>>>>> >> Hi Ed,
>>>>>> >> eclipse projects.
>>>>>> EPackage to
>>>>>> to be the
>>>>>> >> Ronaldo
Re: NullPointerException in XMLSaveImpl.saveDataTypeMany [message #423284 is a reply to message #423262] |
Fri, 26 September 2008 05:31   |
Nope most elements didn't have a target namespace... I guess I'll have to add them manually to every element.
A little background might be usefull:
I started out with the xpdl2.1 XSD (http://www.wfmc.org/standards/bpmnxpdl_31.xsd) and created a model and generated java from that.
However, I have little experience with XSD's and decided it might be easier to reload from java annotations from that point on.
That might explain why I do have a DocumentRoot generated, a thing I don't have when generating the model from java annotations directly.
When it all seemed to work, I read posts like http://www.eclipsezone.com/eclipse/forums/t91748.html to eliminate the prefixes.
(Well I guess I misinterpreted them).
I also noted that all my interfaces are now annotated with a name='*_._type' in the extended metadata annotation.
I'd swear this was not the case earlier on.
I'm not sure if this is good or bad, as I read that this should be ok when using a DocumentRoot... (?)
( http://dev.eclipse.org/newslists/news.eclipse.tools.emf/msg2 6745.html)
But, as I'm not modifing the xsd but the java annotations instead and reloading the genmodel from these java annotations, do I still need that
(old?) documentroot?
I created a new testproject from java and indeed no documentroot was generated.
That would also explain why adding an element directly to the resource.getContents() did serialize ok,
while using an (old?) documentroot did not serialize ok.
I assumed that starting with an xsd, would create the same model as when you're starting from java...
But the documentroot thing shows that's not the case?
Ronaldo
Ed Merks wrote:
> Ronaldo,
> target namespace?
>> * @generated
>> Ed Merks wrote:
>>> Ronaldo,
>>> have on it?
>>>> @Override
>>>> * @generated
>>>> super();
>>>> * @generated
>>>> Boolean.TRUE);
>>>> Boolean.TRUE);
>>>> Boolean.TRUE);
>>>> Boolean.TRUE);
>>>> Boolean.TRUE);
>>>> Boolean.TRUE);
>>>> return result;
>>>> @Override
>>>> "UTF-8");
>>>> "UTF-8");
>>>> Boolean.TRUE);
>>>> Boolean.TRUE);
>>>> Boolean.TRUE);
>>>> Boolean.TRUE);
>>>> Boolean.TRUE);
>>>> Boolean.TRUE);
>>>> // return result;
>>>> I hope this helps.
>>>> Ronaldo
>>>> Ed Merks wrote:
>>>>> Ronaldo,
>>>>> Comments below.
>>>>> Ronaldo wrote:
>>>>>> Hi Ed,
>>>>>> <Activities/>
>>>>>> Ronaldo
>>>>>>>> eclipse editor).
>>>>>>>> does it?
>>>>>>>> The error is
>>>>>>>> Code:
>>>>>>>> Resource resource =
>>>>>>>> Many thanks,
>>>>>>>> Ronaldo
>>>>>>>> Ed Merks wrote:
>>>>>>>> > Ronaldo,
>>>>>>>> > Comments below.
>>>>>>>> > Ronaldo wrote:
>>>>>>>> >> Hi Ed,
>>>>>>>> >> eclipse projects.
>>>>>>>> EPackage to
>>>>>>>> to be the
>>>>>>>> >> Ronaldo
Re: NullPointerException in XMLSaveImpl.saveDataTypeMany [message #423291 is a reply to message #423284] |
Fri, 26 September 2008 07:33   |
Ronaldo,
Comments below.
That one had a target namespace.
Did you know you can export your Ecore to XSD? Keep in mind though that
XSD -> Ecore -> XSD is not a round trip because XSD -> Ecore is slightly
lossy. But Ecore -> XSD -> Ecore is supposed to be a round trip because
we generate all the necessary ecore:* annotations to make it roundtrip.
Using this mechanism, you could discover what you needed to change in
the original XSD to produce the desired Ecore...
We, given sufficient annotations of the right form, you'll get the same
thing. The Ecore -> Java with @model -> Ecore is supposed to be a round
trip after all...
> prefixes.
A better way to have eliminated the prefixes is to use
DocumentRoot.getXMLNSPrefixMap().put("", XyzPackage.eNS_URI). This way
you end up with an xmlns="<nsURI>" in the document and all elements will
be implicitly qualified by this namespace. Of course attributes will
still need explicit qualification, so I'm not sure you'd be totally
happy with the result. But given that I assume you want the
serialization to conform to the schema and the schema requires qualified
local elements and attributes, I don't think you have all that much choice.
This comes from anonymous type definitions.
An anonymous type can never be used in an xsi:type. Sometimes that fact
can be used to deduce a more appropriate element name...
> that (old?) documentroot?
The document root determines the appropriate element name at the root of
the document. Without a document root, the name of the type will be
used as the root element name, but that's not going to conform to the
schema since a schema will always specify a global element to use for
the root.
> generated.
Not sure about that. The DocumentRoot interface has @model on it, so I
assume you'd have to delete that for it to just disappear...
If you're okay with a serialization that doesn't conform to the schema
then it's okay. The document root serialization issue was a result of
inconsistent annotations (annotations that would never have been
produced from a real schema).
Given the corresponding annotations, yes.
I'm sure you've left out a little detail. After all, you've already
mentioned reloading the model from the @model changes and that didn't
make the DocumentRoot disappear... When reading the newsgroups for a
long time you start to learn that people leave out tiny but little
important details. :-P
> Ronaldo
> Ed Merks wrote:
>> Ronaldo,
>> a target namespace?
>>> * @generated
>>> Ed Merks wrote:
>>>> Ronaldo,
>>>> have on it?
>>>>> @Override
>>>>> * @generated
>>>>> super();
>>>>> * @generated
>>>>> Boolean.TRUE);
>>>>> Boolean.TRUE);
>>>>> Boolean.TRUE);
>>>>> Boolean.TRUE);
>>>>> Boolean.TRUE);
>>>>> Boolean.TRUE);
>>>>> return result;
>>>>> @Override
>>>>> "UTF-8");
>>>>> "UTF-8");
>>>>> Boolean.TRUE);
>>>>> Boolean.TRUE);
>>>>> Boolean.TRUE);
>>>>> Boolean.TRUE);
>>>>> Boolean.TRUE);
>>>>> Boolean.TRUE);
>>>>> // return result;
>>>>> I hope this helps.
>>>>> Ronaldo
>>>>> Ed Merks wrote:
>>>>>> Ronaldo,
>>>>>> Comments below.
>>>>>> Ronaldo wrote:
>>>>>>> Hi Ed,
>>>>>>> <Activities/>
>>>>>>> Ronaldo
>>>>>>>>> eclipse editor).
>>>>>>>>> does it?
>>>>>>>>> The error is
>>>>>>>>> Code:
>>>>>>>>> Resource resource =
>>>>>>>>> Many thanks,
>>>>>>>>> Ronaldo
>>>>>>>>> Ed Merks wrote:
>>>>>>>>> > Ronaldo,
>>>>>>>>> > Comments below.
>>>>>>>>> > Ronaldo wrote:
>>>>>>>>> >> Hi Ed,
>>>>>>>>> different
>>>>>>>>> >> eclipse projects.
>>>>>>>>> eliminate the
>>>>>>>>> are
>>>>>>>>> schema...
>>>>>>>>> EPackage to
>>>>>>>>> want to be the
>>>>>>>>> >> Ronaldo
Re: NullPointerException in XMLSaveImpl.saveDataTypeMany [message #423294 is a reply to message #423291] |
Fri, 26 September 2008 08:04   |
Hi Ed,
Thanks for the extensive answers. Yes, I'm sure I've left out something, if I only knew what...
I decided to take a step back, create a new project and reload the xsd again.
Then, step by step I'll try to find the solution.
Unfortunately, importing the xsd (http://www.wfmc.org/standards/bpmnxpdl_31.xsd) shows errors, see attachment.
I cannot tell if the xsd is not ok or if there's an error somewhere in emf.
Ronaldo
Ed Merks wrote:
> Ronaldo,
> Comments below.
> trip after all...
>> prefixes.
> the root.
>> generated.
>> Ronaldo
>> Ed Merks wrote:
>>> Ronaldo,
>>> a target namespace?
>>>> * @generated
>>>> Ed Merks wrote:
>>>>> Ronaldo,
>>>>> have on it?
>>>>>> @Override
>>>>>> * @generated
>>>>>> super();
>>>>>> * @generated
>>>>>> Boolean.TRUE);
>>>>>> Boolean.TRUE);
>>>>>> Boolean.TRUE);
>>>>>> Boolean.TRUE);
>>>>>> Boolean.TRUE);
>>>>>> Boolean.TRUE);
>>>>>> return result;
>>>>>> @Override
>>>>>> "UTF-8");
>>>>>> "UTF-8");
>>>>>> Boolean.TRUE);
>>>>>> Boolean.TRUE);
>>>>>> Boolean.TRUE);
>>>>>> Boolean.TRUE);
>>>>>> Boolean.TRUE);
>>>>>> Boolean.TRUE);
>>>>>> // return result;
>>>>>> I hope this helps.
>>>>>> Ronaldo
>>>>>> Ed Merks wrote:
>>>>>>> Ronaldo,
>>>>>>> Comments below.
>>>>>>> Ronaldo wrote:
>>>>>>>> Hi Ed,
>>>>>>>> <Activities/>
>>>>>>>> Ronaldo
>>>>>>>>>> eclipse editor).
>>>>>>>>>> does it?
>>>>>>>>>> The error is
>>>>>>>>>> Code:
>>>>>>>>>> Resource resource =
>>>>>>>>>> Many thanks,
>>>>>>>>>> Ronaldo
>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>> > Ronaldo,
>>>>>>>>>> > Comments below.
>>>>>>>>>> > Ronaldo wrote:
>>>>>>>>>> >> Hi Ed,
>>>>>>>>>> different
>>>>>>>>>> >> eclipse projects.
>>>>>>>>>> eliminate the
>>>>>>>>>> are
>>>>>>>>>> schema...
>>>>>>>>>> EPackage to
>>>>>>>>>> want to be the
>>>>>>>>>> >> Ronaldo
Re: NullPointerException in XMLSaveImpl.saveDataTypeMany [message #423297 is a reply to message #423294] |
Fri, 26 September 2008 08:43  |
Ronaldo,
Comments below.
Ronaldo wrote:
> Hi Ed,
> again.
> attachment.
> emf.
The XML Schema for schemas has a regular expression for validating that
XPaths are well formed and that regular expression doesn't allow
spaces. This schema has spaces in their regular expressions though.
You can just ignore these errors since key/keyref and unique are ignored
in XSD -> Ecore mapping.
> Ronaldo
> Ed Merks wrote:
>> Ronaldo,
>> Comments below.
>> that XSD -> Ecore -> XSD is not a round trip because XSD -> Ecore is
>> slightly lossy. But Ecore -> XSD -> Ecore is supposed to be a round
>> trip because we generate all the necessary ecore:* annotations to
>> make it roundtrip. Using this mechanism, you could discover what you
>> needed to change in the original XSD to produce the desired Ecore...
>> same thing. The Ecore -> Java with @model -> Ecore is supposed to be
>> a round trip after all...
>>> the prefixes.
>> way you end up with an xmlns="<nsURI>" in the document and all
>> elements will be implicitly qualified by this namespace. Of course
>> attributes will still need explicit qualification, so I'm not sure
>> you'd be totally happy with the result. But given that I assume you
>> want the serialization to conform to the schema and the schema
>> requires qualified local elements and attributes, I don't think you
>> fact can be used to deduce a more appropriate element name...
>>> need that (old?) documentroot?
>> of the document. Without a document root, the name of the type will
>> be used as the root element name, but that's not going to conform to
>> the schema since a schema will always specify a global element to use
>> for the root.
>>> generated.
>> I assume you'd have to delete that for it to just disappear...
>> schema then it's okay. The document root serialization issue was a
>> result of inconsistent annotations (annotations that would never have
>> been produced from a real schema).
>>> Ronaldo
>>> Ed Merks wrote:
>>>> Ronaldo,
>>>> have a target namespace?
>>>>> * @generated
>>>>> Ed Merks wrote:
>>>>>> Ronaldo,
>>>>>> DocumentRoot have on it?
>>>>>>> @Override
>>>>>>> * @generated
>>>>>>> super();
>>>>>>> * @generated
>>>>>>> Boolean.TRUE);
>>>>>>> Boolean.TRUE);
>>>>>>> Boolean.TRUE);
>>>>>>> Boolean.TRUE);
>>>>>>> Boolean.TRUE);
>>>>>>> Boolean.TRUE);
>>>>>>> return result;
>>>>>>> @Override
>>>>>>> "UTF-8");
>>>>>>> "UTF-8");
>>>>>>> Boolean.TRUE);
>>>>>>> Boolean.TRUE);
>>>>>>> Boolean.TRUE);
>>>>>>> Boolean.TRUE);
>>>>>>> Boolean.TRUE);
>>>>>>> Boolean.TRUE);
>>>>>>> // return result;
>>>>>>> I hope this helps.
>>>>>>> Ronaldo
>>>>>>> Ed Merks wrote:
>>>>>>>> Ronaldo,
>>>>>>>> Comments below.
>>>>>>>> Ronaldo wrote:
>>>>>>>>> Hi Ed,
>>>>>>>>> <Activities/>
>>>>>>>>> Ronaldo
>>>>>>>>>>> eclipse editor).
>>>>>>>>>>> does it?
>>>>>>>>>>> The error is
>>>>>>>>>> get the factory for that package?
>>>>>>>>>>> Code:
>>>>>>>>>>> Resource resource =
>>>>>>>>>>> too.
>>>>>>>>>> you invoke "Generate Test Code". Does that have the same
>>>>>>>>>> problem?
>>>>>>>>>>> Many thanks,
>>>>>>>>>>> Ronaldo
>>>>>>>>>>> Ed Merks wrote:
>>>>>>>>>>> > Ronaldo,
>>>>>>>>>>> > Comments below.
>>>>>>>>>>> > Ronaldo wrote:
>>>>>>>>>>> >> Hi Ed,
>>>>>>>>>>> different
>>>>>>>>>>> >> eclipse projects.
>>>>>>>>>>> eliminate the
>>>>>>>>>>> element are
>>>>>>>>>>> schema...
>>>>>>>>>>> extendedMetaData);
>>>>>>>>>>> the EPackage to
>>>>>>>>>>> want to be the
>>>>>>>>>>> >> Ronaldo
Current Time: Sun Jul 27 08:20:16 EDT 2025
Powered by FUDForum. Page generated in 0.05987 seconds
