Home » Modeling » EMF » How to make EMF use extendedMetaData
How to make EMF use extendedMetaData [message #423229] |
Thu, 25 September 2008 06:28  |
Hi all,
Short Question: Which property do I have to set to use metadata?
I've set the Suppress EMF Metadata property to false in the genmodel,
but the XYZResourceFactoryImpl doesn't initialize the extendedMetaData
when I regenerate the model.
Explanation:
I've got two models, of which one (ABC) is using the extendedMetaData.
When I generate that last one, I get code in the ABCResourceFactoryImpl
like:
protected ExtendedMetaData extendedMetaData;
public ModelResourceFactoryImpl() {
super();
extendedMetaData = new BasicExtendedMetaData(new
EPackageRegistryImpl(EPackage.Registry.INSTANCE));
extendedMetaData.putPackage(null, ModelPackage.eINSTANCE);
public Resource createResource(URI uri) {
XMLResource result = new ModelResourceImpl(uri);
result.getDefaultSaveOptions().put(
XMLResource.OPTION_EXTENDED_META_DATA, extendedMetaData);
result.getDefaultLoadOptions().put(
In the other model (XYZ), this code is not generated and in its
createResource method, this code is generated:
XMLResource.OPTION_EXTENDED_META_DATA, Boolean.TRUE);
I've looked at the genmodel of both models, and in both models, the
Suppress EMF Metadata is set to false...
Why is code generated for model XYZ not using extendedMetaData? Which
TIA
Ronaldo
Re: How to make EMF use extendedMetaData [message #423235 is a reply to message #423229] |
Thu, 25 September 2008 06:50   |
Ronaldo,
Comments below.
Ronaldo wrote:
> Hi all,
That's an overloaded question...
That's unrelated. That suppresses the generation of @model annotations
in the generated Javadoc.
> Explanation:
> ABCResourceFactoryImpl like:
> super();
I'd expect this for a model corresponding to a null targetNamespace schema.
That I'd expect for a schema with a targetNamespace.
They both use extended metadata, but the null targetNamespace thing is
tricky because the nsURI of the EPackage must uniquely identify it and
hence we can't support many packages all with null nsURI. So the
package corresponding to a null targetNamespace schema is assigned an
nsURI and then needs special handling so that it's treated as it the
nsURI were null...
> TIA
> Ronaldo
Re: How to make EMF use extendedMetaData [message #423236 is a reply to message #423235] |
Thu, 25 September 2008 07:17   |
Hi Ed,
Thanks for the quick answer. Yes, I have 2 models in 2 different eclipse
projects.
They both use a null target namespace, in order to eliminate the
prefixes in the xml.
I was just wondering what (which setting) causes the code
to be generated. (as opposed to
Ronaldo
Ed Merks wrote:
> Ronaldo,
> Comments below.
> Ronaldo wrote:
>> Hi all,
>> Explanation:
>> super();
> nsURI were null...
>> TIA
>> Ronaldo
Re: How to make EMF use extendedMetaData [message #423238 is a reply to message #423236] |
Thu, 25 September 2008 07:28  |
Ronaldo,
Comments below.
Ronaldo wrote:
> Hi Ed,
> eclipse projects.
XML documents with at least a namespace for the root element are
generally more consumable because they identify their schema...
A null target namespace schema produces an annotation on the EPackage to
indicate the package is not qualified.
This package doesn't have such an annotation.
Note that you can't have two different packages that both want to be the
one for the null namespace both working at the same time.
> Ronaldo
> Ed Merks wrote:
>> Ronaldo,
>> Comments below.
>> Ronaldo wrote:
>>> Hi all,
>>> extendedMetaData when I regenerate the model.
>> annotations in the generated Javadoc.
>>> Explanation:
>>> extendedMetaData. When I generate that last one, I get code in the
>>> super();
>> schema.
>> is tricky because the nsURI of the EPackage must uniquely identify it
>> and hence we can't support many packages all with null nsURI. So the
>> nsURI were null...
>>> TIA
>>> Ronaldo
Current Time: Sun Jul 27 04:14:30 EDT 2025
Powered by FUDForum. Page generated in 0.07629 seconds
