Home » Modeling » EMF » CreateChildCommand and EStore
CreateChildCommand and EStore [message #423193] Wed, 24 September 2008 12:52 Go to next message
Originally posted by: swt.magellium.fr
Hello !
It's me and my EStore again :o)
Whenever a model object is created, I want to be sure that it has an
EStore set, because all my model objects need to have an EStore.
There's no problem when I use "model" code. But when using commands, (at
the "edit" level,) model objects are created by the framework and
doesn't have any EStore.
I can manually change every "collectNewChildDescriptors" methods (in
every generated ItemProviderAdapters) so that they don't use "standard"
model object creation (AModelFactory.createAnEClass()), but the
"store's" model object creation
(store.create(AModelPackage.Literals.AN_E_CLASS)) instead.
Is it the right place to do this ???
I may also override every "AddCommand"s, so that before it is executed,
I can check that the model object to be added has an EStore...
Is this a better solution ???
Is there another (better) solution ??????
Thanks in advance !!!!!!!!!!!
Stephane
Re: CreateChildCommand and EStore [message #423195 is a reply to message #423193] Wed, 24 September 2008 13:07 Go to previous messageGo to next message
Stephane,
Comments below.
SWT wrote:
> Hello !
If only if was an online store with real profits and you shared them. :-P
That's a bit of a problem because model objects are created with a
factory and unless all instances share just one global store you really
don't have a store when you first create them.
> (at the "edit" level,) model objects are created by the framework and
> "standard" model object creation (AModelFactory.createAnEClass()), but
> the "store's" model object creation
I suppose. The CDO approach was to treat the objects as if they were
dynamic objects (the data is stored in the settings as for a dynamic
EObject) and only when the object is attached to the parent is the store
of the parent associated with it. After all, most of the children
created won't actually be used, so you wouldn't want them to be cached
or worse yet, persisted in the store...
> executed, I can check that the model object to be added has an EStore...
Maybe Eike will explain how CDO manages this...
I think so. Methods like ResourceImpl.attached/attachedHelper would be
useful for having the resource associate a store with the object when it
becomes attached to the resource... Again, I think CDO has implemented
quite a nice solution for all this...
> Stephane
Re: CreateChildCommand and EStore [message #423196 is a reply to message #423195] Wed, 24 September 2008 13:27 Go to previous messageGo to next message
Ed,
Comments below :)
Ed Merks wrote :
> Stephane,
> Comments below.
> SWT wrote:
>> Hello !
Hehe ^^
Right...
If I understand well, in CDO, model objects are dynamic EObjects until they have an EStore set.
This seems to be the best!
How can I mix the two behaviours ?
Eike, Eike !!! Where are you ?!?! :p
I already did this.
When an EObject is attached to a Resource, I set the store... (and set it back to null when it is detached...)
I also coded the EStore so that whenever a child object is set (on a parent object which is managed by the store),
I check that this child has a store (if it's not the case, I set it...)
Thanks again for your patience !
I hope Eike will read this and help me :)
>> Stephane
Re: CreateChildCommand and EStore [message #423202 is a reply to message #423196] Wed, 24 September 2008 14:29 Go to previous messageGo to next message
Hi Stephane,
Sorry that I forgot what the purpose of your EStore is. Would you mind
to give a short explanation?
In CDO the integration of a model with a backend is mainly based on two
classes:
- CDOObjectImpl:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.cdo/plugins/org.eclipse.emf.cdo/src/org/eclipse /emf/internal/cdo/CDOObjectImpl.java?revision=1.68&root= Modeling_Project
- CDOStore:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.cdo/plugins/org.eclipse.emf.cdo/src/org/eclipse /emf/internal/cdo/CDOStore.java?root=Modeling_Project&vi ew=co
An important aspect of the design is that each CDOObject has a CDOState
which is managed by the CDOStateMachine:
- CDOState:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.cdo/plugins/org.eclipse.emf.cdo/src/org/eclipse /emf/cdo/CDOState.java?root=Modeling_Project&view=co
- CDOStateMachine:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.emf/org .eclipse.emf.cdo/plugins/org.eclipse.emf.cdo/src/org/eclipse /emf/internal/cdo/CDOStateMachine.java?revision=1.86&roo t=Modeling_Project
If an object is in state TRANSIENT it uses the eSettings array for its
data and in all other states it delegates to the CDOStore.
Cheers
/Eike
SWT schrieb:
> Ed,
> Comments below :)
> Ed Merks wrote :
>> Stephane,
>> Comments below.
>> SWT wrote:
>>> Hello !
>> :-P
> Hehe ^^
>> really don't have a store when you first create them.
> Right...
>>> and doesn't have any EStore.
>>> but the "store's" model object creation
>> store of the parent associated with it. After all, most of the
>> children created won't actually be used, so you wouldn't want them to
>> be cached or worse yet, persisted in the store...
>>> EStore...
>> be useful for having the resource associate a store with the object
>> when it becomes attached to the resource... Again, I think CDO has
>> implemented quite a nice solution for all this...
> I already did this.
>>> Stephane
Re: CreateChildCommand and EStore [message #423224 is a reply to message #423202] Thu, 25 September 2008 04:57 Go to previous messageGo to next message
Eike,
My EStore has quite the same purpose as CDOStore. The two main
differences are that I use WebServices to send and receive model
objects, and that I have quite a complex client-server mapping. I don't
know the other differences in details, because I didn't have much time
to learn CDO (and I'm still an EMF newbie ^^).
Here is the little story (you can directly go to the next chapter ^^) :
After seeing that CDO was not directly usable in my project, I choose to
create my own communication system, but I didn't know about EStore at
that time. After working with proxies for a while, and facing many
problems, Martin told me about EStore. This was the best choice for me
so I changed my design to use EStore. At that time I should have
switched to using CDO (and contributing the additions I needed). But I
didn't, and now it's too late :'(
My "CommEStore" is nearly finished. I'm now facing problems using the
"edit" generated code... That's the cause of this mailing...
For the moment, I'll take a deep look at these classes.
Thanks a lot !
Stephane
Eike Stepper a écrit :
> Hi Stephane,
> classes:
> - CDOObjectImpl:
> - CDOStore:
> - CDOState:
> - CDOStateMachine:
> Cheers
> /Eike
> SWT schrieb:
>> Ed,
>> Comments below :)
>> Ed Merks wrote :
>>> Stephane,
>>> Comments below.
>>> SWT wrote:
>>>> Hello !
>>> :-P
>> Hehe ^^
>> Right...
>>>> EStore...
>> I already did this.
>>>> Stephane
Re: CreateChildCommand and EStore [message #423226 is a reply to message #423224] Thu, 25 September 2008 05:22 Go to previous messageGo to next message
SWT schrieb:
> Eike,
An indication that CDOStore might be used instead of another solution to
the same problem.
> The two main differences are that I use WebServices to send and
> receive model objects, and that I have quite a complex client-server
> mapping.
I don't know what you mean by "client-server mapping" but I can't
remember that you asked how CDO could be used with webservices. Maybe we
had found a nice solution...
> I don't know the other differences in details, because I didn't have
> much time to learn CDO (and I'm still an EMF newbie ^^).
I bet the time you spent with your own solution was more expensive
already ;-)
> to create my own communication system, but I didn't know about EStore
> at that time. After working with proxies for a while, and facing many
It's never too late to revise wrong decisions :)
Cheers
/Eike
> Thanks a lot !
> Stephane
>> Hi Stephane,
>> mind to give a short explanation?
>> two classes:
>> - CDOObjectImpl:
>> - CDOStore:
>> CDOState which is managed by the CDOStateMachine:
>> - CDOState:
>> - CDOStateMachine:
>> its data and in all other states it delegates to the CDOStore.
>> Cheers
>> /Eike
>> SWT schrieb:
>>> Ed,
>>> Comments below :)
>>> Ed Merks wrote :
>>>> Stephane,
>>>> Comments below.
>>>> SWT wrote:
>>>>> Hello !
>>>> them. :-P
>>> Hehe ^^
>>>>> an EStore set, because all my model objects need to have an EStore.
>>> Right...
>>>>> commands, (at the "edit" level,) model objects are created by the
>>>>> framework and doesn't have any EStore.
>>>>> (in every generated ItemProviderAdapters) so that they don't use
>>>> were dynamic objects (the data is stored in the settings as for a
>>>> dynamic EObject) and only when the object is attached to the parent
>>>> is the store of the parent associated with it. After all, most of
>>>> the children created won't actually be used, so you wouldn't want
>>>> them to be cached or worse yet, persisted in the store...
>>>>> EStore...
>>>> would be useful for having the resource associate a store with the
>>>> object when it becomes attached to the resource... Again, I think
>>>> CDO has implemented quite a nice solution for all this...
>>> I already did this.
>>>>> Stephane
Re: CreateChildCommand and EStore [message #423227 is a reply to message #423226] Thu, 25 September 2008 06:00 Go to previous message
Eike Stepper wrote :
> SWT schrieb:
>> Eike,
> the same problem.
>> mapping.
You're right, I should have asked it. :'( :'(
I'll explain "client-server mapping" :
For instance, I have a "client" class (an EObject). I also have a
"server" class, or more clearly, a DTO class (Data Transfer Object
class) which is equivalent to "CDOClass" (if I'm not mistaken...)
So I "map" each features of the "client" class to the "server" class.
The simple case is when a feature exists on both classes (on the
"server" side, it's not called a feature but a "bean property"...).
There are some cases where a feature on the "client" is mapped by nested
bean properties.
There also are some cases where a feature doesn't exist at all on the
"server" side. But the opposite feature may exist on the "server" side
(and mapped via a bean property), so I can use it to retrieve the
feature value.
If the opposite feature does not exist, I have some other ways to "map"
the feature, that is to say, make the right call on the server side to
get (or set) the feature value... (I won't describe this in detail, but
it's in these case that I have "complex mapping" which is often
project-specific...)
Another case can also be seen : When there is no DTO ("server") class
corresponding to a local model class. I didn't handle this case for the
moment...
It seems that CDO handles all this a bit differently...
> already ;-)
It is too late : My boss won't let me change this now... But he knows
about it, and if I have another project which is based on the same kind
of design later, I will have time to spend on CDO :)
Stephane
> Cheers
> /Eike
>> Thanks a lot !
>> Stephane
>>> Hi Stephane,
>>> two classes:
>>> - CDOObjectImpl:
>>> - CDOStore:
>>> - CDOState:
>>> - CDOStateMachine:
>>> Cheers
>>> /Eike
>>> SWT schrieb:
>>>> Ed,
>>>> Comments below :)
>>>> Ed Merks wrote :
>>>>> Stephane,
>>>>> Comments below.
>>>>> SWT wrote:
>>>>>> Hello !
>>>>> them. :-P
>>>> Hehe ^^
>>>> Right...
>>>>>> EStore...
>>>> I already did this.
>>>>>> Stephane
Previous Topic:Elements unique identification
Next Topic:How to make EMF use extendedMetaData
Current Time: Sun Jul 20 20:27:20 EDT 2025
Powered by FUDForum. Page generated in 0.12347 seconds
