Home » Modeling » EMF » How do I inherit from an EDataType
How do I inherit from an EDataType [message #423189] Wed, 24 September 2008 10:59 Go to next message
if I read the ecore-Metamodel right there is currently no
straightforward way to inherit from a EDataType. What do I do if I want
to have an EClass that inherits from an already existing (non-E) class?
Is there a reason why this is prohibited?
Alexander Dotor
Re: How do I inherit from an EDataType [message #423192 is a reply to message #423189] Wed, 24 September 2008 12:09 Go to previous message
Alexander,
You can use an EClass just like an EDataType in that you can set the
instance class name to some existing Java interface. You can mark the
EClass with isInterface and isAbstract true, so you don't end up with a
generated Impl class that implements that interface. This EClass can
then be used as a super type for your modeled classes.
Alexander Dotor wrote:
> Hello,
> want to have an EClass that inherits from an already existing (non-E)
> class?
> Cheers,
> Alexander Dotor
Previous Topic:[Databinding] Generic visualization of EObjects
Next Topic:Initialize multivalued attributes/references
Current Time: Sat Jul 26 21:21:24 EDT 2025
Powered by FUDForum. Page generated in 0.03810 seconds
