Home » Modeling » EMF » improve resource loading performance
improve resource loading performance [message #423108] Tue, 23 September 2008 09:38 Go to next message
I need to improve the loading performance for a resource.
For the sample I use an XML-serialised resource which is a 470KB file.
With the loadOption XMLResource.OPTION_DEFER_IDREF_RESOLUTION I gained ~35%
That's fine but not enough, indeed it takes 2.5s to load the resource from
the file.
whereas with a simple xpp parser it takes ~260ms, indeed it does not
create all the emf references.
I just need to obtain the resource for consumption (read-only), not for
authoring (read/write).
What can I do ?
Thanks in advance,
regards.
Guillaume.
Re: improve resource loading performance [message #423116 is a reply to message #423108] Tue, 23 September 2008 10:22 Go to previous messageGo to next message
--------------090601030502060402000207
Guillaume,
Comments below.
gouin wrote:
> ~35%
Another approach would be to use ResourceImpl.setIntrinsicIDToEObjectMap
if you have intrinsic IDs.
> from the file. whereas with a simple xpp parser it takes ~260ms,
> indeed it does not create all the emf references.
> for authoring (read/write).
> What can I do ?
You've looked at this?
EMF Performance Tips
< http://www.eclipse.org/modeling/emf/docs/performance/EMFPerf ormanceTips.html>
> Thanks in advance,
> regards.
> Guillaume.
<html>
<head>
http-equiv="Content-Type">
</head>
Guillaume,<br>
<br>
Comments below.<br>
<br>
gouin wrote:
<blockquote
cite="mid:75c250ba2de1a6f526dd8e686ae0edb3$1@www.eclipse.org"
type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
<br>
~35%
<br>
</blockquote>
ResourceImpl.setIntrinsicIDToEObjectMap if you have intrinsic IDs.<br>
<blockquote
type="cite"><br>
from the file. whereas with a simple xpp parser it takes ~260ms, indeed
<br>
<br>
<br>
Re: improve resource loading performance [message #423166 is a reply to message #423116] Wed, 24 September 2008 05:36 Go to previous message
Thanks Ed for your prompt response,
Yes I looked at EMF Performance Tips
That's where I found the OPTION_DEFER_IDREF_RESOLUTION option.
With all the optimisations I have done, I always have the delay specified
(2,5s) which is unacceptable in my context.
Is there any hope to improve that by a factor near 10 the load of a
resource?
The resource contains ~2300 elements (of 10 different types) with ~11400
attributes.
I've got ~26 million "eIsSet" and ~17 million "eGet" invocations with an
average time of 0/1µs each.
Does the problem come from the size of the resource (minimal in my sample
: 470KB) or from its complexity?
Thanks in advance,
Guillaume.
Previous Topic:Editing a generic attribute in the property sheet pane
Next Topic:Problems with read-only resources in an editing domain
Current Time: Thu Jul 24 22:31:29 EDT 2025
Powered by FUDForum. Page generated in 0.04712 seconds
