Home » Modeling » EMF » CDO make table DB bug
CDO make table DB bug [message #423056] Mon, 22 September 2008 07:23 Go to next message
Guys,
Cannot file bugs at the moment. Bugzilla seems to not be working.
Anwyay this is the text of the bug:
Infinite loop found in
org.eclipse.emf.cdo.server.internal.db.ClassMapping.java
Steps To Reproduce:
Register a model with CDO containing a class called Project
Register a second model with CDO containing a different class called Project
Add a Project from the first model
Add a Project from the second model
Error
More information:
When an exception occurs in the following method, the catch shows a
tracer entry but fails to progress the loop resulting in an infinite
loop and a server hang. The client eventually throws a timeout
exception. Some kind of condition needs to be added to the for loop to
return the failure elegantly rather than bringing down the server?
protected IDBTable addTable(String name)
A correlary to this is that if the database tables are simply labelled
by their class names, does that mean that registering 2 different ecore
models with the same server that happen to have classes of the same name
will fail to be added to the database correctly? Can the db table names
be qualified with their namespace etc... to ensure this doesnt happen?
PGR
Re: CDO make table DB bug [message #423059 is a reply to message #423056] Mon, 22 September 2008 09:31 Go to previous messageGo to next message
bug now filed as #248134.
phantomjinx wrote:
> Guys,
> Steps To Reproduce:
> Project
> Error
> More information:
> Regards
> PGR
Re: CDO make table DB bug (NEW CONFIG PROPERTY) [message #423068 is a reply to message #423059] Mon, 22 September 2008 11:05 Go to previous message
An exception should be thrown now.
And I added a new "qualifiedNames" config property for the mapping strategy,
e.g.
<store type="db">
<mappingStrategy type="horizontal">
<property name="qualifiedNames" value="false"/>
Cheers
/Eike
> phantomjinx wrote:
>> Guys,
>> Steps To Reproduce:
>> Project
>> Error
>> More information:
>> to return the failure elegantly rather than bringing down the server?
>> labelled by their class names, does that mean that registering 2
>> different ecore models with the same server that happen to have
>> classes of the same name will fail to be added to the database
>> correctly? Can the db table names be qualified with their namespace
>> Regards
>> PGR
Previous Topic:Manage compatibility between model files
Next Topic:[Teneo] How to model a map?
Current Time: Sun Jul 27 09:26:37 EDT 2025
Powered by FUDForum. Page generated in 0.03222 seconds
