Home » Modeling » EMF » [Teneo] How to model a map?
[Teneo] How to model a map? [message #423053] Mon, 22 September 2008 07:07 Go to next message
Originally posted by: luzi.anderegg.ergon.ch
I modelled a map in my ecore according to
http://wiki.eclipse.org/EMF/FAQ#How_do_I_create_a_Map_in_EMF .3F. If I
use this map in my program, a MappingException arises? Is there anything
special with maps and teneo? Do I have to annotate my ecore?
Luzi
Re: [Teneo] How to model a map? [message #423054 is a reply to message #423053] Mon, 22 September 2008 07:20 Go to previous messageGo to next message
--------------030705080105020905060908
Hi Luzi,
Yes maps should work. There are two ways in which Teneo can map maps:
- as a list of map entries (key, value pair), in this case the hibernate mapping will have a list as
the association
- as a real map (so with a map tag in the hbm).
If you set the option PersistenceOptions.EMAP_AS_TRUE_MAP to false (default is true) then Teneo will
map your emap as a list.
Attached you can find an example of an emap from the Teneo testcases.
Can you post your ecore and the resulting hbm?
gr. Martin
> Regards,
> Luzi
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Content-Type: text/xml;
name="emap.ecore"
Content-Disposition: inline;
filename="emap.ecore"
<ecore:EPackage xmi:version="2.0"
xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="emap"
nsURI=" http://www.eclipse.org/emf/teneo/samples/emf/schemaconstruct s/emap" nsPrefix="emap">
<eClassifiers xsi:type="ecore:EClass" name="Book">
<eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="name" value="Book"/>
<details key="kind" value="elementOnly"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="title" lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//String">
<details key="kind" value="element"/>
<details key="name" value="title"/>
</eAnnotations>
</eStructuralFeatures>
<eStructuralFeatures xsi:type="ecore:EReference" name="writers" upperBound="-1"
eType="#//StringToWriterMapEntry" containment="true" resolveProxies="false">
<details key="name" value="writers"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="keyWords" upperBound="-1"
eType="#//StringToStringMapEntry" containment="true" resolveProxies="false">
<details key="name" value="keyWords"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="cityByWriter" upperBound="-1"
eType="#//WriterToStringMapEntry" containment="true" resolveProxies="false">
<details key="name" value="cityByWriter"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="categoryByDate" upperBound="-1"
eType="#//DateToCategoryMapEntry" containment="true" resolveProxies="false">
<details key="name" value="categoryByDate"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EEnum" name="Category">
<details key="name" value="Category"/>
</eAnnotations>
<eLiterals name="Complex"/>
<eLiterals name="Simple" value="1"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="CategoryObject" instanceClassName="org.eclipse.emf.common.util.Enumerator">
<details key="name" value="Category:Object"/>
<details key="baseType" value="Category"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EDataType" name="Date" instanceClassName="java.util.Date">
<details key="name" value="Date"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="DateToCategoryMapEntry" instanceClassName="java.util.Map$Entry">
<details key="name" value="dateToCategoryMapEntry"/>
<details key="kind" value="empty"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="key" eType="#//Date">
<details key="kind" value="attribute"/>
<details key="name" value="key"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="value" eType="#//Category"
defaultValueLiteral="Complex" unsettable="true">
<details key="name" value="value"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="StringToStringMapEntry" instanceClassName="java.util.Map$Entry">
<details key="name" value="StringToStringMapEntry"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="key" eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//String">
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="value" eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//String">
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="StringToWriterMapEntry" instanceClassName="java.util.Map$Entry">
<details key="name" value="StringToWriterMapEntry"/>
</eAnnotations>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="value" eType="#//Writer"
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Writer">
<details key="name" value="Writer"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//String">
<details key="name" value="name"/>
</eAnnotations>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="WriterToStringMapEntry" instanceClassName="java.util.Map$Entry">
<details key="name" value="WriterToStringMapEntry"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="key" eType="#//Writer"
</eAnnotations>
</eAnnotations>
</eClassifiers>
</ecore:EPackage>
name="emap.xsd"
filename="emap.xsd"
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema"
targetNamespace=" http://www.eclipse.org/emf/teneo/samples/emf/schemaconstruct s/emap"
xmlns=" http://www.eclipse.org/emf/teneo/samples/emf/schemaconstruct s/emap"
<xsd:complexType name="Book">
<xsd:sequence>
<xsd:element name="title" type="xsd:string" />
<xsd:element maxOccurs="unbounded" minOccurs="0" name="writers"
type="StringToWriterMapEntry"
<xsd:element maxOccurs="unbounded" minOccurs="0" name="keyWords"
type="StringToStringMapEntry"
<xsd:element maxOccurs="unbounded" minOccurs="0" name="cityByWriter"
type="WriterToStringMapEntry"
<xsd:element maxOccurs="unbounded" minOccurs="0" name="categoryByDate"
type="dateToCategoryMapEntry"
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="Writer">
<xsd:sequence>
<xsd:element name="name" type="xsd:string" />
</xsd:sequence>
</xsd:complexType>
<xsd:complexType ecore:instanceClass="java.util.Map$Entry" name="StringToWriterMapEntry">
<xsd:attribute name="key" type="xsd:string" />
<xsd:attribute name="value" type="xsd:IDREF" ecore:reference="Writer" />
</xsd:complexType>
<xsd:complexType ecore:instanceClass="java.util.Map$Entry" name="WriterToStringMapEntry">
<xsd:attribute name="key" type="xsd:IDREF" ecore:reference="Writer" />
<xsd:attribute name="value" type="xsd:string" />
</xsd:complexType>
<xsd:complexType ecore:instanceClass="java.util.Map$Entry" name="StringToStringMapEntry">
</xsd:complexType>
<xsd:simpleType ecore:instanceClass="java.util.Date" name="Date">
<xsd:restriction base="xsd:dateTime"/>
</xsd:simpleType>
<xsd:complexType ecore:instanceClass="java.util.Map$Entry" name="dateToCategoryMapEntry">
<xsd:attribute name="key" type="Date" />
<xsd:attribute name="value" type="Category" />
</xsd:complexType>
<xsd:simpleType name="Category">
<xsd:restriction base="xsd:NCName">
<xsd:enumeration value="Complex"/>
<xsd:enumeration value="Simple"/>
</xsd:restriction>
</xsd:simpleType>
</xsd:schema>
name="EMapAction_mysql_a_o_hibernate.hbm.xml"
filename="EMapAction_mysql_a_o_hibernate.hbm.xml"
PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiPz4KPCFET0NU WVBFIGhpYmVy
bmF0ZS1tYXBwaW5nIFBVQkxJQyAiLS8vSGliZXJuYXRlL0hpYmVybmF0ZSBN YXBwaW5nIERU
RCAzLjAvL0VOIiAiaHR0cDovL2hpYmVybmF0ZS5zb3VyY2Vmb3JnZS5uZXQv aGliZXJuYXRl
LW1hcHBpbmctMy4wLmR0ZCI+Cgo8aGliZXJuYXRlLW1hcHBpbmcgYXV0by1p bXBvcnQ9ImZh
bHNlIj4KCTx0eXBlZGVmIG5hbWU9ImVtYXAuQ2F0ZWdvcnlPYmplY3QiIGNs YXNzPSJvcmcu
ZWNsaXBzZS5lbWYudGVuZW8uaGliZXJuYXRlLm1hcHBpbmcuRGVmYXVsdFRv U3RyaW5nVXNl
clR5cGUiPgoJCTxwYXJhbSBuYW1lPSJlcGFja2FnZSI+aHR0cDovL3d3dy5l Y2xpcHNlLm9y
Zy9lbWYvdGVuZW8vc2FtcGxlcy9lbWYvc2NoZW1hY29uc3RydWN0cy9lbWFw PC9wYXJhbT4K
CQk8cGFyYW0gbmFtZT0iZWRhdGF0eXBlIj5DYXRlZ29yeU9iamVjdDwvcGFy YW0+Cgk8L3R5
cGVkZWY+Cgk8Y2xhc3MgbmFtZT0ib3JnLmVjbGlwc2UuZW1mLnRlbmVvLnNh bXBsZXMuZW1m
LnNjaGVtYWNvbnN0cnVjdHMuZW1hcC5pbXBsLkJvb2tJbXBsIiBlbnRpdHkt bmFtZT0iQm9v
ayIgYWJzdHJhY3Q9ImZhbHNlIiBsYXp5PSJmYWxzZSIgZGlzY3JpbWluYXRv ci12YWx1ZT0i
Qm9vayIgdGFibGU9ImBib29rYCI+CgkJPG1ldGEgYXR0cmlidXRlPSJlY2xh c3NOYW1lIj5C
b29rPC9tZXRhPgoJCTxtZXRhIGF0dHJpYnV0ZT0iZXBhY2thZ2UiPmh0dHA6 Ly93d3cuZWNs
aXBzZS5vcmcvZW1mL3RlbmVvL3NhbXBsZXMvZW1mL3NjaGVtYWNvbnN0cnVj dHMvZW1hcDwv
bWV0YT4KCQk8aWQgdHlwZT0ibG9uZyIgbmFtZT0iZV9pZCIgY29sdW1uPSJl X2lkIiBhY2Nl
c3M9Im9yZy5lY2xpcHNlLmVtZi50ZW5lby5oaWJlcm5hdGUubWFwcGluZy5p ZGVudGlmaWVy
LklkZW50aWZpZXJQcm9wZXJ0eUhhbmRsZXIiPgoJCQk8bWV0YSBhdHRyaWJ1 dGU9InN5bnRo
ZXRpY0lkIj50cnVlPC9tZXRhPgoJCQk8Z2VuZXJhdG9yIGNsYXNzPSJuYXRp dmUiLz4KCQk8
L2lkPgoJCTxkaXNjcmltaW5hdG9yIGNvbHVtbj0iYGR0eXBlYCIgdHlwZT0i c3RyaW5nIi8+
CgkJPHZlcnNpb24gbmFtZT0iZV92ZXJzaW9uIiBjb2x1bW49ImVfdmVyc2lv biIgYWNjZXNz
PSJvcmcuZWNsaXBzZS5lbWYudGVuZW8uaGliZXJuYXRlLm1hcHBpbmcucHJv cGVydHkuVmVy
c2lvblByb3BlcnR5SGFuZGxlciI+CgkJCTxtZXRhIGF0dHJpYnV0ZT0ic3lu dGhldGljVmVy
c2lvbiI+dHJ1ZTwvbWV0YT4KCQk8L3ZlcnNpb24+CgkJPHByb3BlcnR5IG5h bWU9InRpdGxl
IiBsYXp5PSJmYWxzZSIgaW5zZXJ0PSJ0cnVlIiB1cGRhdGU9InRydWUiIG5v dC1udWxsPSJ0
cnVlIiB1bmlxdWU9ImZhbHNlIiB0eXBlPSJqYXZhLmxhbmcuU3RyaW5nIj4K CQkJPGNvbHVt
biBub3QtbnVsbD0idHJ1ZSIgdW5pcXVlPSJmYWxzZSIgbmFtZT0iYHRpdGxl YCIvPgoJCTwv
cHJvcGVydHk+CgkJPG1hcCBuYW1lPSJ3cml0ZXJzIiBsYXp5PSJ0cnVlIiBj YXNjYWRlPSJh
bGwsZGVsZXRlLW9ycGhhbiI+CgkJCTxrZXkgdXBkYXRlPSJ0cnVlIiBmb3Jl aWduLWtleT0i
Ym9va193cml0ZXJzIj4KCQkJCTxjb2x1bW4gbmFtZT0iYGJvb2tfd3JpdGVy c19lX2lkYCIg
bm90LW51bGw9ImZhbHNlIiB1bmlxdWU9ImZhbHNlIi8+CgkJCTwva2V5PgoJ CQk8bWFwLWtl
eSB0eXBlPSJqYXZhLmxhbmcuU3RyaW5nIi8+CgkJCTxvbmUtdG8tbWFueSBl bnRpdHktbmFt
ZT0iV3JpdGVyIi8+CgkJPC9tYXA+CgkJPG1hcCBuYW1lPSJrZXlXb3JkcyIg bGF6eT0idHJ1
ZSIgY2FzY2FkZT0iYWxsLGRlbGV0ZS1vcnBoYW4iPgoJCQk8a2V5IHVwZGF0 ZT0idHJ1ZSI+
CgkJCQk8Y29sdW1uIG5hbWU9ImBib29rX2tleXdvcmRzX2VfaWRgIiBub3Qt bnVsbD0iZmFs
c2UiIHVuaXF1ZT0iZmFsc2UiLz4KCQkJPC9rZXk+CgkJCTxtYXAta2V5IHR5 cGU9ImphdmEu
bGFuZy5TdHJpbmciLz4KCQkJPGVsZW1lbnQgdHlwZT0iamF2YS5sYW5nLlN0 cmluZyIvPgoJ
CTwvbWFwPgoJCTxtYXAgbmFtZT0iY2l0eUJ5V3JpdGVyIiBsYXp5PSJ0cnVl IiBjYXNjYWRl
PSJhbGwsZGVsZXRlLW9ycGhhbiI+CgkJCTxrZXkgdXBkYXRlPSJ0cnVlIj4K CQkJCTxjb2x1
bW4gbmFtZT0iYGJvb2tfY2l0eWJ5d3JpdGVyX2VfaWRgIiBub3QtbnVsbD0i ZmFsc2UiIHVu
aXF1ZT0iZmFsc2UiLz4KCQkJPC9rZXk+CgkJCTxtYXAta2V5LW1hbnktdG8t bWFueSBlbnRp
dHktbmFtZT0iV3JpdGVyIi8+CgkJCTxlbGVtZW50IHR5cGU9ImphdmEubGFu Zy5TdHJpbmci
Lz4KCQk8L21hcD4KCQk8bWFwIG5hbWU9ImNhdGVnb3J5QnlEYXRlIiBsYXp5 PSJ0cnVlIiBj
YXNjYWRlPSJhbGwsZGVsZXRlLW9ycGhhbiI+CgkJCTxrZXkgdXBkYXRlPSJ0 cnVlIj4KCQkJ
CTxjb2x1bW4gbmFtZT0iYGJvb2tfY2F0ZWdvcnlieWRhdGVfZV9pZGAiIG5v dC1udWxsPSJm
YWxzZSIgdW5pcXVlPSJmYWxzZSIvPgoJCQk8L2tleT4KCQkJPG1hcC1rZXkg dHlwZT0idGlt
ZXN0YW1wIi8+CgkJCTxlbGVtZW50PgoJCQkJPHR5cGUgbmFtZT0ib3JnLmVj bGlwc2UuZW1m
LnRlbmVvLmhpYmVybmF0ZS5tYXBwaW5nLkVOdW1Vc2VyVHlwZSI+CgkJCQkJ PHBhcmFtIG5h
bWU9ImVudW1DbGFzcyI+b3JnLmVjbGlwc2UuZW1mLnRlbmVvLnNhbXBsZXMu ZW1mLnNjaGVt
YWNvbnN0cnVjdHMuZW1hcC5DYXRlZ29yeTwvcGFyYW0+CgkJCQk8L3R5cGU+ CgkJCTwvZWxl
bWVudD4KCQk8L21hcD4KCTwvY2xhc3M+Cgk8Y2xhc3MgbmFtZT0ib3JnLmVj bGlwc2UuZW1m
LnRlbmVvLnNhbXBsZXMuZW1mLnNjaGVtYWNvbnN0cnVjdHMuZW1hcC5pbXBs LldyaXRlcklt
cGwiIGVudGl0eS1uYW1lPSJXcml0ZXIiIGFic3RyYWN0PSJmYWxzZSIgbGF6 eT0iZmFsc2Ui
IGRpc2NyaW1pbmF0b3ItdmFsdWU9IldyaXRlciIgdGFibGU9ImB3cml0ZXJg Ij4KCQk8bWV0
YSBhdHRyaWJ1dGU9ImVjbGFzc05hbWUiPldyaXRlcjwvbWV0YT4KCQk8bWV0 YSBhdHRyaWJ1
dGU9ImVwYWNrYWdlIj5odHRwOi8vd3d3LmVjbGlwc2Uub3JnL2VtZi90ZW5l by9zYW1wbGVz
L2VtZi9zY2hlbWFjb25zdHJ1Y3RzL2VtYXA8L21ldGE+CgkJPGlkIHR5cGU9 ImxvbmciIG5h
bWU9ImVfaWQiIGNvbHVtbj0iZV9pZCIgYWNjZXNzPSJvcmcuZWNsaXBzZS5l bWYudGVuZW8u
aGliZXJuYXRlLm1hcHBpbmcuaWRlbnRpZmllci5JZGVudGlmaWVyUHJvcGVy dHlIYW5kbGVy
Ij4KCQkJPG1ldGEgYXR0cmlidXRlPSJzeW50aGV0aWNJZCI+dHJ1ZTwvbWV0 YT4KCQkJPGdl
bmVyYXRvciBjbGFzcz0ibmF0aXZlIi8+CgkJPC9pZD4KCQk8ZGlzY3JpbWlu YXRvciBjb2x1
bW49ImBkdHlwZWAiIHR5cGU9InN0cmluZyIvPgoJCTx2ZXJzaW9uIG5hbWU9 ImVfdmVyc2lv
biIgY29sdW1uPSJlX3ZlcnNpb24iIGFjY2Vzcz0ib3JnLmVjbGlwc2UuZW1m LnRlbmVvLmhp
YmVybmF0ZS5tYXBwaW5nLnByb3BlcnR5LlZlcnNpb25Qcm9wZXJ0eUhhbmRs ZXIiPgoJCQk8
bWV0YSBhdHRyaWJ1dGU9InN5bnRoZXRpY1ZlcnNpb24iPnRydWU8L21ldGE+ CgkJPC92ZXJz
aW9uPgoJCTxwcm9wZXJ0eSBuYW1lPSJuYW1lIiBsYXp5PSJmYWxzZSIgaW5z ZXJ0PSJ0cnVl
IiB1cGRhdGU9InRydWUiIG5vdC1udWxsPSJ0cnVlIiB1bmlxdWU9ImZhbHNl IiB0eXBlPSJq
YXZhLmxhbmcuU3RyaW5nIj4KCQkJPGNvbHVtbiBub3QtbnVsbD0idHJ1ZSIg dW5pcXVlPSJm
YWxzZSIgbmFtZT0iYG5hbWVgIi8+CgkJPC9wcm9wZXJ0eT4KCTwvY2xhc3M+ CjwvaGliZXJu
YXRlLW1hcHBpbmc+
--------------030705080105020905060908--
Re: [Teneo] How to model a map? [message #423061 is a reply to message #423054] Mon, 22 September 2008 10:36 Go to previous messageGo to next message
Unfortunately, I'm not allowed to post the whole ecore. Below you find
the parts containing the map:
<eClassifiers xsi:type="ecore:EClass" name="IntegerToToolPinMapEntry"
http://www.eclipse.org/emf/2002/Ecore#//EIntegerObject"/>
eType="#//ToolPin"
containment="true"/>
</eClassifiers>
and the referencing class:
<eClassifiers xsi:type="ecore:EClass" name="ToolElement">
<eStructuralFeatures xsi:type="ecore:EReference" name="inputPins"
upperBound="-1"
eType="#//IntegerToToolPinMapEntry" containment="true"/>
</eClassifiers>
Luzi
Martin Taal wrote:
> Hi Luzi,
> mapping will have a list as the association
> (default is true) then Teneo will map your emap as a list.
> gr. Martin
>> anything special with maps and teneo? Do I have to annotate my ecore?
>> Regards,
>> Luzi
Re: [Teneo] How to model a map? [message #423064 is a reply to message #423061] Mon, 22 September 2008 10:58 Go to previous messageGo to next message
Hi Luzi,
For my info, can you also post the relevant part of the mapping? And the stack trace of the
mappingexception?
gr. Martin
> eType="#//ToolPin"
> </eClassifiers>
> upperBound="-1"
> </eClassifiers>
> Luzi
> Martin Taal wrote:
>> Hi Luzi,
>> hibernate mapping will have a list as the association
>> gr. Martin
>>> Regards,
>>> Luzi
The Netherlands
Re: [Teneo] How to model a map? [message #423070 is a reply to message #423064] Mon, 22 September 2008 11:07 Go to previous messageGo to next message
Hi Martin,
here is the relevant part of the mapping (I hope):
<class name="xxxxxxxxxxxxxxxxxx.impl.ToolElementImpl"
entity-name="ToolElement" abstract="false" lazy="false"
discriminator-value="ToolElement" table="`toolelement`">
<meta attribute="eclassName">ToolElement</meta>
<meta attribute="epackage">http:///xxxxxxxxxxxxxx.ecore</meta>
<map name="inputPins" lazy="true" cascade="all,delete-orphan">
<key update="true" foreign-key="toolelement_inputpins">
<column name="`toolelement_inputpins_e_id`" not-null="false"
unique="false"/>
</key>
<map-key type="java.lang.Integer"/>
<one-to-many entity-name="ToolPin"/>
</map>
</class>
Gr.
Luzi
Martin Taal wrote:
> Hi Luzi,
> stack trace of the mappingexception?
> gr. Martin
>> eType="#//ToolPin"
>> </eClassifiers>
>> upperBound="-1"
>> </eClassifiers>
>> Luzi
>> Martin Taal wrote:
>>> Hi Luzi,
>>> gr. Martin
>>>> I use this map in my program, a MappingException arises? Is there
>>>> Regards,
>>>> Luzi
Re: [Teneo] How to model a map? [message #423073 is a reply to message #423070] Mon, 22 September 2008 11:14 Go to previous message
Hi Luzi,
And can you post the mappingexception?
gr. Martin
> Hi Martin,
> not-null="false" unique="false"/>
> </key>
> </map>
> </class>
> Gr.
> Luzi
> Martin Taal wrote:
>> Hi Luzi,
>> the stack trace of the mappingexception?
>> gr. Martin
>>> find the parts containing the map:
>>> eType="#//ToolPin"
>>> </eClassifiers>
>>> upperBound="-1"
>>> </eClassifiers>
>>> Luzi
>>> Martin Taal wrote:
>>>> Hi Luzi,
>>>> gr. Martin
>>>>> Regards,
>>>>> Luzi
The Netherlands
Previous Topic:CDO make table DB bug
Next Topic:Re: Does a datatype describing the name of a EStructuralFeature exist?
Current Time: Wed Jul 23 20:34:24 EDT 2025
Powered by FUDForum. Page generated in 0.25760 seconds
