CDO-Hibernate setup problems [message #422939] |
Fri, 19 September 2008 07:37  |
Hi all,
I try to setup cdo with a HibernateStore backend. After fighting with
https://bugs.eclipse.org/bugs/show_bug.cgi?id=238254 the server starts
now, but hibernate is not able to see CDOResource (trace at the bottom).
My target:
CDO I200809110653
EMF I200809021800
Net4j I200809110620
Teneo M200809101825
eclipse-equinox 3.4
some more core bundles from eclipse 3.4
hibernate libs copied from the CDO development target (those from the
spingsource repository)
My application:
Bundle A: contains an Activator that starts the server
Dependencies:
Require-Bundle: ch.psi.cpt.gpdb.domain;bundle-version="1.0.0",
org.eclipse.core.runtime;bundle-version="3.4.0",
org.eclipse.emf.cdo.server;bundle-version="1.0.0",
org.eclipse.net4j.jvm;bundle-version="1.0.0",
org.eclipse.emf.cdo;bundle-version="1.0.0",
org.eclipse.net4j.tcp;bundle-version="1.0.0",
org.eclipse.emf.cdo.server.hibernate.teneo;bundle-version="2.0.0 ",
com.mysql.jdbc;bundle-version="5.1.6"
Bundle B: contains the domain model (emf/cdo)
Dependencies:
Require-Bundle: org.eclipse.core.runtime,
org.eclipse.emf.ecore;visibility:=reexport,
org.eclipse.emf.cdo;visibility:=reexport,
org.eclipse.emf.teneo.hibernate;visibility:=reexport,
org.hibernate;bundle-version="3.2.6";visibility:=reexport
The org.hibernate bundle contains the line: Eclipse-BuddyPolicy: dependent
Since org.eclipse.emf.cdo has no dependency on org.hibernate (for good
reason), I have no idea how this can be fixed. It also seems strange to
convert my domain model bundle to a fragment and attach it to
org.hibernate..
Has anybody an idea how to fix this class loading problem?
Cheers and thanks
Daniel
@Eike After I have a setup that works, I'm willing to implement the
hibernate query support, since my customer decided to put some effort into
CDO. This is good news =)
[ERROR] Unknown entity: CDOResource
org.hibernate.MappingException: Unknown entity: CDOResource
at
org.hibernate.impl.SessionFactoryImpl.getEntityPersister(Ses sionFactoryImpl.java:550)
at
org.hibernate.impl.SessionImpl.getOuterJoinLoadable(SessionI mpl.java:1584)
at org.hibernate.impl.SessionImpl.list(SessionImpl.java:1550)
at org.hibernate.impl.CriteriaImpl.list(CriteriaImpl.java:283)
at
org.eclipse.emf.cdo.server.internal.hibernate.HibernateStore Reader.readResourceID(HibernateStoreReader.java:103)
at
org.eclipse.emf.cdo.internal.server.ResourceManager.loadID(R esourceManager.java:92)
at
org.eclipse.emf.cdo.internal.server.ResourceManager.getResou rceID(ResourceManager.java:53)
at
org.eclipse.emf.cdo.internal.server.protocol.ResourceIDIndic ation.indicating(ResourceIDIndication.java:51)
at
org.eclipse.emf.cdo.internal.server.protocol.CDOServerIndica tion.indicating(CDOServerIndication.java:116)
at org.eclipse.net4j.signal.Indication.execute(Indication.java: 48)
at
org.eclipse.net4j.signal.IndicationWithResponse.execute(Indi cationWithResponse.java:38)
at
org.eclipse.emf.cdo.internal.server.protocol.CDOReadIndicati on.execute(CDOReadIndication.java:35)
at org.eclipse.net4j.signal.Signal.runSync(Signal.java:186)
at org.eclipse.net4j.signal.Signal.run(Signal.java:167)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:885)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:907)
at java.lang.Thread.run(Thread.java:619)
Re: CDO-Hibernate setup problems [message #422963 is a reply to message #422951] |
Fri, 19 September 2008 12:30   |
Hi Roger,
thanks for your reply. Answers and even more questions are inlined.
> Hi Daniel
> it's not a class loading problem, but a hibernate mapping problem.
Uff.. While setting up an osgi server, I overlooked that there are other
exception than ClassNotFounds :-) Thanks for clarifying this.
> In org.eclipse.emf.cdo.server.hibernate/mapping/resource.hbm.xm l there is
> the mapping:
> <class entity-name="CDOResource" abstract="false" lazy="false"
> discriminator-value="cdoresource" table="`cdo_resources`">
> <meta attribute="eclassName">CDOResource</meta>
> Obviously in your setup, this mapping file was not registered with
> hibernate.
You are right. I do not register any mapping files in my actual setup.
> Did you undeploy org.eclipse.emf.cdo.server.hibernate to your workspace
> and use this for your server?
No, my server is a simple bundle with the following code invoked from the
Activator's start method:
<snip>
IManagedContainer container = IPluginContainer.INSTANCE;
ITCPAcceptor tcpAcceptor = TCPUtil.getAcceptor(container,
"127.0.0.1:2036");
CDOServerUtil.addRepository(container,
HbStoreRepositoryProvider.getInstance().createRepository(REP OSITORY_NAME,
new HashMap<String, String>()));
CDOSessionConfiguration config = CDOUtil.createSessionConfiguration();
connector = TCPUtil.getConnector(container,"127.0.0.1:2036");
config.setConnector(connector);
config.setRepositoryName(REPOSITORY_NAME);
config.setLegacySupportEnabled(false);
session = config.openSession();
session.getPackageRegistry().putEPackage(DomainPlugin.getPac kage());
</snip>
I copied the class HbStoreRepositoryProvider from the hibernate test
bundle. I assumed that cdo is initializing cdo specific hibernate
mappings. Do I have to do it by myself? It seems to that I am missing a
piece between hibernate and cdo.
> Regards
> Roger
Thanks for your help and regards
Daniel
Re: CDO-Hibernate setup problems [message #423052 is a reply to message #423050] |
Mon, 22 September 2008 06:44   |
hi martin,
my model consists of one package only!
my generated mapping:
<!DOCTYPE hibernate-mapping PUBLIC "-//Hibernate/Hibernate Mapping DTD
3.0//EN" "http://hibernate.sourceforge.net/hibernate-mapping-3.0.dtd">
<hibernate-mapping auto-import="false">
<class name="ch.psi.cpt.gpdb.domain.impl.BaseEntityImpl"
entity-name="BaseEntity" abstract="false" lazy="false"
discriminator-value="BaseEntity" table="`baseentity`">
<meta attribute="eclassName">BaseEntity</meta>
<meta attribute="epackage">http://gapadaba.psi.ch/domain/1.0.0</meta>
<tuplizer entity-mode="pojo"
class=" org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDORe visionTuplizer "/>
<tuplizer entity-mode="dynamic-map"
<id type="long" name="e_id" column="e_id"
access=" org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDOSy ntheticIdPropertyHandler ">
<meta attribute="syntheticId">true</meta>
<generator class="native"/>
</id>
<discriminator column="`dtype`" type="string"/>
<version name="e_version" column="e_version"
access=" org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDOSy ntheticVersionPropertyHandler ">
<meta attribute="syntheticVersion">true</meta>
</version>
<property name="resourceID"
type=" org.eclipse.emf.cdo.server.internal.hibernate.tuplizer.CDOID UserType ">
<column name="_resID_Entity"/>
<column name="_resID_ID"/>
<column name="_resID_class"/>
</property>
<property name="containerID"
<column name="_contID_Entity"/>
<column name="_contID_ID"/>
<column name="_contID_class"/>
</property>
<property name="containingFeatureID" column="_contFeatureID" type="int"/>
<property name="id" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="java.lang.Long">
<column not-null="false" unique="false" name="`id`"/>
</property>
</class>
<subclass name="ch.psi.cpt.gpdb.domain.impl.PersonImpl"
entity-name="Person" abstract="false" lazy="false" extends="BaseEntity"
discriminator-value="Person">
<meta attribute="eclassName">Person</meta>
<property name="firstName" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`firstname`"/>
</property>
<property name="lastName" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`lastname`"/>
</property>
</subclass>
<subclass name="ch.psi.cpt.gpdb.domain.impl.PatientImpl"
entity-name="Patient" abstract="false" lazy="false" extends="Person"
discriminator-value="Patient">
<meta attribute="eclassName">Patient</meta>
<list name="physician" lazy="true" table="`patient_physician`">
<key update="true">
<column name="`patient_e_id`" not-null="true" unique="false"/>
</key>
<list-index column="`patient_physician_idx`"/>
<many-to-many entity-name="Physician" unique="false"
foreign-key="patient_physician">
<column name="`physician_e_id`" not-null="true" unique="false"/>
</many-to-many>
</list>
<many-to-one name="currentState" entity-name="PatientState"
cascade="merge,persist,save-update,lock,refresh" not-null="false"
lazy="false" insert="true" update="true"/>
<property name="diagnosis" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`diagnosis`"/>
</property>
</subclass>
<subclass name="ch.psi.cpt.gpdb.domain.impl.PhysicianImpl"
entity-name="Physician" abstract="false" lazy="false" extends="Person"
discriminator-value="Physician">
<meta attribute="eclassName">Physician</meta>
<list name="patients" lazy="true" table="`physician_patients`">
<key update="true">
</key>
<list-index column="`physician_patients_idx`"/>
<many-to-many entity-name="Patient" unique="false"
foreign-key="physician_patients">
</many-to-many>
</list>
</subclass>
<class name="ch.psi.cpt.gpdb.domain.impl.ProtonTherapyCenterImpl"
entity-name="ProtonTherapyCenter" abstract="false" lazy="false"
discriminator-value="ProtonTherapyCenter" table="`protontherapycenter`">
<meta attribute="eclassName">ProtonTherapyCenter</meta>
</id>
</version>
</property>
</property>
<list name="physicians" table="`protontherapycenter_physicians`"
lazy="true">
<key update="true">
<column name="`protontherapycenter_e_id`" not-null="true"
unique="false"/>
</key>
<list-index column="`protontherapycenter_physicians_idx`"/>
<many-to-many entity-name="Physician" unique="true"
foreign-key="protontherapycenter_physicians">
</many-to-many>
</list>
<list name="patients" table="`protontherapycenter_patients`" lazy="true">
<key update="true">
unique="false"/>
</key>
<list-index column="`protontherapycenter_patients_idx`"/>
<many-to-many entity-name="Patient" unique="true"
foreign-key="protontherapycenter_patients">
</many-to-many>
</list>
</class>
<subclass name="ch.psi.cpt.gpdb.domain.impl.PatientStateImpl"
entity-name="PatientState" abstract="false" lazy="false"
extends="BaseEntity" discriminator-value="PatientState">
<meta attribute="eclassName">PatientState</meta>
<property name="name" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`name`"/>
</property>
<one-to-one name="patients" entity-name="Patient"
cascade="merge,persist,save-update,lock,refresh" lazy="false"
property-ref="currentState"/>
</subclass>
</hibernate-mapping>
my small model:
<ecore:EPackage xmi:version="2.0"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="domain"
nsURI="http://gapadaba.psi.ch/domain/1.0.0" nsPrefix="">
<eClassifiers xsi:type="ecore:EClass" name="Patient"
eSuperTypes="#//Person">
<eStructuralFeatures xsi:type="ecore:EReference" name="physician"
upperBound="-1"
eType="#//Physician" eOpposite="#//Physician/patients"/>
<eStructuralFeatures xsi:type="ecore:EReference" name="currentState"
eType="#//PatientState"
eOpposite="#//PatientState/patients"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="diagnosis"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Physician"
<eStructuralFeatures xsi:type="ecore:EReference" name="patients"
upperBound="-1"
eType="#//Patient" eOpposite="#//Patient/physician"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Person"
eSuperTypes="#//BaseEntity">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="firstName"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="lastName"
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="BaseEntity">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="id"
http://www.eclipse.org/emf/2002/Ecore#//ELongObject"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="ProtonTherapyCenter">
<eStructuralFeatures xsi:type="ecore:EReference" name="physicians"
upperBound="-1"
eType="#//Physician"/>
upperBound="-1"
eType="#//Patient"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="PatientState"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
defaultValueLiteral=""/>
eType="#//Patient"
eOpposite="#//Patient/currentState"/>
</eClassifiers>
</ecore:EPackage>
Thanks for your help!
Daniel
Re: CDO-Hibernate setup problems [message #423055 is a reply to message #423052] |
Mon, 22 September 2008 07:22   |
Sorry Daniel, I should have read your post better, you already mention CDOClassProxy...
Can you see/post the stack trace from the server?
gr. Martin
daniel wrote:
> hi martin,
> <meta
> </id>
> </version>
> </property>
> </property>
> type="int"/>
> </property>
> </class>
> <meta
> update="true" not-null="false" unique="false" type="java.lang.String">
> </property>
> </property>
> </subclass>
> <meta
> <key update="true">
> unique="false"/>
> </key>
> unique="false"/>
> </many-to-many>
> </list>
> </property>
> </subclass>
> <meta
> <key update="true">
> unique="false"/>
> </key>
> unique="false"/>
> </many-to-many>
> </list>
> </subclass>
> <meta
> </id>
> </version>
> </property>
> </property>
> type="int"/>
> lazy="true">
> <key update="true">
> </key>
> unique="false"/>
> </many-to-many>
> </list>
> lazy="true">
> <key update="true">
> </key>
> unique="false"/>
> </many-to-many>
> </list>
> </class>
> <meta
> </property>
> </subclass>
> my small model:
> xmlns:xmi="http://www.omg.org/XMI"
> upperBound="-1"
> </eClassifiers>
> upperBound="-1"
> </eClassifiers>
> </eClassifiers>
> </eClassifiers>
> upperBound="-1"
> upperBound="-1"
> </eClassifiers>
> eType="#//Patient"
> </eClassifiers>
> </ecore:EPackage>
> Daniel
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: CDO-Hibernate setup problems [message #423252 is a reply to message #423247] |
Thu, 25 September 2008 10:19  |
daniel kroeni schrieb:
> I digged deeper and found that the patch is not necessary if the
> mappingFile location starts with a '/'
> <store type="hibernate">
> <mappingProvider type="file">
> <mappingFile location="/mappings/gapadaba.hbm.xml"/>
> </mappingProvider>
> </store>
> but to enable
> org.eclipse.emf.cdo.server.internal.hibernate.FileHibernateM appingProvider
> to find my mapping file, I had to add the following buddy policy to
> the manifest of the bundle: org.eclipse.emf.cdo.server.hibernate
> Shall I add a Bugzilla for this one?
Yes, then we can discuss it with Martin.
I could also imagine of an Eclipse-BuddyPolicy: registered...
>> And the other exception looks as if you are not generating your model
>> for CDO. Have you already read
>> http://wiki.eclipse.org/Preparing_EMF_Models_for_CDO ?
> Sure I did! The server runs without problems if I use:
Hmm, then it looks like a problem in the HibernateStore.
Can you please also add a Bugzilla to track this?
Cheers
/Eike
FUDForum. Page generated in 0.37468 seconds
